[DemoCode下载]
M051系列的两种捕获形式
802|12
PWM捕获
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 3 $
* $Date: 14/01/28 11:44a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series PWM Generator and Capture Timer Driver Sample Code
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
/* Macro, type and constant definitions        */
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
* @brief       PWMA IRQ Handler
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     ISR to handle PWMA interrupt event
void PWMA_IRQHandler(void)
    /*In this sample code, user will not use PWMA channel 0~3 PIIR interrupt and CAPIF capture interrupt.
      Defined following code as 0 for reducing interrupt execution time and code size. */
#if 0
    uint32_t u32PwmIntFlag, u32CapIntFlag0, u32CapIntFlag1;
    /* Handle PWMA Capture function */
    u32CapIntFlag0 = PWMA->CCR0;
    u32CapIntFlag1 = PWMA->CCR2;
    if(u32CapIntFlag0 & PWM_CCR0_CAPIF0_Msk)
        PWMA->CCR0 &= (PWM_CCR_MASK | PWM_CCR0_CAPIF0_Msk);
    else if(u32CapIntFlag0 & PWM_CCR0_CAPIF1_Msk)
        PWMA->CCR0 &= (PWM_CCR_MASK | PWM_CCR0_CAPIF1_Msk);
    else if(u32CapIntFlag1 & PWM_CCR2_CAPIF2_Msk)
        PWMA->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF2_Msk);
    else if(u32CapIntFlag1 & PWM_CCR2_CAPIF3_Msk)
        PWMA->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF3_Msk);
    /* Handle PWMA Timer function */
    u32PwmIntFlag = PWMA->PIIR;
    if(u32PwmIntFlag & PWM_PIIR_PWMIF0_Msk)
        PWMA->PIIR = PWM_PIIR_PWMIF0_Msk;
    else if(u32PwmIntFlag & PWM_PIIR_PWMIF1_Msk)
        PWMA->PIIR = PWM_PIIR_PWMIF1_Msk;
    else if(u32PwmIntFlag & PWM_PIIR_PWMIF2_Msk)
        PWMA->PIIR = PWM_PIIR_PWMIF2_Msk;
    else if(u32PwmIntFlag & PWM_PIIR_PWMIF3_Msk)
        PWMA->PIIR = PWM_PIIR_PWMIF3_Msk;
#endif
* @brief       PWMB IRQ Handler
* @param       None
* @return      None
* @details     ISR to handle PWMB interrupt event
void PWMB_IRQHandler(void)
//    uint32_t u32PwmIntFlag;
    uint32_t u32CapIntFlag1;
    /* Handle PWMB Capture function */
    u32CapIntFlag1 = PWMB->CCR2;
    /* PWMB channel 2 Capture interrupt */
        PWMB->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF2_Msk);
/* Capture function to calculate the input waveform information                         */
/* u32Count[4] : Keep the internal counter value when input signal rising / falling     */
/*               happens        */
/* time    A    B     C     D                                                           */
/*           ___   ___   ___   ___   ___   ___   ___   ___                              */
/*      ____|   |_|   |_|   |_|   |_|   |_|   |_|   |_|   |_____                        */
/* index              0 1   2 3                                                         */
/* The capture internal counter down count from 0x10000, and reload to 0x10000 after    */
/* input signal falling happens (Time B/C/D)                                            */
void CalPeriodTime(PWM_T *PWM, uint32_t u32Ch)
    uint16_t u32Count[4];
    uint32_t u32i;
    uint16_t u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid;
    /* Clear Capture Falling Indicator (Time A) */
    PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH);
    /* Wait for Capture Falling Indicator  */
    while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 2);
    /* Clear Capture Falling Indicator (Time B)*/
    u32i = 0;
    while(u32i < 4)
        /* Clear Capture Falling and Rising Indicator */
        PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH | PWM_CAPTURE_INT_RISING_LATCH);
        /* Get Capture Falling Latch Counter Data */
        u32Count[u32i++] = PWM_GET_CAPTURE_FALLING_DATA(PWM, u32Ch);
        /* Wait for Capture Rising Indicator */
        /* Clear Capture Rising Indicator */
        PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_RISING_LATCH);
        /* Get Capture Rising Latch Counter Data */
        u32Count[u32i++] = PWM_GET_CAPTURE_RISING_DATA(PWM, u32Ch);
    u16RisingTime = u32Count[1];
    u16FallingTime = u32Count[0];
    u16HighPeroid = u32Count[1] - u32Count[2];
    u16LowPeroid = 0x10000 - u32Count[1];
    u16TotalPeroid = 0x10000 - u32Count[2];
    printf("\nPWM generate: \nHigh Period=7199 ~ 7201, Low Period=16799 ~ 16801, Total Period=23999 ~ 24001\n");
    printf("\nCapture Result: Rising Time = %d, Falling Time = %d \nHigh Period = %d, Low Period = %d, Total Period = %d.\n\n",
           u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid);
    if((u16HighPeroid < 7199) || (u16HighPeroid > 7201) || (u16LowPeroid < 16799) || (u16LowPeroid > 16801) || (u16TotalPeroid < 23999) || (u16TotalPeroid > 24001))
        printf("Capture Test Fail!!\n");
    else
        printf("Capture Test Pass!!\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC clock */
    CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
    /* Waiting for IRC22M clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk));
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLK_S_Msk;
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_HIRC;
    CLK->CLKDIV &= ~CLK_CLKDIV_HCLK_N_Msk;
