[应用相关]
CANopen资料之1:如何通过程序发送SDO,PDO报文
6488|17
wangjiahao88|  楼主 | 2018-8-23 13:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
sdo.c
   This file is part of CanFestival, a library implementing CanOpen Stack.
pdo
  Stack.
  Copyright (C): Edouard TISSERANT and Francis DUPIN
  See COPYING file for copyrights details.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
  USA
#include "pdo.h"
#include "objacces.h"
#include "canfestival.h"
#include "sysdep.h"
** @file   pdo.c
** @author Edouard TISSERANT and Francis DUPIN
** @date   Tue Jun  5 09:32:32 2007
** @brief
** @param d
** @param TPDO_com TPDO communication parameters OD entry
** @param TPDO_map TPDO mapping parameters OD entry
** @return
UNS8 buildPDO (CO_Data * d, UNS8 numPdo, Message * pdo)
  const indextable *TPDO_com = d->objdict + d->firstIndex->PDO_TRS + numPdo;
  const indextable *TPDO_map = d->objdict + d->firstIndex->PDO_TRS_MAP + numPdo;
  UNS8 prp_j = 0x00;
  UNS32 offset = 0x00000000;
  const UNS8 *pMappingCount = (UNS8 *) TPDO_map->pSubindex[0].pObject;
  pdo->cob_id = (UNS16) UNS16_LE(*(UNS32*)TPDO_com->pSubindex[1].pObject & 0x7FF);
  pdo->rtr = NOT_A_REQUEST;
  MSG_WAR (0x3009, "  PDO CobId is : ",
           *(UNS32 *) TPDO_com->pSubindex[1].pObject);
  MSG_WAR (0x300D, "  Number of objects mapped : ", *pMappingCount);
  do
      UNS8 dataType;            /* Unused */
      UNS8 tmp[] = { 0, 0, 0, 0, 0, 0, 0, 0 };  /* temporary space to hold bits */
      /* pointer fo the var which holds the mapping parameter of an mapping entry  */
      UNS32 *pMappingParameter =
        (UNS32 *) TPDO_map->pSubindex[prp_j + 1].pObject;
      UNS16 index = (UNS16) ((*pMappingParameter) >> 16);
      UNS32 Size = (UNS32) (*pMappingParameter & (UNS32) 0x000000FF);     /* Size in bits */
      /* get variable only if Size != 0 and Size is lower than remaining bits in the PDO */
      if (Size && ((offset + Size) <= 64))
          UNS32 ByteSize = 1 + ((Size - 1) >> 3);        /*1->8 => 1 ; 9->16 => 2, ... */
          UNS8 subIndex =
            (UNS8) (((*pMappingParameter) >> (UNS8) 8) & (UNS32) 0x000000FF);
          MSG_WAR (0x300F, "  got mapping parameter : ", *pMappingParameter);
          MSG_WAR (0x3050, "    at index : ", TPDO_map->index);
          MSG_WAR (0x3051, "    sub-index : ", prp_j + 1);
          if (getODentry (d, index, subIndex, tmp, &ByteSize, &dataType, 0) !=
              OD_SUCCESSFUL)
              MSG_ERR (0x1013,
                       " Couldn't find mapped variable at index-subindex-size : ",
                       (UNS32) (*pMappingParameter));
              return 0xFF;
          /* copy bit per bit in little endian */
          CopyBits ((UNS8) Size, ((UNS8 *) tmp), 0, 0,
                    (UNS8 *) & pdo->data[offset >> 3], (UNS8)(offset % 8), 0);
          offset += Size;
      prp_j++;
  while (prp_j < *pMappingCount);
  pdo->len = (UNS8)(1 + ((offset - 1) >> 3));
  MSG_WAR (0x3015, "  End scan mapped variable", 0);
  return 0;
wangjiahao88|  楼主 | 2018-8-23 13:50 | 只看该作者
** @param d
** @param cobId
** @return
UNS8
sendPDOrequest (CO_Data * d, UNS16 RPDOIndex)
  UNS16 *pwCobId;
  UNS16 offset = d->firstIndex->PDO_RCV;
  UNS16 lastIndex = d->lastIndex->PDO_RCV;
  if (!d->CurrentCommunicationState.csPDO)
      return 0;
  /* Sending the request only if the cobid have been found on the PDO
     receive */
  /* part dictionary */
  MSG_WAR (0x3930, "sendPDOrequest RPDO Index : ", RPDOIndex);
  if (offset && RPDOIndex >= 0x1400)
      offset += RPDOIndex - 0x1400;
