两个例程
700|15
kangzj|  楼主 | 2018-9-19 13:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AD, TE, TI, IO, WRITE
本人使用Cy7c68013A进行开发,其它例程都已经完成,控制传输找资料已经完成.
只是剩下       DriverObject-> MajorFunction[IRP_MJ_WRITE]   =   Ezusb_Write;       //写入数据
      DriverObject-> MajorFunction[IRP_MJ_READ]   =   Ezusb_Read;           //读取数据
这两个例程没有完成,本人没有写过此类例程,不知如何下手,有知道的朋友告知一下相关的消息也行,谢谢了
zwll| | 2018-9-19 13:03 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
kangzj|  楼主 | 2018-9-19 13:20 | 只看该作者
NTSTATUS
Ezusb_Read(
        IN   PDEVICE_OBJECT   DeviceObject,
        IN   PIRP                       Irp
        PMDL                                       mdl;
        PURB                                       urb;
        ULONG                                     totalLength;
        ULONG                                     stageLength;
        ULONG                                     urbFlags;
        BOOLEAN                                 read;
        NTSTATUS                               ntStatus;
        ULONG_PTR                             virtualAddress;
        PFILE_OBJECT                       fileObject;
        PDEVICE_EXTENSION             deviceExtension;
        PIO_STACK_LOCATION           irpStack;
        PIO_STACK_LOCATION           nextStack;
        PBULKUSB_RW_CONTEXT         rwContext;
        PUSBD_PIPE_INFORMATION   pipeInformation;
PVOID   IoBuffer;
        //   initialize   variables
        urb   =   NULL;
        mdl   =   NULL;
        rwContext   =   NULL;
        totalLength   =   0;
        irpStack   =   IoGetCurrentIrpStackLocation(Irp);
        fileObject   =   irpStack-> FileObject;
        read   =   (irpStack-> MajorFunction   ==   IRP_MJ_READ)   ?   TRUE   :   FALSE;
        deviceExtension   =   (PDEVICE_EXTENSION)   DeviceObject-> DeviceExtension;
        IoBuffer                       =   Irp-> AssociatedIrp.SystemBuffer;
        if(fileObject   &&   fileObject-> FsContext)   {
                pipeInformation   =   fileObject-> FsContext;
                if((UsbdPipeTypeBulk   !=   pipeInformation-> PipeType)   &&
                      (UsbdPipeTypeInterrupt   !=   pipeInformation-> PipeType))   {
                         ntStatus   =   STATUS_INVALID_HANDLE;
                        goto   BulkUsb_DispatchRead_Exit;
        else   {
        rwContext   =   (PBULKUSB_RW_CONTEXT)
                                ExAllocatePool(NonPagedPool,
                                                              sizeof(BULKUSB_RW_CONTEXT));
        if(rwContext   ==   NULL)   {
                ntStatus   =   STATUS_INSUFFICIENT_RESOURCES;
        if(Irp-> MdlAddress)   {
                totalLength   =   MmGetMdlByteCount(Irp-> MdlAddress);
        if(totalLength   >   BULKUSB_TEST_BOARD_TRANSFER_BUFFER_SIZE)   {
                ntStatus   =   STATUS_INVALID_PARAMETER;
                ExFreePool(rwContext);
        if(totalLength   ==   0)   {
                ntStatus   =   STATUS_SUCCESS;
        urbFlags   =   USBD_SHORT_TRANSFER_OK;
        virtualAddress   =   (ULONG_PTR)   MmGetMdlVirtualAddress(Irp-> MdlAddress);
        if(read)   {
                urbFlags   |=   USBD_TRANSFER_DIRECTION_IN;
        else   {
                urbFlags   |=   USBD_TRANSFER_DIRECTION_OUT;
        //   the   transfer   request   is   for   totalLength.
