GD32 SD卡驱动
3388|31
chenqiang10|  楼主 | 2018-9-30 19:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
初始化
D_Err SD_Init(void)
    SD_Err Status = SD_OK;
    /* Configure GPIO about SDIO interface */
    GPIO_Configuration();
    /* Enable the SDIO and DMA2 Clock */
    RCC_AHBPeriphClock_Enable(RCC_AHBPERIPH_SDIO | RCC_AHBPERIPH_DMA2, ENABLE);
    /* Deinitialize the SDIO */
    SDIO_DeInit();
    /* Configure the communication clock and the work voltage */
    Status = SD_PWR_ON();
    if (Status != SD_OK)
        return(Status);
    /* Init the card */
    Status = SD_Init_Card();
        return(Status);
    /* Configure the SDIO peripheral */
    /* HCLK = SDIOCLK = 72 MHz, SDIO_CLK = HCLK/(2 + 1) = 24 MHz */
    SDIO_InitStructure.SDIO_ClockDiv = 0x04;
    SDIO_InitStructure.SDIO_ClockEdge = SDIO_CLOCKEDGE_RISING;
    SDIO_InitStructure.SDIO_ClockBypassState = SDIO_CLOCKBYPASSSTATE_DISABLE;
    SDIO_InitStructure.SDIO_ClockPWRSave = SDIO_CLOCKPWRSAVE_DISABLE;
    SDIO_InitStructure.SDIO_BusMode = SDIO_BUSMODE_1B;
    SDIO_InitStructure.SDIO_HWFlowCtrlState = SDIO_HWFLOWCTRLSTATE_ENABLE;
    SDIO_Init(&SDIO_InitStructure);
    return(Status);
SD_Err SD_PWR_ON(void)
    uint32_t response = 0, count = 0;
    uint8_t busy =0;
    uint32_t SDType = SD_STD_CAPACITY;
    SDIO_InitStructure.SDIO_ClockDiv = 298;
    SDIO_InitStructure.SDIO_ClockEdge = SDIO_CLOCKEDGE_RISING ;
    SDIO_InitStructure.SDIO_HWFlowCtrlState = SDIO_HWFLOWCTRLSTATE_DISABLE;
    /* Configure Power State to ON */
    SDIO_SetPWRState(SDIO_PWRSTATE_ON);
    /* Enable SDIO Clock */
    SDIO_Clock_Enable(ENABLE);
    /* Send CMD0 to reset the card(No response required) */
    SDIO_CmdInitStructure.SDIO_CMDParameter = 0x0;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_GO_IDLE_STATE;
    SDIO_CmdInitStructure.SDIO_ResponseType = SDIO_RESPONSETYPE_NO;
    SDIO_CmdInitStructure.SDIO_WaitINTState = SDIO_WAITINTSTATE_NO;
    SDIO_CmdInitStructure.SDIO_CSMState = SDIO_CSMSTATE_ENABLE;
    SDIO_SendCMD(&SDIO_CmdInitStructure);
    /* Check CMD errors */
    Status = Check_Err();
        return(Status);
    /* Send CMD8 to verify SD card interface operating condition(R7 response required) */
    SDIO_CmdInitStructure.SDIO_CMDParameter = SD_CHECK_PATTERN;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SEND_IF_COND;
    SDIO_CmdInitStructure.SDIO_ResponseType = SDIO_RESPONSETYPE_SHORT;
    if (Check_Err_R7() == SD_OK)
        CardType = SDIO_STD_CAPACITY_SD_CARD_V2_0; /* SD Card 2.0 */
        SDType = SD_HIGH_CAPACITY;
    /* Send CMD55, the next CMD is Application Specific Commands */
    SDIO_CmdInitStructure.SDIO_CMDParameter = 0x00;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_APP_CMD;
    /* It is SD memory card */
    if (Check_Err_R1(SDIO_APP_CMD) == SD_OK)
        /* Send ACMD41 SD_APP_OP_COND with Argument 0x80100000 */
        while ((!busy) && (count < SD_MAX_VOLT_TRIAL))
            /* SEND CMD55 APP_CMD with RCA as 0 */
            Status = Check_Err_R1(SDIO_APP_CMD);
                return(Status);
            /* Send ACMD41 to know the work voltage */
            SDIO_CmdInitStructure.SDIO_CMDParameter = SD_VOLTAGE_WINDOW_SD | SDType;
            SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SD_APP_OP_COND;
            Status = Check_Err_R3();
                return(Status);
            response = SDIO_GetResponse(SDIO_RESP1);
            busy = (uint8_t) (((response >> 31) == 1) ? 1 : 0);
            count++;
        if (count >= SD_MAX_VOLT_TRIAL)
            Status = SD_INVALID_VOLTRANGE;
            return(Status);
        /* It is SDHC card */
        if (response &= SD_HIGH_CAPACITY)
            CardType = SDIO_HIGH_CAPACITY_SD_CARD;
    }/* else MMC Card */
  return(Status);
chenqiang10|  楼主 | 2018-9-30 19:17 | 只看该作者
SD_Err SD_PowerOFF(void)
    /* Set Power State to OFF */
