[技术问答]
麻烦给我些程序看,新手
1892|18
shen_hao|  楼主 | 2017-7-14 09:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
i2c spi的程序,最好是简单一些的,体量小一点的,谢谢
yiyigirl2014| | 2017-7-14 19:20 | 只看该作者
你玩哪个单片机?
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/29/2016
//  File Function: N76E003 I2C master mode demo code, the Slave address = 0xA4
//   ____________            _____________
//  |            |   SDA    |             |
//  |N76E003(M) |          | N76E003(S) |
//  |(I2C_Master)|          | (I2C_Slave) |
//  |            |   SCL    |             |
//  |____________|          |_____________|
//  The protocol of I2C is same the "24LC64"
#include <stdio.h>
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_Define.h"
#define I2C_CLOCK               13
#define EEPROM_SLA              0xA4
#define EEPROM_WR               0
#define EEPROM_RD               1
#define ERROR_CODE              0x78
#define PAGE_SIZE               32
void Init_I2C(void)
//    /* Set I2C clock rate */
    I2CLK = I2C_CLOCK;
    /* Enable I2C */
    set_I2CEN;
void I2C_Error(void)
//    P3 = I2STAT;
//    P3 = ERROR_CODE;
    while (1);
void I2C_Process(UINT8 u8DAT)
    UINT32 u32Count;
//----  Page Write----------------------------------------------------------------------------
    /* Step1 */
    set_STA;                                    /* Send Start bit to I2C EEPROM */
    clr_SI;
    while (!SI);                                //Check SI set or not
    if (I2STAT != 0x08)                         //Check status value after every step
        I2C_Error();
    /* Step2 */
    clr_STA;                                    //STA=0
    I2DAT = (EEPROM_SLA | EEPROM_WR);
    clr_SI;
    if (I2STAT != 0x18)
        I2C_Error();
    /* Step3 */
    I2DAT = 0x00;                               //address high for I2C EEPROM
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step4 */
    I2DAT = 0x00;                               //address low for I2C EEPROM
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step5 */
    for (u32Count = 0; u32Count < PAGE_SIZE; u32Count++)
        I2DAT = u8DAT;
        clr_SI;
        if (I2STAT != 0x28)
            I2C_Error();
        u8DAT = ~u8DAT;
//----  Waitting the ready for I2C write------------------------------------------------------
    /* Step6 */
    do{
        set_STO;
        clr_SI;
        set_STA;                                //Check if no ACK is returned by EEPROM, it is under timed-write cycle
        clr_SI;
            I2C_Error();
        clr_STA;
        clr_SI;
    }while (I2STAT != 0x18);
    /* Step7 */
    set_STO;
    clr_SI;
    while (STO);                                /* Check STOP signal */
//----  Page Read ----------------------------------------------------------------------------
    /* Step8 */
    set_STA;
    clr_SI;
        I2C_Error();
    /* Step9 */
    clr_STA;
    clr_SI;
    if (I2STAT != 0x18)
        I2C_Error();
    /* Step10 */
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step11 */
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step12 */
    /* Repeated START */
    set_STA;
    clr_SI;
    if (I2STAT != 0x10)                         //Check status value after every step
        I2C_Error();
    /* Step13 */
    clr_STA;                                    //STA needs to be cleared after START codition is generated
    I2DAT = (EEPROM_SLA | EEPROM_RD);
    clr_SI;
    if (I2STAT != 0x40)
        I2C_Error();
    /* Step14 */
    for (u32Count = 0; u32Count <PAGE_SIZE-1; u32Count++)
        set_AA;
        clr_SI;
        if (I2STAT != 0x50)
            I2C_Error();
        if (I2DAT != u8DAT)
            I2C_Error();
        u8DAT = ~u8DAT;
    /* Step15 */
    clr_AA;
    clr_SI;
    if (I2STAT != 0x58)
        I2C_Error();
    /* Step16 */
    set_STO;
    clr_SI;
void main(void)
    /* Note
       MCU power on system clock is HIRC (22.1184MHz), so Fsys = 22.1184MHz
    Set_All_GPIO_Quasi_Mode;
    Init_I2C();                                 //initial I2C circuit
    I2C_Process(0x55);                          /* I2C Master will send 0x55,0xAA,.... to slave */
    P0 = 0x00;
    P3 = 0x00;
    while (1);
yiyigirl2014| | 2017-7-14 19:21 | 只看该作者
/* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved.                                         */
//  Date   : May/1/2015
//  File Function: N76E003 I2C Slave demo code
#include <stdio.h>
#include "Common.h"
#include "Delay.h"
//  N76E885-series I2C slave mode demo code, the Slave address = 0xA4
//  |            |   SDA    |             |
//  |            |   SCL    |             |
UINT8 data_received[34], data_num = 0;
void I2C_ISR(void) interrupt 6
    switch (I2STAT)
        case 0x00:
            STO = 1;
            break;
        case 0x60:
            AA = 1;
            //P3 = 0x60;
            break;
        case 0x68:
                                                P02 = 0;
            while(1);
            break;
        case 0x80:
            //P3 = 0x80;
            data_received[data_num] = I2DAT;
            data_num++;
            if (data_num == 34)
                AA = 0;
            else
                AA = 1;
            break;
        case 0x88:
            //P3 = 0x88;
            data_num = 0;
            AA = 1;
            break;
        case 0xA0:
            //P3 = 0xA0;
            AA = 1;
            break;
        case 0xA8:
            //P3 = 0xA0;
            I2DAT = data_received[data_num];
            data_num++;
            AA = 1;
            break;
        case 0xB8:
            //P3 = 0xB8;
            data_num++;
            AA = 1;
            break;
        case 0xC0:
            AA = 1;
            break;
        case 0xC8:
            //P3 = 0xC8;
            AA = 1;
            break;
    SI = 0;
    while(STO);
void Init_I2C(void)
    P13_Quasi_Mode;                         //set SCL (P13) is Quasi mode
    P14_Quasi_Mode;                         //set SDA (P14) is Quasi mode
    SDA = 1;                                //set SDA and SCL pins high
    SCL = 1;
    set_P0SR_6;                             //set SCL (P06) is  Schmitt triggered input select.
