12864不带字库显示问题
1841|4
 楼主| 123294382 发表于 2018-9-13 16:30 | 显示全部楼层 |阅读模式
我的显示为什么不正常,错在了哪里啊?程序如下
#include <reg52.h>
#include <string.h>
#include "zf.h"
#include "io.h"
#define  uchar  unsigned char
#define  uint   unsigned int
uchar ye=0,lie=0;
#define DB P0
#define chr_width 7
#define chn_width 15
unsigned char disp_no;
unsigned char position,which;
/*****************************延时*************************/
void delay(uint i)
  while(--i);
/****************12864液晶写数据命令地址函数*****************/
void writedacm(uchar dat,uchar log)        //写数据 RS=1数据,RS=0命令
        delay(8);
        RW = 0;
        if(log)         RS=1;
        else     RS=0;
        E = 1;
        DB = dat;
        E = 0;
/************************页列设置*************************/
void set_YL( uchar y, uchar x)  //ye -> 0 : 7 页 lie -> 0 :63 列
   y= y&0x07|0xb8;
   writedacm(y,0);
   x= x&0x3f|0x40;
   writedacm(x,0);
/*************************12864液晶屏幕选择函数************/
void setPM(uchar PX) //选择屏幕( 0-左屏,1-右屏,2-全屏  )
   switch(PX){
    case 0 :        CS1 = 0;        CS2 = 1;   break;
    case 1 :        CS1 = 1;    CS2 = 0;   break;
    case 2 :    CS1 = 0;    CS2 = 0;
/******************左右屏设置*************************/
void chear()  //清屏(0-清左屏1-清右屏,2-清全屏 ),
{    uchar i,j;
         setPM(2);
         for(i = 0;i <8;i++)
         { set_YL(i,0);
           for(j = 0;j <64 ; j++)
           writedacm(0x00,1);
void SetOnOff(uchar onoff) //1-开显示 0-关
if(onoff == 1){ setPM(2); writedacm(0x3f,0);}
if(onoff == 0){ setPM(2); writedacm(0x3e,0);}
/******************** 12864液晶复位函数******************/
void init_lcd()
        Reset = 0; delay(2);
    Reset = 1; delay(2);
    chear();           //清屏
    SetOnOff(1) ;
        delay(100);
        CS1=1;               //刚开始关闭两屏
        CS2=1;
        delay(100);
        writedacm(0x3e,0);         //显示关
        writedacm(0xb8,0);         //定义Y坐标
        writedacm(0xC0,0);
        writedacm(0x40,0);   //设定X坐标
        writedacm(0x3f,0);   //显示开
void DrawBmp(uchar x0,bit layer,uchar width,uchar *bmp)
        uchar x,i=0,j=16; //RAMadr表示显存的物理地址
        uchar page=0;
        delay(10);
        if (layer) page=2;
        delay(10);
        for (x=x0;x<(x0+width);x++)
            delay(10);
                setPM(0);//显示左半屏
            writedacm(0xb8,0);//从第一行开始显示
                writedacm(bmp,1);//写第一行字上半部分
                i=i+1;
                delay(10);
                setPM(0);
                writedacm(0xb8+1,0);//从第一行开始显示
                writedacm(bmp[j],1);//写第一行字下半部分
                j=j+1;
#define welcome_hanzi 6
void disp_welcome(void)
