MATLAB编程-频率调制FM
811|1
             figure 1. 调制信号和调频信号
        figure 2. 调制信号频谱和调频信号频谱
% 主程序 频率调制
% fm1.m
% Matlab demonstration script for frequency modulation.The message signal
% is +2 for 0<t<t0/3,-2 for t0/3<t<2t0/3,and zero otherwise.
echo on
t0=0.15; %signal duration
ts=0.0005; %sample interval
fc=200; %载波 frequency
kf=50; %modulation index
fs=1/ts; %sampling frequency
t=[0:ts:t0]; %time vector
df=0.25; %required frequency resolution
% message signal
m=[2*ones(1,t0/(3*ts)),-2*ones(1,t0/(3*ts)),zeros(1,t0/(3*ts)+1)];
int_m(1)=0;
for i=1:length(t)-1 %integral of m
    int_m(i+1)=int_m(i)+m(i)*ts;
    echo off;
end
echo on;
[M,m,df1]=fftseq(m,ts,df); %Fourier transform
M=M/fs; %scaling
f=[0:df1:df1*(length(m)-1)]-fs/2; %frequency vector
u=cos(2*pi*fc*t+2*pi*kf*int_m); %modulated signal
[U,u,df]=fftseq(u,ts,df); %Fourier transform
U=U/fs; %scaling
pause %Press any key to see plot of the message and the modulated signal
subplot(211)
plot(t,m(1:length(t)))
axis([0 0.15 -2.1 2.1])
xlabel('Time')
title('The message signal')
subplot(212)
plot(t,u(1:length(t)))
xlabel('Time')
title('The modulated signal')
subplot(211)
plot(f,abs(fftshift(M)))
xlabel('Frequency')
title('Magnitude spectrum of the message signal')
subplot(212)
plot(f,abs(fftshift(U)))
xlabel('Frequency')
title('Magnitude spectrum of the modulated signal')
% -----主程序调用的函数,单独编程,程序名是MATLAB自动命名为函数名----
% MATLAB函数fftseq.m,将时间序列m,采样间隔ts和要求的频率分辨率df作为输入,就得长度为2的幂的序列,
% 这个序列的FFT(M)和所要的频率分辨率。
function [M,m,df]=fftseq(m,ts,df)
% [M,m,df]=fftseq(m,ts,df)
% [M,m,df]=fftseq(m,ts)
% FFTSEQ Generates M,the FFT of the sequence m.
% The sequence is zero-padded to meet the required frequency resolution df.
% ts is the sampling interval.The output df is the final frequency resolution.
% Output m is the zero-padded version of input m,M is the FFT.
fs=1/ts;
if nargin == 2
    n1=0;
else
    n1=fs/df;
end
n2=length(m);
n=2^(max(nextpow2(n1),nextpow2(n2)));
M=fft(m,n);
m=[m,zeros(1,n-n2)];
df=fs/n;
end
gaoyang9992006|  楼主 | 2017-8-23 19:28 | 只看该作者
希望对大家学习这些理论有所帮助。
认证:西安公路研究院南京院
简介:主要工作从事监控网络与通信网络设计,以及从事基于嵌入式的通信与控制设备研发。擅长单片机嵌入式系统物联网设备开发,音频功放电路开发。
1897