      if (offset <= lastIndex)
          /* get the CobId */
          pwCobId = d->objdict[offset].pSubindex[1].pObject;
          MSG_WAR (0x3930, "sendPDOrequest cobId is : ", *pwCobId);
            Message pdo;
            pdo.cob_id = UNS16_LE(*pwCobId);
            pdo.rtr = REQUEST;
            pdo.len = 0;
            return canSend (d->canHandle, &pdo);
  MSG_ERR (0x1931, "sendPDOrequest : RPDO Index not found : ", RPDOIndex);
  return 0xFF;
** @param d
** @param m
** @return
UNS8
proceedPDO (CO_Data * d, Message * m)
  UNS8 numPdo;
  UNS8 numMap;                  /* Number of the mapped varable */
  UNS8 *pMappingCount = NULL;   /* count of mapped objects... */
  /* pointer to the var which is mapped to a pdo... */
  /*  void *     pMappedAppObject = NULL;   */
     mapping entry */
  UNS32 *pMappingParameter = NULL;
  UNS8 *pTransmissionType = NULL;       /* pointer to the transmission
                                           type */
  UNS16 *pwCobId = NULL;
  UNS8 Size;
  UNS8 offset;
  UNS8 status;
  UNS32 objDict;
  UNS16 offsetObjdict;
  UNS16 lastIndex;
  status = state2;
  MSG_WAR (0x3935, "proceedPDO, cobID : ", (UNS16_LE(m->cob_id) & 0x7ff));
  offset = 0x00;
  numPdo = 0;
  numMap = 0;
  if ((*m).rtr == NOT_A_REQUEST)
      offsetObjdict = d->firstIndex->PDO_RCV;
      if (offsetObjdict)
        while (offsetObjdict <= lastIndex)
            switch (status)
              case state2:
                pwCobId = d->objdict[offsetObjdict].pSubindex[1].pObject;
                if (*pwCobId == UNS16_LE(m->cob_id))
                    /* The cobId is recognized */
                    status = state4;
                    MSG_WAR (0x3936, "cobId found at index ",
                             0x1400 + numPdo);
                    break;
                else
                    /* received cobId does not match */
                    numPdo++;
                    offsetObjdict++;
                    status = state2;
                    break;
              case state4:     /* Get Mapped Objects Number */
                /* The cobId of the message received has been found in the
                   dictionnary. */
                offsetObjdict = d->firstIndex->PDO_RCV_MAP;
                lastIndex = d->lastIndex->PDO_RCV_MAP;
                pMappingCount =
                  (UNS8 *) (d->objdict + offsetObjdict +
                            numPdo)->pSubindex[0].pObject;
                numMap = 0;
                while (numMap < *pMappingCount)
                    UNS32 ByteSize;
                    pMappingParameter =
                      (UNS32 *) (d->objdict + offsetObjdict +
                                 numPdo)->pSubindex[numMap + 1].pObject;
                    if (pMappingParameter == NULL)
                        MSG_ERR (0x1937, "Couldn't get mapping parameter : ",
                                 numMap + 1);
                        return 0xFF;
                    /* Get the addresse of the mapped variable. */
                    /* detail of *pMappingParameter : */
                    /* The 16 hight bits contains the index, the medium 8 bits
                       contains the subindex, */
                    /* and the lower 8 bits contains the size of the mapped
                       variable. */
                    Size = (UNS8) (*pMappingParameter & (UNS32) 0x000000FF);
                    /* set variable only if Size != 0 and
                     * Size is lower than remaining bits in the PDO */