    set_EI2C;                               //enable      I2C interrupt by setting IE1 bit 0
    set_EA;
    I2ADDR = EEPROM_SLA;                    //define own slave address
    set_I2CEN;                              //enable I2C circuit
    set_AA;
void main(void)
    /* Initial I2C function */
    while (1);
yiyigirl2014| | 2017-7-14 19:22 | 只看该作者
* @file     main.c
* @version  V3.0
* $Revision: 2 $
* $Date: 15/05/22 3:03p $
* @brief    Configure SPI0 as Master mode and demonstrate how to communicate
*           with an off-chip SPI Slave device with FIFO mode. This sample
*           code needs to work with SPI_SlaveFifoMode sample code.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define TEST_COUNT 16
uint32_t g_au32SourceData[TEST_COUNT];
uint32_t g_au32DestinationData[TEST_COUNT];
volatile uint32_t g_u32TxDataCount;
volatile uint32_t g_u32RxDataCount;
/* Function prototype declaration */
void SYS_Init(void);
void SPI_Init(void);
/* Main function */
int main(void)
    uint32_t u32DataCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Configure UART0: 115200, 8-bit word, no parity bit, 1 stop bit. */
    UART_Open(UART0, 115200);
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|             SPI Master Mode Sample Code (M05xxDN/DE only)            |\n");
    printf("\n");
    printf("Configure SPI0 as a master.\n");
    printf("Bit length of a transaction: 32\n");
    printf("The I/O connection for SPI0:\n");
    printf("    SPISS0(P1.4)\n    SPICLK0(P1.7)\n");
    printf("    MISO_0(P1.6)\n    MOSI_0(P1.5)\n\n");
    printf("SPI controller will enable FIFO mode and transfer %d data to a off-chip slave device.\n", TEST_COUNT);
    printf("In the meanwhile the SPI controller will receive %d data from the off-chip slave device.\n", TEST_COUNT);
    printf("After the transfer is done, the %d received data will be printed out.\n", TEST_COUNT);
    printf("The SPI master configuration is ready.\n");
    for(u32DataCount = 0; u32DataCount < TEST_COUNT; u32DataCount++)
        /* Write the initial value to source buffer */
        g_au32SourceData[u32DataCount] = 0x00550000 + u32DataCount;
        /* Clear destination buffer */
        g_au32DestinationData[u32DataCount] = 0;
    printf("Before starting the data transfer, make sure the slave device is ready. Press any key to start the transfer.\n");
    getchar();
    printf("\n");
    /* Set TX FIFO threshold, enable TX FIFO threshold interrupt and RX FIFO time-out interrupt */
    SPI_EnableFIFO(SPI0, 4, 4);
    SPI_EnableInt(SPI0, SPI_FIFO_TX_INT_MASK | SPI_FIFO_TIMEOUT_INT_MASK);
    g_u32TxDataCount = 0;
    g_u32RxDataCount = 0;
    NVIC_EnableIRQ(SPI0_IRQn);
    /* Wait for transfer done */
    while(g_u32RxDataCount < TEST_COUNT);
    /* Print the received data */
    printf("Received data:\n");
        printf("%d:\t0x%X\n", u32DataCount, g_au32DestinationData[u32DataCount]);
    /* Disable TX FIFO threshold interrupt and RX FIFO time-out interrupt */
    SPI_DisableInt(SPI0, SPI_FIFO_TX_INT_MASK | SPI_FIFO_TIMEOUT_INT_MASK);
    NVIC_DisableIRQ(SPI0_IRQn);
    printf("The data transfer was done.\n");
    printf("\n\nExit SPI driver sample code.\n");
    /* Reset SPI0 */
    SPI_Close(SPI0);
    while(1);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable external 12MHz XTAL */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Switch HCLK clock source to HXT and set HCLK divider to 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
    /* Select HXT as the clock source of UART0 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select HCLK as the clock source of SPI0 */
    CLK_SetModuleClock(SPI0_MODULE, CLK_CLKSEL1_SPI0_S_HCLK, MODULE_NoMsk);
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable SPI0 peripheral clock */
    CLK_EnableModuleClock(SPI0_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Setup SPI0 multi-function pins */
    SYS->P1_MFP = SYS_MFP_P14_SPISS0 | SYS_MFP_P15_MOSI_0 | SYS_MFP_P16_MISO_0 | SYS_MFP_P17_SPICLK0;
void SPI_Init(void)
    /* Init SPI        */
    /* Configure as a master, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    /* Set IP clock divider. SPI clock rate = 1MHz */
    SPI_Open(SPI0, SPI_MASTER, SPI_MODE_0, 32, 1000000);
    /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
    SPI_EnableAutoSS(SPI0, SPI_SS, SPI_SS_ACTIVE_LOW);
void SPI0_IRQHandler(void)
    /* Check RX EMPTY flag */
    while(SPI_GET_RX_FIFO_EMPTY_FLAG(SPI0) == 0)
        /* Read RX FIFO */
        g_au32DestinationData[g_u32RxDataCount++] = SPI_READ_RX0(SPI0);
    /* Check TX FULL flag and TX data count */
    while((SPI_GET_TX_FIFO_FULL_FLAG(SPI0) == 0) && (g_u32TxDataCount < TEST_COUNT))
        /* Write to TX FIFO */
        SPI_WRITE_TX0(SPI0, g_au32SourceData[g_u32TxDataCount++]);
    if(g_u32TxDataCount >= TEST_COUNT)
         SPI_DisableInt(SPI0, SPI_FIFO_TX_INT_MASK); /* Disable TX FIFO threshold interrupt */
    /* Check the RX FIFO time-out interrupt flag */
    if(SPI_GetIntFlag(SPI0, SPI_FIFO_TIMEOUT_INT_MASK))
        /* If RX FIFO is not empty, read RX FIFO. */
        while((SPI0->STATUS & SPI_STATUS_RX_EMPTY_Msk) == 0)
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
* @file     main.c
* @version  V3.0
* $Revision: 2 $
* $Date: 15/05/22 3:06p $
* @brief    Configure SPI0 as Slave mode and demonstrate how to communicate
*           with an off-chip SPI Master device with FIFO mode. This sample
*           code needs to work with SPI_MasterFifoMode sample code.
