[范例教程]
【M0】 MG32F02A 学习笔记⑳ IIC主机模式
1213|0
noctor|  楼主 | 2018-11-20 13:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
     上回我们说到了MG32F02A的UART0 SPI的使用。帖子详情:https://bbs.21ic.com/icview-2586596-1-1.html
      突然发现原来IIC还没挂上来。。
由于代码比较多,就先只挂主机的吧:
#include "MG32x02z_DRV.H"
#include "iic.h"
#include <stdio.h>
#include "MG32x02z_I2C_DRV.h"
I2C_Struct* I2Cx;
typedef uint8_t u8;
typedef uint16_t u16;
typedef uint32_t u32;
typedef uint64_t u64;
#define URTX URT0
#define MYBINARYIMAGE2_LENGTH 20
I2C_HandleTypeDef gSI2C0_Handle;
I2C_HandleTypeDef gSI2C1_Handle;
uint8_t SendBuf[MYBINARYIMAGE2_LENGTH]={0};
uint8_t const String0[] = {"Wel"};
uint8_t lDataBuffer[80];
void SysTick_Handler(void)
    //to do......
        IncTick();
void CSC_Init (void)
        CSC_PLL_TyprDef CSC_PLL_CFG;
  UnProtectModuleReg(MEMprotect);             // Setting flash wait state
  MEM_SetFlashWaitState(MEM_FWAIT_ONE);        // 50MHz> Sysclk >=25MHz
  UnProtectModuleReg(CSCprotect);
        CSC_CK_APB_Divider_Select(APB_DIV_1);        // Modify CK_APB divider        APB=CK_MAIN/1
        CSC_CK_AHB_Divider_Select(AHB_DIV_1);        // Modify CK_AHB divider        AHB=APB/1
        /* CK_HS selection */
        CSC_IHRCO_Select(IHRCO_12MHz);                        // IHRCO Sel 12MHz
        CSC_IHRCO_Cmd(ENABLE);
        while(CSC_GetSingleFlagStatus(CSC_IHRCOF) == DRV_Normal);
        CSC_ClearFlag(CSC_IHRCOF);
        CSC_CK_HS_Select(HS_CK_IHRCO);                        // CK_HS select IHRCO
        /* PLL */
        CSC_PLL_CFG.InputDivider=PLLI_DIV_2;        // 12M/2=6M
        CSC_PLL_CFG.Multiplication=PLLIx16;                // 6M*16=96M
        CSC_PLL_CFG.OutputDivider=PLLO_DIV_2;        // PLLO=96M/2=48M
        CSC_PLL_Config(&CSC_PLL_CFG);
        CSC_PLL_Cmd(ENABLE);
        while(CSC_GetSingleFlagStatus(CSC_PLLF) == DRV_Normal);
        CSC_ClearFlag(CSC_PLLF);
        /* CK_MAIN */
        CSC_CK_MAIN_Select(MAIN_CK_HS);
        /* Configure ICKO function */
        /* Configure peripheral clock */
        CSC_PeriphProcessClockSource_Config(CSC_I2C0_CKS, CK_APB);
        CSC_PeriphProcessClockSource_Config(CSC_UART0_CKS, CK_APB);
        CSC_PeriphOnModeClock_Config(CSC_ON_I2C0,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_UART0,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_PortB,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_PortE,ENABLE);
void I2C0_ByteMode_Master_Init(void)
    I2C_InitTypeDef SI2C0_Init;
    SI2C0_Init.Instance = I2C0;
    SI2C0_Init.CK_I2C_PR_Frequency = 12000000;
    SI2C0_Init.SCL_Clock = 400000;
    I2C_ByteMode_Init(&SI2C0_Init);
    gSI2C0_Handle.Instance = I2C0;
    printf("I2C_IsDeviceReady\n\r");
DRV_Return I2C_ByteMode_Init(I2C_InitTypeDef *SI2C)
    uint16_t lI2C_Pre = 1;
    uint16_t lI2C_DIV = 1;
    uint16_t lI2C_HT_LT = 0;
    uint16_t lI2C_LT;
    uint16_t lI2C_HT;
                PIN_InitTypeDef PINX_InitStruct;
    //===== Check I2C Busy =====//
    if(__I2C_GetFlagStatus(SI2C->Instance, I2C_FLAG_BUSYF))
        return DRV_Busy;
    __I2C_Disable(SI2C->Instance);
    //===== GPIO Initial =====//
      //===== CSC for GPIO Config =====//
    UnProtectModuleReg(CSCprotect);                                             // Unprotect CSC module
    CSC_PeriphOnModeClock_Config(CSC_ON_PortB, ENABLE);                                    // Enable PortB clock
    ProtectModuleReg(CSCprotect);                                               // protect CSC module
//      //===== GPIO Config =====//
    PINX_InitStruct.PINX_Mode                    = PINX_Mode_OpenDrain_O;            // Pin select pusu pull mode
    PINX_InitStruct.PINX_PUResistant        = PINX_PUResistant_Enable;         // Enable pull up resistor
    PINX_InitStruct.PINX_Speed              = PINX_Speed_High;
    PINX_InitStruct.PINX_OUTDrive           = PINX_OUTDrive_Level0;             // Pin output driver full strength.