                    if (Size && ((offset + Size) <= (m->len << 3)))
                        CopyBits (Size, (UNS8 *) & m->data[offset >> 3],
                                  offset % 8, 0, ((UNS8 *) tmp), 0, 0);
                        /*1->8 => 1 ; 9->16 =>2, ... */
                        ByteSize = (UNS32)(1 + ((Size - 1) >> 3));
                        objDict =
                          setODentry (d, (UNS16) ((*pMappingParameter) >> 16),
                                      (UNS8) (((*pMappingParameter) >> 8) &
                                              0xFF), tmp, &ByteSize, 0);
                        if (objDict != OD_SUCCESSFUL)
                            MSG_ERR (0x1938,
                                     "error accessing to the mapped var : ",
                                     numMap + 1);
                            MSG_WAR (0x2939, "         Mapped at index : ",
                            MSG_WAR (0x2940, "                subindex : ",
                                     ((*pMappingParameter) >> 8) & 0xFF);
                            return 0xFF;
                        MSG_WAR (0x3942,
                                 "Variable updated by PDO cobid : ",
                                 UNS16_LE(m->cob_id));
                        MSG_WAR (0x3943, "         Mapped at index : ",
                        MSG_WAR (0x3944, "                subindex : ",
                        offset += Size;
                    numMap++;
                  }             /* end loop while on mapped variables */
                if (d->RxPDO_EventTimers)
                    TIMEVAL EventTimerDuration = *(UNS16 *)d->objdict[offsetObjdict].pSubindex[5].pObject;
                    if(EventTimerDuration){
                        DelAlarm (d->RxPDO_EventTimers[numPdo]);
                        d->RxPDO_EventTimers[numPdo] = SetAlarm (d, numPdo, d->RxPDO_EventTimers_Handler,
                        MS_TO_TIMEVAL (EventTimerDuration), 0);
                return 0;
              }                 /* end switch status */
          }                     /* end while */
    }                           /* end if Donnees */
  else if ((*m).rtr == REQUEST)
      MSG_WAR (0x3946, "Receive a PDO request cobId : ", UNS16_LE(m->cob_id));
      status = state1;
      offsetObjdict = d->firstIndex->PDO_TRS;
      lastIndex = d->lastIndex->PDO_TRS;
      if (offsetObjdict)
            /* study of all PDO stored in the objects dictionary */
            switch (status)
              case state1:     /* check the CobId */
                /* get CobId of the dictionary which match to the received PDO
                pwCobId =
                   (d->objdict +
                             offsetObjdict)->pSubindex[1].pObject;
                    status = state4;
                    break;
                else
                    numPdo++;
                    offsetObjdict++;
                status = state1;
                break;
              case state4:     /* check transmission type */
                pTransmissionType =
                  (UNS8 *) d->objdict[offsetObjdict].pSubindex[2].pObject;
                /* If PDO is to be sampled and send on RTR, do it */
                if ((*pTransmissionType == TRANS_RTR))
                    status = state5;
                    break;
                /* RTR_SYNC means data prepared at SYNC, transmitted on RTR */
                else if ((*pTransmissionType == TRANS_RTR_SYNC))
                    if (d->PDO_status[numPdo].
