[DemoCode下载]
MINI51的PDID以及SYS相关操作演示
987|10
dongnanxibei|  楼主 | 2018-4-22 20:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.00
* $Date: 15/10/06 1:21p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to get PDID, get and clear reset source, configure
*           BOD, and output system clock to CKO pin with the system
*           clock / 4 frequency
* @note
* Copyright (C) 2012 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Mini51Series.h"
#define SIGNATURE       0x125ab234
#define FLAG_ADDR       0x200007FC
extern char GetChar(void);
/*  Brown Out Detector IRQ Handler        */
void BOD_IRQHandler(void)
    /* Clear Interrupt Flag */
    SYS->BODCTL |= SYS_BODCR_BOD_INTF_Msk;
    printf("Brown Out is Detected\n");
/*  Power Down Wake Up IRQ Handler        */
void PWRWU_IRQHandler(void)
    /* Clear Power Down Wake Up interrupt flag */
    CLK->PWRCON |= CLK_PWRCON_PD_WU_STS_Msk;
    printf("Wake Up Interrupt is asserted\n");
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System Clock        */
    /* Set P5 multi-function pins for XTAL1 and XTAL2 */
    SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
    SYS->P5_MFP |= (SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2);
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK_EnableXtalRC(CLK_PWRCON_HXT|CLK_PWRCON_HIRC_EN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL_STB_Msk | CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Switch HCLK clock source to XTL */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_XTAL,CLK_CLKDIV_HCLK(1));
    /* STCLK to XTL STCLK to XTL */
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLK_S_XTAL);
    /* Enable IP clock */
    CLK_EnableModuleClock(UART_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART_MODULE,CLK_CLKSEL1_UART_S_XTAL,CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P0 multi-function pins for UART RXD and TXD */
    SYS->P0_MFP &= ~(SYS_MFP_P01_Msk | SYS_MFP_P00_Msk);
    SYS->P0_MFP |= (SYS_MFP_P01_RXD | SYS_MFP_P00_TXD);
    /* Set P3 multi-function pins for Clock Output */
    SYS->P3_MFP = SYS_MFP_P36_CKO;
    /* To update the variable SystemCoreClock */
    SystemCoreClockUpdate();
    /* Lock protected registers */
    SYS_LockReg();
void UART_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART_RST);
    /* Configure UART and set UART Baudrate */
    UART_Open(UART, 115200);
/*  Main Function        */
int32_t main (void)
    uint32_t u32data;
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART for printf */
    UART_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
        This sample code will show some function about system manager controller and clock controller:
        1. Read PDID
        2. Get and clear reset source
        3. Setting about BOD
        4. Output system clock from CKO pin, and the output frequency = system clock / 4
    printf("+----------------------------------------+\n");
    printf("|    Mini51 System Driver Sample Code    |\n");
    if (M32(FLAG_ADDR) == SIGNATURE) {
        printf("  CPU Reset success!\n");
        M32(FLAG_ADDR) = 0;
        printf("  Press any key to continue ...\n");
        GetChar();
    /* Misc system function test        */
    /* Read Part Device ID */
    printf("Product ID 0x%x\n", SYS->PDID);
    /* Get reset source from last operation */
    u32data = SYS_GetResetSrc();
    printf("Reset Source 0x%x\n", u32data);
    /* Clear reset source */
    SYS_ClearResetSrc(u32data);
    /* Unlock protected registers for Brown-Out Detector settings */
    SYS_UnlockReg();
    /* Check if the write-protected registers are unlocked before BOD setting and CPU Reset */
    if (SYS->RegLockAddr != 0) {
        printf("Protected Address is Unlocked\n");
    /* Enable Brown-Out Detector and Low Voltage Reset function, and set Brown-Out Detector voltage 2.7V ,
       Enable Brown-Out Interrupt function */
    SYS_EnableBOD(SYS_BODCR_BOD_INTERRUPT_EN,SYS_BODCR_BOD_VL_2_7V);
    /* Enable BOD IRQ */
    NVIC_EnableIRQ(BOD_IRQn);
    /* Write a signature work to SRAM to check if it is reset by software */
    M32(FLAG_ADDR) = SIGNATURE;
    printf("\n\n  >>> Reset CPU <<<\n");
    /* Waiting for message send out */
    UART_WAIT_TX_EMPTY(UART);
    /* Switch HCLK clock source to Internal 22MHz */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_IRC22M,0);
    /* Enable CKO and output frequency = system clock / 4 */
    CLK_EnableCKO(CLK_CLKSEL2_FRQDIV_HCLK,1,0);
    /* Reset CPU */
    SYS_ResetCPU();
dongnanxibei|  楼主 | 2018-4-22 21:06 | 只看该作者
该例子也对欠压复位做了演示。
wahahaheihei| | 2018-4-22 21:45 | 只看该作者
大部分简单的特别操作都在这个例子里。
幸福小强| | 2018-4-22 22:02 | 只看该作者
没想到用外部晶振还要先配置管脚。
xinpian101| | 2018-4-22 22:25 | 只看该作者
IP时钟原来就是模块时钟,串口模块,PWM模块,或者说外设。
yiyigirl2014| | 2018-4-23 11:21 | 只看该作者
一个配置就好了。
merry_zsp| | 2018-4-24 16:21 | 只看该作者
支持下,我习惯用库,基本不用寄存器的。
mintspring| | 2018-4-26 12:50 | 只看该作者
是这两条决定的,因此可以封装未一个函数比较好。
HKingS| | 2018-4-26 23:14 | 只看该作者
支持下,好久没关注mini51系列了,觉得其他家的M0或者STM8比这个性价比好多了。
xuanhuanzi| | 2018-4-27 11:20 | 只看该作者
BOD这个非常好用。
Puremr| | 2018-4-28 15:18 | 只看该作者
同意,这两个可以封装为一个库函数的。