* @note
#include <stdio.h>
/* Main function */
int main(void)
    volatile uint32_t u32TxDataCount, u32RxDataCount;
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("|           SPI Slave Mode Sample Code (M05xxDN/DE only)               |\n");
    printf("\n");
    printf("Configure SPI0 as a slave.\n");
    printf("SPI controller will enable FIFO mode and transfer %d data to a off-chip master device.\n", TEST_COUNT);
    printf("In the meanwhile the SPI controller will receive %d data from the off-chip master device.\n", TEST_COUNT);
    for(u32TxDataCount = 0; u32TxDataCount < TEST_COUNT; u32TxDataCount++)
        g_au32SourceData[u32TxDataCount] = 0x00AA0000 + u32TxDataCount;
        g_au32DestinationData[u32TxDataCount] = 0;
    u32TxDataCount = 0;
    u32RxDataCount = 0;
    printf("Press any key if the master device configuration is ready.\n");
    getchar();
    printf("\n");
    /* Set TX FIFO threshold and enable FIFO mode. */
    /* Access TX and RX FIFO */
    while(u32RxDataCount < TEST_COUNT)
        if((SPI_GET_TX_FIFO_FULL_FLAG(SPI0) == 0) && (u32TxDataCount < TEST_COUNT))
            SPI_WRITE_TX0(SPI0, g_au32SourceData[u32TxDataCount++]); /* Write to TX FIFO */
        if(SPI_GET_RX_FIFO_EMPTY_FLAG(SPI0) == 0)
            g_au32DestinationData[u32RxDataCount++] = SPI_READ_RX0(SPI0); /* Read RX FIFO */
    for(u32RxDataCount = 0; u32RxDataCount < TEST_COUNT; u32RxDataCount++)
        printf("%d:\t0x%X\n", u32RxDataCount, g_au32DestinationData[u32RxDataCount]);
    /* Reset SPI0 */
    SPI_Close(SPI0);
    while(1);
void SYS_Init(void)
void SPI_Init(void)
    /* Init SPI        */
    /* Configure as a slave, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    /* Configure SPI0 as a low level active device. */
    SPI_Open(SPI0, SPI_SLAVE, SPI_MODE_0, 32, NULL);
yiyigirl2014| | 2017-7-14 19:23 | 只看该作者
* @file     main.c
* @version  V3.00
* $Revision: 7 $
* $Date: 15/05/22 3:01p $
* @brief    Implement SPI Master loop back transfer. This sample code needs to
*           connect MISO_0 pin and MOSI_0 pin together. It will compare the
*           received data with transmitted data.
* @note
#include <stdio.h>
#define TEST_COUNT             64
/* Main function */
int main(void)
    uint32_t u32DataCount, u32TestCount, u32Err;
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("+--------------------------------------------------------------------+\n");
    printf("|                   M051 SPI Driver Sample Code                      |\n");
    printf("\n");
    printf("\nThis sample code demonstrates SPI0 self loop back data transfer.\n");
    printf(" SPI0 configuration:\n");
    printf("     Master mode; data width 32 bits.\n");
    printf(" I/O connection:\n");
    printf("     P1.5 MOSI <--> P1.6 MISO \n");
    printf("\nSPI0 Loopback test ");
    u32Err = 0;
    for(u32TestCount = 0; u32TestCount < 0x1000; u32TestCount++)
        /* set the source data and clear the destination buffer */
            g_au32SourceData[u32DataCount] = u32DataCount;
        u32DataCount = 0;
        if((u32TestCount & 0x1FF) == 0)
            putchar('.');
        while(1)
            /* Write to TX register */
            SPI_WRITE_TX0(SPI0, g_au32SourceData[u32DataCount]);
            /* Trigger SPI data transfer */
            SPI_TRIGGER(SPI0);
            /* Check SPI0 busy status */
            while(SPI_IS_BUSY(SPI0));
            /* Read received data */
            g_au32DestinationData[u32DataCount] = SPI_READ_RX0(SPI0);
            u32DataCount++;
            if(u32DataCount >= TEST_COUNT)
                break;
        /*  Check the received data */
            if(g_au32DestinationData[u32DataCount] != g_au32SourceData[u32DataCount])
                u32Err = 1;
        if(u32Err)
            break;
    if(u32Err)
        printf(" [FAIL]\n\n");
    else
        printf(" [PASS]\n\n");
    /* Close SPI0 */
    SPI_Close(SPI0);
    while(1);
void SYS_Init(void)
    /* Switch HCLK clock source to HXT and HCLK source divide 1 */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CyclesPerUs automatically. */
void SPI_Init(void)
    /* Init SPI        */
    /* Set IP clock divider. SPI clock rate = 2MHz */
    SPI_Open(SPI0, SPI_MASTER, SPI_MODE_0, 32, 2000000);
* @file     main.c
* @version  V3.00
* $Revision: 7 $
* $Date: 15/05/22 2:41p $
* @brief    M051 Series I2C Driver Sample Code (Master)
* @note
#include <stdio.h>
#define PLLCON_SETTING      SYSCLK_PLLCON_50MHz_XTAL
#define PLL_CLOCK           50000000
/* Global variables        */
volatile uint8_t g_u8DeviceAddr;
volatile uint8_t g_au8MstTxData[3];
volatile uint8_t g_u8MstRxData;
volatile uint8_t g_u8MstDataLen;
volatile uint8_t g_u8MstEndFlag = 0;
typedef void (*I2C_FUNC)(uint32_t u32Status);
static volatile I2C_FUNC s_I2C0HandlerFn = NULL;
/*  I2C0 IRQ Handler        */
void I2C0_IRQHandler(void)