                        transmit_type_parameter & PDO_RTR_SYNC_READY)
                        /*Data ready, just send */
                                 &d->PDO_status[numPdo].last_message);
                        return 0;
                    else
                        /* if SYNC did never occur, transmit current data */
                        /* DS301 do not tell what to do in such a case... */
                        MSG_ERR (0x1947,
                                 "Not ready RTR_SYNC TPDO send current data : ",
                        status = state5;
                    break;
                else if ((*pTransmissionType == TRANS_EVENT_PROFILE) ||
                         (*pTransmissionType == TRANS_EVENT_SPECIFIC))
                    /* Zap all timers and inhibit flag */
                    d->PDO_status[numPdo].event_timer =
                      DelAlarm (d->PDO_status[numPdo].event_timer);
                    d->PDO_status[numPdo].inhibit_timer =
                      DelAlarm (d->PDO_status[numPdo].inhibit_timer);
                    d->PDO_status[numPdo].transmit_type_parameter &=
                      ~PDO_INHIBITED;
                    /* Call  PDOEventTimerAlarm for this TPDO,
                     * this will trigger emission et reset timers */
                    PDOEventTimerAlarm (d, numPdo);
                    return 0;
                else
                    /* The requested PDO is not to send on request. So, does
                       nothing. */
                    MSG_WAR (0x2947, "PDO is not to send on request : ",
                    return 0xFF;
              case state5:     /* build and send requested PDO */
                  Message pdo;
                  if (buildPDO (d, numPdo, &pdo))
                      MSG_ERR (0x1948, " Couldn't build TPDO number : ", numPdo);
                      return 0xFF;
                  return 0;
          }                     /* end while */
    }                           /* end if Requete */
  return 0;
** @param NbBits
** @param SrcByteIndex
** @param SrcBitIndex
** @param SrcBigEndian
** @param DestByteIndex
** @param DestBitIndex
** @param DestBigEndian
void
CopyBits (UNS8 NbBits, UNS8 * SrcByteIndex, UNS8 SrcBitIndex,
          UNS8 SrcBigEndian, UNS8 * DestByteIndex, UNS8 DestBitIndex,
          UNS8 DestBigEndian)
  /* This loop copy as many bits that it can each time, crossing */
  /* successively bytes */
  // boundaries from LSB to MSB.
  while (NbBits > 0)
      /* Bit missalignement between src and dest */
      INTEGER8 Vect = DestBitIndex - SrcBitIndex;
      /* We can now get src and align it to dest */
      UNS8 Aligned =
        Vect > 0 ? *SrcByteIndex << Vect : *SrcByteIndex >> -Vect;
      /* Compute the nb of bit we will be able to copy */
      UNS8 BoudaryLimit = (Vect > 0 ? 8 - DestBitIndex : 8 - SrcBitIndex);
      UNS8 BitsToCopy = BoudaryLimit > NbBits ? NbBits : BoudaryLimit;
      /* Create a mask that will serve in: */
      UNS8 Mask =
        ((0xff << (DestBitIndex + BitsToCopy)) |
         (0xff >> (8 - DestBitIndex)));
      /* - Filtering src */
      UNS8 Filtered = Aligned & ~Mask;
      /* - and erase bits where we write, preserve where we don't */
      *DestByteIndex &= Mask;
      /* Then write. */
      *DestByteIndex |= Filtered;
      /*Compute next time cursors for src */
      if ((SrcBitIndex += BitsToCopy) > 7)      /* cross boundary ? */
          SrcBitIndex = 0;      /* First bit */
          SrcByteIndex += (SrcBigEndian ? -1 : 1);      /* Next byte */
      /*Compute next time cursors for dest */
      if ((DestBitIndex += BitsToCopy) > 7)
          DestBitIndex = 0;     /* First bit */
          DestByteIndex += (DestBigEndian ? -1 : 1);    /* Next byte */
      /*And decrement counter. */
      NbBits -= BitsToCopy;
void sendPdo(CO_Data * d, UNS32 pdoNum, Message * pdo)
  /*store_as_last_message */
  d->PDO_status[pdoNum].last_message = *pdo;
  MSG_WAR (0x396D, "sendPDO cobId :", UNS16_LE(pdo->cob_id));
  MSG_WAR (0x396E, "     Nb octets  : ", pdo->len);
  canSend (d->canHandle, pdo);
** @param d
** @return
UNS8
sendPDOevent (CO_Data * d)
  /* Calls _sendPDOevent specifying it is not a sync event */
  return _sendPDOevent (d, 0);
UNS8
sendOnePDOevent (CO_Data * d, UNS8 pdoNum)
  Message pdo;
  if (!d->CurrentCommunicationState.csPDO ||
      (d->PDO_status[pdoNum].transmit_type_parameter & PDO_INHIBITED))
      return 0;
  offsetObjdict = (UNS16) (d->firstIndex->PDO_TRS + pdoNum);
  MSG_WAR (0x3968, "  PDO is on EVENT. Trans type : ",
           *((UNS8 *) d->objdict[offsetObjdict].pSubindex[2].pObject));
  memset(&pdo, 0, sizeof(pdo));
  if (buildPDO (d, pdoNum, &pdo))
      MSG_ERR (0x3907, " Couldn't build TPDO number : ",
               pdoNum);
      return 0;
  /*Compare new and old PDO */
  if (d->PDO_status[pdoNum].last_message.cob_id == pdo.cob_id
      && d->PDO_status[pdoNum].last_message.len == pdo.len
      && memcmp(d->PDO_status[pdoNum].last_message.data,
                                        pdo.data, 8) == 0
      /* No changes -> go to next pdo */
      return 0;
  else
      TIMEVAL EventTimerDuration;
      TIMEVAL InhibitTimerDuration;
      MSG_WAR (0x306A, "Changes TPDO number : ", pdoNum);
      /* Changes detected -> transmit message */
        *(UNS16 *) d->objdict[offsetObjdict].pSubindex[5].
