[范例教程]
【M0】 MG32F02A 学习笔记⑨ SPI0 DMA标准发送与接收
2865|125
noctor|  楼主 | 2018-9-30 13:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
     上回我们说到了MG32F02A的SPI0通过标准四线制全双工方式进行数据通信。帖子详情:https://bbs.21ic.com/icview-2561446-1-1.html
      这次我们就按照老样子,搭载DMA功能进行传输。
      上次我们说过,UART的DMA功能感觉并没有多简化,然而我发现在SPI的发送端上也是一样的结果,同样需要手动每次传输数据之前使能一次DMA外设发送功能才能发送,而且一样要使用while等待TCF_FLAG的到来。、
      主机发送代码:
#include "MG32x02z_DRV.H"
#include <stdio.h>
typedef uint8_t u8;
typedef uint16_t u16;
typedef uint32_t u32;
typedef uint64_t u64;
#define Dummy_Data         0xFFFFFFFF
#define SPI_NSS         PB0     // SPI_NSS
#define URTX URT0
#define MYBINARYIMAGE2_LENGTH 20
uint8_t SendBuf[MYBINARYIMAGE2_LENGTH]={0};//__attribute__((at(0x20001000)));
void CSC_Init (void)
        CSC_PLL_TyprDef CSC_PLL_CFG;
  UnProtectModuleReg(MEMprotect);             // Setting flash wait state
  MEM_SetFlashWaitState(MEM_FWAIT_ONE);        // 50MHz> Sysclk >=25MHz
  UnProtectModuleReg(CSCprotect);
        CSC_CK_APB_Divider_Select(APB_DIV_1);        // Modify CK_APB divider        APB=CK_MAIN/1
        CSC_CK_AHB_Divider_Select(AHB_DIV_1);        // Modify CK_AHB divider        AHB=APB/1
        /* CK_HS selection */
        CSC_IHRCO_Select(IHRCO_12MHz);                        // IHRCO Sel 12MHz
        CSC_IHRCO_Cmd(ENABLE);
        while(CSC_GetSingleFlagStatus(CSC_IHRCOF) == DRV_Normal);
        CSC_ClearFlag(CSC_IHRCOF);
        CSC_CK_HS_Select(HS_CK_IHRCO);                        // CK_HS select IHRCO
        /* PLL */
        CSC_PLL_CFG.InputDivider=PLLI_DIV_2;        // 12M/2=6M
        CSC_PLL_CFG.Multiplication=PLLIx16;                // 6M*16=96M
        CSC_PLL_CFG.OutputDivider=PLLO_DIV_2;        // PLLO=96M/2=48M
        CSC_PLL_Config(&CSC_PLL_CFG);
        CSC_PLL_Cmd(ENABLE);
        while(CSC_GetSingleFlagStatus(CSC_PLLF) == DRV_Normal);
        CSC_ClearFlag(CSC_PLLF);
        /* CK_MAIN */
        CSC_CK_MAIN_Select(MAIN_CK_HS);
        /* Configure ICKO function */
        /* Configure peripheral clock */
        CSC_PeriphProcessClockSource_Config(CSC_SPI0_CKS, CK_APB);
        CSC_PeriphOnModeClock_Config(CSC_ON_SPI0,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_PortB,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_PortE,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_DMA,ENABLE);
void InitSPI0(void)
                PIN_InitTypeDef PINX_InitStruct;
        //===Set CSC init====
        //MG32x02z_CSC_Init.h(Configuration Wizard)
        //Select CK_HS source = CK_IHRCO
        //Select IHRCO = 12Mz
        //Select CK_MAIN Source = CK_HS
        //Configure PLL->Select APB Prescaler = CK_MAIN/1
        /*=== 1. Enable CSC to SPI clock ===*/
        //[A] When Use Wizard
        //Configure Peripheral On Mode Clock->SPI0 = Enable and Select SPI0_PR Source = CK_APB
        //Configure Peripheral On Mode Clock->Port B = Enable
        //[B] When Use Driver
//          UnProtectModuleReg(CSCprotect);                                                          // Unprotect CSC module
//          CSC_PeriphOnModeClock_Config(CSC_ON_SPI0, ENABLE);                  // Enable SPI0 module clock
//          CSC_PeriphOnModeClock_Config(CSC_ON_PortB, ENABLE);                  // Enable PortB clock
//          CSC_PeriphProcessClockSource_Config(CSC_SPI0_CKS, CK_APB);  // CK_SPIx_PR = CK_APB = 12MHz
//          ProtectModuleReg(CSCprotect);                                                           // protect CSC module
        /*=== 2. Default Initial SPI ===*/
        SPI_DeInit(SPI0);
