[应用相关]
原子操作
1014|8
hfdy01|  楼主 | 2018-10-8 21:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用TIME0循环读四路风扇转速,是直接用time0来计算脉宽,我是循环开中断来做的,
(TA0CCTL1&= ~CCIE;  TA0CCTL2|= CCIE;)-->(TA0CCTL2&= ~CCIE;  TA0CCTL3|= CCIE;)......
(TA0CCTL4&= ~CCIE;  TA0CCTL1|= CCIE;)
在中断里面关掉自己中断的使能和 TA0CTL|=TACLR;有没有潜在的危险?
char  fan_times_tmp = 0;                   //用来记录次数的中间变量
char  fan_flag = 0;                        //进入中断标志位
#pragma vector=TIMER0_A1_VECTOR
//__interrupt void TIMER0_A1_ISR(void)
__interrupt void TIMER0_A(void)
  switch(TA0IV)
    case  0: break;                             // No interrupt
    case  2:
            if((TA0CCTL1&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
              P3OUT ^= BIT2;
           else if((TA0CCTL1&CM_2)&&(fan_flag == 1))
             speed_tmp[fan_times_tmp++] = TA0CCR1;
              fan_flag = 0;
              if(fan_times_tmp == fan_data_time)
                 fan_a = 0;
                 for(fan_i=0;fan_i<fan_data_time;fan_i++)
                 fan_a +=speed_tmp[fan_i];
                 fan_a >>= 5;              //除以4求平均值,以免数据不停跳变
                 fan_speed[0] = fan_a;
                 fan_i = 0;
              //   TA0CCTL1&= ~CCIE;
              //   TA0CCTL2|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL1 &= ~CCIFG; break;
                break;                          // CCR1 not used
    case  4:
      if((TA0CCTL2&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
           else if((TA0CCTL2&CM_2)&&(fan_flag == 1))
              speed_tmp[fan_times_tmp++] = TA0CCR2;
              fan_flag = 0;
                 fan_a = 0;
                 fan_i = 0;
                 TA0CCTL2&= ~CCIE;
                 TA0CCTL3|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL2 &= ~CCIFG;
      break;
      break;            // CCR2 not used
    case  6:
      if((TA0CCTL3&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
           else if((TA0CCTL3&CM_2)&&(fan_flag == 1))
              speed_tmp[fan_times_tmp++] = TA0CCR3;
              fan_flag = 0;
                 fan_a = 0;
                 fan_i = 0;
                 TA0CCTL3&= ~CCIE;
                 TA0CCTL1|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL3 &= ~CCIFG;
      break;         // reserved
    case  8:
      if((TA0CCTL4&CM_2)&&(fan_flag == 0))
            {                                   //清计数器
              TA0CTL|=TACLR;
              fan_flag = 1;
           else if((TA0CCTL4&CM_2)&&(fan_flag == 1))
              speed_tmp[fan_times_tmp++] = TA0CCR4;
              fan_flag = 0;
                 fan_a = 0;
                 fan_i = 0;
                 TA0CCTL4&= ~CCIE;
                 TA0CCTL1|= CCIE;
                 fan_times_tmp = 0;
      TA0CCTL4 &= ~CCIFG;
      break;         // reserved
    case 10:                           // reserved
    case 12:                         // reserved
    case 14: //TA1CCTL1 &= ~COV;                  // overflow
      break;
    default:break;
CallReceiver| | 2018-10-8 21:40 | 只看该作者
会不会在执行TA2CCTL1 &= ~CCIE;被中断硬件修改CCIFG位造成不可预知的情况?
boy1990| | 2018-10-8 21:41 | 只看该作者
测脉宽用“捕足”不行吗?
sourceInsight| | 2018-10-8 21:50 | 只看该作者
测脉宽可以用外部中断捕获上下沿的时间点来计算出来
bbapple| | 2018-10-8 21:51 | 只看该作者
楼主的这个问题其实是中断的优先级问题以及中断嵌套问题。
handleMessage| | 2018-10-8 21:54 | 只看该作者
楼主在中断中关闭这个中断的使能,是不会被打断的,所以不会有风险。
labasi| | 2018-10-9 12:13 | 只看该作者
何谓原子操作呢
paotangsan| | 2018-10-9 12:37 | 只看该作者
直接关闭中断操作即可啊
wakayi| | 2018-10-9 12:52 | 只看该作者
非常感谢楼主分享