    PINX_InitStruct.PINX_FilterDivider      = PINX_FilterDivider_Bypass;        // Pin input deglitch filter clock divider bypass
    PINX_InitStruct.PINX_Inverse            = PINX_Inverse_Disable;             // Pin input data not inverse
    PINX_InitStruct.PINX_Alternate_Function = 2;                                // Pin AFS = 2
    if(SI2C->Instance == I2C0)
        GPIO_PinMode_Config(PINB(10),&PINX_InitStruct);                         // I2C0 SCL setup at PB10
        GPIO_PinMode_Config(PINB(11),&PINX_InitStruct);                         // I2C0 SDA setup at PB11
//       GPIO_PinMode_Config(PINC(4),&PINX_InitStruct);                          // I2C0 SCL setup at PC4
//       GPIO_PinMode_Config(PINC(5),&PINX_InitStruct);                          // I2C0 SDA setup at PC5
//       GPIO_PinMode_Config(PINC(8),&PINX_InitStruct);                          // I2C0 SCL setup at PC8
//       GPIO_PinMode_Config(PINC(9),&PINX_InitStruct);                          // I2C0 SDA setup at PC9
//       GPIO_PinMode_Config(PIND(5),&PINX_InitStruct);                          // I2C0 SCL setup at PD5
//       GPIO_PinMode_Config(PIND(6),&PINX_InitStruct);                          // I2C0 SDA setup at PD6
//       GPIO_PinMode_Config(PINE(0),&PINX_InitStruct);                          // I2C0 SCL setup at PE0
//       GPIO_PinMode_Config(PINE(1),&PINX_InitStruct);                          // I2C0 SDA setup at PE1
    if(SI2C->Instance == I2C1)
        GPIO_PinMode_Config(PINC(10),&PINX_InitStruct);                         // I2C1 SCL setup at PC10
        GPIO_PinMode_Config(PINC(11),&PINX_InitStruct);                         // I2C1 SDA setup at PC11
        GPIO_PinMode_Config(PIND(8),&PINX_InitStruct);                          // I2C1 SCL setup at PD8
        GPIO_PinMode_Config(PIND(9),&PINX_InitStruct);                          // I2C1 SDA setup at PD9
        GPIO_PinMode_Config(PINE(2),&PINX_InitStruct);                          // I2C1 SCL setup at PE2
        GPIO_PinMode_Config(PINE(3),&PINX_InitStruct);                          // I2C1 SDA setup at PE3
    //===== I2C Initial =====//
      //=== CSC for I2C Config ===//
        CSC_PeriphOnModeClock_Config(CSC_ON_I2C0, ENABLE);                      // Enable I2C0 module clock
        CSC_PeriphOnModeClock_Config(CSC_ON_I2C1, ENABLE);                      // Enable I2C1 module clock
      //=== I2C Config ===//
    //===== I2C Output Clock Config =====//
    // CK_I2C_PR
    // SCL Output Clock
    // HT + LT, <= 32 >=9, CK_I2C_PR / SCL Clock / Prescaler / DIV
    do{
        lI2C_HT_LT = SI2C->CK_I2C_PR_Frequency / SI2C->SCL_Clock / lI2C_Pre / lI2C_DIV;
        if((lI2C_HT_LT >= 32) || (lI2C_HT_LT <=9))
            lI2C_Pre ++;
            if(lI2C_Pre > 8)
                lI2C_Pre = 1;
                lI2C_DIV ++;
    }while((lI2C_HT_LT >= 32) || (lI2C_HT_LT <=9));
    lI2C_LT = (lI2C_HT_LT >> 1);
    lI2C_HT = lI2C_HT_LT - lI2C_LT;
    __I2C_SetClockSource(SI2C->Instance, I2C_CLK_SRC_PROC);
    __I2C_SetClockPrescaler(SI2C->Instance, lI2C_Pre - 1);
    __I2C_SetClockDivider(SI2C->Instance, lI2C_DIV - 1);
    __I2C_SetSCLHighTime(SI2C->Instance, lI2C_HT - 1);
    __I2C_SetSCLLowTime(SI2C->Instance, lI2C_HT - 1);
