[DemoCode下载]
M451的DSP内核FFT应用
1402|4
yiyigirl2014|  楼主 | 2018-6-28 15:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.0
* $Date: 16/09/22 10:04a $
* @brief
*         Display how to use DSP FFT function
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#include "arm_math.h"
#define TEST_LENGTH_SAMPLES 2048 //Must be fftsize*2
* External Input and Output buffer Declarations for FFT Bin Example
extern float32_t testInput_f32_10khz[TEST_LENGTH_SAMPLES];
static float32_t testOutput[TEST_LENGTH_SAMPLES/2];
* Global variables for FFT Bin Example
uint32_t fftSize = 1024;
uint32_t ifftFlag = 0;
uint32_t doBitReverse = 1;
/* Reference index at which max energy of bin ocuurs */
uint32_t refIndex = 213, testIndex = 0;
arm_cfft_radix4_instance_f32 S;
float32_t maxValue,Mainfreq;
int CalTime;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
    CLK_SetCoreClock(72000000);
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, CLK_CLKDIV0_UART(1));
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, 0);
void UART_Init(void)
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL = SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD;
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
        /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART for printf */
    UART_Init();
                /* Measure FFT calcultion time */
                TIMER_Open(TIMER0, TIMER_CONTINUOUS_MODE, 1);
                TIMER_Start(TIMER0);
                /* Initialize the CFFT/CIFFT module */
                arm_cfft_radix4_init_f32(&S, fftSize,ifftFlag, doBitReverse);
                /* Process the data through the CFFT/CIFFT module */
                arm_cfft_radix4_f32(&S, testInput_f32_10khz);
                TIMER_Close(TIMER0);
                /* Process the data through the Complex Magnitude Module for calculating the magnitude at each bin */
                arm_cmplx_mag_f32(testInput_f32_10khz, testOutput,fftSize/2);
                /* Calculates maxValue and returns corresponding BIN value */
                arm_max_f32(testOutput, fftSize/2, &maxValue, &testIndex);
                CalTime=TIMER_GetCounter(TIMER0);
                /* Mainfreq=testindex*sample rate/fftsize */
                Mainfreq=testIndex*5000/fftSize;
                printf("Main frequency is %f\n",Mainfreq);
                printf("time is %d \n",CalTime);
    while(1);
yiyigirl2014|  楼主 | 2018-6-28 15:21 | 只看该作者
EC_M451_DSP_FFT_V1.0.zip (4.43 MB)
Puremr| | 2018-6-28 16:37 | 只看该作者
M451不是ARM的内核吗?怎么变成DSP的内核了?
Puremr| | 2018-6-28 16:38 | 只看该作者
新唐NuMicro® M451基础系列是基于ARM® Cortex®-M4内核的新一代32位的微控制器,宽工作电压(2.5V ~ 5.5V),工业级温度(-40℃ ~ 105℃),内置22.1184MHz晶振(在25℃,5V时精度1%),可配置Data Flash,强抗干扰性(ESD 8KV、EFT 4KV),封装类型有LQFP48、LQFP64和LQFP100。
这不是DSP的内核吧。
zhuotuzi| | 2018-6-28 18:36 | 只看该作者
Puremr 发表于 2018-6-28 16:38
新唐NuMicro® M451基础系列是基于ARM® Cortex®-M4内核的新一代32位的微控制器,宽工作电压(2.5V ~ 5.5V) ...
含有浮点运算单元和DSP的
ARM® Cortex™-M4內核
    - 最高可运行至72 MHz
