[DemoCode下载]
新唐最新N76E003_BSP_Keil_C51_V1.0.3重磅发布
2330|6
Harvard|  楼主 | 2017-11-4 22:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
REVISION HISTORY Date Revision Description
2016.12.28
1.00
Initially issued.
2017.2.1
1.01
1. Add HIRC modify
2. Add SPI master / slave control demo code include interrupt and polling
2017.6.20
1.02
1. Add POR disable instruction in startup.a51
2. Add ADC read band-gap and calculate VDD value demo
3. Add ADC 16 times optimize demo
4. Add read UCID sample code
2017.9.26
1.03
1. Modify ADC read band-gap and calculate VDD value demo
在此下载 N76E003_BSP_Keil_C51_V1.0.3 [color=#999999 !important][
http://www.nuvoton-mcu.com/forum.php?mod=attachment&aid=Mjc5MHxkYjVhNGM3OXwxNTA5ODA2NzU2fDE1M3wxMTYyNg%3D%3D
天灵灵地灵灵| | 2017-11-5 17:37 | 只看该作者
终于更新了,看来修正了不少内容
天灵灵地灵灵| | 2017-11-5 17:38 | 只看该作者
明天上班下载看看,把之前的移植过去
玛尼玛尼哄| | 2017-11-5 18:03 | 只看该作者
之前网友反应的问题应该这个版本都解决了
捉虫天师| | 2017-11-6 17:59 | 只看该作者
添加了不少例子啊,越多越好
挖东衣宇| | 2017-11-7 09:38 | 只看该作者
Nov. 2 2017 Page 1 of 2 Rev 1.03 N76E003 BSP Revision History N76E003 BSP for...
N76E003 BSP for KEIL C51 Revision History
Reversion 1.03 (Release 2017-11-2)
Modify ADC read band-gap and calculate VDD demo.
Modify UART0 project option setting.
Modify IAP_Dataflash_EEPROM the XRAM storage address start from 0x280.
Modify function_define.h file define of Set_All_GPIO_Quasi_Mode P0M2.
Modify function_define.h file TIMER0_MODE3_ENABLE / TIMER1_MODE3_ENABLE setting.
冷画| | 2017-11-7 09:39 | 只看该作者
冒泡