        pObject;
      InhibitTimerDuration =
        *(UNS16 *) d->objdict[offsetObjdict].pSubindex[3].
        pObject;
      /* Start both event_timer and inhibit_timer */
      if (EventTimerDuration)
          DelAlarm (d->PDO_status[pdoNum].event_timer);
          d->PDO_status[pdoNum].event_timer =
            SetAlarm (d, pdoNum, &PDOEventTimerAlarm,
      if (InhibitTimerDuration)
          DelAlarm (d->PDO_status[pdoNum].inhibit_timer);
          d->PDO_status[pdoNum].inhibit_timer =
            SetAlarm (d, pdoNum, &PDOInhibitTimerAlarm,
                      US_TO_TIMEVAL (InhibitTimerDuration *
                                     100), 0);
          /* and inhibit TPDO */
          d->PDO_status[pdoNum].transmit_type_parameter |=
            PDO_INHIBITED;
      sendPdo(d, pdoNum, &pdo);
    return 1;
void
PDOEventTimerAlarm (CO_Data * d, UNS32 pdoNum)
  /* This is needed to avoid deletion of re-attribuated timer */
  d->PDO_status[pdoNum].event_timer = TIMER_NONE;
  /* force emission of PDO by artificially changing last emitted */
  d->PDO_status[pdoNum].last_message.cob_id = 0;
  sendOnePDOevent (d, (UNS8) pdoNum);
void
PDOInhibitTimerAlarm (CO_Data * d, UNS32 pdoNum)
  d->PDO_status[pdoNum].inhibit_timer = TIMER_NONE;
  /* Remove inhibit flag */
  d->PDO_status[pdoNum].transmit_type_parameter &= ~PDO_INHIBITED;
void
_RxPDO_EventTimers_Handler(CO_Data *d, UNS32 pdoNum)
wangjiahao88|  楼主 | 2018-8-23 13:51 | 只看该作者
** @param d
** @param isSyncEvent
** @return
UNS8 _sendPDOevent (CO_Data * d, UNS8 isSyncEvent)
  UNS8 pdoNum = 0x00;           /* number of the actual processed pdo-nr. */
  UNS8 status = state3;
  UNS16 offsetObjdict = d->firstIndex->PDO_TRS;
  UNS16 offsetObjdictMap = d->firstIndex->PDO_TRS_MAP;
  UNS16 lastIndex = d->lastIndex->PDO_TRS;
      return 0;
/* study all PDO stored in the objects dictionary */
  if (offsetObjdict)
      Message pdo;/* = Message_Initializer;*/
          switch (status)
            case state3:
              if ( /* bSubCount always 5 with objdictedit -> check disabled */
                   /*d->objdict[offsetObjdict].bSubCount < 5 ||*/
                   /* check if TPDO is not valid */
                   *(UNS32 *) d->objdict[offsetObjdict].pSubindex[1].