        unsigned char cyc_counter;
        delay(10);
        for(cyc_counter=0; cyc_counter<6; cyc_counter++)
                delay(10);
                DrawBmp(16+cyc_counter*chn_width,0,chn_width,chn_font+(cyc_counter+welcome_hanzi)*chn_width*2);
        delay(10);
disp_no = 0x00;
/**********************主函数*****************************/
main()
            init_lcd();
                chear();
                disp_welcome();
                while(1);
/*******************下面是字库摸******************************/
//汉字用的字号是五号字
unsigned char code chn_font[]={
无(0)  池(1)  流(2)  压(3)  容(4)  量(5)
新(6)  乡(7)  安(8)  科(9)  电(10) 子(11)  ----这里的6个汉字必须是连续的,给显示公司用
型(12) 号(13) 异(14) 充(15) 放(16) 次(17)
数(18) 生(19) 产(20) 额(21) 定(22) 编(23)
常(24) 满(25) 低(26) 温(27) 度(28) 非(29)
字(30) 日(31) 期(32) 镉(33) 镍(34) 锂(35)
/*--  文字:  无0  --*/
/*--  宋体11;  此字体下对应的点阵为:宽x高=15x15   --*/
/*--  高度不是8的倍数,现调整为:宽度x高度=15x16  --*/
0x00,0x22,0x22,0x22,0x22,0x22,0xFE,0x22,0xE2,0x22,0x22,0x23,0x32,0x20,0x00,0x00,
0x20,0x20,0x10,0x08,0x06,0x01,0x00,0x1F,0x20,0x20,0x20,0x20,0x3C,0x00,
/*--  文字:  池1  --*/
0x10,0x61,0x86,0x60,0x40,0xFC,0x20,0x20,0xFF,0x10,0x10,0xF8,0x10,0x00,0x00,0x02,
0x3E,0x01,0x00,0x00,0x1F,0x20,0x20,0x27,0x20,0x22,0x23,0x20,0x38,0x00,
/*--  文字:  流2  --*/
0x10,0x61,0x02,0xC6,0x00,0xA4,0x34,0x2D,0xA6,0x24,0xA4,0x34,0x66,0x04,0x00,0x04,
0x3C,0x03,0x20,0x10,0x0F,0x00,0x00,0x3F,0x00,0x1F,0x20,0x20,0x38,0x00,
/*--  文字:  压3  --*/
0x00,0x00,0xFE,0x02,0x42,0x42,0x42,0xFA,0x42,0x42,0x42,0x42,0x03,0x02,0x00,0x20,
0x18,0x07,0x10,0x10,0x10,0x10,0x1F,0x10,0x10,0x11,0x16,0x10,0x10,0x00,
/*--  文字:  容4  --*/
0x10,0x4C,0x44,0x24,0x94,0x44,0x25,0x26,0x44,0x84,0x14,0x24,0x4C,0x04,0x00,0x04,
0x04,0x02,0x01,0x3E,0x22,0x22,0x22,0x22,0x22,0x3F,0x01,0x02,0x02,0x00,
/*--  文字:  量5  --*/
0x00,0x20,0x20,0xBE,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xBF,0x22,0x20,0x00,0x00,
0x20,0x28,0x2F,0x2A,0x2A,0x2A,0x3F,0x2A,0x2A,0x2A,0x2F,0x28,0x20,0x00,
/*--  文字:  新6  --*/
0x20,0x24,0x2C,0x35,0xE6,0x34,0x2C,0x00,0xFE,0x24,0x24,0xE2,0x33,0x22,0x00,0x10,
0x09,0x15,0x21,0x1F,0x05,0x29,0x10,0x0F,0x00,0x00,0x3F,0x00,0x00,0x00,
/*--  文字:  乡7  --*/
0x00,0x00,0x00,0x10,0x18,0x94,0x52,0x31,0x10,0x08,0x04,0xC0,0x00,0x00,0x00,0x00,
0x20,0x20,0x21,0x21,0x11,0x11,0x09,0x05,0x03,0x01,0x00,0x00,0x00,0x00,
/*--  文字:  安8  --*/
0x40,0x50,0x4C,0x44,0x44,0xC4,0x75,0x46,0x44,0xC4,0x44,0x54,0x4C,0x40,0x00,0x00,
0x20,0x20,0x20,0x13,0x12,0x0C,0x04,0x06,0x09,0x08,0x10,0x30,0x00,0x00,
/*--  文字:  科9  --*/
0x14,0x14,0x94,0xFE,0x93,0x12,0x00,0x20,0xC4,0x18,0x00,0xFF,0x00,0x00,0x00,0x04,
0x03,0x00,0x3F,0x00,0x01,0x02,0x02,0x02,0x02,0x02,0x3F,0x01,0x01,0x00,
