[STM32F1]
STM32虚拟U盘问题
4734|20
七颗咖啡豆|  楼主 | 2018-4-11 09:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用的内部ram 40K空间虚拟成U盘空间
然后把U盘大小参数改成36M,
这样电脑识别出来的U盘有34M+
然后我复制一个400K左右的串口助手到U盘中
双击竟然能正常运行
惊呆了
七颗咖啡豆|  楼主 | 2018-4-11 09:12 | 只看该作者
单片机STM32F103RCT6直接贴上CUBEMAX生成的usbd_storage_if.c经过修改后的文件
  * [url=home.php?mod=space&uid=288409]@file[/url]           : usbd_storage_if.c
  * [url=home.php?mod=space&uid=895143]@version[/url]        : v2.0_Cube
  * [url=home.php?mod=space&uid=247401]@brief[/url]          : Memory management layer.
  * This notice applies to any and all portions of this file
  * that are not between comment pairs USER CODE BEGIN and
  * USER CODE END. Other portions of this file, whether
  * inserted by the user or by software development tools
  * are owned by their respective copyright owners.
  * Copyright (c) 2018 STMicroelectronics International N.V.
  * All rights reserved.
  * Redistribution and use in source and binary forms, with or without
  * modification, are permitted, provided that the following conditions are met:
  * 1. Redistribution of source code must retain the above copyright notice,
  *    this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright notice,
  *    this list of conditions and the following disclaimer in the documentation
  *    and/or other materials provided with the distribution.
  * 3. Neither the name of STMicroelectronics nor the names of other
  *    contributors to this software may be used to endorse or promote products
  *    derived from this software without specific written permission.
  * 4. This software, including modifications and/or derivative works of this
  *    software, must execute solely and exclusively on microcontroller or
  *    microprocessor devices manufactured by or for STMicroelectronics.
  * 5. Redistribution and use of this software other than as permitted under
  *    this license is void and will automatically terminate your rights under
  *    this license.
  * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
  * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
  * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "usbd_storage_if.h"
/* USER CODE BEGIN INCLUDE */
/* USER CODE END INCLUDE */
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* Private variables ---------------------------------------------------------*/
/* USER CODE END PV */
/** @addtogroup STM32_USB_OTG_DEVICE_LIBRARY
  * [url=home.php?mod=space&uid=247401]@brief[/url] Usb device.
/** @defgroup USBD_STORAGE
  * @brief Usb mass storage device module
/** @defgroup USBD_STORAGE_Private_TypesDefinitions
  * @brief Private types.
/* USER CODE BEGIN PRIVATE_TYPES */
/* USER CODE END PRIVATE_TYPES */
/** @defgroup USBD_STORAGE_Private_Defines
  * @brief Private defines.
#define STORAGE_LUN_NBR                  1
#define STORAGE_BLK_NBR                  80
#define STORAGE_BLK_SIZ                  0x200
/* USER CODE BEGIN PRIVATE_DEFINES */
#define mySTORAGE_BLK_NBR                  0x10000
uint8_t test[STORAGE_BLK_NBR*STORAGE_BLK_SIZ];//40K
/* USER CODE END PRIVATE_DEFINES */
/** @defgroup USBD_STORAGE_Private_Macros
  * @brief Private macros.
/* USER CODE BEGIN PRIVATE_MACRO */
/* USER CODE END PRIVATE_MACRO */
/** @defgroup USBD_STORAGE_Private_Variables
  * @brief Private variables.
