[通用8051核FLASH系列] 收到开发板啦,试试硬件SPI驱动74HC595!!
2365|1
 楼主| 2083759 发表于 2018-3-5 20:59 | 显示全部楼层 |阅读模式
接下来用原来开发的产品上8位数码管,两片74HC595级联,仿真器调试模式
不知道为什么图片上传后方向会变
下面是代码
#include "HC89F003.h"
#define u8 unsigned char
#define u16 unsigned int
#define u32 unsigned long
sbit RCLK = P0^0;
u8 xs,miao;
u32 hm;
u8 code LED[] = {0x0A,0xFA,0x8C,0xA8,0x78,0x29,0x09,0xBA,0x08,0x28,0x00};//0-9,-
void LED_OUT(u8 X)
            SPDAT=X;
                  while((SPSTAT&0x80)==0x00);  //查询SPI传输是否完成
                  SPSTAT=0xf0;                 //写1清除所有标志
void Timer3init(void)
     T3CON =0x00;
           TH3=(65536-8000)/256;
           TL3=(65536-8000)%256;
           ET3=1;
           T3CON |= 0x04;
void display(void)
     u8 bai,shi,ge,a1,a2,a3,a4,a5;
                                                bai=hm%100000000/10000000;
                                                shi=hm%10000000/1000000;
                                                ge=hm%1000000/100000;
                                                a1=hm%100000/10000;
                                                a2=hm%10000/1000;
                                                a3=hm%1000/100;
                                                a4=hm%100/10;
                                                a5=hm%10;
         switch(xs)
                   case 0:
                                                         LED_OUT(0x20);                   //位选数据
                                                         LED_OUT(LED[bai]);  //段选数据
                                                         RCLK = 0; RCLK = 1;
                                                         xs=1;
                           break;
                   case 1:
                                                         LED_OUT(0x02);
                                                         LED_OUT(LED[shi]);
                                                         RCLK = 0; RCLK = 1;
                                                   xs=2;
                           break;
                   case 2:
                                             LED_OUT(0x04);
                                                         LED_OUT(LED[ge]);
                                                         RCLK = 0; RCLK = 1;
                                                         xs=3;
                           break;
                   case 3:
                                                         LED_OUT(0x08);
                                                         LED_OUT(LED[a1]);
                                                         RCLK = 0; RCLK = 1;
                                                         xs=4;
                           break;
                   case 4:
                                                         LED_OUT(0x01);
                                                         LED_OUT(LED[a2]);
                                                         RCLK = 0; RCLK = 1;
                                                         xs=5;
                           break;
                   case 5:
                                             LED_OUT(0x40);
                                             LED_OUT(LED[a3]);
                                             RCLK = 0; RCLK = 1;
                                             xs=6;
                           break;
                   case 6:
                                                         LED_OUT(0x80);
                                                         LED_OUT(LED[a4]);
                                                         RCLK = 0; RCLK = 1;
                                                         xs=7;
                           break;
                   case 7:
                                                        LED_OUT(0x10);
                                                        LED_OUT(LED[a5]);
                                                        RCLK = 0; RCLK = 1;
                                                        xs=0;
                          break;
void Init(void)
                WDTCCR = 0x00;                                                //关闭看门狗
                while((CLKCON&0x20)!=0x20);                        //等待内部高频晶振起振
                CLKSWR = 0x53;                                                //选择内部高频时钟为主时钟,内部高频RC 8分频,Fosc=4MHz
                while((CLKSWR&0xC0)!=0x40);                        //等待内部高频切换完成
                CLKDIV = 0x00;                                                //Fosc 0分频得到Fcpu,Fcpu=4MHz
void SPI_Init(void)
     P0M0=0x88;           //P00 P01推挽输出
     P0M1=0x08;                  //P02推挽输出 P03输入
           SCK_MAP=0x01;        //SPI_SCK脚映射至P01上
           MOSI_MAP=0x02;       //SPI_MOSI脚映射至P02上
//           MISO_MAP=0x03;   //74HC595用不到MISO
           SPCTL=0xdf;              //SPI设置
int main (void)
     Init();
     Timer3init();
     SPI_Init();
                 EA=1;
           while(1);
void Timer3_ISR (void) interrupt 9
                 display();
           hm++;
最后说说这芯片的外设管脚的映射功能真强大,大大方便开发了还有不用库的话最好换个头文件,自带的不太好用好像,附件随便提供头文件 HC89F003.rar (6.79 KB, 下载次数: 17)
siman275 发表于 2018-3-5 21:53 | 显示全部楼层
很好的分享
