发新帖我要提问
返回列表
[STM32F4]
CubeMX工具生成的SDIO DMA代码无法工作
楼主: lanjackg2003
lanjackg2003|  楼主 | 2018-4-16 16:40 | 只看该作者 回帖奖励 |倒序浏览
huzi2099 发表于 2018-4-16 15:55
好像第一个扇区写有问题
  while (1)
我重新测试了一下,代码没有问题,写卡都能够成功
问题是在那个HAL_SD_ErrorCallback 函数,每次写卡都会触发这个error错误,但是写卡都能够成功。
感觉CubeMX的逻辑处理还是有点问题,至少之前有人反馈跟我相类似的问题
https://community.st.com/docs/DOC-1546-cubemx-sdio-dma-fatfs-configuration
https://community.st.com/thread/42555-stm32-with-sd-card-and-fatfs-using-cubemx-write-error-and-write-speed-solution
参考这两个网页的pdf,我将代码修改为
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f4xx_hal.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
SD_HandleTypeDef hsd;
DMA_HandleTypeDef hdma_sdio_rx;
DMA_HandleTypeDef hdma_sdio_tx;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_SDIO_SD_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
        HAL_SD_CardStateTypeDef eRet1 ;
        HAL_SD_CardStateTypeDef eRet2 ;
                uint8_t sd_state= 0;
HAL_SD_StateTypeDef state_return;
HAL_SD_CardStateTypeDef sd_card_state_return;
        #define        SD_WAIT_TIMEOUT          1000000
                uint32_t timeout = 0;
                uint32_t uAddr = 0x88FF;
                __align(4) char kk[512] = "chinese.......";
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval None
int main(void)
  /* USER CODE BEGIN 1 */
        int index = 0;
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_USART1_UART_Init();
  MX_SDIO_SD_Init();
  /* USER CODE BEGIN 2 */
#if 0
                while(timeout--)
                eRet1 = HAL_SD_GetCardState(&hsd);
                if(eRet1 == HAL_SD_CARD_READY)
                        break;
                HAL_Delay(1000);
#endif
        while(index < 10 )
                index++;
                sprintf(kk,"chinese index == %d",index);
        HAL_SD_WriteBlocks_DMA(&hsd,kk,uAddr,1);
        uAddr += 1;
do
state_return= HAL_SD_GetState(&hsd);
timeout++;
} while((HAL_SD_STATE_BUSY== state_return) && (SD_WAIT_TIMEOUT > timeout));
if(HAL_SD_STATE_READY!= state_return){ return 0;}
timeout = 0;
do
sd_card_state_return= HAL_SD_GetCardState(&hsd);
timeout++;
} while((HAL_SD_CARD_TRANSFER!= sd_card_state_return)&& (SD_WAIT_TIMEOUT > timeout));
if((SD_WAIT_TIMEOUT <= timeout)){ return HAL_TIMEOUT;}
#if 0
timeout = 2;
        while(timeout--)
                eRet2 = HAL_SD_GetCardState(&hsd);
                if(eRet2 == HAL_SD_CARD_READY)
                        break;
                HAL_Delay(1000);
#endif
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
timeout = 122;
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* SDIO init function */
  hsd.Instance = SDIO;
  hsd.Init.ClockEdge = SDIO_CLOCK_EDGE_RISING;
  hsd.Init.ClockBypass = SDIO_CLOCK_BYPASS_DISABLE;
  hsd.Init.ClockPowerSave = SDIO_CLOCK_POWER_SAVE_DISABLE;
  hsd.Init.BusWide = SDIO_BUS_WIDE_1B;
  hsd.Init.HardwareFlowControl = SDIO_HARDWARE_FLOW_CONTROL_DISABLE;
  hsd.Init.ClockDiv = 0;
  if (HAL_SD_Init(&hsd) != HAL_OK)
  if (HAL_SD_ConfigWideBusOperation(&hsd, SDIO_BUS_WIDE_4B) != HAL_OK)
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
  * Enable DMA controller clock
  /* DMA controller clock enable */
  __HAL_RCC_DMA2_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA2_Stream3_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA2_Stream3_IRQn, 6, 0);
  HAL_NVIC_EnableIRQ(DMA2_Stream3_IRQn);
  /* DMA2_Stream6_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA2_Stream6_IRQn, 6, 0);
  HAL_NVIC_EnableIRQ(DMA2_Stream6_IRQn);
/** Pinout Configuration
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
/* USER CODE BEGIN 4 */
void HAL_SD_TxCpltCallback(SD_HandleTypeDef *hsd)
                //printf("HAL_SD_TxCpltCallback \r\n");
                int k = 0;
                k++;
void HAL_SD_RxCpltCallback(SD_HandleTypeDef *hsd)
                int k = 0;
                k++;
                //printf("HAL_SD_RxCpltCallback \r\n");
void HAL_SD_ErrorCallback(SD_HandleTypeDef *hsd)
                int k = 0;
                k++;
//printf("HAL_SD_ErrorCallback \r\n");
void HAL_SD_AbortCallback(SD_HandleTypeDef *hsd)
                //printf("HAL_SD_AbortCallback \r\n");
                int k = 0;
                k++;
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  file: The file name as string.