    SDIO_SetPWRState(SDIO_PWRSTATE_OFF);
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:18 | 只看该作者
SD_Err SD_Init_Card(void)
    uint16_t rca = 0x01;
    if (SDIO_GetPWRState() == SDIO_PWRSTATE_OFF)
        Status = SD_REQUEST_NOT_APPLICABLE;
        return(Status);
    /* The card is not I/O only card */
    if (SDIO_SECURE_DIGITAL_IO_CARD != CardType)
        /* Send CMD2 to get the CID */
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_ALL_SEND_CID;
        SDIO_CmdInitStructure.SDIO_ResponseType = SDIO_RESPONSETYPE_LONG;
        Status = Check_Err_R2();
        if (SD_OK != Status)
          return(Status);
        CID_Tab[0] = SDIO_GetResponse(SDIO_RESP1);
        CID_Tab[1] = SDIO_GetResponse(SDIO_RESP2);
        CID_Tab[2] = SDIO_GetResponse(SDIO_RESP3);
        CID_Tab[3] = SDIO_GetResponse(SDIO_RESP4);
    /* The card is SD memory or the I/O card has the memory portion */
    if ((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) || (SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType) || (SDIO_SECURE_DIGITAL_IO_COMBO_CARD == CardType)
     || (SDIO_HIGH_CAPACITY_SD_CARD == CardType))
        /* Send CMD3 to set the RCA */
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SET_REL_ADDR;
        Status = Check_Err_R6(SDIO_SET_REL_ADDR, &rca);
            return(Status);
        RCA = rca;
        /* Send CMD9 SEND_CSD with argument as card's RCA */
        SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t)(rca << 16);
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SEND_CSD;
            return(Status);
        CSD_Tab[0] = SDIO_GetResponse(SDIO_RESP1);
        CSD_Tab[1] = SDIO_GetResponse(SDIO_RESP2);
        CSD_Tab[2] = SDIO_GetResponse(SDIO_RESP3);
        CSD_Tab[3] = SDIO_GetResponse(SDIO_RESP4);
    Status = SD_OK;
    return(Status);
SD_Err SD_Get_Card_Information(SD_CardInformation *cardinfo)
    uint8_t tmp = 0;
    /* Card type */
    cardinfo->CardType = (uint8_t)CardType;
    /* Relative card address */
    cardinfo->RCA = (uint16_t)RCA;
    /* CSD Bytes */
    /* Byte 0 */
    tmp = (uint8_t)((CSD_Tab[0] & 0xFF000000) >> 24);
    cardinfo->SD_csd.CSDStruct = (tmp & 0xC0) >> 6;
    cardinfo->SD_csd.SysSpecVersion = (tmp & 0x3C) >> 2;
    cardinfo->SD_csd.Reserved1 = tmp & 0x03;
    /* Byte 1 */
    tmp = (uint8_t)((CSD_Tab[0] & 0x00FF0000) >> 16);
    cardinfo->SD_csd.TAAC = tmp;
    /* Byte 2 */
    tmp = (uint8_t)((CSD_Tab[0] & 0x0000FF00) >> 8);
    cardinfo->SD_csd.NSAC = tmp;
    /* Byte 3 */
    tmp = (uint8_t)(CSD_Tab[0] & 0x000000FF);
    cardinfo->SD_csd.MaxBusClkFrec = tmp;
    /* Byte 4 */
    tmp = (uint8_t)((CSD_Tab[1] & 0xFF000000) >> 24);
    cardinfo->SD_csd.CardComdClasses = tmp << 4;
    /* Byte 5 */
    tmp = (uint8_t)((CSD_Tab[1] & 0x00FF0000) >> 16);
    cardinfo->SD_csd.CardComdClasses |= (tmp & 0xF0) >> 4;
    cardinfo->SD_csd.RdBlockLen = tmp & 0x0F;
    /* Byte 6 */
    tmp = (uint8_t)((CSD_Tab[1] & 0x0000FF00) >> 8);
    cardinfo->SD_csd.PartBlockRead = (tmp & 0x80) >> 7;
    cardinfo->SD_csd.WrBlockMisalign = (tmp & 0x40) >> 6;
    cardinfo->SD_csd.RdBlockMisalign = (tmp & 0x20) >> 5;
    cardinfo->SD_csd.DSRImpl = (tmp & 0x10) >> 4;
    cardinfo->SD_csd.Reserved2 = 0; /* Reserved */
    /* The card is SDSC card */
    if ((CardType == SDIO_STD_CAPACITY_SD_CARD_V1_1) || (CardType == SDIO_STD_CAPACITY_SD_CARD_V2_0))
        cardinfo->SD_csd.DeviceSize = (tmp & 0x03) << 10;
        /* Byte 7 */
        tmp = (uint8_t)(CSD_Tab[1] & 0x000000FF);
        cardinfo->SD_csd.DeviceSize |= (tmp) << 2;
        /* Byte 8 */
        tmp = (uint8_t)((CSD_Tab[2] & 0xFF000000) >> 24);
        cardinfo->SD_csd.DeviceSize |= (tmp & 0xC0) >> 6;
        cardinfo->SD_csd.MaxRdCurrentVDDMin = (tmp & 0x38) >> 3;
        cardinfo->SD_csd.MaxRdCurrentVDDMax = (tmp & 0x07);
        /* Byte 9 */
        tmp = (uint8_t)((CSD_Tab[2] & 0x00FF0000) >> 16);
