[STM32F4] STM32F407 FATFS R0.13a 怎么读取FIL 文件大小
3655|10
 楼主| 十里荷香 发表于 2018-7-19 13:42 | 显示全部楼层 |阅读模式
教各位大神,有谁用的是 FATFS R0.13a的版本
/* File object structure (FIL) */
typedef struct {
        FFOBJID        obj;                        /* Object identifier (must be the 1st member to detect invalid object pointer) */
        BYTE        flag;                        /* File status flags */
        BYTE        err;                        /* Abort flag (error code) */
        FSIZE_t        fptr;                        /* File read/write pointer (Zeroed on file open) */
        DWORD        clust;                        /* Current cluster of fpter (invalid when fptr is 0) */
        DWORD        sect;                        /* Sector number appearing in buf[] (0:invalid) */
#if !FF_FS_READONLY
        DWORD        dir_sect;                /* Sector number containing the directory entry (not used at exFAT) */
        BYTE*        dir_ptr;                /* Pointer to the directory entry in the win[] (not used at exFAT) */
#endif
#if FF_USE_FASTSEEK
        DWORD*        cltbl;                        /* Pointer to the cluster link map table (nulled on open, set by application) */
#endif
#if !FF_FS_TINY
        BYTE        buf[FF_MAX_SS];        /* File private data read/write window */
#endif
} FIL;
FIL怎么没有了DWORD        fsize;                        /* File size */
原来R0.1都有的啊
typedef struct {
        FATFS*        fs;                                /* Pointer to the related file system object (**do not change order**) */
        WORD        id;                                /* Owner file system mount ID (**do not change order**) */
        BYTE        flag;                        /* Status flags */
        DWORD        fptr;                        /* File read/write pointer (Zeroed on file open) */
        DWORD        sclust;                        /* File start cluster (0:no cluster chain, always 0 when fsize is 0) */
        DWORD        clust;                        /* Current cluster of fpter (not valid when fprt is 0) */
        DWORD        dsect;                        /* Sector number appearing in buf[] (0:invalid) */
#if !_FS_READONLY
        DWORD        dir_sect;                /* Sector number containing the directory entry */
        BYTE*        dir_ptr;                /* Pointer to the directory entry in the win[] */
#endif
#if _USE_FASTSEEK
        DWORD*        cltbl;                        /* Pointer to the cluster link map table (Nulled on file open) */
#endif
#if _FS_LOCK
        UINT        lockid;                        /* File lock ID origin from 1 (index of file semaphore table Files[]) */
#endif
#if !_FS_TINY
        BYTE        buf[_MAX_SS];        /* File private data read/write window */
#endif
} FIL;
这个我现在要怎么知道打开文件的大小?
wakayi 发表于 2018-7-19 15:14 | 显示全部楼层
请问楼主这个版本从哪里看啊
yklstudent 发表于 2018-7-20 11:37 来自手机 | 显示全部楼层
一切资料官网都用
 楼主| 十里荷香 发表于 2018-7-23 15:56 | 显示全部楼层
请问楼主这个版本从哪里看啊
ff.h文件里
观海 发表于 2018-7-24 09:01 | 显示全部楼层
这种系统和别的系统有什么不同吗
wakayi 发表于 2018-7-24 12:39 | 显示全部楼层
mj1114 发表于 2018-7-24 14:19 | 显示全部楼层
用f_stat指令来查看文件大小
FRESULT fr; FILINFO *fno; fno=(FILINFO*)mymalloc(SRAMIN,sizeof(FILINFO)); f_stat((const TCHAR*)"0:/AV.txt",fno); u32 size=fno->fsize; myfree(SRAMIN,fno); printf("%x,感谢老司机,谢谢。",size);  发表于 2019-10-7 21:52
binoo7 发表于 2018-11-1 21:25 | 显示全部楼层
楼主有fatfs R0.13c的移植视频有吗
z328368944 发表于 2019-10-7 21:53 | 显示全部楼层
没办法咯,人家说改就改哈哈哈哈。按照老司机指导f_stat解决了
z328368944 发表于 2019-10-7 21:54 | 显示全部楼层
FRESULT fr;
FILINFO *fno;
myfree(SRAMIN,fno);
