菜农芯唐ISP学习笔记
4673|16
 楼主| hotpower 发表于 2010-12-21 00:04 | 显示全部楼层 |阅读模式
 楼主| hotpower 发表于 2010-12-21 00:05 | 显示全部楼层
串口链接按键分析:
..\APROM.bin
..\DataFlash.bin
0        18:51:30        NuMicro ISP Wri        IRP_MJ_CREATE
  Serial0        SUCCESS        Options: Open 打开串口
1        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_BAUD_RATE
  Serial0        SUCCESS
2        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_LINE_CONTROL
  Serial0        SUCCESS
3        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_CHARS
  Serial0        SUCCESS
4        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_HANDFLOW
  Serial0        SUCCESS
5        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_BAUD_RATE
  Serial0        SUCCESS
6        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_LINE_CONTROL
  Serial0        SUCCESS
7        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_CHARS
  Serial0        SUCCESS
8        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_GET_HANDFLOW
  Serial0        SUCCESS
9        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_BAUD_RATE
  Serial0        SUCCESS        Rate: 57600  波特率为57600BPS
10        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_RTS
  Serial0        SUCCESS        RTS = 1
11        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_DTR
  Serial0        SUCCESS        DTR = 1
12        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_LINE_CONTROL
  Serial0        SUCCESS        StopBits: 1   1位停止位
                        Parity: NONE  不校验
                        WordLength: 8 字长8位数据位
13        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_CHAR
  Serial0        SUCCESS        EOF:0
                        ERR:0
                        BRK:0
                        EVT:0
                        XON:11
                        XOFF:13
14        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_HANDFLOW
  Serial0        SUCCESS        Shake:1
                        Replace:40
                        XonLimit:2048
                        XoffLimit:512
15        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_WAIT_MASK
  Serial0        SUCCESS        Mask: RXCHAR TXEMPTY
16        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_QUEUE_SIZE
  Serial0        SUCCESS        InSize: 1024 OutSize: 128
17        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_SET_TIMEOUTS
  Serial0        SUCCESS        RI:100
                        RM:0
                        RC:0
                        WM:0
                        WC:0
18        18:51:30        NuMicro ISP Wri        IOCTL_SERIAL_PURGE
  Serial0        SUCCESS        Purge: TXABORT RXABORT TXCLEAR RXCLEAR
19        18:51:30        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_SYNC_PACKNO(0xA4)
    A4 00 00 00 CMD           = 0x000000A4
    01 00 00 00 Packet number = 0x00000001
    01 00 00 00 equal to PN   = 0x00000001
    00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20        18:51:30        NuMicro ISP Wri        IRP_MJ_READ
  Serial0        SUCCESS        Length 64: 从机应答命令:Checksum Packet Number
    A6 00 00 00 Checksum      = 0x000000A6(0xA4+0x01+0x01)
    02 00 00 00 Packet Number = 0x00000002
    88 0E                                           校 验 和=0x0E88
    FF FF
    00 F0 01 00 Config1       = 0x0001F000
21        18:51:30        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_GET_FLASHMODE(0xCA)
    CA 00 00 00 CMD           = 0x000000CA
    03 00 00 00 Packet number = 0x00000003
    00 00 00 00
    00 00 00 00
22        18:51:30        NuMicro ISP Wri        IRP_MJ_READ
    CD 00 00 00 Checksum      = 0x000000CD
    04 00 00 00 Packet number = 0x00000004
    02 00 00 00
23        18:51:30        NuMicro ISP Wri        IRP_MJ_WRITE
    05 00 00 00 Packet number = 0x00000005
    05 00 00 00
    00 00 00 00
24        18:51:30        NuMicro ISP Wri        IRP_MJ_READ
    AE 00 00 00 Checksum      = 0x000000AE
    06 00 00 00 Packet number = 0x00000006
    02 00 00 00
25        18:51:30        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_GET_FWVER (0xA6)
    A6 00 00 00 CMD           = 0x000000A6
    07 00 00 00 Packet number = 0x00000007
    00 00 00 00
    00 00 00 00
26        18:51:30        NuMicro ISP Wri        IRP_MJ_READ
    AD 00 00 00 Checksum      = 0x000000AD
    08 00 00 00 Packet number = 0x00000008
    11 00 00 00
27        18:51:30        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_GET_DEVICEID (0xB1)
    B1 00 00 00 CMD           = 0x000000B1
    09 00 00 00 Packet number = 0x00000009
    00 00 00 00
    00 00 00 00
28        18:51:30        NuMicro ISP Wri        IRP_MJ_READ
    BA 00 00 00 Checksum      = 0x000000BA
    0A 00 00 00 Packet number = 0x0000000A
    00 5A 00 00
29        18:51:30        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_READ_CONFIG (0xA2)
    A2 00 00 00 CMD           = 0x000000A2