        cardinfo->SD_csd.MaxWrCurrentVDDMin = (tmp & 0xE0) >> 5;
        cardinfo->SD_csd.MaxWrCurrentVDDMax = (tmp & 0x1C) >> 2;
        cardinfo->SD_csd.DeviceSizeMul = (tmp & 0x03) << 1;
        /* Byte 10 */
        tmp = (uint8_t)((CSD_Tab[2] & 0x0000FF00) >> 8);
        cardinfo->SD_csd.DeviceSizeMul |= (tmp & 0x80) >> 7;
        cardinfo->CardCapacity = (cardinfo->SD_csd.DeviceSize + 1) ;
        cardinfo->CardCapacity *= (1 << (cardinfo->SD_csd.DeviceSizeMul + 2));
        cardinfo->CardBlockSize = 1 << (cardinfo->SD_csd.RdBlockLen);
        cardinfo->CardCapacity *= cardinfo->CardBlockSize;
    /* The card is SDHC card */
    else if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)
        /* Byte 7 */
        cardinfo->SD_csd.DeviceSize = (tmp & 0x3F) << 16;
        /* Byte 8 */
        cardinfo->SD_csd.DeviceSize |= (tmp << 8);
        /* Byte 9 */
        cardinfo->SD_csd.DeviceSize |= (tmp);
        /* Byte 10 */
        cardinfo->CardCapacity = (cardinfo->SD_csd.DeviceSize + 1) * 512 * 1024;
        cardinfo->CardBlockSize = 512;
    cardinfo->SD_csd.EraseGrSize = (tmp & 0x40) >> 6;
    cardinfo->SD_csd.EraseGrMul = (tmp & 0x3F) << 1;
    /* Byte 11 */
    tmp = (uint8_t)(CSD_Tab[2] & 0x000000FF);
    cardinfo->SD_csd.EraseGrMul |= (tmp & 0x80) >> 7;
    cardinfo->SD_csd.WrProtectGrSize = (tmp & 0x7F);
    /* Byte 12 */
    tmp = (uint8_t)((CSD_Tab[3] & 0xFF000000) >> 24);
    cardinfo->SD_csd.WrProtectGrEnable = (tmp & 0x80) >> 7;
    cardinfo->SD_csd.ManDeflECC = (tmp & 0x60) >> 5;
    cardinfo->SD_csd.WrSpeedFact = (tmp & 0x1C) >> 2;
    cardinfo->SD_csd.MaxWrBlockLen = (tmp & 0x03) << 2;
    /* Byte 13 */
    tmp = (uint8_t)((CSD_Tab[3] & 0x00FF0000) >> 16);
    cardinfo->SD_csd.MaxWrBlockLen |= (tmp & 0xC0) >> 6;
    cardinfo->SD_csd.WriteBlockPaPartial = (tmp & 0x20) >> 5;
    cardinfo->SD_csd.Reserved3 = 0;
    cardinfo->SD_csd.ContentProtectAppli = (tmp & 0x01);
    /* Byte 14 */
    tmp = (uint8_t)((CSD_Tab[3] & 0x0000FF00) >> 8);
    cardinfo->SD_csd.FileFormatGrouop = (tmp & 0x80) >> 7;
    cardinfo->SD_csd.CopyFlag = (tmp & 0x40) >> 6;
    cardinfo->SD_csd.PermWrProtect = (tmp & 0x20) >> 5;
    cardinfo->SD_csd.TempWrProtect = (tmp & 0x10) >> 4;
    cardinfo->SD_csd.FileFormat = (tmp & 0x0C) >> 2;
    cardinfo->SD_csd.ECC = (tmp & 0x03);
    /* Byte 15 */
    tmp = (uint8_t)(CSD_Tab[3] & 0x000000FF);
    cardinfo->SD_csd.CSD_CRC = (tmp & 0xFE) >> 1;
    cardinfo->SD_csd.Reserved4 = 1;
    /* CID Bytes */
    /* Byte 0 */
    tmp = (uint8_t)((CID_Tab[0] & 0xFF000000) >> 24);
    cardinfo->SD_cid.ManufacturerID = tmp;
    /* Byte 1 */
    tmp = (uint8_t)((CID_Tab[0] & 0x00FF0000) >> 16);
    cardinfo->SD_cid.OEM_AppliID = tmp << 8;
    /* Byte 2 */
    tmp = (uint8_t)((CID_Tab[0] & 0x000000FF00) >> 8);
    cardinfo->SD_cid.OEM_AppliID |= tmp;
    /* Byte 3 */
    tmp = (uint8_t)(CID_Tab[0] & 0x000000FF);
    cardinfo->SD_cid.ProdName1 = tmp << 24;
    /* Byte 4 */
    tmp = (uint8_t)((CID_Tab[1] & 0xFF000000) >> 24);
    cardinfo->SD_cid.ProdName1 |= tmp << 16;
    /* Byte 5 */
    tmp = (uint8_t)((CID_Tab[1] & 0x00FF0000) >> 16);
    cardinfo->SD_cid.ProdName1 |= tmp << 8;
    /* Byte 6 */
    tmp = (uint8_t)((CID_Tab[1] & 0x0000FF00) >> 8);
    cardinfo->SD_cid.ProdName1 |= tmp;
    /* Byte 7 */
    tmp = (uint8_t)(CID_Tab[1] & 0x000000FF);
    cardinfo->SD_cid.ProdName2 = tmp;
    /* Byte 8 */
    tmp = (uint8_t)((CID_Tab[2] & 0xFF000000) >> 24);
    cardinfo->SD_cid.ProdRev = tmp;
    /* Byte 9 */
    tmp = (uint8_t)((CID_Tab[2] & 0x00FF0000) >> 16);
    cardinfo->SD_cid.ProdSN = tmp << 24;
    /* Byte 10 */
    tmp = (uint8_t)((CID_Tab[2] & 0x0000FF00) >> 8);
    cardinfo->SD_cid.ProdSN |= tmp << 16;
    /* Byte 11 */
    tmp = (uint8_t)(CID_Tab[2] & 0x000000FF);
    cardinfo->SD_cid.ProdSN |= tmp << 8;
    /* Byte 12 */