                   pObject & 0x80000000)
                  MSG_WAR (0x3960, "Not a valid PDO ", 0x1800 + pdoNum);
                  /*Go next TPDO */
                  status = state11;
                  break;
              /* get the PDO transmission type */
              pTransmissionType =
              MSG_WAR (0x3962, "Reading PDO at index : ", 0x1800 + pdoNum);
              /* check if transmission type is SYNCRONOUS */
              /* message transmited every n SYNC with n=TransmissionType */
              if (isSyncEvent &&
                  (*pTransmissionType >= TRANS_SYNC_MIN) &&
                  (*pTransmissionType <= TRANS_SYNC_MAX) &&
                  (++d->PDO_status[pdoNum].transmit_type_parameter ==
                   *pTransmissionType))
                  /*Reset count of SYNC */
                  d->PDO_status[pdoNum].transmit_type_parameter = 0;
                  MSG_WAR (0x3964, "  PDO is on SYNCHRO. Trans type : ",
                           *pTransmissionType);
                    Message msg_init = Message_Initializer;
                    pdo = msg_init;
                      MSG_ERR (0x1906, " Couldn't build TPDO number : ",
                               pdoNum);
                      status = state11;
                      break;
                  status = state5;
                  /* If transmission RTR, with data sampled on SYNC */
              else if (isSyncEvent && (*pTransmissionType == TRANS_RTR_SYNC))
                  if (buildPDO
                      (d, pdoNum, &d->PDO_status[pdoNum].last_message))
                      MSG_ERR (0x1966, " Couldn't build TPDO number : ",
                               pdoNum);
                        ~PDO_RTR_SYNC_READY;
                  else
                        PDO_RTR_SYNC_READY;
                  status = state11;
                  break;
                  /* If transmission on Event and not inhibited, check for changes */
              else
                if ( (isSyncEvent && (*pTransmissionType == TRANS_SYNC_ACYCLIC))
                     (!isSyncEvent && (*pTransmissionType == TRANS_EVENT_PROFILE || *pTransmissionType == TRANS_EVENT_SPECIFIC)
                       && !(d->PDO_status[pdoNum].transmit_type_parameter & PDO_INHIBITED)))
                  sendOnePDOevent(d, pdoNum);
                  status = state11;
              else
                  MSG_WAR (0x306C,
                           "  PDO is not on EVENT or synchro or not at this SYNC. Trans type : ",
                  status = state11;
              break;
            case state5:       /*Send the pdo */
              status = state11;
              break;
            case state11:      /*Go to next TPDO */
              pdoNum++;
              offsetObjdict++;
              offsetObjdictMap++;
              MSG_WAR (0x3970, "next pdo index : ", pdoNum);
              status = state3;
              break;
            default:
              MSG_ERR (0x1972, "Unknown state has been reached :", status);
              return 0xFF;
            }                   /* end switch case */
        }                       /* end while */
  return 0;
** @param d
** @param OD_entry
** @param bSubindex
** @return always 0
UNS32 TPDO_Communication_Parameter_Callback (CO_Data * d,
                                       const indextable * OD_entry,
                                       UNS8 bSubindex)
  /* If PDO are actives */
  if (d->CurrentCommunicationState.csPDO)
    switch (bSubindex)
      case 2:                  /* Changed transmition type */
      case 3:                  /* Changed inhibit time */
      case 5:                  /* Changed event time */
          const indextable *TPDO_com = d->objdict + d->firstIndex->PDO_TRS;
          UNS8 numPdo = (UNS8) (OD_entry - TPDO_com);    /* number of the actual processed pdo-nr. */
          d->PDO_status[numPdo].transmit_type_parameter = 0;
          /* Call  PDOEventTimerAlarm for this TPDO, this will trigger emission et reset timers */
          return 0;
      default:                 /* other subindex are ignored */
        break;
  return 0;
wangjiahao88|  楼主 | 2018-8-23 13:52 | 只看该作者
void PDOInit (CO_Data * d)
  /* For each TPDO mapping parameters */
  UNS16 pdoIndex = 0x1800;      /* OD index of TDPO */
  if (offsetObjdict)
        /* Assign callbacks to sensible TPDO mapping subindexes */
        UNS32 errorCode;
        ODCallback_t *CallbackList;
        /* Find callback list */
