[应用相关] STM32 RC522相关驱动
3309|28
 楼主| gaoke231 发表于 2018-2-28 21:23 | 显示全部楼层 |阅读模式
关于RC522的一些函数 常用的还是前面几个吧。足以应对门禁系统
RC522
初始化
void RC522_Init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);            //使能PF端口时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;          //推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //IO口速度为50MHz
        GPIO_Init(GPIOF, &GPIO_InitStructure);
        GPIO_SetBits(GPIOF,GPIO_Pin_1|GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_4);  //拉高
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;          //上拉输入
 楼主| gaoke231 发表于 2018-2-28 21:24 | 显示全部楼层
//寻卡
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
   char status;
   unsigned int  unLen;
   unsigned char ucComMF522Buf[MAXRLEN];
   ClearBitMask(Status2Reg,0x08);
   WriteRawRC(BitFramingReg,0x07);
   SetBitMask(TxControlReg,0x03);
   ucComMF522Buf[0] = req_code;
   status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
   if ((status == MI_OK) && (unLen == 0x10))
       *pTagType     = ucComMF522Buf[0];
       *(pTagType+1) = ucComMF522Buf[1];
   else
   {   status = MI_ERR;
   return status;
 楼主| gaoke231 发表于 2018-2-28 21:25 | 显示全部楼层
//防冲撞
char PcdAnticoll(unsigned char *pSnr)
    char status;
    unsigned char i,snr_check=0;
    unsigned int  unLen;
    WriteRawRC(BitFramingReg,0x00);
    ClearBitMask(CollReg,0x80);
    ucComMF522Buf[0] = PICC_ANTICOLL1;
    ucComMF522Buf[1] = 0x20;
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
    if (status == MI_OK)
             for (i=0; i<4; i++)
             *(pSnr+i)  = ucComMF522Buf[i];
             snr_check ^= ucComMF522Buf[i];
         if (snr_check != ucComMF522Buf[i])
         {   status = MI_ERR;    }
    SetBitMask(CollReg,0x80);
    return status;
 楼主| gaoke231 发表于 2018-2-28 21:26 | 显示全部楼层
//选卡
char PcdSelect(unsigned char *pSnr)
    char status;
    unsigned char i;
    unsigned int  unLen;
    ucComMF522Buf[1] = 0x70;
    ucComMF522Buf[6] = 0;
    for (i=0; i<4; i++)
            ucComMF522Buf[i+2] = *(pSnr+i);
            ucComMF522Buf[6]  ^= *(pSnr+i);
    CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x18))
    {   status = MI_OK;  }
    else
    return status;
 楼主| gaoke231 发表于 2018-2-28 21:27 | 显示全部楼层
//验证卡片密码
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
    char status;
    unsigned int  unLen;
    unsigned char i,ucComMF522Buf[MAXRLEN];
    ucComMF522Buf[0] = auth_mode;
    ucComMF522Buf[1] = addr;
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+2] = *(pKey+i);   }
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+8] = *(pSnr+i);   }
//   memcpy(&ucComMF522Buf[2], pKey, 6);
//   memcpy(&ucComMF522Buf[8], pSnr, 4);
    status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
    if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
    return status;
 楼主| gaoke231 发表于 2018-2-28 21:28 | 显示全部楼层
//读取M1卡一块数据
char PcdRead(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_READ;
    CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x90))
//   {   memcpy(pData, ucComMF522Buf, 16);   }
        for (i=0; i<16; i++)
        {    *(pData+i) = ucComMF522Buf[i];   }