    tmp = (uint8_t)((CID_Tab[3] & 0xFF000000) >> 24);
    cardinfo->SD_cid.ProdSN |= tmp;
    /* Byte 13 */
    tmp = (uint8_t)((CID_Tab[3] & 0x00FF0000) >> 16);
    cardinfo->SD_cid.Reserved1 |= (tmp & 0xF0) >> 4;
    cardinfo->SD_cid.ManufactDate = (tmp & 0x0F) << 8;
    /* Byte 14 */
    tmp = (uint8_t)((CID_Tab[3] & 0x0000FF00) >> 8);
    cardinfo->SD_cid.ManufactDate |= tmp;
    /* Byte 15 */
    tmp = (uint8_t)(CID_Tab[3] & 0x000000FF);
    cardinfo->SD_cid.CID_CRC = (tmp & 0xFE) >> 1;
    cardinfo->SD_cid.Reserved2 = 1;
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:31 | 只看该作者
SD_Err SD_BusWide_Configure(uint32_t WideMode)
    /* MMC Card doesn't support this feature */
    if (SDIO_MULTIMEDIA_CARD == CardType)
        Status = SD_UNSUPPORTED_FEATURE;
        return(Status);
    else if ((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) || (SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType) || (SDIO_HIGH_CAPACITY_SD_CARD == CardType))
        if (SDIO_BUSMODE_8B == WideMode)
            return(Status);
        else if (SDIO_BUSMODE_4B == WideMode)
            Status = WideBus_Enable(ENABLE);
            if (SD_OK == Status)
                SDIO_InitStructure.SDIO_ClockDiv = 0x01;
                SDIO_InitStructure.SDIO_BusMode = SDIO_BUSMODE_4B;
        else
            Status = WideBus_Enable(DISABLE);
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:32 | 只看该作者
SD_Err SD_Set_Devicemode(uint32_t Mode)
    /* Select the transfer mode */
    if ((Mode == SD_DMA_MODE) || (Mode == SD_POLLING_MODE))
       TransmissionMode = Mode;
    else
        Status = SD_INVALID_PARAMETER;
    return(Status);
SD_Err SD_Select_Deselect_Card(uint32_t addr)
    /* Send CMD7 SDIO_SEL_DESEL_CARD */
    SDIO_CmdInitStructure.SDIO_CMDParameter =  addr;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SEL_DESEL_CARD;
    Status = Check_Err_R1(SDIO_SEL_DESEL_CARD);
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:33 | 只看该作者
SD_Err SD_ReadBlock(uint32_t addr, uint32_t *readbuff, uint16_t BlockSize)
    uint32_t count = 0, *tempbuff = readbuff;
    uint8_t power = 0;
    if (NULL == readbuff)
        return(Status);
    TransferError = SD_OK;
    TransferEnd = 0;
    TotalNumberOfBytes = 0;
    /* Clear all DSM configuration */
    SDIO_DataInitStructure.SDIO_DataTimeOut = 0;
    SDIO_DataInitStructure.SDIO_DataLength = 0;
    SDIO_DataInitStructure.SDIO_DataBlockSize = SDIO_DATABLOCKSIZE_1B;
    SDIO_DataInitStructure.SDIO_TransDirection = SDIO_TRANSDIRECTION_TOCARD;
    SDIO_DataInitStructure.SDIO_TransMode = SDIO_TRANSMODE_BLOCK;
    SDIO_DataInitStructure.SDIO_DSMState = SDIO_DSMSTATE_DISABLE;
    SDIO_DataConfig(&SDIO_DataInitStructure);
    SDIO_DMA_Enable(DISABLE);
    /* Check whether the card is locked */
    if (SDIO_GetResponse(SDIO_RESP1) & SD_CARD_LOCKED)
        Status = SD_LOCK_UNLOCK_FAILED;
        return(Status);
    /* SDHC card the blocksize is fixed in 512B */
        BlockSize = 512;
        addr /= 512;
    if ((BlockSize > 0) && (BlockSize <= 2048) && ((BlockSize & (BlockSize - 1)) == 0))
        power = Bytes_To_PowerTwo(BlockSize);
        /* CMD16 Set Block Size for Card */
        SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t) BlockSize;
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SET_BLOCKLEN;
        Status = Check_Err_R1(SDIO_SET_BLOCKLEN);
            return(Status);
    else
        return(Status);
    /* SDIO data transmisson config */
    SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT;
    SDIO_DataInitStructure.SDIO_DataLength = BlockSize;
    SDIO_DataInitStructure.SDIO_DataBlockSize = (uint32_t) power << 4;
    SDIO_DataInitStructure.SDIO_TransDirection = SDIO_TRANSDIRECTION_TOSDIO;
    SDIO_DataInitStructure.SDIO_DSMState = SDIO_DSMSTATE_ENABLE;
    TotalNumberOfBytes = BlockSize;
    StopCondition = 0;
    DestBuffer = readbuff;
