[应用相关]
adc中断一进去就再也出不来了
1058|14
Listate|  楼主 | 2018-10-24 20:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//#include "keypad.h"
#include "1602(zhp)LT.h"
//#include"舵机.h"
#include"BoardConfig.h"
软件延时
//typedef unsigned int uint;
//typedef unsigned char uchar;
#define CPU_F ((double)8000000)
#define DELAY_US(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define DELAY_MS(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define num 20
unsigned char wan,qian,bai,shi,ge;
unsigned int results[num]={0};
unsigned char t=0;
unsigned int ave=0;
unsigned int filter[2];
void transform(unsigned int dat)
  wan=dat/10000+0x30;
  qian=dat%10000/1000+0x30;
  bai=dat%1000/100+0x30;
  shi=dat%100/10+0x30;
  ge=dat%10+0x30;
void main()
  WDTCTL = WDTPW+WDTHOLD;  //关闭看门狗
  BCSCTL1 &= ~XT2OFF;
  while(IFG1&OFIFG)
    IFG1&= ~OFIFG;
    DELAY_US(50);
  BCSCTL2 |= SELM_2+SELS+DIVS_3; //MCLK 8M,SMCLK 1M
  lcd_init1602 ();
  //keypad_init();
  //write1char1602(0,0,i/10+0x30);
  //BoardConfig(0xb8);//11111000
  //_EINT();
  WDTCTL=WDTPW+WDTHOLD;
  P6SEL|=BIT1;
  ADC12CTL0=ADC12ON+SHT0_8+SHT1_8+MSC;
  ADC12CTL1=SHP+CONSEQ_2+CSTARTADD_1;
  ADC12MCTL1=INCH_1;
  ADC12IE=BIT1;
  ADC12CTL0|=ENC;
  _EINT();
  ADC12CTL0|=ADC12SC;
  while(2);
#pragma vector=ADC_VECTOR
__interrupt void ADC12ISR()
  ADC12IFG=0X00;
  t++;
  filter[0]=ADC12MEM0;
  if(filter[0]-filter[1]>5)
    ave=ave+filter[1];
  else
    ave=ave+filter[0];
  if(t==11)
    t=0;
    ave=(unsigned int)(ave/11);
    transform(ave);
    write1char1602(0,0,wan);
    write1char1602(1,0,qian);
    write1char1602(2,0,bai);
    write1char1602(3,0,shi);
    write1char1602(4,0,ge);
    ave=0;
  filter[1]=filter[0];
我明明读了ADC12MEM啊,为什么还是不能清除ADC12IFG呢?
Mozarts| | 2018-10-24 20:28 | 只看该作者
楼主的在中断执行的程序太多了。
_gege| | 2018-10-24 20:31 | 只看该作者
中断太多,这次完成了,下一次又接着来到了。所以总是执行中断的。
Edisons| | 2018-10-24 20:32 | 只看该作者
不知道为啥,发现好多同学喜欢在中断服务程序中放很多程序
laozhongyi| | 2018-10-24 20:34 | 只看该作者
建议把不必要的操作都放到主程序里
wanglaojii| | 2018-10-24 20:36 | 只看该作者
如果CPU的运行速度比较慢的话,在还没有运行完这些代码,ADC下一次的中断又到来了
zhouhuanの| | 2018-10-24 20:38 | 只看该作者
你在刚进行中断的时候清除了ADC的中断标志位,但是还没有跳出中断,ADC的中断标志位又置位,所以会误以为没有跳出中断
handleMessage| | 2018-10-24 20:39 | 只看该作者
建议把不必要的代码放到主函数main()里
bbapple| | 2018-10-24 20:41 | 只看该作者
可以把清除中断标志位的语句放在中断服务子程序的最后面
sourceInsight| | 2018-10-24 20:46 | 只看该作者
建议把不必要的操作都放到主程序里,让中断服务程序尽量简短
Thorald| | 2018-10-24 21:00 | 只看该作者
ADC的中断标志位又置位
yiy| | 2018-10-25 15:15 | 只看该作者
找个ADC的例子看看操作流程。
hanzhen654| | 2018-10-25 20:09 | 只看该作者
中断里面不需要放这么多执行程序吧?
hanzhen654| | 2018-10-25 20:10 | 只看该作者
参考火哥 原子的代码,
paotangsan| | 2018-11-6 14:47 | 只看该作者
清除中断标志位
