用sprintf老报错一般是啥原因
329|4
xxmmi|  楼主 | 2017-11-27 22:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用sprintf老报错一般是啥原因
kangzj| | 2017-11-27 22:31 | 只看该作者
程序呢
xxmmi|  楼主 | 2017-11-27 22:33 | 只看该作者
#include <project.h>
int main()
    /* Place your initialization/startup code here (e.g. MyInst_Start()) */
    int16 res;
    float vol;
    int16 value;
    char tstr;
    ADC1_Start();
    LCD1_Start();
    LCD1_ClearDisplay();
    ADC1_StartConvert();
    LCD1_Position(0,0);
    LCD1_Position(1,8);
    for(;;)
     while(ADC1_IsEndConversion(ADC1_WAIT_FOR_RESULT)==0);
      res=ADC1_GetResult16();
      vol=ADC1_CountsTo_Volts(res);
      sprintf(tstr,"%+1.4f",vol);
      value=(int)80*vol/5.0;
      if(Pin_2_Read()==0)
        LCD1_Position(0,0);
        LCD1_PrintString("Measured Voltage is:");
        LCD1_Position(1,0);
        LCD1_PrintString(tstr);
        LCD1_PrintString(" V                ");
    else
        LCD1_DrawHorizontalBG(1,0,80,value);
   /* Place your application code here. */
/* [] END OF FILE */
zwll| | 2017-11-27 22:35 | 只看该作者
是不是缺少包含的头文件??
xxmmi|  楼主 | 2017-11-27 22:36 | 只看该作者
默认不为0吗