    /* Send CMD17 READ_SINGLE_BLOCK */
    SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t)addr;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_READ_SINGLE_BLOCK;
    Status = Check_Err_R1(SDIO_READ_SINGLE_BLOCK);
        return(Status);
    /* In case of single block transfer, no need of stop transfer at all.*/
    if (TransmissionMode == SD_POLLING_MODE)
    /* Polling mode */
        while (!(SDIO->STR &(SDIO_FLAG_RXORE | SDIO_FLAG_DTCRCFAIL | SDIO_FLAG_DTTMOUT | SDIO_FLAG_DTBLKEND | SDIO_FLAG_STBITE)))
            if (SDIO_GetBitState(SDIO_FLAG_RXFIFOHF) != RESET)
                for (count = 0; count < 8; count++)
                    *(tempbuff + count) = SDIO_ReadData();
                tempbuff += 8;
        if (SDIO_GetBitState(SDIO_FLAG_DTTMOUT) != RESET)
            SDIO_ClearBitState(SDIO_FLAG_DTTMOUT);
            Status = SD_DATA_TIMEOUT;
            return(Status);
        else if (SDIO_GetBitState(SDIO_FLAG_DTCRCFAIL) != RESET)
            SDIO_ClearBitState(SDIO_FLAG_DTCRCFAIL);
            Status = SD_DATA_CRC_FAIL;
            return(Status);
        else if (SDIO_GetBitState(SDIO_FLAG_RXORE) != RESET)
            SDIO_ClearBitState(SDIO_FLAG_RXORE);
            Status = SD_RX_OVERRUN;
            return(Status);
        else if (SDIO_GetBitState(SDIO_FLAG_STBITE) != RESET)
            SDIO_ClearBitState(SDIO_FLAG_STBITE);
            Status = SD_START_BIT_ERR;
            return(Status);
        while (SDIO_GetBitState(SDIO_FLAG_RXDTVAL) != RESET)
            *tempbuff = SDIO_ReadData();
            tempbuff++;
        /* Clear all the static flags */
        SDIO_ClearBitState(SDIO_STATIC_FLAGS);
    else if (TransmissionMode == SD_DMA_MODE)
        /* DMA mode */
        /* Enable SDIO corresponding interrupts */
        SDIO_INTConfig(SDIO_INT_CCRCFAIL | SDIO_INT_DTTMOUT | SDIO_INT_DTEND | SDIO_INT_RXORE | SDIO_INT_STBITE, ENABLE);
        /* Enable the DMA of SDIO */
        SDIO_DMA_Enable(ENABLE);
        DMA_RxConfiguration(readbuff, BlockSize);
        while (DMA_GetBitState(DMA2_FLAG_TC4) == RESET)
    return(Status);
SD_Err SD_ReadMultiBlocks(uint32_t addr, uint32_t *readbuff, uint16_t BlockSize, uint32_t NumberOfBlocks)
    uint8_t power = 0;
        return(Status);
    TransferEnd = 0;
        return(Status);
        BlockSize = 512;
        addr /= 512;
    if ((BlockSize > 0) && (BlockSize <= 2048) && (0 == (BlockSize & (BlockSize - 1))))
            return(Status);
    else
        return(Status);
    if (NumberOfBlocks > 1)
        /* Common to all modes */
        if (NumberOfBlocks * BlockSize > SD_MAX_DATA_LENGTH)
          return(Status);
        TotalNumberOfBytes = NumberOfBlocks * BlockSize;
        StopCondition = 1;
        SDIO_DataInitStructure.SDIO_DataLength = NumberOfBlocks * BlockSize;
        /* Send CMD18 READ_MULT_BLOCK */
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_READ_MULT_BLOCK;
        Status = Check_Err_R1(SDIO_READ_MULT_BLOCK);
            return(Status);
            /* Polling mode */
            while (!(SDIO->STR &(SDIO_FLAG_RXORE | SDIO_FLAG_DTCRCFAIL | SDIO_FLAG_DTEND | SDIO_FLAG_DTTMOUT | SDIO_FLAG_STBITE)))
                    for (count = 0; count < SD_HALFFIFO; count++)
                    tempbuff += SD_HALFFIFO;
                return(Status);
                return(Status);
                return(Status);
                return(Status);
                tempbuff++;
            if (SDIO_GetBitState(SDIO_FLAG_DTEND) != RESET)
                /* In Case Of sdcard Send Command STOP_TRANSMISSION */
                if ((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) || (SDIO_HIGH_CAPACITY_SD_CARD == CardType) || (SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType))
                    /* Send CMD12 STOP_TRANSMISSION */
                    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_STOP_TRANSMISSION;