/* USER CODE BEGIN INQUIRY_DATA_FS */
/** USB Mass storage Standard Inquiry Data. */
const int8_t STORAGE_Inquirydata_FS[] = {/* 36 */
  /* LUN 0 */
  0x00,
  0x80,
  0x02,
  0x02,
  (STANDARD_INQUIRY_DATA_LEN - 5),
  0x00,
  0x00,
  0x00,
  'S', 'T', 'M', ' ', ' ', ' ', ' ', ' ', /* Manufacturer : 8 bytes */
  'P', 'r', 'o', 'd', 'u', 'c', 't', ' ', /* Product      : 16 Bytes */
  '0', '.', '0' ,'1'                      /* Version      : 4 Bytes */
/* USER CODE END INQUIRY_DATA_FS */
/* USER CODE BEGIN PRIVATE_VARIABLES */
/* USER CODE END PRIVATE_VARIABLES */
/** @defgroup USBD_STORAGE_Exported_Variables
  * @brief Public variables.
extern USBD_HandleTypeDef hUsbDeviceFS;
/* USER CODE BEGIN EXPORTED_VARIABLES */
/* USER CODE END EXPORTED_VARIABLES */
/** @defgroup USBD_STORAGE_Private_FunctionPrototypes
  * @brief Private functions declaration.
static int8_t STORAGE_Init_FS(uint8_t lun);
static int8_t STORAGE_GetCapacity_FS(uint8_t lun, uint32_t *block_num, uint16_t *block_size);
static int8_t STORAGE_IsReady_FS(uint8_t lun);
static int8_t STORAGE_IsWriteProtected_FS(uint8_t lun);
static int8_t STORAGE_Read_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_Write_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_GetMaxLun_FS(void);
/* USER CODE BEGIN PRIVATE_FUNCTIONS_DECLARATION */
//const uint8_t MBK[]={
//0xEB, 0x3C, 0x90, 0x4D, 0x53, 0x44, 0x4F, 0x53, 0x35, 0x2E, 0x30, 0x00, 0x02, 0x01, 0x06, 0x00,
//0x02, 0x00, 0x02, 0x50, 0x00, 0xF8, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
//0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x29, 0x9D, 0x27, 0x98, 0x4C, 0x4E, 0x4F, 0x20, 0x4E, 0x41,
//0x4D, 0x45, 0x20, 0x20, 0x20, 0x20, 0x46, 0x41, 0x54, 0x31, 0x32, 0x20, 0x20, 0x20, 0x33, 0xC9,
//0x8E, 0xD1, 0xBC, 0xF0, 0x7B, 0x8E, 0xD9, 0xB8, 0x00, 0x20, 0x8E, 0xC0, 0xFC, 0xBD, 0x00, 0x7C,
//0x38, 0x4E, 0x24, 0x7D, 0x24, 0x8B, 0xC1, 0x99, 0xE8, 0x3C, 0x01, 0x72, 0x1C, 0x83, 0xEB, 0x3A,
//0x66, 0xA1, 0x1C, 0x7C, 0x26, 0x66, 0x3B, 0x07, 0x26, 0x8A, 0x57, 0xFC, 0x75, 0x06, 0x80, 0xCA,
//0x02, 0x88, 0x56, 0x02, 0x80, 0xC3, 0x10, 0x73, 0xEB, 0x33, 0xC9, 0x8A, 0x46, 0x10, 0x98, 0xF7,