    //===== I2C Opration Mode Config =====//
    __I2C_GeneralCallAddress_Disable(SI2C->Instance);
    __I2C_SlaveAddressDetect_Disable(SI2C->Instance, (I2C_SADR_1 | I2C_SADR_2));
    //===== I2C Interrupt Config =====//
        NVIC_EnableIRQ(I2C0_IRQn);
        NVIC_SetPriority(I2C0_IRQn, 1);                                         // Suggest SYSTICK Priority = 0
        //           Other Priority > 0
        NVIC_EnableIRQ(I2Cx_IRQn);
        NVIC_SetPriority(I2Cx_IRQn, 1);                                         // Suggest SYSTICK Priority = 0
    __I2C_ITEA_Disable(SI2C->Instance);
    __I2C_IT_Disable(SI2C->Instance, (I2C_IT_TMOUT | I2C_IT_EVENT | I2C_IT_ERR | I2C_IT_BUF | I2C_IT_WUP));
    //===== I2C Timeout Config =====//
    __I2C_TMO_Disable(SI2C->Instance);
    __I2C_SetTimeOutClockSource(SI2C->Instance, I2C_TMO_CKS_DIV64);
    __I2C_SetTimeOutDetectionMode(SI2C->Instance, I2C_TMO_MDS_GENERAL);
    __I2C_SetTimeOutCount(SI2C->Instance, I2C_TMO_MDS_GENERAL);
    //===== I2C Enable =====//
    __I2C_Enable(SI2C->Instance);
        //        I2Cx->CR0.B[0] |= I2C_CR0_BUF_EN_enable_b0;
    return DRV_Success;
void I2C_Delay(uint32_t Delay)
DRV_Return I2C_IsDeviceReady(I2C_HandleTypeDef *SI2C, uint16_t DevAddress, uint32_t Trials)
//-----Check I2C Busy ------------------
    if(__I2C_GetFlagStatus(SI2C->Instance, I2C_FLAG_BUSYF) != CLR)
        return DRV_Busy;
//-----Set_Config-----------------------
    SI2C->State.W = 0;
    SI2C->SlaveAddress = DevAddress & 0xFFFE;
    SI2C->pData = 0x00000000;
    SI2C->Count = 0;
    SI2C->Control.W = I2C_XferNext_STOP;
//-----Start----------------------------
    do{
        SI2C->State.W = 0;
        Set_STA_STO_AA_100(SI2C->Instance);
        do{
            I2C_ByteMode_Handle(SI2C);
        }while(SI2C->State.MBit.Done == 0);
        if((SI2C->State.W & (I2C_State_BusError | \
                                   I2C_State_ArbitrationLost | \
                                   I2C_State_NACK)) == 0)
            return DRV_Success;
        I2C_Delay(1);
    }while(-- Trials > 0);
    return DRV_Failure;
void I2C_ByteMode_Handle(I2C_HandleTypeDef *SI2C)
    uint8_t lState;
    if(__I2C_GetStateFlag(SI2C->Instance) == 0)
        return;
    lState = __I2C_GetStatusCode(SI2C->Instance);
    switch(lState){
        case 0x00:  // Bus Error
            SI2C->State.W |= I2C_State_BusError | \
                                   I2C_State_Done;;
            break;
        case 0x08:  // SLA+W sent and ACK received
        case 0x10:  // Repeated start condition
            Set_STA_STO_AA_000(SI2C->Instance);
            __I2C_SendSBUF(SI2C->Instance, ((uint8_t)SI2C->SlaveAddress));
            break;
        case 0x18:  // MT SLA+W sent and ACK received
        case 0x28:  // MT DATA sent and ACK received
            if(SI2C->Count == 0)
                Set_STA_STO_AA_010(SI2C->Instance);
                __I2C_ClearStateFlag(SI2C->Instance);
                while(__I2C_GetStatusCode(SI2C->Instance) == lState);
                SI2C->State.W |= I2C_State_Done;
                return;
            __I2C_SendSBUF(SI2C->Instance, ((uint8_t)*SI2C->pData));
            SI2C->pData ++;
            SI2C->Count --;
            break;