                    Status = Check_Err_R1(SDIO_STOP_TRANSMISSION);
                        return(Status);
            /* DMA mode */
            SDIO_INTConfig(SDIO_INT_DTCRCFAIL | SDIO_INT_DTTMOUT | SDIO_INT_DTEND | SDIO_INT_RXORE | SDIO_INT_STBITE, ENABLE);
            DMA_RxConfiguration(readbuff, (NumberOfBlocks * BlockSize));
            while ((TransferEnd == 0) && (TransferError == SD_OK))
            if (TransferError != SD_OK)
                return(TransferError);
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:47 | 只看该作者
SD_Err SD_WriteBlock(uint32_t addr, uint32_t *writebuff, uint16_t BlockSize)
    uint8_t  power = 0, cardstate = 0;
    uint32_t timeout = 0, bytestransferred = 0;
    uint32_t cardstatus = 0, count = 0, restwords = 0;
    uint32_t *tempbuff = writebuff;
    if (writebuff == NULL)
        return(Status);
    TransferEnd = 0;
        return(Status);
        BlockSize = 512;
        addr /= 512;
    /* Set the block size, both on controller and card */
            return(Status);
    else
        return(Status);
    /* Wait till card is ready for writing data */
    SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t) (RCA << 16);
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SEND_STATUS;
    Status = Check_Err_R1(SDIO_SEND_STATUS);
        return(Status);
    cardstatus = SDIO_GetResponse(SDIO_RESP1);
    timeout = 10000;
    while (((cardstatus & 0x00000100) == 0) && (timeout > 0))
        /* Card is busy, continue to send CMD13 to polling the state of the card */
        timeout--;
            return(Status);
    /* Polling timeout */
    if (timeout == 0)
        return(SD_ERROR);
    /* Send CMD24 WRITE_SINGLE_BLOCK */
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_WRITE_SINGLE_BLOCK;
    Status = Check_Err_R1(SDIO_WRITE_SINGLE_BLOCK);
        return(Status);
    StopCondition = 0;
    SrcBuffer = writebuff;
    /* In case of single data block transfer no need of stop command at all */
        /* Polling mode */
        while (!(SDIO->STR & (SDIO_FLAG_DTBLKEND | SDIO_FLAG_TXURE | SDIO_FLAG_DTCRCFAIL | SDIO_FLAG_DTTMOUT | SDIO_FLAG_STBITE)))
            if (SDIO_GetBitState(SDIO_FLAG_TXFIFOHE) != RESET)
                if ((TotalNumberOfBytes - bytestransferred) < 32)
                    restwords = ((TotalNumberOfBytes - bytestransferred) % 4 == 0) ? ((TotalNumberOfBytes - bytestransferred) / 4) : (( TotalNumberOfBytes -  bytestransferred) / 4 + 1);
                    for (count = 0; count < restwords; count++, tempbuff++, bytestransferred += 4)
                        SDIO_WriteData(*tempbuff);
                else
                        SDIO_WriteData(*(tempbuff + count));
                    tempbuff += 8;
                    bytestransferred += 32;
            return(Status);
            return(Status);
        else if (SDIO_GetBitState(SDIO_FLAG_TXURE) != RESET)
            SDIO_ClearBitState(SDIO_FLAG_TXURE);
            Status = SD_TX_UNDERRUN;
            return(Status);
            return(Status);
        /* DMA mode */
        SDIO_INTConfig(SDIO_INT_DTCRCFAIL | SDIO_INT_DTTMOUT | SDIO_INT_DTEND | SDIO_INT_TXURE | SDIO_INT_STBITE, ENABLE);
        DMA_TxConfiguration(writebuff, BlockSize);
    /* Wait till the card is in programming state */
    Status = IsCardProgramming(&cardstate);
    while ((Status == SD_OK) && ((cardstate == SD_CARD_PROGRAMMING) || (cardstate == SD_CARD_RECEIVING)))
    return(Status);
SD_Err SD_WriteMultiBlocks(uint32_t addr, uint32_t *writebuff, uint16_t BlockSize, uint32_t NumberOfBlocks)
    uint32_t bytestransferred = 0;
    uint32_t count = 0, restwords = 0;
        return(Status);
    TransferEnd = 0;
        return(Status);
        BlockSize = 512;
        addr /= 512;
            return(Status);
    else
        return(Status);
    /* Wait till card is ready for data writing */