        /*=== 3. Configure clock divider ===*/                                                // SPI clock = 1MHz
        SPI_Clock_Select(SPI0, SPI_CK_SPIx_PR);                                         // CK_SPIx = CK_SPIx_PR
        SPI_PreDivider_Select(SPI0, SPI_PDIV_2);                                        // PDIV outpu = CK_SPIx /2
        SPI_Prescaler_Select(SPI0, SPI_PSC_3);                                                // Prescaler outpu = PDIV outpu /3
        SPI_Divider_Select(SPI0, SPI_DIV_2);                                                // DIV outpu = PDIV outpu /2
        /*=== 4. Configure SPI data line, mode and data size... ===*/
        SPI_DataLine_Select(SPI0, SPI_Standard);                        // SPI data line 1-line Bidirectional~ SPI0_MOSI
        SPI_ModeAndNss_Select(SPI0, SPI_MasterWithNss);                                        // Master
        SPI_ClockPhase_Select(SPI0, SPI_LeadingEdge);                                // CPHA = 0
        SPI_ClockPolarity_Select(SPI0, SPI_Low);                                        // CPOL = 0
        SPI_FirstBit_Select(SPI0, SPI_MSB);                                                 // MSB first
        SPI_DataSize_Select(SPI0, SPI_8bits);                                                // Data size 8bits
        /*=== 5. Config SPI0 IO ===*/
        PINX_InitStruct.PINX_Mode                                = PINX_Mode_PushPull_O;         // Pin select pusu pull mode
        PINX_InitStruct.PINX_PUResistant                = PINX_PUResistant_Enable;        // Enable pull up resistor
        PINX_InitStruct.PINX_Speed                                = PINX_Speed_Low;
        PINX_InitStruct.PINX_OUTDrive                        = PINX_OUTDrive_Level0;         // Pin output driver full strength.
        PINX_InitStruct.PINX_FilterDivider                = PINX_FilterDivider_Bypass;// Pin input deglitch filter clock divider bypass
        PINX_InitStruct.PINX_Inverse                        = PINX_Inverse_Disable;         // Pin input data not inverse
        PINX_InitStruct.PINX_Alternate_Function = 2;                                                // Pin AFS = 2
        GPIO_PinMode_Config(PINB(2),&PINX_InitStruct);                                                // CLK setup at PB2
        PINX_InitStruct.PINX_OUTDrive                        = PINX_OUTDrive_Level0;         // Pin output drive strength 1/4
        GPIO_PinMode_Config(PINB(3),&PINX_InitStruct);                                                // MOSI setup at PB3
        PINX_InitStruct.PINX_Alternate_Function = 2;                                                // Pin AFS = 0
        GPIO_PinMode_Config(PINB(0),&PINX_InitStruct);                                                // NSS setup at PB0
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_OpenDrain_O;
        GPIO_PinMode_Config(PINB(1),&PINX_InitStruct);                                                // MISO setup at PB1
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_PushPull_O;                  // Pin select Push Pull mode
        PINX_InitStruct.PINX_Alternate_Function  = 0;                                                         // Pin AFS = 0
        GPIO_PinMode_Config(PINE(13),&PINX_InitStruct);                                                  // PE13
        GPIO_PinMode_Config(PINE(14),&PINX_InitStruct);                                                  // PE14
        GPIO_PinMode_Config(PINE(15),&PINX_InitStruct);                                                  // PE15
        /*=== 6. Enable SPI ===*/
        SPI_Cmd(SPI0, ENABLE);
void DMA_Init(void)