        case 0x20:  // MT SLA+W sent NACK received
        case 0x30:  // MT DATA sent NACK received
        case 0x48:  // MR SLA+R sent NACK received
            SI2C->State.W |= I2C_State_NACK | \
                                   I2C_State_Done;
            return;
        case 0x38:  // Arbitration lost
            SI2C->State.W |= I2C_State_ArbitrationLost | \
                                   I2C_State_Done;
            break;
        case 0x40:  // SLA+R sent and ACK received
            Set_STA_STO_AA_001(SI2C->Instance);
        case 0x50:  // Data Received and ACK sent
            if(SI2C->Count <= 1)
            *SI2C->pData = __I2C_ReceiveSBUF(SI2C->Instance);
            SI2C->Count--;
            SI2C->pData++;
            break;
        case 0x58:  // Data Received and NACK sent
            if((SI2C->Control.W & I2C_XferNext_Mask) == I2C_XferNext_RepeatStart)
            else
            break;
        case 0x60:  // Own SLA+W has bee Received ACK has been returned
        case 0x68:  // Arbitration lost in SLA+R/W as master,
                    // Own SLA+W has been Received ACK has bee returned
        case 0x70:  // General Call address has been received ACK has been returned
        case 0x78:  // Arbitration lost in SLA+R/W as master,
        case 0x80:  // Data byte has been received ACK has been return
        case 0x88:  // Data byte has been received Not ACK has been return
        case 0x90:  // Previously address with General Call address
        case 0x98:  // Previously address with General Call address
        case 0xA0:  // A STOP or repeated START has been received while will addressed as SLV/REC
        case 0xA8:  // Own SLA+R has bee Received ACK has been returned
        case 0xB0:  // Arbitration lost in SLA+R/W as master,
                    // Own SLA+R has been Received ACK has bee returned
        case 0xB8:  // Data byte in SIDAT has been transmitted ACK has been received
        case 0xC0:  // Data byte or Last data byte in SIDAT has been transmitted Not ACK has been received
        case 0xC8:  // Last Data byte in SIDAT has been transmitted ACK has been received
        case 0xD0:
        case 0xD8:
        case 0xE0:
        case 0xE8:
        case 0xF0:
        case 0xF8:  // Bus Idle
        default:
            break;
    while(__I2C_GetStateFlag(SI2C->Instance) != 0);
DRV_Return I2C_ByteMode_MasterTransmit(I2C_HandleTypeDef *SI2C, uint16_t DevAddress, uint8_t *pData, uint16_t Lenth)
//-----Check----------------------------
        return DRV_Busy;
    SI2C->State.W = 0;
    SI2C->pData = pData;
    SI2C->Count = Lenth;
    do{
                               I2C_State_NACK)) != 0)
        return DRV_Failure;
    return DRV_Success;
DRV_Return I2C_ByteMode_MasterReceive(I2C_HandleTypeDef *SI2C, uint16_t DevAddress, uint8_t *pData, uint16_t Lenth)
        return DRV_Busy;
    SI2C->State.W = 0;
    SI2C->SlaveAddress = DevAddress | 0x0001;
    do{
        return DRV_Failure;
    return DRV_Success;
void Sample_URT0_Init(void)
    URT_BRG_TypeDef  URT_BRG;
    URT_Data_TypeDef DataDef;
    //==Set CSC init
    //MG32x02z_CSC_Init.h(Configuration Wizard)
    //Select CK_HS source = CK_IHRCO