    uint32_t u32Status;
    u32Status = I2C_GET_STATUS(I2C0);
    if(I2C_GET_TIMEOUT_FLAG(I2C0))
        /* Clear I2C0 Timeout Flag */
        I2C_ClearTimeoutFlag(I2C0);
    else
        if(s_I2C0HandlerFn != NULL)
            s_I2C0HandlerFn(u32Status);
/*  I2C Rx Callback Function        */
void I2C_MasterRx(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted and prepare SLA+W */
        I2C_SET_DATA(I2C0, (g_u8DeviceAddr << 1));    /* Write SLA+W to Register I2CDAT */
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
    else if(u32Status == 0x18)                  /* SLA+W has been transmitted and ACK has been received */
        I2C_SET_DATA(I2C0, g_au8MstTxData[g_u8MstDataLen++]);
    else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NACK has been received */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
    else if(u32Status == 0x28)                  /* DATA has been transmitted and ACK has been received */
        if(g_u8MstDataLen != 2)
        else
            I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_SI);
    else if(u32Status == 0x10)                  /* Repeat START has been transmitted and prepare SLA+R */
        I2C_SET_DATA(I2C0, ((g_u8DeviceAddr << 1) | 0x01));   /* Write SLA+R to Register I2CDAT */
    else if(u32Status == 0x40)                  /* SLA+R has been transmitted and ACK has been received */
    else if(u32Status == 0x58)                  /* DATA has been received and NACK has been returned */
        g_u8MstRxData = (unsigned char) I2C_GET_DATA(I2C0);
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STO_SI);
        g_u8MstEndFlag = 1;
    else
        /* TO DO */
        printf("Status 0x%x is NOT processed\n", u32Status);
/*  I2C Tx Callback Function        */
void I2C_MasterTx(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted */
        I2C_SET_DATA(I2C0, g_u8DeviceAddr << 1);    /* Write SLA+W to Register I2CDAT */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        if(g_u8MstDataLen != 3)
        else
            g_u8MstEndFlag = 1;
    else
        /* TO DO */
void SYS_Init(void)
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    /* Waiting for external XTAL clock ready */
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART & I2C0 module clock */
    CLK_EnableModuleClock(I2C0_MODULE);
    /* Select UART module clock source */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Configure the SDA0 & SCL0 of I2C0 pins */
    SYS->P3_MFP &= ~(SYS_MFP_P34_Msk | SYS_MFP_P35_Msk);
    SYS->P3_MFP |= SYS_MFP_P34_SDA0 | SYS_MFP_P35_SCL0;
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
void I2C0_Init(void)
    /* Open I2C module and set bus clock */
    I2C_Open(I2C0, 100000);
    /* Get I2C0 Bus Clock */
    printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
    /* Set I2C 4 Slave Addresses */
    I2C_SetSlaveAddr(I2C0, 0, 0x15, 0);   /* Slave Address : 0x15 */
    I2C_SetSlaveAddr(I2C0, 1, 0x35, 0);   /* Slave Address : 0x35 */
    I2C_SetSlaveAddr(I2C0, 2, 0x55, 0);   /* Slave Address : 0x55 */
    I2C_SetSlaveAddr(I2C0, 3, 0x75, 0);   /* Slave Address : 0x75 */
    /* Enable I2C interrupt */
    I2C_EnableInt(I2C0);
    NVIC_EnableIRQ(I2C0_IRQn);
void I2C0_Close(void)
    /* Disable I2C0 interrupt and clear corresponding NVIC bit */
    I2C_DisableInt(I2C0);
    NVIC_DisableIRQ(I2C0_IRQn);
    /* Disable I2C0 and close I2C0 clock */
    I2C_Close(I2C0);
    CLK_DisableModuleClock(I2C0_MODULE);
int32_t I2C0_Read_Write_SLAVE(uint8_t slvaddr)
    uint32_t i;
    g_u8DeviceAddr = slvaddr;
    for(i = 0; i < 0x100; i++)
        g_au8MstTxData[0] = (uint8_t)((i & 0xFF00) >> 8);
        g_au8MstTxData[1] = (uint8_t)(i & 0x00FF);
        g_au8MstTxData[2] = (uint8_t)(g_au8MstTxData[1] + 3);
        g_u8MstDataLen = 0;
        g_u8MstEndFlag = 0;
        /* I2C function to write data to slave */
        s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTx;
        /* I2C as master sends START signal */
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA);
        /* Wait I2C Tx Finish */
        while(g_u8MstEndFlag == 0);
        g_u8MstEndFlag = 0;
        /* I2C function to read data from slave */
        s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterRx;
        g_u8MstDataLen = 0;
        /* Wait I2C Rx Finish */
        /* Compare data */
        if(g_u8MstRxData != g_au8MstTxData[2])
            printf("I2C Byte Write/Read Failed, Data 0x%x\n", g_u8MstRxData);
            return -1;
    printf("Master Access Slave (0x%X) Test OK\n", slvaddr);
    return 0;
/*  Main Function        */
int32_t main(void)
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    SYS_LockReg();
        This sample code sets I2C bus clock to 100kHz. Then, Master accesses Slave with Byte Write
        and Byte Read operations, and check if the read data is equal to the programmed data.