         DMA_BaseInitTypeDef DMATestPattern;
    // 1.Enable DMA
    DMA_Cmd(ENABLE);
    // 2.Enable Channel0
    DMA_Channel_Cmd(DMAChannel0, ENABLE);
    DMA_BaseInitStructure_Init(&DMATestPattern);
    // 3.initial & modify parameter
        // DMA channel select
        DMATestPattern.DMAChx = DMAChannel0;
        // channel x source/destination auto increase address
        DMATestPattern.SrcSINCSel = ENABLE;
        DMATestPattern.DestDINCSel = DISABLE;
        // DMA source peripheral config
        DMATestPattern.SrcSymSel = DMA_MEM_Read;
        // DMA destination peripheral config
        DMATestPattern.DestSymSel = DMA_SPI0_TX;
        // DMA Burst size config
        DMATestPattern.BurstDataSize = DMA_BurstSize_1Byte;
        // DMA transfer data count initial number
        DMATestPattern.DMATransferNUM = MYBINARYIMAGE2_LENGTH;
        // source/destination config
        DMATestPattern.DMASourceAddr = (uint32_t *)&SendBuf;
        DMATestPattern.DMADestinationAddr = &SPI0->TDAT;
                                SPI_DMASend_Cmd(SPI0, ENABLE);
                                DMA_Base_Init(&DMATestPattern);
int main()
        u32 i;
        u8 x,y;
        CSC_Init();
        InitSPI0();
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_PushPull_O;          // Pin select digital input mode
        GPIO_PinMode_Config(PINE(15),&PINX_InitStruct);                                          // D6 setup at PE15
        DMA_Init();
        DMA_StartRequest(DMAChannel0);
        i=0;
    while(1)
            i++;
            if(i>=500000)
                                SPI_DMASend_Cmd(SPI0, ENABLE);      //每次发送前都要使能一次
                                SPI_NSS=1;
                                SPI_NSS=0;
                                PE15=0;
                                SendBuf[0]=0x05;
                                PE15=0;
                                i=1;
                                while (DMA_GetSingleFlagStatus(DMA, DMA_FLAG_CH0_TCF) == DRV_UnHappened);
                                DMA_ClearFlag(DMA, DMA_FLAG_CH0_TCF);
                                DMA_Channel_Cmd(DMAChannel0, DISABLE);
                                DMA_SetSourceAddress(DMAChannel0, SendBuf);
                                memset(SendBuf,0,sizeof(u8));
                                PE15=1;
     这样就能实现SPI的DMA发送功能了,但是要记住,NSS还是需要自己手动拉高拉低的。
      从机接收程序:
#define URTX URT0
uint8_t RcvBuf[MYBINARYIMAGE2_LENGTH] = {0};// __attribute__((at(0x20003800)));
        /* PLL */
        /* CK_MAIN */
        CSC_PeriphProcessClockSource_Config(CSC_UART0_CKS, CK_APB);
        CSC_PeriphOnModeClock_Config(CSC_ON_UART0,ENABLE);
void InitSPI0(void)
        SPI_DeInit(SPI0);
        SPI_ModeAndNss_Select(SPI0, SPI_SlaveWithNss);                                // Slave with NSS
        //SPI_ModeAndNss_Select(SPI0, SPI_Slave);                                        // Slave
        SPI_NSSInputSignal_Select(SPI0,SPI_NssPin);                                        // Nss
        SPI_SlaveModeReceivedThreshold_Select(SPI0, SPI_1Byte);     // Set SPI0 received data buffer high threshold
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_Digital_I;          // Pin select digital input mode
        GPIO_PinMode_Config(PINB(2),&PINX_InitStruct);                                          // CLK setup at PB26
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_OpenDrain_O; ; //PINX_Mode_PushPull_O;// PINX_Mode_OpenDrain_O;                  // Pin select Push Pull mode
         PINX_InitStruct.PINX_Mode                                 = PINX_Mode_PushPull_O;   //PINX_Mode_PushPull_O;         // Setting pusu pull mode