    //Select IHRCO = 11.0592M
    //Select CK_MAIN Source = CK_HS
    //Configure PLL->Select APB Prescaler = CK_MAIN/1
    //Configure Peripheral On Mode Clock->Port B/URT0 = Enable
    //Configure Peripheral On Mode Clock->URT0->Select URT0_PR Source = CK_APB(11.0592)
    //==Set GPIO init
    //MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOB->Pin8/9
    //GPIO port initial is 0xFFFF
    //Pin8 mode is PPO/Pin9 mode is ODO
    //Pin8/9 pull-up resister Enable
    //Pin8/9 function URT0_TX/RX
  PINX_InitStruct.PINX_Mode                                 = PINX_Mode_PushPull_O;                  // Pin select Push Pull mode
        PINX_InitStruct.PINX_Speed                                   = PINX_Speed_Low;
        PINX_InitStruct.PINX_Alternate_Function  = 3;                                // Pin AFS = URT0_TX
        GPIO_PinMode_Config(PINB(8),&PINX_InitStruct);                                                          // TXD at PB8
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_OpenDrain_O;                 // Pin select Open Drain mode
        PINX_InitStruct.PINX_Alternate_Function  = 3;                                // Pin AFS = URT0_RX
        GPIO_PinMode_Config(PINB(9),&PINX_InitStruct);                                                          // RXD at PB9
    //=====Set Clock=====//
    //---Set BaudRate---//
    URT_BRG.URT_InteranlClockSource = URT_BDClock_PROC;
    URT_BRG.URT_BaudRateMode = URT_BDMode_Separated;
    URT_BRG.URT_PrescalerCounterReload = 0;                        //Set PSR
    URT_BRG.URT_BaudRateCounterReload = 3;                        //Set RLR
    URT_BaudRateGenerator_Config(URTX, &URT_BRG);                    //BR115200 = f(CK_URTx)/(PSR+1)/(RLR+1)/(OS_NUM+1)
    URT_BaudRateGenerator_Cmd(URTX, ENABLE);                    //Enable BaudRateGenerator
    //---TX/RX Clock---//
    URT_TXClockSource_Select(URTX, URT_TXClock_Internal);        //URT_TX use BaudRateGenerator
    URT_RXClockSource_Select(URTX, URT_RXClock_Internal);        //URT_RX use BaudRateGenerator
    URT_TXOverSamplingSampleNumber_Select(URTX, 25);                //Set TX OS_NUM
    URT_RXOverSamplingSampleNumber_Select(URTX, 25);                //Set RX OS_NUM
    URT_RXOverSamplingMode_Select(URTX, URT_RXSMP_3TIME);
    URT_TX_Cmd(URTX, ENABLE);                                    //Enable TX
    URT_RX_Cmd(URTX, ENABLE);                                    //Enable RX
    //=====Set Mode=====//
    //---Set Data character config---//
    DataDef.URT_TX_DataLength  = URT_DataLength_8;
    DataDef.URT_RX_DataLength  = URT_DataLength_8;
    DataDef.URT_TX_DataOrder   = URT_DataTyped_LSB;
    DataDef.URT_RX_DataOrder   = URT_DataTyped_LSB;
    DataDef.URT_TX_Parity      = URT_Parity_No;
    DataDef.URT_RX_Parity      = URT_Parity_No;
    DataDef.URT_TX_StopBits    = URT_StopBits_1_0;
    DataDef.URT_RX_StopBits    = URT_StopBits_1_0;
    DataDef.URT_TX_DataInverse = DISABLE;
    DataDef.URT_RX_DataInverse = DISABLE;
    URT_DataCharacter_Config(URTX, &DataDef);
    //---Set Mode Select---//
    URT_Mode_Select(URTX, URT_URT_mode);
    //---Set DataLine Select---//
    URT_DataLine_Select(URTX, URT_DataLine_2);
    //=====Set Error Control=====//
    // to do...