//0x66, 0x16, 0x03, 0x46, 0x1C, 0x13, 0x56, 0x1E, 0x03, 0x46, 0x0E, 0x13, 0xD1, 0x8B, 0x76, 0x11,
//0x60, 0x89, 0x46, 0xFC, 0x89, 0x56, 0xFE, 0xB8, 0x20, 0x00, 0xF7, 0xE6, 0x8B, 0x5E, 0x0B, 0x03,
//0xC3, 0x48, 0xF7, 0xF3, 0x01, 0x46, 0xFC, 0x11, 0x4E, 0xFE, 0x61, 0xBF, 0x00, 0x00, 0xE8, 0xE6,
//0x00, 0x72, 0x39, 0x26, 0x38, 0x2D, 0x74, 0x17, 0x60, 0xB1, 0x0B, 0xBE, 0xA1, 0x7D, 0xF3, 0xA6,
//0x61, 0x74, 0x32, 0x4E, 0x74, 0x09, 0x83, 0xC7, 0x20, 0x3B, 0xFB, 0x72, 0xE6, 0xEB, 0xDC, 0xA0,
//0xFB, 0x7D, 0xB4, 0x7D, 0x8B, 0xF0, 0xAC, 0x98, 0x40, 0x74, 0x0C, 0x48, 0x74, 0x13, 0xB4, 0x0E,
//0xBB, 0x07, 0x00, 0xCD, 0x10, 0xEB, 0xEF, 0xA0, 0xFD, 0x7D, 0xEB, 0xE6, 0xA0, 0xFC, 0x7D, 0xEB,
//0xE1, 0xCD, 0x16, 0xCD, 0x19, 0x26, 0x8B, 0x55, 0x1A, 0x52, 0xB0, 0x01, 0xBB, 0x00, 0x00, 0xE8,
//0x3B, 0x00, 0x72, 0xE8, 0x5B, 0x8A, 0x56, 0x24, 0xBE, 0x0B, 0x7C, 0x8B, 0xFC, 0xC7, 0x46, 0xF0,
//0x3D, 0x7D, 0xC7, 0x46, 0xF4, 0x29, 0x7D, 0x8C, 0xD9, 0x89, 0x4E, 0xF2, 0x89, 0x4E, 0xF6, 0xC6,
//0x06, 0x96, 0x7D, 0xCB, 0xEA, 0x03, 0x00, 0x00, 0x20, 0x0F, 0xB6, 0xC8, 0x66, 0x8B, 0x46, 0xF8,
//0x66, 0x03, 0x46, 0x1C, 0x66, 0x8B, 0xD0, 0x66, 0xC1, 0xEA, 0x10, 0xEB, 0x5E, 0x0F, 0xB6, 0xC8,
//0x4A, 0x4A, 0x8A, 0x46, 0x0D, 0x32, 0xE4, 0xF7, 0xE2, 0x03, 0x46, 0xFC, 0x13, 0x56, 0xFE, 0xEB,
//0x4A, 0x52, 0x50, 0x06, 0x53, 0x6A, 0x01, 0x6A, 0x10, 0x91, 0x8B, 0x46, 0x18, 0x96, 0x92, 0x33,
//0xD2, 0xF7, 0xF6, 0x91, 0xF7, 0xF6, 0x42, 0x87, 0xCA, 0xF7, 0x76, 0x1A, 0x8A, 0xF2, 0x8A, 0xE8,
//0xC0, 0xCC, 0x02, 0x0A, 0xCC, 0xB8, 0x01, 0x02, 0x80, 0x7E, 0x02, 0x0E, 0x75, 0x04, 0xB4, 0x42,
//0x8B, 0xF4, 0x8A, 0x56, 0x24, 0xCD, 0x13, 0x61, 0x61, 0x72, 0x0B, 0x40, 0x75, 0x01, 0x42, 0x03,
//0x5E, 0x0B, 0x49, 0x75, 0x06, 0xF8, 0xC3, 0x41, 0xBB, 0x00, 0x00, 0x60, 0x66, 0x6A, 0x00, 0xEB,
//0xB0, 0x42, 0x4F, 0x4F, 0x54, 0x4D, 0x47, 0x52, 0x20, 0x20, 0x20, 0x20, 0x0D, 0x0A, 0x52, 0x65,
//0x6D, 0x6F, 0x76, 0x65, 0x20, 0x64, 0x69, 0x73, 0x6B, 0x73, 0x20, 0x6F, 0x72, 0x20, 0x6F, 0x74,
//0x68, 0x65, 0x72, 0x20, 0x6D, 0x65, 0x64, 0x69, 0x61, 0x2E, 0xFF, 0x0D, 0x0A, 0x44, 0x69, 0x73,