        //   we   can   perform   a   max   of   BULKUSB_MAX_TRANSFER_SIZE
        //   in   each   stage.
        if(totalLength   >   BULKUSB_MAX_TRANSFER_SIZE)   {
                stageLength   =   BULKUSB_MAX_TRANSFER_SIZE;
        else   {
                stageLength   =   totalLength;
        mdl   =   IoAllocateMdl((PVOID)   virtualAddress,
                                                totalLength,
                                                FALSE,
                                                FALSE,
                                                NULL);
        if(mdl   ==   NULL)   {
        //   map   the   portion   of   user-buffer   described   by   an   mdl   to   another   mdl
        IoBuildPartialMdl(Irp-> MdlAddress,
                                            mdl,
                                            stageLength);
        urb   =   ExAllocatePool(NonPagedPool,
                                                  sizeof(struct   _URB_BULK_OR_INTERRUPT_TRANSFER));
        if(urb   ==   NULL)   {
                IoFreeMdl(mdl);
        UsbBuildInterruptOrBulkTransferRequest(
                                                        urb,
                                                        sizeof(struct   _URB_BULK_OR_INTERRUPT_TRANSFER),
                                                        pipeInformation-> PipeHandle,
                                                        NULL,
                                                        mdl,
                                                        stageLength,
                                                        urbFlags,
                                                        NULL);
        //   set   BULKUSB_RW_CONTEXT   parameters.
         rwContext-> Urb                           =   urb;
        rwContext-> Mdl                           =   mdl;
        rwContext-> Length                     =   totalLength   -   stageLength;
        rwContext-> Numxfer                   =   0;
        rwContext-> VirtualAddress     =   virtualAddress   +   stageLength;
        rwContext-> DeviceExtension   =   deviceExtension;
        //   use   the   original   read/write   irp   as   an   internal   device   control   irp
        nextStack   =   IoGetNextIrpStackLocation(Irp);
        nextStack-> MajorFunction   =   IRP_MJ_INTERNAL_DEVICE_CONTROL;
        nextStack-> Parameters.Others.Argument1   =   (PVOID)   urb;
        nextStack-> Parameters.DeviceIoControl.IoControlCode   =
        IOCTL_INTERNAL_USB_SUBMIT_URB;
        IoSetCompletionRoutine(Irp,
                                                       (PIO_COMPLETION_ROUTINE)Ezusb_ReadWriteCompletion,
                                                      rwContext,
                                                      TRUE,
                                                      TRUE,
                                                      TRUE);
        //   since   we   return   STATUS_PENDING   call   IoMarkIrpPending.
        //   This   is   the   boiler   plate   code.
        //   This   may   cause   extra   overhead   of   an   APC   for   the   Irp   completion
        //   but   this   is   the   correct   thing   to   do.
        IoMarkIrpPending(Irp);
        //BulkUsb_IoIncrement(deviceExtension);
        ntStatus   =   IoCallDriver(deviceExtension-> StackDeviceObject,
                                                        Irp);
        if(!NT_SUCCESS(ntStatus))   {
                //   if   the   device   was   yanked   out,   then   the   pipeInformation
                 //   field   is   invalid.
                //   similarly   if   the   request   was   cancelled,   then   we   need   not
                //   invoked   reset   pipe/device.
                if((ntStatus   !=   STATUS_CANCELLED)   &&
                       (ntStatus   !=   STATUS_DEVICE_NOT_CONNECTED))   {
                        ULONG   pipenum   =   *((PULONG)   irpStack);
                        /*ntStatus   =   UsbResetPipe(DeviceObject,
        pipeInformation);*/
        pipenum);
                                //ntStatus   =   BulkUsb_ResetDevice(DeviceObject);
                else   {
        //   we   return   STATUS_PENDING   and   not   the   status   returned   by   the   lower   layer.
        return   STATUS_PENDING;
BulkUsb_DispatchRead_Exit:
        Irp-> IoStatus.Status   =   ntStatus;
        Irp-> IoStatus.Information   =   0;
        IoCompleteRequest(Irp,   IO_NO_INCREMENT);
        return   ntStatus;
这是我找资料写的一个写例程.我用softIce进行调试时if(fileObject   &&   fileObject-> FsContext)   这里就没有往下执行,直接跳到
        else   {
kangzj|  楼主 | 2018-9-19 13:25 | 只看该作者
NTSTATUS
Ezusb_Read(
        IN   PIRP                       Irp
        PMDL                                       mdl;
        PURB                                       urb;
        ULONG                                     totalLength;
        ULONG                                     stageLength;
        ULONG                                     urbFlags;
        BOOLEAN                                 read;
        NTSTATUS                               ntStatus;
PVOID   IoBuffer;
        urb   =   NULL;
        mdl   =   NULL;
        rwContext   =   NULL;
        totalLength   =   0;
        else   {
        if(read)   {
        else   {
        //   in   each   stage.