    printf("\n");
    printf("+-------------------------------------------------------+\n");
    printf("| M05xx I2C Driver Sample Code(Master) for access Slave |\n");
    printf("|                                                       |\n");
    printf("| I2C Master (I2C0) <---> I2C Slave(I2C0)               |\n");
    printf("Configure I2C0 as a master.\n");
    printf("The I/O connection for I2C0:\n");
    printf("I2C0_SDA(P3.4), I2C0_SCL(P3.5)\n");
    /* Init I2C0 */
    I2C0_Init();
    printf("\n");
    printf("Check I2C Slave(I2C0) is running first!\n");
    printf("Press any key to continue.\n");
    getchar();
    /* Access Slave with no address */
    printf("\n");
    printf(" == No Mask Address ==\n");
    I2C0_Read_Write_SLAVE(0x15);
    I2C0_Read_Write_SLAVE(0x35);
    I2C0_Read_Write_SLAVE(0x55);
    I2C0_Read_Write_SLAVE(0x75);
    printf("SLAVE Address test OK.\n");
    /* Access Slave with address mask */
    printf("\n");
    printf(" == Mask Address ==\n");
    I2C0_Read_Write_SLAVE(0x15 & ~0x01);
    I2C0_Read_Write_SLAVE(0x35 & ~0x04);
    I2C0_Read_Write_SLAVE(0x55 & ~0x01);
    I2C0_Read_Write_SLAVE(0x75 & ~0x04);
    printf("SLAVE Address Mask test OK.\n");
    /* Close I2C0 */
    I2C0_Close();
    while(1);
* @file     main.c
* @version  V3.00
* $Revision: 6 $
* $Date: 14/11/14 10:48a $
* @brief    M051 Series I2C Driver Sample Code (Slave)
* @note
#include <stdio.h>
uint32_t slave_buff_addr;
uint8_t g_au8SlvData[256];
uint8_t g_au8SlvRxData[3];
volatile uint8_t g_u8SlvDataLen;
static I2C_FUNC s_I2C0HandlerFn = NULL;
    uint32_t u32Status;
    else
/*  I2C TRx Callback Function        */
void I2C_SlaveTRx(uint32_t u32Status)
    if(u32Status == 0x60)                       /* Own SLA+W has been receive; ACK has been return */
        g_u8SlvDataLen = 0;
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI_AA);
    else if(u32Status == 0x80)                 /* Previously address with own SLA address
                                                   Data has been received; ACK has been returned*/
        g_au8SlvRxData[g_u8SlvDataLen] = (unsigned char) I2C_GET_DATA(I2C0);
        g_u8SlvDataLen++;
        if(g_u8SlvDataLen == 2)
            slave_buff_addr = (g_au8SlvRxData[0] << 8) + g_au8SlvRxData[1];
        if(g_u8SlvDataLen == 3)
            g_au8SlvData[slave_buff_addr] = g_au8SlvRxData[2];
            g_u8SlvDataLen = 0;
    else if(u32Status == 0xA8)                  /* Own SLA+R has been receive; ACK has been return */
        I2C_SET_DATA(I2C0, g_au8SlvData[slave_buff_addr]);
        slave_buff_addr++;
    else if(u32Status == 0xC0)                 /* Data byte or last data in I2CDAT has been transmitted
                                                   Not ACK has been received */
    else if(u32Status == 0x88)                 /* Previously addressed with own SLA address; NOT ACK has
                                                   been returned */
        g_u8SlvDataLen = 0;
    else if(u32Status == 0xA0)                 /* A STOP or repeated START has been received while still
                                                   addressed as Slave/Receiver*/
        g_u8SlvDataLen = 0;
    else
        /* TO DO */
void SYS_Init(void)
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    /* Set I2C 4 Slave Addresses Mask */
    I2C_SetSlaveAddrMask(I2C0, 0, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 1, 0x04);
    I2C_SetSlaveAddrMask(I2C0, 2, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 3, 0x04);
    I2C_Close(I2C0);
/*  Main Function        */
int32_t main(void)
    uint32_t i;
    SYS_UnlockReg();
    SYS_Init();
    UART0_Init();
    SYS_LockReg();
    printf("|  M05xx I2C Driver Sample Code(Slave) for access Slave |\n");
    printf("|                                                       |\n");
    printf("Configure I2C0 as a slave.\n");
    /* Init I2C0 */
    I2C0_Init();
    /* I2C enter no address SLV mode */
        g_au8SlvData[i] = 0;
    /* I2C function to Slave receive/transmit data */
    s_I2C0HandlerFn = I2C_SlaveTRx;
    printf("\n");
    printf("I2C Slave Mode is Running.\n");
    while(1);
yiyigirl2014| | 2017-7-14 19:24 | 只看该作者
* @file     main.c
* @version  V3.00
* $Revision: 5 $
* @brief    M051 Series I2C Driver Sample Code for Wake-up (Master)
* @note
#include <stdio.h>
    uint32_t u32Status;
    else
/*  I2C Master Tx Wake Up Callback Function        */
void I2C_MasterTxWakeup(uint32_t u32Status)
        g_u8MstEndFlag = 1;
    else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NOT ACK has been received */
        I2C_STOP(I2C0);
        g_u8MstEndFlag = 1;
    else
        /* TO DO */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        else
        g_u8MstEndFlag = 1;
    else
        /* TO DO */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        else
            g_u8MstEndFlag = 1;
    else
        /* TO DO */
void SYS_Init(void)
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    I2C_Close(I2C0);
    uint32_t i;
        g_u8MstDataLen = 0;
        g_u8MstEndFlag = 0;
        g_u8MstEndFlag = 0;
        g_u8MstDataLen = 0;
        /* Compare data */
            return -1;
    return 0;
/*  Main Function        */
int32_t main(void)
    SYS_UnlockReg();
    SYS_Init();
    UART0_Init();
    SYS_LockReg();
        This sample code sets I2C bus clock to 100kHz. After wake-up, then accesses Slave with Byte
        Write and Byte Read operations, and check if the read data is equal to the programmed data.
    printf("+-----------------------------------------------------------------------+\n");
    printf("| M05xx I2C Driver Sample Code (Master) for wake-up & access Slave test |\n");
    printf("|        |\n");
    /* Init I2C0 to access Slave */
    I2C0_Init();
    printf("\n");
    printf("Check I2C slave at power down status.\n");
    printf("Press any key to Wake up slave.\n");
    getchar();
    /* Set the Slave address to wake-up*/
    g_u8DeviceAddr = 0x15;
    /* I2C function to wake-up slave*/
    s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTxWakeup;
    /* Send a START condition to bus */
    /*Access to the corresponding address Slave*/
    printf("\n");
    printf("\n");
    /* Close I2C0 */
    I2C0_Close();
    while(1);
shen_hao|  楼主 | 2017-7-14 21:44 | 只看该作者
有没有不是BSP的程序?M453
Harvard| | 2017-7-15 13:45 | 只看该作者
003 bsp里面都带了 好好看看吧
icecut| | 2017-7-15 14:11 | 只看该作者
这样贴程序能看么?
http://antriver.com/stm32/Middlewares/Third_Party.html
来这里看看吧
@若水| | 2017-7-17 08:53 | 只看该作者
百度一搜,什么程序都有
@若水| | 2017-7-17 08:54 | 只看该作者
icecut 发表于 2017-7-15 14:11
这样贴程序能看么?