//0x6B, 0x20, 0x65, 0x72, 0x72, 0x6F, 0x72, 0xFF, 0x0D, 0x0A, 0x50, 0x72, 0x65, 0x73, 0x73, 0x20,
//0x61, 0x6E, 0x79, 0x20, 0x6B, 0x65, 0x79, 0x20, 0x74, 0x6F, 0x20, 0x72, 0x65, 0x73, 0x74, 0x61,
//0x72, 0x74, 0x0D, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xAC, 0xCB, 0xD8, 0x55, 0xAA
0xEB,0x3C,0x90,0x4D,0x53,0x44,0x4F,0x53,0x35,0x2E,0x30,0x00,0x02,0x01,0x04,0x00,
        0x02,0x00,0x02,0x00,0x00,0xF8,0xFE,0x00,0x3F,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x01,0x00,0x80,0x00,0x29,0x83,0xCB,0x31,0x2E,0x4E,0x4F,0x20,0x4E,0x41,
        0x4D,0x45,0x20,0x20,0x20,0x20,0x46,0x41,0x54,0x31,0x36,0x20,0x20,0x20,0x33,0xC9,
        0x8E,0xD1,0xBC,0xF0,0x7B,0x8E,0xD9,0xB8,0x00,0x20,0x8E,0xC0,0xFC,0xBD,0x00,0x7C,
        0x38,0x4E,0x24,0x7D,0x24,0x8B,0xC1,0x99,0xE8,0x3C,0x01,0x72,0x1C,0x83,0xEB,0x3A,
        0x66,0xA1,0x1C,0x7C,0x26,0x66,0x3B,0x07,0x26,0x8A,0x57,0xFC,0x75,0x06,0x80,0xCA,
        0x02,0x88,0x56,0x02,0x80,0xC3,0x10,0x73,0xEB,0x33,0xC9,0x8A,0x46,0x10,0x98,0xF7,
        0x66,0x16,0x03,0x46,0x1C,0x13,0x56,0x1E,0x03,0x46,0x0E,0x13,0xD1,0x8B,0x76,0x11,
        0x60,0x89,0x46,0xFC,0x89,0x56,0xFE,0xB8,0x20,0x00,0xF7,0xE6,0x8B,0x5E,0x0B,0x03,
        0xC3,0x48,0xF7,0xF3,0x01,0x46,0xFC,0x11,0x4E,0xFE,0x61,0xBF,0x00,0x00,0xE8,0xE6,
        0x00,0x72,0x39,0x26,0x38,0x2D,0x74,0x17,0x60,0xB1,0x0B,0xBE,0xA1,0x7D,0xF3,0xA6,
        0x61,0x74,0x32,0x4E,0x74,0x09,0x83,0xC7,0x20,0x3B,0xFB,0x72,0xE6,0xEB,0xDC,0xA0,
        0xFB,0x7D,0xB4,0x7D,0x8B,0xF0,0xAC,0x98,0x40,0x74,0x0C,0x48,0x74,0x13,0xB4,0x0E,
        0xBB,0x07,0x00,0xCD,0x10,0xEB,0xEF,0xA0,0xFD,0x7D,0xEB,0xE6,0xA0,0xFC,0x7D,0xEB,
        0xE1,0xCD,0x16,0xCD,0x19,0x26,0x8B,0x55,0x1A,0x52,0xB0,0x01,0xBB,0x00,0x00,0xE8,
        0x3B,0x00,0x72,0xE8,0x5B,0x8A,0x56,0x24,0xBE,0x0B,0x7C,0x8B,0xFC,0xC7,0x46,0xF0,
        0x3D,0x7D,0xC7,0x46,0xF4,0x29,0x7D,0x8C,0xD9,0x89,0x4E,0xF2,0x89,0x4E,0xF6,0xC6,
        0x06,0x96,0x7D,0xCB,0xEA,0x03,0x00,0x00,0x20,0x0F,0xB6,0xC8,0x66,0x8B,0x46,0xF8,
        0x66,0x03,0x46,0x1C,0x66,0x8B,0xD0,0x66,0xC1,0xEA,0x10,0xEB,0x5E,0x0F,0xB6,0xC8,
        0x4A,0x4A,0x8A,0x46,0x0D,0x32,0xE4,0xF7,0xE2,0x03,0x46,0xFC,0x13,0x56,0xFE,0xEB,