        return(Status);
            return(Status);
            /* CMD55 the next command is Application Specific Commands */
                return(Status);
            /*ACMD23 Pre-erased to improve performance */
            SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t)NumberOfBlocks;
            SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SET_BLOCK_COUNT;
            Status = Check_Err_R1(SDIO_SET_BLOCK_COUNT);
                return(Status);
        /* Send CMD25 WRITE_MULT_BLOCK with argument data address */
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_WRITE_MULT_BLOCK;
        Status = Check_Err_R1(SDIO_WRITE_MULT_BLOCK);
            return(Status);
        StopCondition = 1;
            /* Polling mode */
            while (!(SDIO->STR & (SDIO_FLAG_TXURE | SDIO_FLAG_DTCRCFAIL | SDIO_FLAG_DTEND | SDIO_FLAG_DTTMOUT | SDIO_FLAG_STBITE)))
                    if (!((TotalNumberOfBytes - bytestransferred) < SD_HALFFIFOBYTES))
                        bytestransferred += SD_HALFFIFOBYTES;
                    else
                                    ((TotalNumberOfBytes - bytestransferred) / 4 + 1);
                return(Status);
                return(Status);
                return(Status);
                return(Status);
                        return(Status);
            /* DMA mode */
            DMA_TxConfiguration(writebuff, (NumberOfBlocks * BlockSize));
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:48 | 只看该作者
SDTransferState SD_GetTransferState(void)
    if (SDIO->STR & (SDIO_FLAG_TXRUN | SDIO_FLAG_RXRUN))
        return(SD_TRANSFER_IN_PROGRESS);
    else
        return(SD_NO_TRANSFER);
SD_Err SD_Stop_Transfer(void)
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:49 | 只看该作者
SD_Err SD_Erase(uint32_t startaddr, uint32_t endaddr)
    uint32_t delay = 0;
    __IO uint32_t maxdelay = 0;
    uint8_t cardstate = 0;
    /* Check if the card command class supports erase command */
    if ((SD_CCC_ERASE&SDIOInfo.SD_csd.CardComdClasses) == 0)
        return(Status);
    maxdelay = 72000 / ((SDIO->CLKCTLR & 0xFF) + 2);
        return(Status);
        startaddr /= 512;
        endaddr /= 512;
    /* According to sd-card spec 1.0 ERASE_GROUP_START (CMD32) and erase_group_end(CMD33) */
        /* Send CMD32 SD_ERASE_GRP_START with argument as addr  */
        SDIO_CmdInitStructure.SDIO_CMDParameter = startaddr;
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SD_ERASE_GRP_START;
        Status = Check_Err_R1(SDIO_SD_ERASE_GRP_START);
            return(Status);
        /* Send CMD33 SD_ERASE_GRP_END with argument as addr  */
        SDIO_CmdInitStructure.SDIO_CMDParameter = endaddr;
        SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SD_ERASE_GRP_END;
        Status = Check_Err_R1(SDIO_SD_ERASE_GRP_END);
            return(Status);
    /* Send CMD38 ERASE */
    SDIO_CmdInitStructure.SDIO_CMDParameter = 0;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_ERASE;
    Status = Check_Err_R1(SDIO_ERASE);
        return(Status);
    for (delay = 0; delay < maxdelay; delay++)
    while ((Status == SD_OK) && ((SD_CARD_PROGRAMMING == cardstate) || (SD_CARD_RECEIVING == cardstate)))
    return(Status);
SD_Err SD_Send_Status(uint32_t *pcardstatus)
    if (pcardstatus == NULL)
        return(Status);
    /* CMD13 to polling the state of the card */
    SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t) RCA << 16;
        return(Status);
    *pcardstatus = SDIO_GetResponse(SDIO_RESP1);
    return(Status);
SD_Err SD_Send_SDStatus(uint32_t *psdstatus)
    uint32_t count = 0;
        return(Status);
    /* Set block size for card if it is not equal to current block size for card. */
    SDIO_CmdInitStructure.SDIO_CMDParameter = 64;
        return(Status);
    /* CMD55 the next command is Application Specific Command*/
        return(Status);