         GPIO_PinMode_Config(PINE(13),&PINX_InitStruct);                                          // D4 setup at PE13
         GPIO_PinMode_Config(PINE(14),&PINX_InitStruct);                                          // D4 setup at PE13
        SPI_Cmd(SPI0, ENABLE);        // Enable SPI
  SPI_IT_Config(SPI0, SPI_INT_RX,ENABLE);
//        SPI_ITEA_Cmd(SPI0, ENABLE);
void Sample_URT0_Init(void)
    URT_BRG_TypeDef  URT_BRG;
    URT_Data_TypeDef DataDef;
    //==Set CSC init
    //Select IHRCO = 11.0592M
    //Configure Peripheral On Mode Clock->Port B/URT0 = Enable
    //Configure Peripheral On Mode Clock->URT0->Select URT0_PR Source = CK_APB(11.0592)
    //==Set GPIO init
    //MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOB->Pin8/9
    //GPIO port initial is 0xFFFF
    //Pin8 mode is PPO/Pin9 mode is ODO
    //Pin8/9 pull-up resister Enable
    //Pin8/9 function URT0_TX/RX
        PINX_InitStruct.PINX_FilterDivider                   = PINX_FilterDivider_Bypass;        // Pin input deglitch filter clock divider bypass
        PINX_InitStruct.PINX_Alternate_Function  = 3;                                // Pin AFS = URT0_TX
        GPIO_PinMode_Config(PINB(8),&PINX_InitStruct);                                                          // TXD at PB8
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_OpenDrain_O;                 // Pin select Open Drain mode
        PINX_InitStruct.PINX_Alternate_Function  = 3;                                // Pin AFS = URT0_RX
        GPIO_PinMode_Config(PINB(9),&PINX_InitStruct);                                                          // RXD at PB9
    //=====Set Clock=====//
    //---Set BaudRate---//
    URT_BRG.URT_InteranlClockSource = URT_BDClock_PROC;
    URT_BRG.URT_BaudRateMode = URT_BDMode_Separated;
    URT_BRG.URT_PrescalerCounterReload = 0;                        //Set PSR
    URT_BRG.URT_BaudRateCounterReload = 3;                        //Set RLR
    URT_BaudRateGenerator_Config(URTX, &URT_BRG);                    //BR115200 = f(CK_URTx)/(PSR+1)/(RLR+1)/(OS_NUM+1)
    URT_BaudRateGenerator_Cmd(URTX, ENABLE);                    //Enable BaudRateGenerator
    //---TX/RX Clock---//
    URT_TXClockSource_Select(URTX, URT_TXClock_Internal);        //URT_TX use BaudRateGenerator
    URT_RXClockSource_Select(URTX, URT_RXClock_Internal);        //URT_RX use BaudRateGenerator
    URT_TXOverSamplingSampleNumber_Select(URTX, 25);                //Set TX OS_NUM
    URT_RXOverSamplingSampleNumber_Select(URTX, 25);                //Set RX OS_NUM
    URT_RXOverSamplingMode_Select(URTX, URT_RXSMP_3TIME);
    URT_TX_Cmd(URTX, ENABLE);                                    //Enable TX
    URT_RX_Cmd(URTX, ENABLE);                                    //Enable RX
    //=====Set Mode=====//
    //---Set Data character config---//
    DataDef.URT_TX_DataLength  = URT_DataLength_8;
    DataDef.URT_RX_DataLength  = URT_DataLength_8;
    DataDef.URT_TX_DataOrder   = URT_DataTyped_LSB;
    DataDef.URT_RX_DataOrder   = URT_DataTyped_LSB;
    DataDef.URT_TX_Parity      = URT_Parity_No;
    DataDef.URT_RX_Parity      = URT_Parity_No;
    DataDef.URT_TX_StopBits    = URT_StopBits_1_0;
    DataDef.URT_RX_StopBits    = URT_StopBits_1_0;
    DataDef.URT_RX_DataInverse = DISABLE;
    URT_DataCharacter_Config(URTX, &DataDef);
    //---Set Mode Select---//
    URT_Mode_Select(URTX, URT_URT_mode);
    //---Set DataLine Select---//
    URT_DataLine_Select(URTX, URT_DataLine_2);
    //=====Set Error Control=====//
    // to do...