来这里看看吧 ...
看不了啊,一片黑
zhuotuzi| | 2017-7-17 12:10 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V0.10
* $Revision: 10 $
* $Date: 15/09/02 10:03a $
* @brief
*           Configure SPI1 as I2S Master mode and demonstrate how I2S works in Master mode.
*           This sample code needs to work with I2S_Slave sample code.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include <string.h>
#include "M451Series.h"
#define PLLCON_SETTING      CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK           72000000
uint32_t g_u32TxValue;
uint32_t g_u32DataCount;
void UART0_Init(void);
/*  Main Function        */
int32_t main(void)
    uint32_t u32RxValue1, u32RxValue2;
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    /* Init UART for print message */
    UART0_Init();
    printf("+-----------------------------------------------------------+\n");
    printf("|            I2S Driver Sample Code (master mode)           |\n");
    printf("  I2S configuration:\n");
    printf("      Sample rate 16 kHz\n");
    printf("      Word width 16 bits\n");
    printf("      Stereo mode\n");
    printf("      I2S format\n");
    printf("      TX value: 0x55005501, 0x55025503, ..., 0x55FE55FF, wraparound\n");
    printf("  The I/O connection for I2S1 (SPI1):\n");
    printf("      I2S1_LRCLK (PA4)\n      I2S1_BCLK(PA7)\n");
    printf("      I2S1_DI (PA6)\n      I2S1_DO (PA5)\n\n");
    printf("  NOTE: Connect with a I2S slave device.\n");
    printf("        This sample code will transmit a TX value 50000 times, and then change to the next TX value.\n");
    printf("        When TX value or the received value changes, the new TX value or the current TX value and the new received value will be printed.\n");
    printf("  Press any key to start ...");
    getchar();
    printf("\n");
    /* Master mode, 16-bit word width, stereo mode, I2S format. */
    SPI1->I2SCTL = I2S_MODE_MASTER | I2S_DATABIT_16 | I2S_STEREO | I2S_FORMAT_I2S;
    /* Set TX and RX FIFO threshold to middle value */
    SPI1->FIFOCTL = I2S_FIFO_TX_LEVEL_WORD_2 | I2S_FIFO_RX_LEVEL_WORD_2;
    /* Sampling rate 16000 Hz; bit clock rate 512 kHz. */
    SPI1->I2SCLK = (SPI1->I2SCLK & ~SPI_I2SCLK_BCLKDIV_Msk) | (11 << SPI_I2SCLK_BCLKDIV_Pos);
    /* Enable I2S */
    SPI1->I2SCTL |= SPI_I2SCTL_I2SEN_Msk;
    NVIC_EnableIRQ(SPI1_IRQn);
    /* Initiate data counter */
    g_u32DataCount = 0;
    /* Initiate TX value and RX value */
    g_u32TxValue = 0x55005501;
    u32RxValue1 = 0;
    u32RxValue2 = 0;
    /* Enable TX threshold level interrupt */
    SPI1->FIFOCTL |= SPI_FIFOCTL_TXTHIEN_Msk;
    /* Enable I2S TX function to transmit data */
    SPI1->I2SCTL |= SPI_I2SCTL_TXEN_Msk;
    /* Enable I2S RX function to receive data */
    SPI1->I2SCTL |= SPI_I2SCTL_RXEN_Msk;
    printf("Start I2S ...\nTX value: 0x%X\n", g_u32TxValue);
    while(1)
        /* Check RX FIFO empty flag */
        if((SPI1->I2SSTS & SPI_I2SSTS_RXEMPTY_Msk) == 0)
            /* Read RX FIFO */
            u32RxValue2 = SPI1->RX;
            if(u32RxValue1 != u32RxValue2)
                u32RxValue1 = u32RxValue2;
                /* If received value changes, print the current TX value and the new received value. */
                printf("TX value: 0x%X;  RX value: 0x%X\n", g_u32TxValue, u32RxValue1);
        if(g_u32DataCount >= 50000)
            g_u32TxValue = 0x55005500 | ((g_u32TxValue + 0x00020002) & 0x00FF00FF); /* g_u32TxValue: 0x55005501, 0x55025503, ..., 0x55FE55FF */
            printf("TX value: 0x%X\n", g_u32TxValue);
            g_u32DataCount = 0;
void SYS_Init(void)
    /* Enable HIRC clock */
    CLK->PWRCTL |= CLK_PWRCTL_HIRCEN_Msk;
    /* Waiting for HIRC clock ready */
    while(!(CLK->STATUS & CLK_STATUS_HIRCSTB_Msk));
    /* Switch HCLK clock source to HIRC */
    CLK->CLKSEL0 = CLK_CLKSEL0_HCLKSEL_HIRC;
    /* Set PLL to Power-down mode and PLLSTB bit in CLK_STATUS register will be cleared by hardware.*/
    CLK->PLLCTL |= CLK_PLLCTL_PD_Msk;
    /* Enable HXT */
    CLK->PWRCTL |= CLK_PWRCTL_HXTEN_Msk;
    /* Enable PLL and Set PLL frequency */
    CLK->PLLCTL = PLLCON_SETTING;
    while(!(CLK->STATUS & CLK_STATUS_PLLSTB_Msk));
    while(!(CLK->STATUS & CLK_STATUS_HXTSTB_Msk));
    /* Switch STCLK source to HCLK/2 and HCLK clock source to PLL */