        0x4A,0x52,0x50,0x06,0x53,0x6A,0x01,0x6A,0x10,0x91,0x8B,0x46,0x18,0x96,0x92,0x33,
        0xD2,0xF7,0xF6,0x91,0xF7,0xF6,0x42,0x87,0xCA,0xF7,0x76,0x1A,0x8A,0xF2,0x8A,0xE8,
        0xC0,0xCC,0x02,0x0A,0xCC,0xB8,0x01,0x02,0x80,0x7E,0x02,0x0E,0x75,0x04,0xB4,0x42,
        0x8B,0xF4,0x8A,0x56,0x24,0xCD,0x13,0x61,0x61,0x72,0x0B,0x40,0x75,0x01,0x42,0x03,
        0x5E,0x0B,0x49,0x75,0x06,0xF8,0xC3,0x41,0xBB,0x00,0x00,0x60,0x66,0x6A,0x00,0xEB,
        0xB0,0x42,0x4F,0x4F,0x54,0x4D,0x47,0x52,0x20,0x20,0x20,0x20,0x0D,0x0A,0x52,0x65,
        0x6D,0x6F,0x76,0x65,0x20,0x64,0x69,0x73,0x6B,0x73,0x20,0x6F,0x72,0x20,0x6F,0x74,
        0x68,0x65,0x72,0x20,0x6D,0x65,0x64,0x69,0x61,0x2E,0xFF,0x0D,0x0A,0x44,0x69,0x73,
        0x6B,0x20,0x65,0x72,0x72,0x6F,0x72,0xFF,0x0D,0x0A,0x50,0x72,0x65,0x73,0x73,0x20,
        0x61,0x6E,0x79,0x20,0x6B,0x65,0x79,0x20,0x74,0x6F,0x20,0x72,0x65,0x73,0x74,0x61,
        0x72,0x74,0x0D,0x0A,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xAC,0xCB,0xD8,0x55,0xAA,
/* USER CODE END PRIVATE_FUNCTIONS_DECLARATION */
USBD_StorageTypeDef USBD_Storage_Interface_fops_FS =
  STORAGE_Init_FS,
  STORAGE_GetCapacity_FS,
  STORAGE_IsReady_FS,
  STORAGE_IsWriteProtected_FS,
  STORAGE_Read_FS,
  STORAGE_Write_FS,
  STORAGE_GetMaxLun_FS,
  (int8_t *)STORAGE_Inquirydata_FS
/* Private functions ---------------------------------------------------------*/
  * @brief  Initializes over USB FS IP
  * @param  lun:
  * @retval USBD_OK if all operations are OK else USBD_FAIL
  /* USER CODE BEGIN 2 */
        uint32_t i;
        for(i=0;i<sizeof(MBK);i++)
                test[i] = MBK[i];
  return (USBD_OK);
  /* USER CODE END 2 */
  * @brief  .
  * @param  lun: .
  * @param  block_num: .
  * @param  block_size: .
  /* USER CODE BEGIN 3 */
  *block_num  = mySTORAGE_BLK_NBR;
  *block_size = STORAGE_BLK_SIZ;
  return (USBD_OK);
  /* USER CODE END 3 */
  * @brief  .
  * @param  lun: .
  /* USER CODE BEGIN 4 */
  return (USBD_OK);
  /* USER CODE END 4 */
  * @brief  .
  * @param  lun: .
  /* USER CODE BEGIN 5 */
  return (USBD_OK);
  /* USER CODE END 5 */
  * @brief  .
  * @param  lun: .