/*--  文字:  电10  --*/
0x00,0x00,0xF8,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xFC,0x08,0x00,0x00,0x00,
0x00,0x07,0x02,0x02,0x02,0x1F,0x22,0x22,0x22,0x22,0x23,0x20,0x38,0x00,
/*--  文字:  子11  --*/
0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xF2,0x52,0x4A,0x46,0x43,0x62,0x40,0x00,0x00,
0x00,0x00,0x00,0x00,0x10,0x20,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  型12  --*/
0x00,0x12,0x92,0x7E,0x12,0x12,0xFE,0x12,0x00,0x7E,0x80,0x00,0xFF,0x00,0x00,0x00,
0x21,0x24,0x24,0x24,0x24,0x25,0x3E,0x24,0x24,0x24,0x25,0x30,0x20,0x00,
/*--  文字:  号13  --*/
0x40,0x40,0x40,0x5E,0xD2,0x52,0x52,0x52,0x52,0x52,0x5F,0x42,0x40,0x40,0x00,0x00,
0x00,0x00,0x02,0x03,0x01,0x11,0x21,0x21,0x11,0x0F,0x00,0x00,0x00,0x00,
/*--  文字:  异14  --*/
0x00,0x00,0x00,0x3E,0xD2,0x52,0x52,0x52,0x52,0xD2,0x5F,0x42,0x70,0x00,0x00,0x22,
0x22,0x12,0x0A,0x07,0x02,0x02,0x02,0x02,0x3F,0x02,0x02,0x02,0x02,0x00,
/*--  文字:  充15  --*/
0x00,0x04,0x44,0x44,0x64,0xD4,0x4D,0x46,0xC4,0x54,0x64,0xC4,0x06,0x04,0x00,0x00,
0x20,0x10,0x08,0x04,0x03,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x38,0x00,
/*--  文字:  放16  --*/
0x08,0x08,0xF9,0x4E,0x48,0xC8,0x08,0x20,0xF8,0x0F,0x08,0xF8,0x0C,0x08,0x00,0x20,
0x18,0x07,0x10,0x10,0x0F,0x20,0x20,0x10,0x09,0x06,0x09,0x10,0x20,0x00,
/*--  文字:  次17  --*/
0x00,0x02,0x8C,0x60,0x98,0x40,0x30,0x0F,0xE8,0x08,0x08,0x28,0x18,0x00,0x00,0x01,
0x01,0x1F,0x20,0x20,0x10,0x0C,0x03,0x00,0x03,0x04,0x08,0x30,0x10,0x00,
/*--  文字:  数18  --*/
0x08,0x4A,0x2C,0x18,0xFF,0x2C,0x4A,0x28,0xF0,0x0F,0x08,0x88,0x7C,0x08,0x00,0x21,
0x21,0x15,0x17,0x09,0x0D,0x13,0x20,0x10,0x0B,0x04,0x0B,0x10,0x20,0x00,
/*--  文字:  生19  --*/
0x80,0x40,0x30,0x1E,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x18,0x10,0x00,0x00,0x20,
0x20,0x20,0x21,0x21,0x21,0x21,0x3F,0x21,0x21,0x21,0x21,0x30,0x20,0x00,
/*--  文字:  产20  --*/
0x00,0x04,0xC4,0x44,0x4C,0x74,0x45,0x46,0x64,0x5C,0x44,0x44,0x44,0x44,0x00,0x20,
0x18,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  额21  --*/
0x4C,0x24,0xBC,0x55,0x56,0xB4,0x0C,0xFA,0x0A,0x0E,0xEA,0x0A,0xFB,0x02,0x00,0x02,
0x01,0x3E,0x12,0x12,0x1E,0x21,0x27,0x10,0x08,0x07,0x08,0x17,0x20,0x00,
/*--  文字:  定22  --*/
0x00,0x10,0x2C,0xA4,0x24,0x24,0x25,0xE6,0x24,0x24,0x24,0x24,0x14,0x0C,0x00,0x20,
0x10,0x08,0x07,0x08,0x10,0x10,0x3F,0x22,0x22,0x22,0x22,0x20,0x20,0x00,
/*--  文字:  编23  --*/
0x20,0xB8,0x67,0x30,0x00,0xFC,0xD4,0x54,0xD5,0x56,0xD4,0x54,0xDC,0x00,0x00,0x09,
0x1B,0x09,0x25,0x18,0x07,0x3F,0x02,0x1F,0x02,0x1F,0x22,0x3F,0x00,0x00,
/*--  文字:  常24  --*/
0x20,0x18,0x08,0x0A,0xEC,0xA8,0xA8,0xAF,0xA8,0xA8,0xEC,0x0A,0x28,0x18,0x00,0x00,