    else
    return status;
 楼主| gaoke231 发表于 2018-2-28 21:29 | 显示全部楼层
//写数据到M1卡一块
char PcdWrite(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_WRITE;
    if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
        //memcpy(ucComMF522Buf, pData, 16);
        {    ucComMF522Buf = *(pData+i);   }
        CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
    return status;
 楼主| gaoke231 发表于 2018-2-28 21:30 | 显示全部楼层
//扣款和充值
char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = dd_mode;
       // memcpy(ucComMF522Buf, pValue, 4);
        {    ucComMF522Buf = *(pValue+i);   }
        CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
        unLen = 0;
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
        if (status != MI_ERR)
        {    status = MI_OK;    }
        ucComMF522Buf[0] = PICC_TRANSFER;
    return status;
 楼主| gaoke231 发表于 2018-2-28 21:32 | 显示全部楼层
//备份钱包
char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_RESTORE;
    ucComMF522Buf[1] = sourceaddr;
        ucComMF522Buf[0] = 0;
        ucComMF522Buf[1] = 0;
        ucComMF522Buf[2] = 0;
        ucComMF522Buf[3] = 0;
        {    status = MI_OK;    }
    if (status != MI_OK)
    {    return MI_ERR;   }
    ucComMF522Buf[1] = goaladdr;
    return status;
 楼主| gaoke231 发表于 2018-2-28 21:33 | 显示全部楼层
//命令卡片进入休眠状态
char PcdHalt(void)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_HALT;
    return MI_OK;
 楼主| gaoke231 发表于 2018-2-28 21:34 | 显示全部楼层
//用MF522计算CRC16函数
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
    unsigned char i,n;
    ClearBitMask(DivIrqReg,0x04);
    WriteRawRC(CommandReg,PCD_IDLE);
    SetBitMask(FIFOLevelReg,0x80);
    for (i=0; i<len; i++)
    {   WriteRawRC(FIFODataReg, *(pIndata+i));   }
    WriteRawRC(CommandReg, PCD_CALCCRC);
    i = 0xFF;
    do
        n = ReadRawRC(DivIrqReg);
        i--;
    while ((i!=0) && !(n&0x04));
    pOutData[0] = ReadRawRC(CRCResultRegL);
    pOutData[1] = ReadRawRC(CRCResultRegM);
 楼主| gaoke231 发表于 2018-2-28 21:35 | 显示全部楼层
// 复位RC522char PcdReset(void)
        //unsigned char i;
    MF522_RST=1;
                delay_us(10);
    MF522_RST=0;
                delay_us(10);
    MF522_RST=1;
                delay_us(10);
    WriteRawRC(CommandReg,PCD_RESETPHASE);
                delay_us(10);
    WriteRawRC(ModeReg,0x3D);            //和Mifare卡通讯,CRC初始值0x6363
    WriteRawRC(TReloadRegL,30);
    WriteRawRC(TReloadRegH,0);
    WriteRawRC(TModeReg,0x8D);
    WriteRawRC(TPrescalerReg,0x3E);
   WriteRawRC(TxAutoReg,0x40);
    return MI_OK;
 楼主| gaoke231 发表于 2018-2-28 21:36 | 显示全部楼层
//读RC632寄存器
unsigned char ReadRawRC(unsigned char Address)
     unsigned char i, ucAddr;
     unsigned char ucResult=0;
     MF522_SCK = 0;
     MF522_NSS = 0;
     ucAddr = ((Address<<1)&0x7E)|0x80;
     for(i=8;i>0;i--)
         MF522_SI = ((ucAddr&0x80)==0x80);
         MF522_SCK = 1;
         ucAddr <<= 1;
         MF522_SCK = 0;
                 delay_us(10);           //STM32需要多加的延时时间。51的不需要加
     for(i=8;i>0;i--)
         MF522_SCK = 1;
         ucResult <<= 1;
         ucResult|=MF522_SO;
         MF522_SCK = 0;
     MF522_NSS = 1;
     MF522_SCK = 1;
