[STM32F1]
stm32F103C8 芯片无法识别问题
2621|6
焊丝滚成球|  楼主 | 2018-3-27 16:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天使用最新的hal库谢啦一个串口打包函数,系统设置都是CUBE设置好的,利用Jlink 下载第一次成功 ,但是第二次下载的时候就找不到芯片了,用串口下载也下载不进去 板子是自己焊的 附上程序,求解答
焊丝滚成球|  楼主 | 2018-3-27 16:47 | 只看该作者
  while (1)
if(USART2_RX_STA&0x8000)
        //len1=USART2_RX_STA&0x3fff;//µÃµ½´Ë´Î½ÓÊÕµ½µÄÊý¾Ý³¤¶È
  HAL_UART_Transmit(&huart3,USART2_RX_BUF,20,1000);
          while(__HAL_UART_GET_FLAG(&huart2,UART_FLAG_TC)!=SET);                //µÈ´ý·¢ËͽáÊø
                USART2_RX_STA=0;
                memset(USART2_RX_BUF,0,20);
                HAL_Delay(500);
if(USART1_RX_STA&0x8000)
        len2=USART1_RX_STA&0x3fff;//µÃµ½´Ë´Î½ÓÊÕµ½µÄÊý¾Ý³¤¶È
  HAL_UART_Transmit(&huart3,USART1_RX_BUF,len2,1000);
          while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_TC)!=SET);                //µÈ´ý·¢ËͽáÊø
        USART1_RX_STA=0;
        memset(USART1_RX_BUF,0,len2);
        len2=0;
HAL_Delay(100);
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
void HAL_MspInit(void)
  /* USER CODE BEGIN MspInit 0 */
  /* USER CODE END MspInit 0 */
  __HAL_RCC_AFIO_CLK_ENABLE();
  HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_4);
  /* System interrupt init*/
  /* MemoryManagement_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(MemoryManagement_IRQn, 0, 0);
  /* BusFault_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(BusFault_IRQn, 0, 0);
  /* UsageFault_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(UsageFault_IRQn, 0, 0);
  /* SVCall_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SVCall_IRQn, 0, 0);
  /* DebugMonitor_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DebugMonitor_IRQn, 0, 0);
  /* PendSV_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(PendSV_IRQn, 0, 0);
    /**DISABLE: JTAG-DP Disabled and SW-DP Disabled
  __HAL_AFIO_REMAP_SWJ_DISABLE();
  /* USER CODE BEGIN MspInit 1 */
  /* USER CODE END MspInit 1 */
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(huart->Instance==USART1)
  /* USER CODE BEGIN USART1_MspInit 0 */
  /* USER CODE END USART1_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_USART1_CLK_ENABLE();
    /**USART1 GPIO Configuration
    PA9     ------> USART1_TX
    PA10     ------> USART1_RX
    GPIO_InitStruct.Pin = GPIO_PIN_9;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_10;
    GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    /* USART1 interrupt Init */
    HAL_NVIC_SetPriority(USART1_IRQn, 2, 0);
    HAL_NVIC_EnableIRQ(USART1_IRQn);
  /* USER CODE BEGIN USART1_MspInit 1 */
  /* USER CODE END USART1_MspInit 1 */
  else if(huart->Instance==USART2)
  /* USER CODE BEGIN USART2_MspInit 0 */
  /* USER CODE END USART2_MspInit 0 */
    __HAL_RCC_USART2_CLK_ENABLE();
    /**USART2 GPIO Configuration
    PA2     ------> USART2_TX
    PA3     ------> USART2_RX
    GPIO_InitStruct.Pin = GPIO_PIN_2;
    GPIO_InitStruct.Pin = GPIO_PIN_3;
    /* USART2 interrupt Init */
    HAL_NVIC_SetPriority(USART2_IRQn, 3, 0);
    HAL_NVIC_EnableIRQ(USART2_IRQn);
  /* USER CODE BEGIN USART2_MspInit 1 */
  /* USER CODE END USART2_MspInit 1 */
  else if(huart->Instance==USART3)
  /* USER CODE BEGIN USART3_MspInit 0 */
  /* USER CODE END USART3_MspInit 0 */
    __HAL_RCC_USART3_CLK_ENABLE();
    /**USART3 GPIO Configuration
    PB10     ------> USART3_TX
    PB11     ------> USART3_RX
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_11;
    /* USART3 interrupt Init */
    HAL_NVIC_SetPriority(USART3_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(USART3_IRQn);
  /* USER CODE BEGIN USART3_MspInit 1 */
  /* USER CODE END USART3_MspInit 1 */
香水城| | 2018-3-28 22:00 | 只看该作者
跟代码关系不大;
如果调试口被占用了,也只是连接不畅,多复位几次总可以;
即使调试口占用了,通过串口ISP方式应该可以【当然,boot脚要配置正确】;
不妨多试几块板;也顺便检查下板子的焊接及连线情况;
xcvista| | 2018-3-30 13:35 | 只看该作者
调试器复位线连了吗?
colin2135| | 2018-3-30 15:20 | 只看该作者
按着RESET重新下载了就可以找到了