        else   {
                                                totalLength,
                                                FALSE,
                                                FALSE,
                                                NULL);
        if(mdl   ==   NULL)   {
                                            mdl,
                                            stageLength);
        if(urb   ==   NULL)   {
                IoFreeMdl(mdl);
                                                        urb,
                                                        NULL,
                                                        mdl,
                                                        stageLength,
                                                        urbFlags,
                                                        NULL);
                                                      rwContext,
                                                      TRUE,
                                                      TRUE,
                                                      TRUE);
                                                        Irp);
        pipeInformation);*/
        pipenum);
                else   {
        return   ntStatus;
        else   {
kangzj|  楼主 | 2018-9-19 13:28 | 只看该作者
我也只是从别的地方抄来的,肯定不对,请高手指正.
juventus9554| | 2018-9-19 13:32 | 只看该作者
FsContext这个具体内容不太清楚,最有可能这个东西没有搞好。
stly| | 2018-9-19 13:35 | 只看该作者
先确认68013A的firmware好了没有?
llljh| | 2018-9-19 13:42 | 只看该作者
建议学MOS开关电源    可控硅控制开关电源速度慢    损耗大   而且体积大  频率响应时间较长
supernan| | 2018-9-19 13:45 | 只看该作者
cypress没有提供driver sample code么?好像《usb原理与工程开发》有提供实例。
kangzj|  楼主 | 2018-9-19 13:48 | 只看该作者
这个是没有提供实例的,没实现IRP_MJ_READ的例程的,他们都是使用IRP_MJ_DEVICE_CONTROL这个例程来传输数据的
pengf| | 2018-9-19 13:51 | 只看该作者
那最终是firmware的问题,还是driver的问题?
kangzj|  楼主 | 2018-9-19 13:54 | 只看该作者
如果是driver的问题,if(fileObject && fileObject- >FsContext) 判断为false的原因是什么?
kangzj|  楼主 | 2018-9-19 13:57 | 只看该作者
这个文件对象是需要创建的,在驱动加载时,这个不好控制, 我没有采用此方法,这种方法是DDK的例子的方法.
ousj| | 2018-9-19 14:02 | 只看该作者
是因为你fileObject- >FsContext为null,fileObject- >FsContext可以记录任意信息,但从这里可以看出是记录PUSBD_PIPE_INFORMATION pipeInformation信息的。
Ezusb驱动我没用过,但大体应该和ddk中的例子bulkusb差不多,fileObject- >FsContext应该在IRP_CREATE中就被赋值了,但你的程序没有成功赋值。
下面摘抄一段bulkusb中的代码
C/C++ code
NTSTATUS
BulkUsb_DispatchCreate(
     IN PIRP           Irp
     for(i=0; i<interface->NumberOfPipes; i++) {
        if(pipeContext == &deviceExtension->PipeContext[i]) {
             // found a match
             BulkUsb_DbgPrint(3, ("open pipe %d\n", i));
            fileObject->FsContext = &interface->Pipes[i];
             ASSERT(fileObject->FsContext);
            pipeContext->PipeOpen = TRUE;
             // increment OpenHandleCounts
             InterlockedIncrement(&deviceExtension->OpenHandleCount);
             // the device is idle if it has no open handles or pending PnP Irps
             // since we just received an open handle request, cancel idle req.
             if(deviceExtension->SSEnable) {
                CancelSelectSuspend(deviceExtension);
morrisk| | 2018-9-19 14:04 | 只看该作者
实际上,在XP下也有问题的。只是屏幕没有显示而已!
试着My computer->property->Advanced->Startup and Recovery auto restart选项勾掉,看看是否能重现问题?
kangzj|  楼主 | 2018-9-19 14:07 | 只看该作者
嗯,那我按大家的说法挨个排查一下,先结贴啦,谢谢哈