  /* USER CODE BEGIN 6 */
        uint32_t i,j,n=0;
  if((blk_addr+blk_len)*STORAGE_BLK_SIZ<sizeof(test))
                for(i=0;i<blk_len;i++)
                        for(j=0;j<STORAGE_BLK_SIZ;j++)
                                buf[n++] = test[(blk_addr+i)*STORAGE_BLK_SIZ+j];
  return (USBD_OK);
  /* USER CODE END 6 */
  * @brief  .
  * @param  lun: .
  /* USER CODE BEGIN 7 */
        uint32_t i,j,n=0;
                                 test[(blk_addr+i)*STORAGE_BLK_SIZ+j] = buf[n++];
  return (USBD_OK);
  /* USER CODE END 7 */
  * @brief  .
  * @param  None
  * @retval .
  /* USER CODE BEGIN 8 */
  return (STORAGE_LUN_NBR - 1);
  /* USER CODE END 8 */
/* USER CODE BEGIN PRIVATE_FUNCTIONS_IMPLEMENTATION */
/* USER CODE END PRIVATE_FUNCTIONS_IMPLEMENTATION */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
a20084666| | 2018-4-11 09:39 | 只看该作者
在A电脑复制,然后到B电脑打开你试试看
七颗咖啡豆|  楼主 | 2018-4-11 09:55 | 只看该作者
a20084666 发表于 2018-4-11 09:39
在A电脑复制,然后到B电脑打开你试试看
没有存flash,只是保存在RAM中  掉电就没了
huzi2099| | 2018-4-11 13:19 | 只看该作者
不可能,你再copy出来试试,或者磁盘扫描一下
copy的时候文件系统没报错而已
huzi2099| | 2018-4-11 13:38 | 只看该作者
以前很多假冒的u盘就这么干的,看起来多,复制也没问题,考出来就完蛋了,或者是原先考入的文件被覆盖了.
xyz549040622| | 2018-4-11 20:20 | 只看该作者
huzi2099 发表于 2018-4-11 13:38
以前很多假冒的u盘就这么干的,看起来多,复制也没问题,考出来就完蛋了,或者是原先考入的文件被覆盖了.[em:4: ...
那为什么可以用呢?同意,许多假u盘就是这么干的,虚拟空间。
huzi2099| | 2018-4-11 20:29 | 只看该作者
可以用是不可能的.
xyz549040622| | 2018-4-11 20:44 | 只看该作者
huzi2099 发表于 2018-4-11 20:29
可以用是不可能的.
因为楼主说可以运行,所以奇怪,应该是不能用的呀。
mmuuss586| | 2018-4-11 23:27 | 只看该作者
厉害,最好发个视屏看下
蝴蝶泉2018| | 2018-4-12 11:58 | 只看该作者
啊啊...这个呀...玩玩就好..
xiuwen89| | 2018-4-12 12:39 | 只看该作者
能运行一点都不奇怪的,Windows自己有缓存,你那文件整个都在缓存里,根本不需要从你的优盘里再读出来。
ta1ent| | 2018-4-12 13:47 | 只看该作者
再copy个其他文件试试呢?比如一张图片,打开看看完整不?
tomzbj| | 2018-4-12 16:39 | 只看该作者
前面有人说了, 换台电脑打开试试.
或者把U盘拔下来, 电脑重启, 再插上试试.
这要真能运行才有鬼了~
877049204| | 2018-4-13 10:30 | 只看该作者
6666,还能这样玩
gujiamao12345| | 2018-4-13 10:44 | 只看该作者
你不是copy到stm32flash了嘛。直接把stm32usb插到另一台电脑,再双击打开这个串口助手。
icecut| | 2018-4-13 13:57 | 只看该作者
st芯片的神奇功效
jcdzxh| | 2018-4-13 14:59 | 只看该作者
cache
xuanhuanzi| | 2018-4-15 17:44 | 只看该作者
你把你桌面的文件珊了,你拔了板子再插入,看看能否复制出来。
huzi2099| | 2018-4-15 20:58 | 只看该作者
不是cach是noerror