  * @param  line: The line in file as a number.
  * @retval None
void _Error_Handler(char *file, int line)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
目前,我也只能忽略那个在DMA写的时候回调的HAL_SD_ErrorCallback 以及DMA Tx的0x02错误
lanjackg2003|  楼主 | 2018-4-16 16:42 | 只看该作者
huzi2099 发表于 2018-4-16 15:43
刚才试了一下是可以的,所有默认的就行,不回调也无所谓,02dmaerror表示busy,不影响,数据可以写下去.
dma完 ...
0x02错误不是  HAL_DMA_ERROR_FE
/** @defgroup DMA_Error_Code DMA Error Code
  * @brief    DMA Error Code
#define HAL_DMA_ERROR_NONE            0x00000000U    /*!< No error                               */
#define HAL_DMA_ERROR_TE              0x00000001U    /*!< Transfer error                         */
#define HAL_DMA_ERROR_FE              0x00000002U    /*!< FIFO error                             */
#define HAL_DMA_ERROR_DME             0x00000004U    /*!< Direct Mode error                      */
#define HAL_DMA_ERROR_TIMEOUT         0x00000020U    /*!< Timeout error                          */
#define HAL_DMA_ERROR_PARAM           0x00000040U    /*!< Parameter error                        */
#define HAL_DMA_ERROR_NO_XFER         0x00000080U    /*!< Abort requested with no Xfer ongoing   */
#define HAL_DMA_ERROR_NOT_SUPPORTED   0x00000100U    /*!< Not supported mode                     */
怎么会是BUSY错误,请问从哪里看到的
lanjackg2003|  楼主 | 2018-4-16 16:47 | 只看该作者
顺便上传在两个英文网站下载的pdf文档,供有需要的人下载学习
STM32 with SD Card and FatFs using CubeMX – Write error and write speed - Solution.pdf (833.64 KB)
SDIO DMA FatFS CubeMX.pdf (529.84 KB)
huzi2099| | 2018-4-16 17:41 | 只看该作者
是,你的对,我看走眼了看成 HAL_StatusTypeDef 类型了
lanjackg2003|  楼主 | 2018-4-16 18:01 | 只看该作者
哈,我也只能give up,等官方的来看看了。
怎么现在21IC没有结贴功能了?~!
huzi2099| | 2018-4-16 18:12 | 只看该作者
你要不套上FATFS再参考一下.
lanjackg2003|  楼主 | 2018-4-16 18:33 | 只看该作者
huzi2099 发表于 2018-4-16 18:12
你要不套上FATFS再参考一下.
FATFS应该是不会影响到底层这块的。
另外想请教一下,你是调用什么函数来清除DMA这个错误标志的
huzi2099| | 2018-4-17 08:09 | 只看该作者
lanjackg2003 发表于 2018-4-16 18:33
FATFS应该是不会影响到底层这块的。
另外想请教一下,你是调用什么函数来清除DMA这个错误标志的 ...
我没再弄了
lanjackg2003|  楼主 | 2018-4-17 11:12 | 只看该作者
好的,没问题
lanjackg2003|  楼主 | 2018-4-17 11:14 | 只看该作者
另外再说明一下:
HAL_SD_TxCpltCallback  HAL_SD_RxCpltCallback  HAL_SD_ErrorCallback HAL_SD_AbortCallback
这个几个回调函数中,最好不要用printf打印数据,否则会出现在下次调用SD_SendSDStatus函数的时候卡死在里面,一直在如下段代码中循环
  /* Get status data */
  while(!__HAL_SD_GET_FLAG(hsd, SDIO_FLAG_RXOVERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_DBCKEND))
    if(__HAL_SD_GET_FLAG(hsd, SDIO_FLAG_RXFIFOHF))
      for(count = 0U; count < 8U; count++)
        *(pSDstatus + count) = SDIO_ReadFIFO(hsd->Instance);
      pSDstatus += 8U;
    if((HAL_GetTick() - tickstart) >=  SDMMC_DATATIMEOUT)
      return HAL_SD_ERROR_TIMEOUT;
