[技术问答]
此帖无效
646|3
zxdplay|  楼主 | 2017-12-23 22:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如何删除该帖
643757107| | 2017-12-24 11:37 | 只看该作者
不用删,已经很好了。
643757107| | 2017-12-24 11:38 | 只看该作者
Nano100的ADC采样,让这个帖子更丰满。
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 10 $
* $Date: 15/06/16 7:23p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Convert ADC channel 0 in Single mode and print conversion results.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Nano100Series.h"
volatile uint8_t u8ADF;
void ADC_IRQHandler(void);
    uint32_t u32Flag;
    // Get ADC conversion finish interrupt flag
    u32Flag = ADC_GET_INT_FLAG(ADC, ADC_ADF_INT);
    if(u32Flag & ADC_ADF_INT)
        u8ADF = 1;
    ADC_CLR_INT_FLAG(ADC, u32Flag);
/* Init System Clock        */
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set HCLK source form HXT and HCLK source divide 1  */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT,CLK_HCLK_CLK_DIVIDER(1));
    /* Enable external 12MHz HXT, 32KHz LXT and HIRC */
    CLK_EnableXtalRC(CLK_PWRCTL_HXT_EN_Msk | CLK_PWRCTL_LXT_EN_Msk | CLK_PWRCTL_HIRC_EN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_HXT_STB_Msk | CLK_CLKSTATUS_LXT_STB_Msk | CLK_CLKSTATUS_HIRC_STB_Msk);
    /*  Set HCLK frequency 42MHz */
    CLK_SetCoreClock(42000000);
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART0_MODULE,CLK_CLKSEL1_UART_S_HXT,CLK_UART_CLK_DIVIDER(1));
    /* Init I/O Multi-function        */
    /* Set PA multi-function pins for UART0 RXD and TXD */
    SYS->PB_L_MFP &= ~( SYS_PB_L_MFP_PB0_MFP_Msk | SYS_PB_L_MFP_PB1_MFP_Msk);
    SYS->PB_L_MFP |= (SYS_PB_L_MFP_PB0_MFP_UART0_RX | SYS_PB_L_MFP_PB1_MFP_UART0_TX );
    /* Set PB multi-function pins for Clock Output */
    SYS->PB_H_MFP = ( SYS->PB_H_MFP & ~SYS_PB_H_MFP_PB12_MFP_Msk ) |  SYS_PB_H_MFP_PB12_MFP_CKO;
    /* Set PA.0 multi-function pin for ADC channel 0 */
    SYS->PA_L_MFP = (SYS->PA_L_MFP & ~SYS_PA_L_MFP_PA0_MFP_Msk) | SYS_PA_L_MFP_PA0_MFP_ADC_CH0;
    /* Disable PA.0 digital input path */
    PA->OFFD |= ((1 << 0) << GP_OFFD_OFFD_Pos);
    /* Lock protected registers */
    SYS_LockReg();
void UART0_Init()
    /* Init UART        */
    UART_Open(UART0, 115200);
int32_t main (void)
    uint32_t u32Result;
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\nThis sample code demonstrate ADC single mode conversion\n");
    printf("It convert channel 0 and print conversion result\n");
    // Enable channel 0
    ADC_Open(ADC, ADC_INPUT_MODE_SINGLE_END, ADC_OPERATION_MODE_SINGLE, ADC_CH_0_MASK);
    // Set reference voltage to AVDD
    ADC_SET_REF_VOLTAGE(ADC, ADC_REFSEL_POWER);
    // Power on ADC
    ADC_POWER_ON(ADC);
    // Enable ADC ADC_IF interrupt
    ADC_EnableInt(ADC, ADC_ADF_INT);
    NVIC_EnableIRQ(ADC_IRQn);
    u8ADF = 0;
    ADC_START_CONV(ADC);
    while (u8ADF == 0);
    u32Result = ADC_GET_CONVERSION_DATA(ADC, 0);
    printf("Channel 0 conversion result is 0x%x\n",u32Result);
    ADC_DisableInt(ADC, ADC_ADF_INT);
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
* $Revision: 10 $
* @note
#include <stdio.h>
    uint32_t u32Flag;
        u8ADF = 1;
void SYS_Init(void)
    SYS_UnlockReg();
    SYS_LockReg();
void UART0_Init()
    /* Init UART        */
int32_t main (void)
    uint32_t u32Result;
    SYS_Init();
    UART0_Init();
    // Enable channel 0
    // Power on ADC
    ADC_POWER_ON(ADC);
    u8ADF = 0;
    while (u8ADF == 0);
    while(1);