    //=====Set Bus Status Detect Control=====//
    // to do...
    //=====Set Data Control=====//
    URT_RXShadowBufferThreshold_Select(URTX, URT_RXTH_1BYTE);
    URT_IdlehandleMode_Select(URTX, URT_IDLEMode_No);
    URT_TXGaudTime_Select(URTX, 0);
    //=====Enable URT Interrupt=====//
    URT_IT_Cmd(URTX, URT_IT_RX, ENABLE);
    URT_ITEA_Cmd(URTX, ENABLE);
    NVIC_EnableIRQ(URT0_IRQn);
    //=====Enable URT=====//
    URT_Cmd(URTX, ENABLE);
        //==See MG32x02z_URT0_IRQ.c when interrupt in
int fputc(int ch,FILE *f)
        URT_SetTXData(URTX,1,ch);
        while(URT_GetITSingleFlagStatus(URTX,URT_IT_TC)==DRV_UnHappened);
        URT_ClearITFlag(URTX,URT_IT_TC);
        return ch;
void UartSendByte(int ch)
void DMA_Init(void)
         DMA_BaseInitTypeDef DMATestPattern;
    // 1.Enable DMA
    DMA_Cmd(ENABLE);
    // 2.Enable Channel0
    DMA_Channel_Cmd(DMAChannel0, ENABLE);
    DMA_BaseInitStructure_Init(&DMATestPattern);
    // 3.initial & modify parameter
        // DMA channel select
        DMATestPattern.DMAChx = DMAChannel0;
        // channel x source/destination auto increase address
        DMATestPattern.SrcSINCSel = ENABLE;
        DMATestPattern.DestDINCSel = DISABLE;
        // DMA source peripheral config
        DMATestPattern.SrcSymSel = DMA_MEM_Read;
        // DMA destination peripheral config
        DMATestPattern.DestSymSel = DMA_SPI0_TX;
        // DMA Burst size config
        DMATestPattern.BurstDataSize = DMA_BurstSize_1Byte;
        // DMA transfer data count initial number
        DMATestPattern.DMATransferNUM = MYBINARYIMAGE2_LENGTH;
        // source/destination config
        DMATestPattern.DMASourceAddr = (uint32_t *)&SendBuf;
        DMATestPattern.DMADestinationAddr = &SPI0->TDAT;//DMA_URT0_TX;// (uint8_t *)&RcvBuf;
                                SPI_DMASend_Cmd(SPI0, ENABLE);
                                DMA_Base_Init(&DMATestPattern);
int main()
        u32 i;
        char RxData;
        uint8_t AddrTemp;
        CSC_Init();
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_PushPull_O;          // Pin select digital input mode
        PINX_InitStruct.PINX_FilterDivider                   = PINX_FilterDivider_Bypass;// Pin input deglitch filter clock divider bypass
        PINX_InitStruct.PINX_Alternate_Function = 0;                                                 // Pin AFS = 0
        GPIO_PinMode_Config(PINE(15),&PINX_InitStruct);                                          // D6 setup at PE15
        Sample_URT0_Init();
        printf("hello\n");
        I2C0_ByteMode_Master_Init();
        i=0;
    while(1)
            i++;
            if(i>=500000)
                                i=0;
                                PE15=0;
      if(I2C_IsDeviceReady(&gSI2C0_Handle, 0xA0, 10) != DRV_Success)
      printf("Target device is not ready\n\r");
                  if(I2C_ByteMode_MasterTransmit(&gSI2C0_Handle, 0xA0, (uint8_t *)String0, (sizeof(String0)-1)) != DRV_Success)
      printf("Mater transmited data fail\n\r");
                        if(I2C_ByteMode_MasterReceive(&gSI2C0_Handle, (uint16_t)0xA0, (uint8_t *)lDataBuffer, (sizeof(String0)-1)) != DRV_Success)
      printf("Mater received data fail\n\r");
                                RxData=I2C_ReceiveSBUF(I2C0);
                                printf("receive:0x%02X\n",RxData);
                PE15=1;
