请问下,GD32中的DMA REMAP要怎么操作
2140|3
 楼主| 37772166 发表于 2018-8-3 10:17 | 显示全部楼层 |阅读模式
把COM0的通道,由1,2、换到3,4。
我按例程上,加入了下面两句。
syscfg_dma_remap_enable(SYSCFG_DMA_REMAP_USART0RX);
syscfg_dma_remap_enable(SYSCFG_DMA_REMAP_USART0TX);
结果程序上DMA发送不成功。一直停在while (RESET == dma_flag_get(DMA_CH3, DMA_FLAG_FTF));
请问下,这个要怎么修改才能行?谢谢!
int main(void)
    dma_parameter_struct dma_init_struct;
    /* enable DMA clock */
    rcu_periph_clock_enable(RCU_DMA);
#ifdef GD32F130_150
    gd_eval_com_init(EVAL_COM1);
#elif defined GD32F170_190
    gd_eval_com_init(EVAL_COM2);
#endif /* GD32F130_150 */
    printf("\n\ra usart dma function test example!\n\r");
#ifdef GD32F130_150
    /* deinitialize DMA channel1 */
    dma_deinit(DMA_CH3);
    dma_init_struct.direction = DMA_MEMORY_TO_PERIPHERAL;
    dma_init_struct.memory_addr = (uint32_t)txbuffer;
    dma_init_struct.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.memory_width = DMA_MEMORY_WIDTH_8BIT;
    dma_init_struct.number = ARRAYNUM(txbuffer);
    dma_init_struct.periph_addr = USART0_TDATA_ADDRESS;
    dma_init_struct.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
    dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_8BIT;
    dma_init_struct.priority = DMA_PRIORITY_ULTRA_HIGH;
    dma_init(DMA_CH3, dma_init_struct);
    /* configure DMA mode */
    dma_circulation_disable(DMA_CH3);
    dma_memory_to_memory_disable(DMA_CH3);
    /* enable DMA channel1 */
    dma_channel_enable(DMA_CH3);
    /* USART DMA enable for transmission and reception */
    usart_dma_transmit_config(USART0, USART_DENT_ENABLE);
    /* wait DMA channel transfer complete */
    while(1){
        /* deinitialize DMA channel2 */
        dma_deinit(DMA_CH4);
        dma_init_struct.direction = DMA_PERIPHERAL_TO_MEMORY;
        dma_init_struct.memory_addr = (uint32_t)rxbuffer;
        dma_init_struct.number = 10;
        dma_init_struct.periph_addr = USART0_RDATA_ADDRESS;
        dma_init(DMA_CH4, dma_init_struct);
        dma_circulation_disable(DMA_CH4);
        dma_memory_to_memory_disable(DMA_CH4);
        dma_channel_enable(DMA_CH4);
        usart_dma_receive_config(USART0, USART_DENR_ENABLE);
        while (RESET == dma_flag_get(DMA_CH4, DMA_FLAG_FTF));
        printf("\n\r%s\n\r",rxbuffer);
 楼主| 37772166 发表于 2018-8-3 19:55 | 显示全部楼层
解决了,加上这句就行了。 rcu_periph_clock_enable(RCU_CFGCMP);
heimaojingzhang 发表于 2018-8-6 12:45 | 显示全部楼层
这是为什么呢
八层楼 发表于 2018-8-7 12:13 | 显示全部楼层
这句话是干嘛用的呢