    //=====Set Bus Status Detect Control=====//
    // to do...
    //=====Set Data Control=====//
    URT_RXShadowBufferThreshold_Select(URTX, URT_RXTH_1BYTE);
    URT_IdlehandleMode_Select(URTX, URT_IDLEMode_No);
    URT_TXGaudTime_Select(URTX, 0);
    //=====Enable URT Interrupt=====//
    URT_IT_Cmd(URTX, URT_IT_RX, ENABLE);
    URT_ITEA_Cmd(URTX, ENABLE);
    NVIC_EnableIRQ(URT0_IRQn);
    //=====Enable URT=====//
    URT_Cmd(URTX, ENABLE);
        //==See MG32x02z_URT0_IRQ.c when interrupt in
int fputc(int ch,FILE *f)
        URT_SetTXData(URTX,1,ch);
        while(URT_GetITSingleFlagStatus(URTX,URT_IT_TC)==DRV_UnHappened);
        URT_ClearITFlag(URTX,URT_IT_TC);
        return ch;
void UartSendByte(int ch)
void DMA_Init(void)
    // 1.Enable DMA
    DMA_Cmd(ENABLE);
        DMATestPattern.SrcSINCSel = DISABLE;//ENABLE;
        DMATestPattern.DestDINCSel = ENABLE;
        DMATestPattern.SrcSymSel = DMA_SPI0_RX;
        DMATestPattern.DestSymSel = DMA_MEM_Write;
        DMATestPattern.DMASourceAddr = &SPI0->RDAT;
        DMATestPattern.DMADestinationAddr = (uint32_t *)&RcvBuf;//DMA_URT0_TX;// (uint8_t *)&RcvBuf;
                                SPI_DMAReceive_Cmd(SPI0, ENABLE);
int main()
        u32 i;
        CSC_Init();
        InitSPI0();
                Sample_URT0_Init();
                DMA_Init();
        i=0;
    while(1)
            i++;
            if(i>=100000)
                                i=0;
                                if(RcvBuf[0]!=0)printf("RX:0x%02X\n",RcvBuf[0]);
                                memset(RcvBuf,0,20*sizeof(u8));
                                DMA_SetDestinationAddress(DMAChannel0, RcvBuf);
quickman| | 2022-7-3 14:12 | 只看该作者
相当全的资料,很适合初学者
beacherblack| | 2022-7-3 14:26 | 只看该作者
以后学习就方便了
vivilyly| | 2022-7-3 14:57 | 只看该作者
分享的资料很高端呢。
tabmone| | 2022-7-3 15:33 | 只看该作者
很详细的开发板资料
lzbf| | 2022-7-3 15:47 | 只看该作者
资料还是相当全面的
sheflynn| | 2022-7-3 16:02 | 只看该作者
谢谢lz分享,很有用
modesty3jonah| | 2022-7-3 16:15 | 只看该作者
资料还是相当全面的
juliestephen| | 2022-7-3 16:29 | 只看该作者
回复查看一下相关的内容。
selongli| | 2022-7-3 16:43 | 只看该作者
很详细的开发板资料
soodesyt| | 2022-7-3 17:39 | 只看该作者
以后学习就方便了
cashrwood| | 2022-7-3 17:53 | 只看该作者
正准备用 来做产品,刚好用上。
rosemoore| | 2022-7-3 18:07 | 只看该作者
这些资料太全了!!!
tifmill| | 2022-7-3 18:21 | 只看该作者
很详细的开发板资料
yeates333| | 2022-7-3 19:20 | 只看该作者
资料还是相当全面的
pklong| | 2022-7-3 19:31 | 只看该作者
以后多交流交流
lzmm| | 2022-7-3 19:51 | 只看该作者
感谢分享,提供的例程很实用
232321122| | 2022-7-3 20:02 | 只看该作者
楼主的资料确实全面,非常感谢
olivem55arlowe| | 2022-7-3 20:13 | 只看该作者
资料还是相当全面的
htmlme| | 2022-7-3 20:25 | 只看该作者
谢谢你共享的资料
