本程序实现按键点亮助学板上的led小灯,按一下点亮一个led,以此类推下面上代码:
main函数- /*---------------------------------------------------------------------------------------------------------*/
- /* Copyright(c) 2011 Nuvoton Technology Corp. All rights reserved. */
- #include "includes.h" //包含所需的头文件
- ** Function name: main
- ** Descriptions: 每按下一次键 小灯就点亮一个 第五下全部熄灭
- ** input parameters: 无
- ** output parameters: 无
- ** Returned value: 无
- int main (void)
- uint8_t flag = 0;
- uint8_t count = 0;
- Set_System(); //封装一些初始化模块
- while(1)
- if (DrvGPIO_GetBit(E_GPB,14) == 0) // 键按下检测
- delay_ms(30);
- flag = 1;
- if(flag)
- if (DrvGPIO_GetBit(E_GPB,14) == 1) //键释放检测
- flag = 0;
- count++;
- if(count>=6) count =1;
- switch(count)
- case 1: DrvGPIO_ClrBit(E_GPA,2); break;
- case 2: DrvGPIO_ClrBit(E_GPA,3); break;
- case 3: DrvGPIO_ClrBit(E_GPA,4); break;
- case 4: DrvGPIO_ClrBit(E_GPA,5); break;
- case 5:
- DrvGPIO_SetBit(E_GPA,2);
- DrvGPIO_SetBit(E_GPA,3);
- DrvGPIO_SetBit(E_GPA,4);
- DrvGPIO_SetBit(E_GPA,5);
- break;
- default:break;
hw_config.c函数- #include "includes.h" //包含所需的头文件
- ** Function name: Set_System
- ** Descriptions: 封装一些初始化模块
- ** input parameters: count
- void Set_System(void)
- RCC_Configuration(); //配置系统时钟
- GPIO_Configuration(); //配置GPIO
- ** Function name: RCC_Configuration
- ** Descriptions: 系统时钟源设置
- ** input parameters: none
- ** output parameters: none
- ** Returned value: none
- void RCC_Configuration(void)
- UNLOCKREG(); // 对写保护位操作时 需要一次向0x50000 0100写入 0x59,0x16,0x88,
- DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1);//与其 SYSCLK->PWRCON.XTL12M_EN = 1; 等同
- // PWRCON寄存器(这些寄存器在上电复位到用户解锁定之前是锁定的)除了 BIT[6]位其他位都受写保护
- // 解除这些需要向 0x50000 0100写入 0x59,0x16,0x88,
- // 令PWRCON寄存器的BITP[0]为1(即设定12M外部晶振)
- delay_ms(100); //while (DrvSYS_GetChipClockSourceStatus(E_SYS_XTL12M) != 1);//等待外部12MHZ晶振就绪
- LOCKREG(); // 向“0x5000_0100”写入任何值,就可以重锁保护寄存器
- ** Function name: GPIO_Configuration
- ** Descriptions: GPIO配置
- void GPIO_Configuration()
- DrvGPIO_Open( E_GPA, 2, E_IO_OUTPUT ); //led端口设置为输出
- DrvGPIO_Open( E_GPA, 3, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 4, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 5, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 14, E_IO_INPUT ); //按键端口设置为输入
- DrvGPIO_Open( E_GPB, 15, E_IO_INPUT );
- ** Function name: delay_ms
- ** Descriptions: 1ms(晶振为12MHZ)延时子程序
- void delay_ms(uint32_t count)
- uint32_t i,j;
- for(i=count;i>0;i--)
- for(j=2395;j>0;j--);
hw_config.h头文件- void Set_System(void);
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void delay_ms(uint32_t count);
includes.h头文件
- #include <stdio.h>
- #include "NUC1xx.h"
- #include "variables.h"
- #include "hw_config.h"
- #include "Driver\DrvSYS.h"
- #include "Driver\DrvGPIO.h"
工程
