#include "MG32x02z_DRV.H"
#include "MG32x02z__Common_DRV.h"
#include <stdio.h>
typedef uint8_t u8;
typedef uint16_t u16;
typedef uint32_t u32;
typedef uint64_t u64;
void SysTick_Handler(void)
//to do......
IncTick();
// <h> Delay Period Setting
// <o0> Clock Prescaler (1~256) <1-256>
// <o1> Main Counter (1~256) <1-256>
//if user wants to delay 1ms and CK_TM00_PR is 12MHz.
//The Total clocks is 12M*1ms = 12000.
//User can set "clock prescaler"=100 and "pulse width"=120 .
#define Simple_Time_Prescaler 100
#define Simple_Time_MainCounter 120
#define URTX URT0
void CSC_Init (void)
CSC_PLL_TyprDef CSC_PLL_CFG;
UnProtectModuleReg(MEMprotect); // Setting flash wait state
MEM_SetFlashWaitState(MEM_FWAIT_ONE); // 50MHz> Sysclk >=25MHz
UnProtectModuleReg(CSCprotect);
CSC_CK_APB_Divider_Select(APB_DIV_1); // Modify CK_APB divider APB=CK_MAIN/1
CSC_CK_AHB_Divider_Select(AHB_DIV_1); // Modify CK_AHB divider AHB=APB/1
/* CK_HS selection */
CSC_IHRCO_Select(IHRCO_12MHz); // IHRCO Sel 12MHz
CSC_IHRCO_Cmd(ENABLE);
while(CSC_GetSingleFlagStatus(CSC_IHRCOF) == DRV_Normal);
CSC_ClearFlag(CSC_IHRCOF);
CSC_CK_HS_Select(HS_CK_IHRCO); // CK_HS select IHRCO
/* PLL */
CSC_PLL_CFG.InputDivider=PLLI_DIV_2; // 12M/2=6M
CSC_PLL_CFG.Multiplication=PLLIx16; // 6M*16=96M
CSC_PLL_CFG.OutputDivider=PLLO_DIV_2; // PLLO=96M/2=48M
CSC_PLL_Config(&CSC_PLL_CFG);
CSC_PLL_Cmd(ENABLE);
while(CSC_GetSingleFlagStatus(CSC_PLLF) == DRV_Normal);
CSC_ClearFlag(CSC_PLLF);
/* CK_MAIN */
CSC_CK_MAIN_Select(MAIN_CK_HS);
/* Configure ICKO function */
/* Configure peripheral clock */
CSC_PeriphProcessClockSource_Config(CSC_UART0_CKS, CK_APB);
CSC_PeriphOnModeClock_Config(CSC_ON_UART0,ENABLE);
CSC_PeriphOnModeClock_Config(CSC_ON_PortB,ENABLE);
CSC_PeriphOnModeClock_Config(CSC_ON_PortC,ENABLE);
CSC_PeriphOnModeClock_Config(CSC_ON_PortE,ENABLE);
CSC_PeriphProcessClockSource_Config(CSC_I2C0_CKS, CK_APB);
CSC_PeriphOnModeClock_Config(CSC_ON_I2C0, ENABLE); // Enable IIC0 module clock
CSC_PeriphOnModeClock_Config(CSC_ON_DMA,ENABLE);
void TM00_Delay_Init(void)
TM_TimeBaseInitTypeDef TM_TimeBase_InitStruct;
// make sure :
//===Set CSC init====
//MG32x02z_CSC_Init.h(Configuration Wizard)
//Select CK_HS source = CK_IHRCO
//Select IHRCO = 12M
//Select CK_MAIN Source = CK_HS
//Configure PLL->Select APB Prescaler = CK_MAIN/1
//Configure Peripheral On Mode Clock->TM00 = Enable
// 1.initial TimeBase structure
TM_TimeBaseStruct_Init(&TM_TimeBase_InitStruct);
// modify parameter
TM_TimeBase_InitStruct.TM_Period = Simple_Time_MainCounter - 1;
TM_TimeBase_InitStruct.TM_Prescaler = Simple_Time_Prescaler - 1;
TM_TimeBase_InitStruct.TM_CounterMode = Cascade;
TM_TimeBase_Init(TM00, &TM_TimeBase_InitStruct);
TM_ClearFlag(TM00, TMx_TOF);
// 3.Start TM00
TM_Timer_Cmd(TM00, ENABLE);
// 4.until TOF flag event (polling)
while(TM_GetSingleFlagStatus(TM00, TMx_TOF) == DRV_UnHappened);
TM_ClearFlag(TM00, TMx_TOF); // clear TOF flag
// TM_Timer_Cmd(TM00, DISABLE);
void delay_ms(int i)
int x=0;
for(x=0;x<i;x++)
int fputc(int ch,FILE *f)
URT_SetTXData(URTX,1,ch);
while(URT_GetITSingleFlagStatus(URTX,URT_IT_TC)==DRV_UnHappened);
URT_ClearITFlag(URTX,URT_IT_TC);
return ch;
void UartSendByte(int ch)
void URT0_Init(void)
URT_BRG_TypeDef URT_BRG;
URT_Data_TypeDef DataDef;
PIN_InitTypeDef PINX_InitStruct;
//==Set GPIO init
//PB8 PPO TX ,PB9 ODO RX
PINX_InitStruct.PINX_Mode = PINX_Mode_PushPull_O; // Pin select Push Pull mode
PINX_InitStruct.PINX_PUResistant = PINX_PUResistant_Enable; // Enable pull up resistor
PINX_InitStruct.PINX_Speed = PINX_Speed_Low;
PINX_InitStruct.PINX_OUTDrive = PINX_OUTDrive_Level0; // Pin output driver full strength.
