程序源码
/* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved. */
#include <stdio.h>
/* Include hear file */
#include "NUC1xx.h"
#include "DrvGPIO.h"
Define variable
static uint32_t TimerCOUN=0;
Function subroutine
void Delay(uint32_t delayCnt)
while(delayCnt--)
__NOP();
__NOP();
uint32_t GetTDR(void)
return TIMER0->TDR;
Interrupt subroutine
void TMR0_IRQHandler(void) // Timer0 interrupt subroutine
TIMER0->TISR.TIF =1;
TimerCOUN++;
MAIN function
int32_t main (void)
uint32_t TEMP=0;
/* SYSCLK =>12Mhz*/
UNLOCKREG();
SYSCLK->PWRCON.XTL12M_EN = 1;
LOCKREG();
/*set GPI0 output*/
DrvGPIO_Open(E_GPA,2, E_IO_OUTPUT);
DrvGPIO_Open(E_GPA,3, E_IO_OUTPUT);
DrvGPIO_Open(E_GPA,4, E_IO_OUTPUT);
DrvGPIO_Open(E_GPA,5, E_IO_OUTPUT);
NVIC_DisableIRQ(TMR0_IRQn); //Disable Timer0 interrupt
outpw(&TIMER0->TCSR ,0 ); //Disable Timer0
/* Step 1. Enable and Select Timer clock source */
SYSCLK->CLKSEL1.TMR0_S = 7; //Select 22Mhz for Timer0 clock source
SYSCLK->APBCLK.TMR0_EN =1; //Enable Timer0 clock source
/* Step 2. Select Operation mode */
TIMER0->TCSR.MODE=1; //Select periodic mode for operation mode
/* Step 3. Select Time out period = (Period of timer clock input) * (8-bit Prescale + 1) * (24-bit TCMP)*/
TIMER0->TCSR.PRESCALE=0; // Set Prescale [0~255]
TIMER0->TCMPR = 2765; // Set TCMPR [0~16777215]
// (1/22118400)*(0+1)*(2765)= 125.01usec or 7999.42Hz
/* Step 4. Enable interrupt */
TIMER0->TCSR.IE = 1;
TIMER0->TISR.TIF = 1; //Write 1 to clear for safty
NVIC_EnableIRQ(TMR0_IRQn); //Enable Timer0 Interrupt
/* Step 5. Enable Timer module */
TIMER0->TCSR.CRST = 1; //Reset up counter
TIMER0->TCSR.CEN = 1; //Enable Timer0
TIMER0->TCSR.TDR_EN=1; // Enable TDR function
while(1)
if (TimerCOUN>8000) //Wait 1 seconds
TEMP++;
TimerCOUN=0;
DrvGPIO_SetPortBits(E_GPA, ~(TEMP<<2));
