[技术问答]
同样的代码,UART0可用,UART5不能用,什么原因
1253|7
以下代码,我测试,NU131,UART0正常使用,UART5不能使用,原因是什么,谁有个准确答案
int main()
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
    /* Waiting for Internal RC clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk));
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLK_S_Msk)) | CLK_CLKSEL0_HCLK_S_HIRC;
    CLK->CLKDIV = (CLK->CLKDIV & (~CLK_CLKDIV_HCLK_N_Msk)) | CLK_CLKDIV_HCLK(1);
    /* Set PLL to Power-down mode */
    CLK->PLLCON |= CLK_PLLCON_PD_Msk;
    /* Enable external XTAL 12MHz clock */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
    /* Waiting for external XTAL clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK->PLLCON = PLLCON_SETTING;
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_PLL_STB_Msk));
    CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLK_S_Msk)) | CLK_CLKSEL0_HCLK_S_PLL;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Enable UART module clock */
    CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk;
    CLK->APBCLK1 |= CLK_APBCLK1_UART5_EN_Msk;
    /* Select UART module clock source */
    CLK->CLKSEL1 = (CLK->CLKSEL1 & (~CLK_CLKSEL1_UART_S_Msk)) | CLK_CLKSEL1_UART_S_HXT;
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
                /* Set GPA multi-function pins for UART5 RXD and TXD */
    SYS->GPA_MFP &= ~(SYS_GPA_MFP_PA0_Msk | SYS_GPA_MFP_PA1_Msk);
    SYS->GPA_MFP |= SYS_GPA_MFP_PA0_UART5_TXD | SYS_GPA_MFP_PA1_UART5_RXD;
    /* Init UART        */
    /* Reset UART0 */
    SYS->IPRSTC2 |=  SYS_IPRSTC2_UART0_RST_Msk;
    SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART0_RST_Msk;
    /* Configure UART0 and set UART0 Baudrate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 9600);
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
    /* Reset UART5 */
    SYS->IPRSTC2 |=  SYS_IPRSTC3_UART5_RST_Msk;
    SYS->IPRSTC2 &= ~SYS_IPRSTC3_UART5_RST_Msk;
    /* Configure UART5 and set UART5 Baudrate */
    UART5->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 9600);
    UART5->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
void SendChar_ToUART5()
                char pu8TxBuf[6] = "abcde\n";
    uint32_t  u32Count, u32delayno;
    for(u32Count = 0; u32Count != 6; u32Count++)
        u32delayno = 0;
        while((UART5->FSR & UART_FSR_TE_FLAG_Msk) == 0)   /* Wait Tx empty and Time-out manner */
            u32delayno++;
            if(u32delayno >= 0x40000000)
                return;
        UART5->THR = pu8TxBuf[u32Count];    /* Send UART Data from buffer */
zhuomuniao110| | 2018-8-24 21:26 | 只看该作者
哪个芯片的?是不是串口5支持的模式没有串口0多。
ansicheng|  楼主 | 2018-8-24 23:05 | 只看该作者
NU131
xyz549040622| | 2018-8-25 10:58 | 只看该作者
没有搞过这个芯片,仔细对比两个串口的不同。
IoTCatcher| | 2018-8-25 15:24 | 只看该作者
/* Reset UART5 */
看左右两边的IPRSTC, 左边2右边3,
/* Reset UART5 */
    SYS->IPRSTC3 |=  SYS_IPRSTC3_UART5_RST_Msk;
    SYS->IPRSTC3 &= ~SYS_IPRSTC3_UART5_RST_Msk;
楼主以后碰到这种问题可以, 全局查找 "UART5", 然后再各个文件看看, 基本配置上的问题就可以解决.
yediezeus| | 2018-8-27 13:54 | 只看该作者
ansicheng|  楼主 | 2018-9-4 11:14 | 只看该作者
IoTCatcher 发表于 2018-8-25 15:24
/* Reset UART5 */
    SYS->IPRSTC2 &= ~SYS_IPRSTC3_ ...
细节问题发现了,确实是
xuanhuanzi| | 2018-9-4 16:01 | 只看该作者
两个配置不同?
