[技术问答]
N73E003外部中断进入不了
1261|8
pmw_56|  楼主 | 2018-4-9 11:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的设置是这样的
void ext0_int_init(void)
//                Enable_INT_Port3;
                TCON |= BIT0;                                 // 外部中断0 ,下边沿触发
//               EIE |= BIT1;
                set_EX0;                                //   外部中断使能
                set_EA;        // global enable bit
void ext0_isr(void) interrupt 0   //  外部0中断
                if(IE0 == 1)
                                IE0 = 0;
                                LED_B_ON();
高人指点下
小灵通2018| | 2018-4-9 17:33 | 只看该作者
参考例子啊
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 I/O Interrupt demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
#if 0
//Following setting in Function_define.h
//   Enable INT port 0~3
//#define         Enable_INT_Port0                                        PICON &= 0xFB;
//#define                Enable_INT_Port1                                        PICON |= 0x01;
//#define                Enable_INT_Port2                                        PICON |= 0x02;
//#define                Enable_INT_Port3                                        PICON |= 0x03;
// Enable each bit low level trig mode
//#define                Enable_BIT7_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_LowLevel_Trig                        PICON&=0xDF;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_LowLevel_Trig                        PICON&=0xEF;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_LowLevel_Trig                        PICON&=0xF7;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_LowLevel_Trig                        PICON&=0xFD;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit high level trig mode
//#define                Enable_BIT7_HighLevel_Trig                        PICON&=0x7F;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_HighLevel_Trig                        PICON&=0x7F;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_HighLevel_Trig                        PICON&=0xDF;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_HighLevel_Trig                        PICON&=0xEF;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_HighLevel_Trig                        PICON&=0xF7;PINEN&=0xFD;PIPEN|=0x02
//#define                Enable_BIT0_HighLevel_Trig                        PICON&=0xFD;PINEN&=0xFE;PIPEN|=0x01
// Enable each bit falling edge trig mode
//#define                Enable_BIT7_FallEdge_Trig                        PICON|=0x80;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_FallEdge_Trig                        PICON|=0x80;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_FallEdge_Trig                        PICON|=0x40;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_FallEdge_Trig                        PICON|=0x40;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_FallEdge_Trig                        PICON|=0x20;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_FallEdge_Trig                        PICON|=0x10;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_FallEdge_Trig                        PICON|=0x08;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_FallEdge_Trig                        PICON|=0x04;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit rasing edge trig mode
//#define                Enable_BIT7_RasingEdge_Trig                        PICON|=0x80;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_RasingEdge_Trig                        PICON|=0x80;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_RasingEdge_Trig                        PICON|=0x20;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_RasingEdge_Trig                        PICON|=0x10;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_RasingEdge_Trig                        PICON|=0x08;PINEN|=0xFD;PIPEN&=0x02
//#define                Enable_BIT0_RasingEdge_Trig                        PICON|=0x04;PINEN|=0xFE;PIPEN&=0x01
#endif
* FUNCTION_PURPOSE: I/O Pin interrupt Service Routine
void EXT_INT0(void) interrupt 0
                                clr_GPIO1;
                        Timer0_Delay1ms(100);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                                clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
void PinInterrupt_ISR (void) interrupt 7
        if(PIF == 0x01)
    PIF = 0x00;                             //clear interrupt flag
                        clr_GPIO1;
                        Timer1_Delay10ms(10);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
        else if (PIF == 0x80)
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
The main C function.  Program execution starts
here after stack initialization.
void main (void)
    P07_Input_Mode;
                set_P0S_7;
                P00_Input_Mode;
                P01_Input_Mode;
                set_P0S_1;
                P12_PushPull_Mode;
                P30_PushPull_Mode;
                P05_PushPull_Mode;
//        P0.5 set as highlevel trig pin interrupt function
//  Keep P0.5 connect to VDD LED will tickle
//  otherwise, MCU into power down mode.
                Enable_INT_Port2;
//                Enable_BIT7_LowLevel_Trig;
                Enable_BIT0_LowLevel_Trig;
                P30 =1;
                P05 = 0;
    set_EPI;                                                        // Enable pin interrupt
                set_EX0;
    while(1)
                        P01=0;
                        P30=0;
                        P01=1;
                        P30=1;
dongnanxibei| | 2018-4-9 18:15 | 只看该作者
你贴个完整的程序啊,这一段谁知道哪儿的问题啊,还要设置为输入模式。
antusheng| | 2018-4-10 23:03 | 只看该作者
设置为输入模式。
pmw_56|  楼主 | 2018-4-14 16:32 | 只看该作者
antusheng 发表于 2018-4-10 23:03
设置为输入模式。
谢谢,搞定了,是IO口设置问题
幸福小强| | 2018-4-15 20:52 | 只看该作者
如果这单片机要是有个配置工具就好了,这么简单的结构,很容易实现。
mintspring| | 2018-4-16 12:27 | 只看该作者
搞定就好。
小灵通2018| | 2018-4-16 17:05 | 只看该作者
这个芯片不复杂,好好读一遍手册,很容易搞定。好多人都是直接就去看代码,没小心代码后面的事情。
yiy| | 2018-4-16 21:28 | 只看该作者
中断的属于输入中断,因此要先配置为IO输入模式,然后启动中断触发等相关设置