        scanIndexOD (d, pdoIndex, &errorCode, &CallbackList);
        if (errorCode == OD_SUCCESSFUL && CallbackList)
            /*Assign callbacks to corresponding subindex */
            /* Transmission type */
            CallbackList[2] = &TPDO_Communication_Parameter_Callback;
            /* Inhibit time */
            CallbackList[3] = &TPDO_Communication_Parameter_Callback;
            /* Event timer */
            CallbackList[5] = &TPDO_Communication_Parameter_Callback;
        pdoIndex++;
        offsetObjdict++;
  /* Trigger a non-sync event */
void
PDOStop (CO_Data * d)
  if (offsetObjdict)
        /* Delete TPDO timers */
        /* Reset transmit type parameter */
        pdoNum++;
        offsetObjdict++;
   Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
wangjiahao88|  楼主 | 2018-8-23 13:53 | 只看该作者
** @file   sdo.c
** @brief
/* #define DEBUG_WAR_CONSOLE_ON */
/* #define DEBUG_ERR_CONSOLE_ON */
#include <stdlib.h>
#include "sysdep.h"
/* Uncomment if your compiler does not support inline functions */
#define NO_INLINE
#ifdef NO_INLINE
#define INLINE
#else
#define INLINE inline
#endif
/*Internals prototypes*/
UNS8 GetSDOClientFromNodeId( CO_Data* d, UNS8 nodeId );
** Called by writeNetworkDict
** @param d
** @param nodeId
** @param index
** @param subIndex
** @param count
** @param dataType
** @param data
** @param Callback
** @param endianize
** @return
INLINE UNS8 _writeNetworkDict (CO_Data* d, UNS8 nodeId, UNS16 index,
                UNS8 subIndex, UNS32 count, UNS8 dataType, void *data, SDOCallback_t Callback, UNS8 endianize, UNS8 useBlockMode);
** Called by readNetworkDict
** @param d
** @param nodeId
** @param index
** @param subIndex
** @param dataType
** @param Callback
** @return
INLINE UNS8 _readNetworkDict (CO_Data* d, UNS8 nodeId, UNS16 index, UNS8 subIndex,
                UNS8 dataType, SDOCallback_t Callback, UNS8 useBlockMode);
/* SDO (un)packing macros */
/** Returns the command specifier (cs, ccs, scs) from the first byte of the SDO
#define getSDOcs(byte) (byte >> 5)
/** Returns the number of bytes without data from the first byte of the SDO. Coded in 2 bits
#define getSDOn2(byte) ((byte >> 2) & 3)
/** Returns the number of bytes without data from the first byte of the SDO. Coded in 3 bits
#define getSDOn3(byte) ((byte >> 1) & 7)
/** Returns the transfer type from the first byte of the SDO
#define getSDOe(byte) ((byte >> 1) & 1)
/** Returns the size indicator from the first byte of the SDO
#define getSDOs(byte) (byte & 1)
/** Returns the indicator of end transmission from the first byte of the SDO
#define getSDOc(byte) (byte & 1)
/** Returns the toggle from the first byte of the SDO
#define getSDOt(byte) ((byte >> 4) & 1)
/** Returns the index from the bytes 1 and 2 of the SDO
#define getSDOindex(byte1, byte2) (((UNS16)byte2 << 8) | ((UNS16)byte1))
/** Returns the subIndex from the byte 3 of the SDO
#define getSDOsubIndex(byte3) (byte3)
/** Returns the subcommand in SDO block transfer
#define getSDOblockSC(byte) (byte & 3)
** @param d
** @param id
void SDOTimeoutAlarm(CO_Data* d, UNS32 id)
        UNS16 offset;
        UNS8 nodeId;
        /* Get the client->server cobid.*/
        offset = d->firstIndex->SDO_CLT;
        if ((offset == 0) || ((offset+d->transfers[id].CliServNbr) > d->lastIndex->SDO_CLT)) {
                return ;
        nodeId = (UNS8) *((UNS32*) d->objdict[offset+d->transfers[id].CliServNbr].pSubindex[3].pObject);
        MSG_ERR(0x1A01, "SDO timeout. SDO response not received.", 0);
        MSG_WAR(0x2A02, "server node id : ", nodeId);
        MSG_WAR(0x2A02, "         index : ", d->transfers[id].index);
        MSG_WAR(0x2A02, "      subIndex : ", d->transfers[id].subIndex);
        /* Reset timer handler */
        d->transfers[id].timer = TIMER_NONE;
        /*Set aborted state*/
        d->transfers[id].state = SDO_ABORTED_INTERNAL;
        /* Sending a SDO abort */
        sendSDOabort(d, d->transfers[id].whoami, d->transfers[id].CliServNbr,
                        d->transfers[id].index, d->transfers[id].subIndex, SDOABT_TIMED_OUT);
        d->transfers[id].abortCode = SDOABT_TIMED_OUT;
        /* Call the user function to inform of the problem.*/
        if(d->transfers[id].Callback)
                /*If ther is a callback, it is responsible to close SDO transfer (client)*/
                (*d->transfers[id].Callback)(d, nodeId);
        /*Reset the line if (whoami == SDO_SERVER) or the callback did not close the line.