0x00,0x00,0x1E,0x02,0x02,0x02,0x3F,0x02,0x02,0x12,0x1E,0x00,0x00,0x00,
/*--  文字:  满25  --*/
0x10,0x61,0x86,0x60,0xA4,0xA4,0xA4,0xEF,0xA4,0xE4,0xAF,0xA4,0xB6,0x24,0x00,0x02,
0x3E,0x01,0x00,0x3F,0x08,0x04,0x03,0x0A,0x07,0x12,0x24,0x1F,0x00,0x00,
/*--  文字:  低26  --*/
0x40,0x20,0xF8,0x07,0x00,0xFC,0x44,0x44,0x44,0xFC,0x42,0x43,0x62,0x40,0x00,0x00,
0x00,0x3F,0x00,0x00,0x1F,0x10,0x08,0x14,0x21,0x06,0x08,0x10,0x3C,0x00,
/*--  文字:  温27  --*/
0x10,0x61,0x86,0x60,0x00,0x7E,0x4A,0x4A,0x4A,0x4A,0x4A,0x7F,0x02,0x00,0x00,0x02,
0x3E,0x01,0x20,0x3F,0x21,0x21,0x3F,0x21,0x3F,0x21,0x21,0x3F,0x20,0x00,
/*--  文字:  度28  --*/
0x00,0x00,0xFC,0x04,0x14,0x14,0x7C,0x55,0x56,0x54,0x7C,0x14,0x16,0x04,0x00,0x20,
0x18,0x07,0x20,0x21,0x21,0x13,0x15,0x09,0x15,0x13,0x21,0x20,0x20,0x00,
/*--  文字:  非29  --*/
0x08,0x48,0x48,0x48,0x48,0xFF,0x00,0x00,0xFF,0x48,0x48,0x48,0x4C,0x08,0x00,0x04,
0x04,0x04,0x04,0x04,0x3F,0x00,0x00,0x3F,0x04,0x04,0x04,0x06,0x04,0x00,
/*--  文字:  字30  --*/
0x00,0x10,0x0C,0x14,0x14,0x14,0x15,0xD6,0x54,0x34,0x14,0x14,0x8C,0x00,0x00,0x01,
0x01,0x01,0x01,0x01,0x11,0x21,0x1F,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
/*--  文字:  日31  --*/
0x00,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xFF,0x02,0x00,0x00,0x00,
0x00,0x00,0x3F,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3F,0x00,0x00,0x00,
/*--  文字:  期32  --*/
0x00,0x04,0xFF,0x94,0x94,0xFF,0x04,0x00,0xFE,0x12,0x12,0x12,0xFF,0x02,0x00,0x22,
0x12,0x0B,0x06,0x02,0x07,0x2A,0x10,0x0F,0x01,0x11,0x21,0x1F,0x00,0x00,
/*--  文字:  镉33  --*/
0x60,0x38,0xE7,0x24,0x24,0x00,0x82,0xBA,0xAA,0xAA,0xAA,0xBA,0x83,0x02,0x00,0x01,
0x01,0x3F,0x11,0x09,0x01,0x3F,0x04,0x06,0x1C,0x06,0x24,0x3F,0x00,0x00,
/*--  文字:  镍34  --*/
0x60,0x38,0xE7,0x24,0x24,0x00,0xFE,0xAA,0xAB,0xAA,0xAA,0xFE,0x00,0x00,0x00,0x01,
0x01,0x1F,0x11,0x29,0x12,0x0A,0x06,0x02,0x3F,0x06,0x0A,0x12,0x22,0x00,
/*--  文字:  锂35  --*/
0x60,0x38,0xE7,0x24,0x24,0x00,0xFE,0x92,0x92,0xFE,0x92,0x92,0xFF,0x02,0x00,0x01,
0x01,0x3F,0x11,0x09,0x21,0x24,0x24,0x24,0x3F,0x24,0x24,0x24,0x20,0x00,
/*--  文字:  记36  --*/
0x20,0x20,0x21,0xE6,0x00,0x00,0xC4,0x44,0x44,0x44,0x44,0x44,0x7E,0x04,0x00,0x00,
0x00,0x00,0x1F,0x08,0x04,0x1F,0x20,0x20,0x20,0x20,0x20,0x20,0x3C,0x00,
/*--  文字:  录37  --*/
0x20,0x20,0xA2,0xAA,0x2A,0x2A,0x2A,0xEA,0x2A,0x2A,0x3F,0xA2,0x20,0x20,0x00,0x10,
0x10,0x08,0x08,0x05,0x12,0x22,0x1F,0x01,0x02,0x05,0x08,0x18,0x08,0x00
雪山飞狐D 发表于 2018-9-13 18:55 | 显示全部楼层
    画一个点的最小程序调通了没?
airwill 发表于 2018-9-13 19:00 | 显示全部楼层
又来让网友帮你改程序嘛
人家没有你的板,调程序不是更麻烦?
建议学习一些调试技巧,借助好的工具把程序调出来。
要知道写程序不算高技术, 调程序才是高技术
Ketose 发表于 2018-9-14 10:29 | 显示全部楼层
随便到网上抄的代码,然后让网友帮你改。
你可以哦。