    0B 00 00 00 Packet number = 0x0000000B
    00 00 00 00
    00 00 00 00
30        18:51:30        NuMicro ISP Wri        IRP_MJ_READ
    0C 00 00 00 Packet number = 0x0000000C
    7F FF FF FF Config0       = 0xFFFFFF7F
31        18:51:30        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_APROM_SIZE (0xAA)
    AA 00 00 00 CMD           = 0x000000AA
    0D 00 00 00 Packet number = 0x0000000D
    00 00 01 00
    00 00 00 00
32        18:51:30        NuMicro ISP Wri        IRP_MJ_READ
    B8 00 00 00 Checksum      = 0x000000B8
    0E 00 00 00 Packet number = 0x0000000E
 楼主| hotpower 发表于 2010-12-21 00:06 | 显示全部楼层
串口开始按键分析:
0        18:53:12        NuMicro ISP Wri        IRP_MJ_WRITE
    00 00 00 00
1        18:53:12        NuMicro ISP Wri        IRP_MJ_READ
2        18:53:12        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_UPDATE_APROM(0xA0)
    A0 00 00 00 CMD           = 0x000000A0
    00 00 00 00 Start Address = 0x00000000
    40 00 00 00 Total Length  = 0x00000040=64
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0000:
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0010:
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0020:
3        18:53:12        NuMicro ISP Wri        IRP_MJ_READ
    C9 0B 00 00 Checksum      = 0x00000BC9(0xA0+0x03+...+0x45+0x46)
4        18:53:15        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_UPDATE_APROM(0x00)
    00 00 00 00 CMD           = 0x00000000
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0030:
    38 39 41 42 43 44 45 46 30 31 32 33 34 35 36 37 Address 0x0040:
    38 39 41 42 43 44 45 46 30 31 32 33 34 35 36 37 Address 0x0050:
    38 39 41 42 43 44 45 46                             Address 0x0060:
5        18:53:15        NuMicro ISP Wri        IRP_MJ_READ
    F1 0C 00 00 Checksum      = 0x00000CF1(0x05+0x30+...+0x45+0x46)
6        18:53:15        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_READ_CHECKSUM(0xC8)
    C8 00 00 00 CMD           = 0x000000C8
                            00 00 00 00 40 00 00 00 结束地址=0x0040
7        18:53:15        NuMicro ISP Wri        IRP_MJ_READ
    0F 01 00 00 Checksum      = 0x0000010F(0xC8+0x07+0x40)
    88 0E                                           校 验 和=0x0E88
    FF FF
    00 F0 01 00
8        18:53:15        NuMicro ISP Wri        IRP_MJ_WRITE
    00 00 00 00
9        18:53:15        NuMicro ISP Wri        IRP_MJ_READ
    02 00 00 00 Packet number = 0x00000002
    88 0E                                           校 验 和=0x0E88
    FF FF
    00 F0 01 00 Start Address = 0x0001F000
10        18:53:15        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_PROGRAM_WERASE(0xC3)
    C3 00 00 00 CMD           = 0x000000C3
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0001F000:
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0001F010:
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0001F020:
11        18:53:15        NuMicro ISP Wri        IRP_MJ_READ
    DD 0C 00 00 Checksum      = 0x00000CDD(0xC3+0x03+...+0x45+0x46)
    88 0E                                           校 验 和=0x0E88
    FF FF
12        18:53:15        NuMicro ISP Wri        IRP_MJ_WRITE
  Serial0        SUCCESS        Length 64: 主机发送命令:CMD_PROGRAM_WERASE(0x00)
    30 31 32 33 34 35 36 37 38 39 41 42 43 44 45 46 Address 0x0001F030:
    38 39 41 42 43 44 45 46 30 31 32 33 34 35 36 37 Address 0x0001F040:
    38 39 41 42 43 44 45 46 30 31 32 33 34 35 36 37 Address 0x0001F050:
    38 39 41 42 43 44 45 46                             Address 0x0001F060:
13        18:53:15        NuMicro ISP Wri        IRP_MJ_READ
    88 0E                                           校 验 和=0x0E88
    FF FF
14        18:53:15        NuMicro ISP Wri        IRP_MJ_WRITE
15        18:53:15        NuMicro ISP Wri        IRP_MJ_READ
    00 02 00 00 Checksum      = 0x00000200(0xC8+0x07+0xF0+0x01+0x40)
    88 0E                                           校 验 和=0x0E88
    FF FF
 楼主| hotpower 发表于 2010-12-21 00:07 | 显示全部楼层
串口断开按键分析:
0        18:54:22        NuMicro ISP Wri        IRP_MJ_CLEANUP        Serial0        SUCCESS
1        18:54:22        NuMicro ISP Wri        IRP_MJ_CLOSE
  Serial0        SUCCESS 关闭串口
 楼主| hotpower 发表于 2010-12-21 07:02 | 显示全部楼层
●█〓██▄▄▄▄▄▄ ●●●●●●→ ''''╭WWWW╮
▄▅██████▅▄▃▂ 传播非典灌水四方 ( ●_●)
███天█马█行█空████ '''',,,;,;,;'''/▇\''
◥⊙▲⊙▲⊙▲⊙▲⊙▲⊙▲◤ 群魔乱舞见阳光/MMMM\
菜农Cortex-M0技术交流群
无冕之王 发表于 2010-12-21 18:07 | 显示全部楼层
这笔记得慢慢看,短时间内看不太明白
xsgy123 发表于 2010-12-21 21:52 | 显示全部楼层
高手的笔记是不是都是一堆堆代码呢
杜_U_ME 发表于 2010-12-21 22:17 | 显示全部楼层
yybj 发表于 2010-12-22 21:51 | 显示全部楼层
菜农的笔记很高深
txcy 发表于 2010-12-23 18:59 | 显示全部楼层
看了很久才明白一点点
无冕之王 发表于 2010-12-23 22:25 | 显示全部楼层
已经看明白了一些
gxgclg 发表于 2010-12-24 21:52 | 显示全部楼层
很深奥的笔记
qqjj2536 发表于 2010-12-24 22:33 | 显示全部楼层
还是没有看懂:L
慢慢研究吧
老鱼探戈 发表于 2011-4-1 15:11 | 显示全部楼层
慢慢看,总有一天会看明白的
 楼主| hotpower 发表于 2011-4-2 07:52 | 显示全部楼层
哈哈,俺不会写笔记
snjsnjzhang 发表于 2011-4-2 14:48 | 显示全部楼层
神加油更新
U灬U 发表于 2011-4-3 12:33 | 显示全部楼层
标记下先 以后慢慢看