     return ucResult;
 楼主| gaoke231 发表于 2018-2-28 21:37 | 显示全部楼层
// 写RC632寄存器
void WriteRawRC(unsigned char Address, unsigned char value)
    MF522_SCK = 0;
    MF522_NSS = 0;
    ucAddr = ((Address<<1)&0x7E);
    for(i=8;i>0;i--)
        MF522_SCK = 1;
        ucAddr <<= 1;
        MF522_SCK = 0;
    for(i=8;i>0;i--)
        MF522_SI = ((value&0x80)==0x80);
        MF522_SCK = 1;
        value <<= 1;
        MF522_SCK = 0;
    MF522_NSS = 1;
    MF522_SCK = 1;
//置RC522寄存器位
void SetBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x0;
    tmp = ReadRawRC(reg);
    WriteRawRC(reg,tmp | mask);  // set bit mask
 楼主| gaoke231 发表于 2018-2-28 21:40 | 显示全部楼层
//清RC522寄存器位
void ClearBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x0;
    WriteRawRC(reg, tmp & ~mask);  // clear bit mask
 楼主| gaoke231 发表于 2018-2-28 21:41 | 显示全部楼层
//通过RC522和ISO14443卡通讯
char PcdComMF522(unsigned char Command,
                 unsigned char *pInData,
                 unsigned char InLenByte,
                 unsigned char *pOutData,
                 unsigned int  *pOutLenBit)
    char status = MI_ERR;
    unsigned char irqEn   = 0x00;
    unsigned char waitFor = 0x00;
    unsigned char lastBits;
    unsigned char n;
    unsigned int i;
    switch (Command)
       case PCD_AUTHENT:
          irqEn   = 0x12;
          waitFor = 0x10;
          break;
       case PCD_TRANSCEIVE:
          irqEn   = 0x77;
          waitFor = 0x30;
          break;
       default:
         break;
    WriteRawRC(ComIEnReg,irqEn|0x80);
    ClearBitMask(ComIrqReg,0x80);
    for (i=0; i<InLenByte; i++)
    {   WriteRawRC(FIFODataReg, pInData[i]);    }
    WriteRawRC(CommandReg, Command);
    if (Command == PCD_TRANSCEIVE)
    {    SetBitMask(BitFramingReg,0x80);  }
    i = 600;//根据时钟频率调整,操作M1卡最大等待时间25ms
    do
         n = ReadRawRC(ComIrqReg);
         i--;
    while ((i!=0) && !(n&0x01) && !(n&waitFor));
    ClearBitMask(BitFramingReg,0x80);
    if (i!=0)
         if(!(ReadRawRC(ErrorReg)&0x1B))
             status = MI_OK;
             if (n & irqEn & 0x01)
             {   status = MI_NOTAGERR;   }
                       n = ReadRawRC(FIFOLevelReg);
                      lastBits = ReadRawRC(ControlReg) & 0x07;
                if (lastBits)
                {   *pOutLenBit = (n-1)*8 + lastBits;   }
                else
                {   *pOutLenBit = n*8;   }
                if (n == 0)
                {   n = 1;    }
                if (n > MAXRLEN)
                {   n = MAXRLEN;   }
                for (i=0; i<n; i++)
                {   pOutData[i] = ReadRawRC(FIFODataReg);    }
         else
   SetBitMask(ControlReg,0x80);           // stop timer now
   return status;
//开启天线
void PcdAntennaOn()
    unsigned char i;
    i = ReadRawRC(TxControlReg);
    if (!(i & 0x03))
        SetBitMask(TxControlReg, 0x03);
 楼主| gaoke231 发表于 2018-2-28 21:42 | 显示全部楼层
//关闭天线
void PcdAntennaOff()
    ClearBitMask(TxControlReg, 0x03);
 楼主| gaoke231 发表于 2018-2-28 21:46 | 显示全部楼层
MFRC522是高度集成的非接触式(13.56MHz)读写卡芯片,此发送模块利用调制和调节的原理,并将它们完全集成到各种非接触式通信方法和协议中。它支持ISO14443A/MIFARE。关于电路的工作原理,我也不能详解,大家可以自己查资料,这里仅针对通信过程做一个详细的介绍,希望对看到的人有所帮助。