PINX_InitStruct.PINX_FilterDivider = PINX_FilterDivider_Bypass; // Pin input deglitch filter clock divider bypass
PINX_InitStruct.PINX_Inverse = PINX_Inverse_Disable; // Pin input data not inverse
PINX_InitStruct.PINX_Alternate_Function = 3; // Pin AFS = URT0_TX
GPIO_PinMode_Config(PINB(8),&PINX_InitStruct); // TXD at PB8
PINX_InitStruct.PINX_Mode = PINX_Mode_OpenDrain_O; // Pin select Open Drain mode
PINX_InitStruct.PINX_Alternate_Function = 3; // Pin AFS = URT0_RX
GPIO_PinMode_Config(PINB(9),&PINX_InitStruct); // RXD at PB9
//=====Set Clock=====//
//---Set BaudRate---//
URT_BRG.URT_InteranlClockSource = URT_BDClock_PROC;
URT_BRG.URT_BaudRateMode = URT_BDMode_Separated;
URT_BRG.URT_PrescalerCounterReload = 0; //Set PSR
URT_BRG.URT_BaudRateCounterReload = 3; //Set RLR
URT_BaudRateGenerator_Config(URTX, &URT_BRG); //BR115200 = f(CK_URTx)/(PSR+1)/(RLR+1)/(OS_NUM+1)
URT_BaudRateGenerator_Cmd(URTX, ENABLE); //Enable BaudRateGenerator
//---TX/RX Clock---//
URT_TXClockSource_Select(URTX, URT_TXClock_Internal); //URT_TX use BaudRateGenerator
URT_RXClockSource_Select(URTX, URT_RXClock_Internal); //URT_RX use BaudRateGenerator
URT_TXOverSamplingSampleNumber_Select(URTX, 25); //Set TX OS_NUM
URT_RXOverSamplingSampleNumber_Select(URTX, 25); //Set RX OS_NUM
URT_RXOverSamplingMode_Select(URTX, URT_RXSMP_3TIME);
URT_TX_Cmd(URTX, ENABLE); //Enable TX
URT_RX_Cmd(URTX, ENABLE); //Enable RX
//=====Set Mode=====//
//---Set Data character config---//
DataDef.URT_TX_DataLength = URT_DataLength_8;
DataDef.URT_RX_DataLength = URT_DataLength_8;
DataDef.URT_TX_DataOrder = URT_DataTyped_LSB;
DataDef.URT_RX_DataOrder = URT_DataTyped_LSB;
DataDef.URT_TX_Parity = URT_Parity_No;
DataDef.URT_RX_Parity = URT_Parity_No;
DataDef.URT_TX_StopBits = URT_StopBits_1_0;
DataDef.URT_RX_StopBits = URT_StopBits_1_0;
DataDef.URT_TX_DataInverse = DISABLE;
DataDef.URT_RX_DataInverse = DISABLE;
URT_DataCharacter_Config(URTX, &DataDef);
//---Set Mode Select---//
URT_Mode_Select(URTX, URT_URT_mode);
//---Set DataLine Select---//
URT_DataLine_Select(URTX, URT_DataLine_2);
//=====Set Data Control=====//
URT_RXShadowBufferThreshold_Select(URTX, URT_RXTH_1BYTE);
URT_IdlehandleMode_Select(URTX, URT_IDLEMode_No);
URT_TXGaudTime_Select(URTX, 0);
//=====Enable URT Interrupt=====//
//URT_IT_Cmd(URTX, URT_IT_RX, ENABLE);
//URT_ITEA_Cmd(URTX, ENABLE);
//NVIC_EnableIRQ(URT0_IRQn);
//=====Enable URT=====//
URT_Cmd(URTX, ENABLE);
//==See MG32x02z_URT0_IRQ.c when interrupt in
int main()
int i;
CSC_Init();
InitTick(12000000,0);
NVIC_EnableIRQ(SysTick_IRQn);
PINX_InitStruct.PINX_Mode = PINX_Mode_PushPull_O; // Pin select digital input mode
PINX_InitStruct.PINX_FilterDivider = PINX_FilterDivider_Bypass;// Pin input deglitch filter clock divider bypass
PINX_InitStruct.PINX_Alternate_Function = 0; // Pin AFS = 0
GPIO_PinMode_Config(PINE(15),&PINX_InitStruct); // D6 setup at PE15
URT0_Init();
printf("hello\n");
while(1)
PE15=0;
Delay(1000);
PE15=1;
Delay(1000);