    CLK->CLKSEL0 = CLK_CLKSEL0_STCLKSEL_HCLK_DIV2 | CLK_CLKSEL0_HCLKSEL_PLL;
    /* Select HXT as the clock source of UART */
    CLK->CLKSEL1 = (CLK->CLKSEL1 & (~CLK_CLKSEL1_UARTSEL_Msk)) | CLK_CLKSEL1_UARTSEL_HXT;
    /* Select HXT as the clock source of SPI1 */
    CLK->CLKSEL2 = (CLK->CLKSEL2 & (~CLK_CLKSEL2_SPI1SEL_Msk)) | CLK_CLKSEL2_SPI1SEL_HXT;
    /* Enable peripheral clock */
    CLK->APBCLK0 = CLK_APBCLK0_UART0CKEN_Msk | CLK_APBCLK0_SPI1CKEN_Msk;
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Configure SPI1 related multi-function pins. */
    /* GPA[7:4] : SPI1_CLK (I2S1_BCLK), SPI1_MISO (I2S1_DI), SPI1_MOSI (I2S1_DO), SPI1_SS (I2S1_LRCLK). */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA4MFP_Msk | SYS_GPA_MFPL_PA5MFP_Msk | SYS_GPA_MFPL_PA6MFP_Msk | SYS_GPA_MFPL_PA7MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA4MFP_SPI1_SS | SYS_GPA_MFPL_PA5MFP_SPI1_MOSI | SYS_GPA_MFPL_PA6MFP_SPI1_MISO | SYS_GPA_MFPL_PA7MFP_SPI1_CLK);
    /* Word length is 8 bits; 1 stop bit; no parity bit. */
    UART0->LINE = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
    /* UART peripheral clock rate 12MHz; UART bit rate 115200 bps. */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
void SPI1_IRQHandler()
    /* Write 2 TX values to TX FIFO */
    SPI1->TX = g_u32TxValue;
    g_u32DataCount += 2;
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
* @file     main.c
* @version  V3.00
* $Revision: 11 $
* @brief    Show how to use I2C interface to access EEPROM.
* @note
#include <stdio.h>
#define PLLCTL_SETTING  CLK_PLLCTL_72MHz_HXT
volatile uint8_t g_au8TxData[3];
volatile uint8_t g_u8RxData;
volatile uint8_t g_u8DataLen;
volatile uint8_t g_u8EndFlag = 0;
    uint32_t u32Status;
    u32Status = I2C0->STATUS;
    if(I2C0->TOCTL & I2C_TOCTL_TOIF_Msk)
        I2C0->TOCTL |= I2C_TOCTL_TOIF_Msk;
    else
        I2C0->DAT = g_u8DeviceAddr << 1;     /* Write SLA+W to Register I2CDAT */
        I2C_SET_CONTROL_REG(I2C0, I2C_CTL_SI);
        I2C0->DAT = g_au8TxData[g_u8DataLen++];
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        if(g_u8DataLen != 2)
        else
            I2C_SET_CONTROL_REG(I2C0, I2C_CTL_STA_SI);
        I2C0->DAT = ((g_u8DeviceAddr << 1) | 0x01);   /* Write SLA+R to Register I2CDAT */
        g_u8RxData = I2C0->DAT;
        I2C_SET_CONTROL_REG(I2C0, I2C_CTL_STO_SI);
        g_u8EndFlag = 1;
    else
        /* TO DO */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        if(g_u8DataLen != 3)
        else
            g_u8EndFlag = 1;
    else
        /* TO DO */
void SYS_Init(void)
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
    CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLKSEL_Msk;
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLKSEL_HIRC;
    CLK->CLKDIV0 &= ~CLK_CLKDIV0_HCLKDIV_Msk;
    CLK->CLKDIV0 |= CLK_CLKDIV0_HCLK(1);
    /* Enable HXT clock (external XTAL 12MHz) */
    /* Waiting for HXT clock ready */
    CLK->PLLCTL = PLLCTL_SETTING;
    CLK->CLKSEL0 &= (~CLK_CLKSEL0_HCLKSEL_Msk);
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLKSEL_PLL;
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For CLK_SysTickDelay()
    /* Enable UART module clock and I2C controller */
    CLK->APBCLK0 |= (CLK_APBCLK0_UART0CKEN_Msk | CLK_APBCLK0_I2C0CKEN_Msk);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK->CLKSEL1 &= ~CLK_CLKSEL1_UARTSEL_Msk;
    CLK->CLKSEL1 |= CLK_CLKSEL1_UARTSEL_HXT;
    /* Set PD multi-function pins for UART0 RXD, TXD and */
    /* Set I2C PA multi-function pins */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA2MFP_I2C0_SDA | SYS_GPA_MFPL_PA3MFP_I2C0_SCL);
    /* Init UART        */
    /* Reset UART IP */
    SYS->IPRST1 |=  SYS_IPRST1_UART0RST_Msk;
    SYS->IPRST1 &= ~SYS_IPRST1_UART0RST_Msk;
    /* Reset I2C0 */
    SYS->IPRST1 |=  SYS_IPRST1_I2C0RST_Msk;
    SYS->IPRST1 &= ~SYS_IPRST1_I2C0RST_Msk;
    /* Enable I2C0 Controller */
    I2C0->CTL |= I2C_CTL_I2CEN_Msk;
    /* I2C0 clock divider, I2C Bus Clock = PCLK(72Mhz) / (4*180) = 100kHz */
    I2C0->CLKDIV = 180 - 1;
    printf("I2C clock %d Hz\n", (SystemCoreClock / (((I2C0->CLKDIV) + 1) << 2)));
    /* Set I2C0 4 Slave Addresses */
    I2C0->ADDR0 = (I2C0->ADDR0 & ~I2C_ADDR0_ADDR_Msk) | (0x15 << I2C_ADDR0_ADDR_Pos);
    I2C0->ADDR1 = (I2C0->ADDR1 & ~I2C_ADDR1_ADDR_Msk) | (0x35 << I2C_ADDR1_ADDR_Pos);
