[DemoCode下载]
M451通过I2C实现收发
837|7
dongnanxibei|  楼主 | 2017-7-19 19:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V0.10
* $Revision: 12 $
* $Date: 15/09/02 10:04a $
* @brief
*           Configure SPI1 as I2S Master mode and demonstrate how I2S works in Master mode.
*           This sample code needs to work with I2S_Slave.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include <string.h>
#include "M451Series.h"
#define PLL_CLOCK           72000000
uint32_t g_u32TxValue;
uint32_t g_u32DataCount;
/* Function prototype declaration */
void SYS_Init(void);
/*  Main Function        */
int32_t main(void)
    uint32_t u32RxValue1, u32RxValue2;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Reset UART0 module */
    SYS_ResetModule(UART0_RST);
    /* Init UART0 to 115200-8n1 for printing messages */
    UART_Open(UART0, 115200);
    printf("+-----------------------------------------------------------+\n");
    printf("|            I2S Driver Sample Code (master mode)           |\n");
    printf("  I2S configuration:\n");
    printf("      Sample rate 16 kHz\n");
    printf("      Word width 16 bits\n");
    printf("      Stereo mode\n");
    printf("      I2S format\n");
    printf("      TX value: 0x55005501, 0x55025503, ..., 0x55FE55FF, wraparound\n");
    printf("  The I/O connection for I2S1 (SPI1):\n");
    printf("      I2S1_LRCLK (PA4)\n      I2S1_BCLK(PA7)\n");
    printf("      I2S1_DI (PA6)\n      I2S1_DO (PA5)\n\n");
    printf("  NOTE: Connect with a I2S slave device.\n");
    printf("        This sample code will transmit a TX value 50000 times, and then change to the next TX value.\n");
    printf("        When TX value or the received value changes, the new TX value or the current TX value and the new received value will be printed.\n");
    printf("  Press any key to start ...");
    getchar();
    printf("\n");
    /* Master mode, 16-bit word width, stereo mode, I2S format. Set TX and RX FIFO threshold to middle value. */
    I2S_Open(SPI1, I2S_MODE_MASTER, 16000, I2S_DATABIT_16, I2S_STEREO, I2S_FORMAT_I2S);
    /* Initiate data counter */
    g_u32DataCount = 0;
    /* Initiate TX value and RX value */
    g_u32TxValue = 0x55005501;
    u32RxValue1 = 0;
    u32RxValue2 = 0;
    /* Enable TX threshold level interrupt */
    I2S_EnableInt(SPI1, I2S_FIFO_TXTH_INT_MASK);
    NVIC_EnableIRQ(SPI1_IRQn);
    printf("Start I2S ...\nTX value: 0x%X\n", g_u32TxValue);
    while(1)
        /* Check RX FIFO empty flag */
        if((SPI1->I2SSTS & SPI_I2SSTS_RXEMPTY_Msk) == 0)
            /* Read RX FIFO */
            u32RxValue2 = I2S_READ_RX_FIFO(SPI1);
            if(u32RxValue1 != u32RxValue2)
                u32RxValue1 = u32RxValue2;
                /* If received value changes, print the current TX value and the new received value. */
                printf("TX value: 0x%X;  RX value: 0x%X\n", g_u32TxValue, u32RxValue1);
        if(g_u32DataCount >= 50000)
            g_u32TxValue = 0x55005500 | ((g_u32TxValue + 0x00020002) & 0x00FF00FF); /* g_u32TxValue: 0x55005501, 0x55025503, ..., 0x55FE55FF */
            printf("TX value: 0x%X\n", g_u32TxValue);
            g_u32DataCount = 0;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Configure PLL */
    CLK_EnablePLL(CLK_PLLCTL_PLLSRC_HXT, PLL_CLOCK);
    /* Switch HCLK clock source to PLL */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(1));
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Select PCLK1 as the clock source of SPI1 */
    CLK_SetModuleClock(SPI1_MODULE, CLK_CLKSEL2_SPI1SEL_PCLK1, MODULE_NoMsk);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(SPI1_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Configure SPI1 related multi-function pins. */
    /* GPA[7:4] : SPI1_CLK (I2S1_BCLK), SPI1_MISO (I2S1_DI), SPI1_MOSI (I2S1_DO), SPI1_SS (I2S1_LRCLK). */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA4MFP_Msk | SYS_GPA_MFPL_PA5MFP_Msk | SYS_GPA_MFPL_PA6MFP_Msk | SYS_GPA_MFPL_PA7MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA4MFP_SPI1_SS | SYS_GPA_MFPL_PA5MFP_SPI1_MOSI | SYS_GPA_MFPL_PA6MFP_SPI1_MISO | SYS_GPA_MFPL_PA7MFP_SPI1_CLK);
void SPI1_IRQHandler()
    /* Write 2 TX values to TX FIFO */
    I2S_WRITE_TX_FIFO(SPI1, g_u32TxValue);
    g_u32DataCount += 2;
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
* @file     main.c
* @version  V0.10
* $Revision: 11 $
* @brief
*           Configure SPI1 as I2S Slave mode and demonstrate how I2S works in Slave mode.
*           This sample code needs to work with I2S_Master.
* @note
#include <stdio.h>
#include <string.h>
/*  Main Function        */
int32_t main(void)
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    printf("+----------------------------------------------------------+\n");
    printf("|            I2S Driver Sample Code (slave mode)           |\n");
    printf("      TX value: 0xAA00AA01, 0xAA02AA03, ..., 0xAAFEAAFF, wraparound\n");
    printf("  NOTE: Connect with a I2S master.\n");
    getchar();
    printf("\n");
    /* Slave mode, 16-bit word width, stereo mode, I2S format. Set TX and RX FIFO threshold to middle value. */
    /* I2S peripheral clock rate is equal to PCLK1 clock rate. */
    I2S_Open(SPI1, I2S_MODE_SLAVE, 0, I2S_DATABIT_16, I2S_STEREO, I2S_FORMAT_I2S);
    g_u32DataCount = 0;
    g_u32TxValue = 0xAA00AA01;
    u32RxValue1 = 0;
    u32RxValue2 = 0;
    while(1)
            /* Read RX FIFO */
            g_u32TxValue = 0xAA00AA00 | ((g_u32TxValue + 0x00020002) & 0x00FF00FF); /* g_u32TxValue: 0xAA00AA01, 0xAA02AA03, ..., 0xAAFEAAFF */
            g_u32DataCount = 0;
void SYS_Init(void)
    /* Configure PLL */
dongnanxibei|  楼主 | 2017-7-19 20:02 | 只看该作者
这两个才是关键,搞两个例子,看晕人。
dongnanxibei|  楼主 | 2017-7-19 20:05 | 只看该作者
有时候关键点就是那么一点。
heisexingqisi| | 2017-7-19 20:17 | 只看该作者
上面分析的很到位,好多功能选择就是一个参数。
598330983| | 2017-7-19 22:15 | 只看该作者
看来要好好总结总结这些使用方法了。
zhuotuzi| | 2017-7-20 15:18 | 只看该作者
搞懂原理了就都简单了。
yiy| | 2017-7-24 21:11 | 只看该作者
I2C这种接口的外部芯片也是非常多的。