          Otherwise this sdo transfer would never be closed. */
        if(d->transfers[id].abortCode == SDOABT_TIMED_OUT)
                resetSDOline(d, (UNS8)id);
#define StopSDO_TIMER(id) \
        MSG_WAR(0x3A05, "StopSDO_TIMER for line : ", line);\
d->transfers[id].timer = DelAlarm(d->transfers[id].timer);
#define StartSDO_TIMER(id) \
        MSG_WAR(0x3A06, "StartSDO_TIMER for line : ", line);\
d->transfers[id].timer = SetAlarm(d,id,&SDOTimeoutAlarm,MS_TO_TIMEVAL(SDO_TIMEOUT_MS),0);
#define RestartSDO_TIMER(id) \
        MSG_WAR(0x3A07, "restartSDO_TIMER for line : ", line);\
if(d->transfers[id].timer != TIMER_NONE) { StopSDO_TIMER(id) StartSDO_TIMER(id) }
** Reset all sdo buffers
** @param d
void resetSDO (CO_Data* d)
        UNS8 j;
        /* transfer structure initialization */
        for (j = 0 ; j < SDO_MAX_SIMULTANEOUS_TRANSFERS ; j++)
                resetSDOline(d, j);
** @param d
** @param line
** @return
UNS32 SDOlineToObjdict (CO_Data* d, UNS8 line)
        UNS32 size;
        UNS32 errorCode;
        MSG_WAR(0x3A08, "Enter in SDOlineToObjdict ", line);
        /* if SDO initiated with e=0 and s=0 count is null, offset carry effective size*/
        if( d->transfers[line].count == 0)
                d->transfers[line].count = d->transfers[line].offset;
        size = d->transfers[line].count;
#ifdef SDO_DYNAMIC_BUFFER_ALLOCATION
        if (size > SDO_MAX_LENGTH_TRANSFER)
                errorCode = setODentry(d, d->transfers[line].index, d->transfers[line].subIndex,
                                (void *) d->transfers[line].dynamicData, &size, 1);
        else
                                (void *) d->transfers[line].data, &size, 1);
#else //SDO_DYNAMIC_BUFFER_ALLOCATION
#endif //SDO_DYNAMIC_BUFFER_ALLOCATION
        if (errorCode != OD_SUCCESSFUL)
                return errorCode;
        MSG_WAR(0x3A08, "exit of SDOlineToObjdict ", line);
        return 0;
labasi| | 2018-9-7 10:22 | 只看该作者
非常感谢楼主分享
xiaoqizi| | 2018-9-7 12:10 | 只看该作者
非常感谢楼主分享
wangjiahao88|  楼主 | 2018-9-7 14:00 | 只看该作者
希望大家 一起探讨吧1
twodiamond| | 2019-11-21 19:54 | 只看该作者
楼主资深
topstarhy| | 2020-1-15 16:11 | 只看该作者
这不是CANfestival协议栈的程序吗,我不知道你分享了什么
wangjiahao88|  楼主 | 2020-1-19 11:30 | 只看该作者
我不知的啊!我以为是他们自己写的!感觉很有参考价值!拿出来给大家分享一下!
星际孤帆| | 2021-4-12 13:24 | 只看该作者
就是,把协议栈的程序包搬过来,不知道它要表达什么,而且搬也不搬完整