    I2C0->ADDR2 = (I2C0->ADDR2 & ~I2C_ADDR2_ADDR_Msk) | (0x55 << I2C_ADDR2_ADDR_Pos);
    I2C0->ADDR3 = (I2C0->ADDR3 & ~I2C_ADDR3_ADDR_Msk) | (0x75 << I2C_ADDR3_ADDR_Pos);
    /* Enable I2C0 interrupt and set corresponding NVIC bit */
    I2C0->CTL |= I2C_CTL_INTEN_Msk;
    I2C0->CTL &= ~I2C_CTL_INTEN_Msk;
    I2C0->CTL &= ~I2C_CTL_I2CEN_Msk;
    CLK->APBCLK0 &= ~CLK_APBCLK0_I2C0CKEN_Msk;
/*  Main Function        */
int32_t main(void)
    uint32_t i;
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    /* Init UART3 for printf */
    UART0_Init();
        This sample code sets I2C bus clock to 100kHz. Then, accesses EEPROM 24LC64 with Byte Write
    printf("|    M451 I2C Driver Sample Code with EEPROM 24LC64     |\n");
    /* Init I2C0 to access EEPROM */
    I2C0_Init();
    g_u8DeviceAddr = 0x50;
        g_au8TxData[0] = (uint8_t)((i & 0xFF00) >> 8);
        g_au8TxData[1] = (uint8_t)(i & 0x00FF);
        g_au8TxData[2] = (uint8_t)(g_au8TxData[1] + 3);
        g_u8DataLen = 0;
        g_u8EndFlag = 0;
        I2C_SET_CONTROL_REG(I2C0,   I2C_CTL_STA);
        while(g_u8EndFlag == 0);
        g_u8EndFlag = 0;
        /* Set EEPROM Address */
        g_u8DataLen = 0;
        /* Compare data */
        if(g_u8RxData != g_au8TxData[2])
            printf("I2C Byte Write/Read Failed, Data 0x%x\n", g_u8RxData);
            return -1;
    printf("I2C Access EEPROM Test OK\n");
    /* Close I2C0 */
    I2C0_Close();
    while(1);
zhuotuzi| | 2017-7-17 12:11 | 只看该作者
* @file     main.c
* @version  V1.0
* $Revision: 6 $
* $Date: 14/08/12 6:35p $
* @brief
*           Demonstrate how to communicate with an off-chip SPI slave device.
*           This sample code needs to work with SPI_SlaveMode.
* @note
#include <stdio.h>
/* Main function */
int main(void)
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    UART0_Init();
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("+--------------------------------------------------------+\n");
    printf("|             SPI Master Mode Sample Code                |\n");
    printf("\n");
    printf("    SPI0_SS (PB.4)\n    SPI0_CLK (PB.2)\n");
    printf("    SPI0_MISO0 (PB.3)\n    SPI0_MOSI0 (PB.5)\n\n");
    printf("SPI controller will transfer %d data to a off-chip slave device.\n", TEST_COUNT);
    printf("Before starting the data transfer, make sure the slave device is ready. Press any key to start the transfer.");
    getchar();
    printf("\n");
    SPI0->FIFOCTL = (2 << SPI_FIFOCTL_TXTH_Pos) | SPI_FIFOCTL_RXTOIEN_Msk | SPI_FIFOCTL_TXTHIEN_Msk;
    SPI0->FIFOCTL = 0;
    /* Disable SPI0 peripheral clock */
    CLK->APBCLK0 &= (~CLK_APBCLK0_SPI0CKEN_Msk);
    while(1);
void SYS_Init(void)
    /* Select HXT as the clock source of HCLK */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLKSEL_Msk)) | CLK_CLKSEL0_HCLKSEL_HXT;
    /* Select PCLK0 as the clock source of SPI0 */
    CLK->CLKSEL2 = (CLK->CLKSEL2 & (~CLK_CLKSEL2_SPI0SEL_Msk)) | CLK_CLKSEL2_SPI0SEL_PCLK0;
    /* Enable UART0 and SPI0 clock */
    CLK->APBCLK0 = CLK_APBCLK0_UART0CKEN_Msk | CLK_APBCLK0_SPI0CKEN_Msk;
    /* Set SPI0 multi-function pins */
    SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk | SYS_GPB_MFPL_PB4MFP_Msk | SYS_GPB_MFPL_PB5MFP_Msk);
    SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB2MFP_SPI0_CLK | SYS_GPB_MFPL_PB3MFP_SPI0_MISO0 | SYS_GPB_MFPL_PB4MFP_SPI0_SS | SYS_GPB_MFPL_PB5MFP_SPI0_MOSI0);
void SPI_Init(void)
    /* Init SPI        */
    /* Enable the automatic hardware slave selection function. Select the SPI0_SS pin and configure as low-active. */
    SPI0->SSCTL = SPI_SSCTL_AUTOSS_Msk | SPI_SS;
    /* Configure SPI0 as a master, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    SPI0->CTL = SPI_MASTER | SPI_CTL_TXNEG_Msk | SPI_CTL_SPIEN_Msk;
    /* Set IP clock divider. SPI clock rate = f_PCLK0 / (5+1) */
    SPI0->CLKDIV = SPI0->CLKDIV & (~SPI_CLKDIV_DIVIDER_Msk) | 5;
        /* Read RX FIFO */
        g_au32DestinationData[g_u32RxDataCount++] = SPI_READ_RX(SPI0);
        SPI_WRITE_TX(SPI0, g_au32SourceData[g_u32TxDataCount++]);
        SPI0->FIFOCTL &= (~SPI_FIFOCTL_TXTHIEN_Msk); /* Disable TX FIFO threshold interrupt */
    if(SPI0->STATUS & SPI_STATUS_RXTOIF_Msk)
zhuomuniao110| | 2017-7-17 19:35 | 只看该作者
去官方下载开发包锕
