[STM32F4] STM32+ LCD- - 内部温度传感器
2623|27
 楼主| chenqiang10 发表于 2017-11-25 22:21 | 显示全部楼层
LCD写入数据
void TFT_WriteData(u16 dat)
        TFT->TFT_DATA = dat<<8;
void TFT_WriteData_Color(u16 color)
        TFT->TFT_DATA = color&0xff00;
        TFT->TFT_DATA = color<<8;
向北lm 发表于 2017-11-25 22:22 | 显示全部楼层
不错,感谢楼主分享
 楼主| chenqiang10 发表于 2017-11-27 12:00 | 显示全部楼层
初始化LCD屏 这个很长,直接使用就行
void TFT_Init(void)
        uint16_t i;
        TFT_GPIO_Config();
        TFT_FSMC_Config();
        //************* Start Initial Sequence **********//
        TFT_WriteCmd(0xCB);
        TFT_WriteData(0x39);
        TFT_WriteData(0x2C);
        TFT_WriteData(0x00);
        TFT_WriteData(0x34);
        TFT_WriteData(0x02);
        TFT_WriteCmd(0xCF);
        TFT_WriteData (0x00);
        TFT_WriteData (0xa2); //c1
        TFT_WriteData (0Xf0);  //30
        TFT_WriteCmd(0xE8);
        TFT_WriteData (0x84);          //85
        TFT_WriteData (0x11);          //00
        TFT_WriteData (0x7a);          //79
        TFT_WriteCmd(0xEA);
        TFT_WriteData (0x66);  //00
        TFT_WriteCmd(0xED);
        TFT_WriteData (0x55);         //64
        TFT_WriteData (0x01);         //03
        TFT_WriteData (0X23);         //12
        TFT_WriteData (0X01);         //81
        TFT_WriteCmd(0xF7);
        TFT_WriteData (0x20);         //20
        TFT_WriteCmd(0xC0);    //Power control
        TFT_WriteData (0x1c);   //VRH[5:0]         //1c
        TFT_WriteCmd(0xC1);    //Power control
        TFT_WriteData (0x13);   //SAP[2:0];BT[3:0]         //13
        TFT_WriteCmd(0xC5);    //VCM control
        TFT_WriteData (0x23);
        TFT_WriteData (0x3F);
        TFT_WriteCmd(0xC7);    //VCM control2
        TFT_WriteData(0xA5);
        TFT_WriteCmd(0xB1);
        TFT_WriteData (0x17);
        TFT_WriteCmd(0x3A);
        TFT_WriteCmd(0xB6);
        TFT_WriteData (0x0A);
        TFT_WriteData (0xa2);  //a2
        TFT_WriteData (0x27);
        TFT_WriteCmd(0x36);    // Memory Access Control
        TFT_WriteData (0x08);           //08        BGR
        TFT_WriteCmd(0xF2);    // 3Gamma Function Disable
        TFT_WriteData (0x02);         //00
        TFT_WriteCmd(0x26);    //Gamma curve selected
        TFT_WriteCmd(0xE0);    //Set Gamma
        TFT_WriteData (0x0F);
        TFT_WriteData (0x14);
        TFT_WriteData (0x0C);
        TFT_WriteData (0x0E);
        TFT_WriteData (0x05);
        TFT_WriteData (0x45);
        TFT_WriteData (0x85);
        TFT_WriteData (0x36);
        TFT_WriteData (0x09);
        TFT_WriteData (0x03);
        TFT_WriteCmd(0XE1);    //Set Gamma
        TFT_WriteData (0x24);
        TFT_WriteData (0x26);
        TFT_WriteData (0x04);
        TFT_WriteData (0x52);
        TFT_WriteData (0x10);
        TFT_WriteData (0x38);
        TFT_WriteData (0x39);
        TFT_WriteCmd(0x2A );
        TFT_WriteData(0xEF);
        TFT_WriteCmd(0x2B );
        TFT_WriteData(0x01);
        TFT_WriteData(0x3F);
        TFT_WriteCmd(0x11);    //Exit Sleep
        for(i=50000; i>0; i--);         //延时
        TFT_WriteCmd(0x29);    //Display on
 楼主| chenqiang10 发表于 2017-11-27 12:01 | 显示全部楼层
设置要操作的窗口范围   xStart:窗口起始X坐标  yStart:窗口起始Y坐标  xEnd:窗口结束X坐标  yEnd:窗口结束Y坐标
void TFT_SetWindow(uint16_t xStart, uint16_t yStart, uint16_t xEnd, uint16_t yEnd)
        TFT_WriteCmd(0x2A);
    TFT_WriteData(xStart/256);
    TFT_WriteData(xStart%256);
    TFT_WriteData(xEnd/256);
    TFT_WriteData(xEnd%256);
    TFT_WriteCmd(0x2b);
    TFT_WriteData(yStart/256);
    TFT_WriteData(yStart%256);
    TFT_WriteData(yEnd/256);
    TFT_WriteData(yEnd%256);
    TFT_WriteCmd(0x2c);
 楼主| chenqiang10 发表于 2017-11-27 12:03 | 显示全部楼层
将LCD清屏成相应的颜色
void TFT_ClearScreen(uint16_t color)
        uint16_t i, j ;
        TFT_SetWindow(0, 0, TFT_XMAX, TFT_YMAX);         //作用区域
          for(i=0; i<TFT_XMAX+1; i++)
                for (j=0; j<TFT_YMAX+1; j++)
                        TFT_WriteData_Color(color);
sopc12 发表于 2017-11-27 16:53 | 显示全部楼层
其实我还没看懂,你具体的用途
doniexun 发表于 2018-1-23 22:18 | 显示全部楼层
楼主写得很认真,感谢
mintspring 发表于 2018-1-26 15:46 来自手机 | 显示全部楼层
使用内部温度传感器检测温度是不准确的,误差比较大。因此通常是不采用此传感器进行测温。