    SDIO_DataInitStructure.SDIO_DataLength = 64;
    SDIO_DataInitStructure.SDIO_DataBlockSize = SDIO_DATABLOCKSIZE_64B;
    /* Send ACMD13 SD_APP_STAUS  with argument as card's RCA.*/
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SD_APP_STAUS;
    Status = Check_Err_R1(SDIO_SD_APP_STAUS);
        return(Status);
                *(psdstatus + count) = SDIO_ReadData();
            psdstatus += 8;
        return(Status);
        return(Status);
        return(Status);
        return(Status);
        *psdstatus = SDIO_ReadData();
        psdstatus++;
    /* Clear all the static status flags*/
    psdstatus -= 16;
    for (count = 0; count < 16; count++)
        psdstatus[count] = ((psdstatus[count] & SD_0TO7BITS) << 24) |((psdstatus[count] & SD_8TO15BITS) << 8) |
                           ((psdstatus[count] & SD_16TO23BITS) >> 8) |((psdstatus[count] & SD_24TO31BITS) >> 24);
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:50 | 只看该作者
SD_Err SD_IRQ(void)
    if (SDIO_GetIntBitState(SDIO_INT_DTEND) != RESET)
        /* Receive data in polling mode, get the remainning words in the FIFO*/
        if (TransmissionMode != SD_DMA_MODE)
            while ((SDIO_GetBitState(SDIO_FLAG_RXDTVAL) != RESET)  &&  (NumberOfBytes < TotalNumberOfBytes))
                *DestBuffer = SDIO_ReadData();
                DestBuffer++;
                NumberOfBytes += 4;
        /* Mul blocks operation, must send CMD12 to stop data transfer*/
        if (StopCondition == 1)
            TransferError = SD_Stop_Transfer();
        else
        SDIO_ClearIntBitState(SDIO_INT_DTEND);
        /* Disenable all the interrupts*/
                       SDIO_INT_TXFIFOHE | SDIO_INT_RXFIFOHF | SDIO_INT_TXURE |
                       SDIO_INT_RXORE | SDIO_INT_STBITE, DISABLE);
        TransferEnd = 1;
        NumberOfBytes = 0;
    if (SDIO_GetIntBitState(SDIO_INT_DTCRCFAIL) != RESET)
        SDIO_ClearIntBitState(SDIO_INT_DTCRCFAIL);
        NumberOfBytes = 0;
        TransferError = SD_DATA_CRC_FAIL;
        return(SD_DATA_CRC_FAIL);
    if (SDIO_GetIntBitState(SDIO_INT_DTTMOUT) != RESET)
        SDIO_ClearIntBitState(SDIO_INT_DTTMOUT);
        NumberOfBytes = 0;
        TransferError = SD_DATA_TIMEOUT;
        return(SD_DATA_TIMEOUT);
    if (SDIO_GetIntBitState(SDIO_INT_RXORE) != RESET)
        SDIO_ClearIntBitState(SDIO_INT_RXORE);
        NumberOfBytes = 0;
        TransferError = SD_RX_OVERRUN;
        return(SD_RX_OVERRUN);
    if (SDIO_GetIntBitState(SDIO_INT_TXURE) != RESET)
        SDIO_ClearIntBitState(SDIO_INT_TXURE);
        NumberOfBytes = 0;
        TransferError = SD_TX_UNDERRUN;
        return(SD_TX_UNDERRUN);
    if (SDIO_GetIntBitState(SDIO_INT_STBITE) != RESET)
        SDIO_ClearIntBitState(SDIO_INT_STBITE);
        NumberOfBytes = 0;
        TransferError = SD_START_BIT_ERR;
        return(SD_START_BIT_ERR);
    return(SD_OK);
static SD_Err Check_Err(void)
    uint32_t timeout;
    timeout = 10000;
    while ((timeout > 0) && (SDIO_GetBitState(SDIO_FLAG_CMDSENT) == RESET))
        timeout--;
    if (timeout == 0)
        Status = SD_CMD_RSP_TIMEOUT;
        return(Status);
    return(Status);
chenqiang10|  楼主 | 2018-9-30 19:51 | 只看该作者
static SD_Err Check_Err_R7(void)
    uint32_t status;
    uint32_t timeout = 10000;
    status = SDIO->STR;
    while (!(status & (SDIO_FLAG_CCRCFAIL | SDIO_FLAG_CMDREND | SDIO_FLAG_CMDTMOUT)) && (timeout > 0))
        timeout--;
        status = SDIO->STR;
    if ((timeout == 0) || (status & SDIO_FLAG_CMDTMOUT))
        /* Card is not V2.0 complient or card does not support the set voltage range */
        SDIO_ClearBitState(SDIO_FLAG_CMDTMOUT);
        return(Status);
    if (status & SDIO_FLAG_CMDREND)
        /* Card is SD V2.0 compliant */
        Status = SD_OK;
        SDIO_ClearBitState(SDIO_FLAG_CMDREND);
        return(Status);
    return(Status);