    /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
    CLK->PLLCON |= CLK_PLLCON_PD_Msk;
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk;
    /* Enable PLL and Set PLL frequency */
    CLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    while(!(CLK->CLKSTATUS & (CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk)));
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL;
    /* Enable IP clock */
    CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_PWM45_EN_Msk | CLK_APBCLK_PWM67_EN_Msk;
    /* IP clock source */
    CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL;
    CLK->CLKSEL2 = CLK_CLKSEL2_PWM45_S_HXT | CLK_CLKSEL2_PWM67_S_HXT;
    /* Reset PWMB channel0~channel3 */
    SYS->IPRSTC2 = SYS_IPRSTC2_PWM47_RST_Msk;
    SYS->IPRSTC2 = 0;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Set P2 multi-function pins for PWMB Channel0~3  */
    SYS->P2_MFP = SYS_MFP_P25_PWM5 | SYS_MFP_P26_PWM6;
void UART0_Init(void)
    /* Init UART        */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(PLL_CLOCK, 115200);
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("+------------------------------------------------------------------------+\n");
    printf("|                          PWM Driver Sample Code                        |\n");
    printf("|        |\n");
    printf("  This sample code will use PWMB channel 2 to capture\n  the signal from PWMB channel 1.\n");
    printf("  I/O configuration:\n");
    printf("    PWM5(P2.5 PWMB channel 1) <--> PWM6(P2.6 PWMB channel 2)\n\n");
    printf("Use PWMB Channel 2(P2.6) to capture the PWMB Channel 1(P2.5) Waveform\n");
    while(1)
        printf("Press any key to start PWM Capture Test\n");
        getchar();
        /* Set the PWMB Channel 1 as PWM output function.                                               */
        /* Assume PWM output frequency is 250Hz and duty ratio is 30%, user can calculate PWM settings by follows.
           duty ratio = (CMR+1)/(CNR+1)
           cycle time = CNR+1
           High level = CMR+1
           PWM clock source frequency = __HXT = 12000000
           (CNR+1) = PWM clock source frequency/prescaler/clock source divider/PWM output frequency
                   = 12000000/2/1/250 = 24000
           (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.)
           CNR = 23999
           duty ratio = 30% ==> (CMR+1)/(CNR+1) = 30%
           CMR = 7199
           Prescale value is 1 : prescaler= 2
           Clock divider is PWM_CSR_DIV1 : clock divider =1
        /* set PWMB channel 1 output configuration */
        PWM_ConfigOutputChannel(PWMB, PWM_CH1, 250, 30);
        /* Enable PWM Output path for PWMB channel 1 */
        PWM_EnableOutput(PWMB, 0x2);
        /* Enable Timer for PWMB channel 1 */
        PWM_Start(PWMB, 0x2);
        /* Set the PWMB channel 2  for capture function                                         */
        /* If input minimum frequency is 250Hz, user can calculate capture settings by follows.
           Capture clock source frequency = __HXT = 12000000 in the sample code.
           (CNR+1) = Capture clock source frequency/prescaler/clock source divider/minimum input frequency
           CNR = 0xFFFF
           (Note: In capture mode, user should set CNR to 0xFFFF to increase capture frequency range.)
        /* set PWMB channel 2 capture configuration */
        PWM_ConfigCaptureChannel(PWMB, PWM_CH2, 166, 0);
        /* Enable capture falling edge interrupt for PWMB channel 2 */
        PWM_EnableCaptureInt(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH);
        /* Enable PWMB NVIC interrupt */
        NVIC_EnableIRQ((IRQn_Type)(PWMB_IRQn));
        /* Enable Timer for PWMB channel 2  */
        PWM_Start(PWMB, 0x4);
        /* Enable Capture Function for PWMB channel 2 */
        PWM_EnableCapture(PWMB, 0x4);
        /* Wait until PWMB channel 2 Timer start to count */
        while(PWMB->PDR2 == 0);
        /* Capture the Input Waveform Data */
        CalPeriodTime(PWMB, PWM_CH2);
        /* Stop PWMB channel 1 (Recommended procedure method 1)                                                 */
        /* Set PWM Timer loaded value(CNR) as 0. When PWM internal counter(PDR) reaches to 0, disable PWM Timer */
        /* Set PWMB channel 1 loaded value as 0 */
        PWM_Stop(PWMB, 0x2);
        /* Wait until PWMB channel 1 Timer Stop */
        while(PWMB->PDR1 != 0);
        /* Disable Timer for PWMB channel 1 */
        PWM_ForceStop(PWMB, 0x2);
        /* Disable PWM Output path for PWMB channel 1 */
        PWM_DisableOutput(PWMB, 0x2);
        /* Stop PWMB channel 2 (Recommended procedure method 1)                                                 */
        /* Disable PWMB NVIC */
        NVIC_DisableIRQ((IRQn_Type)(PWMB_IRQn));
        /* Set loaded value as 0 for PWMB channel 2 */
        PWM_Stop(PWMB, 0x4);
        /* Wait until PWMB channel 2 current counter reach to 0 */
        while(PWMB->PDR2 != 0);
        /* Disable Timer for PWMB channel 2 */
        PWM_ForceStop(PWMB, 0x4);
        /* Disable Capture Function and Capture Input path for  PWMB channel 2*/
        PWM_DisableCapture(PWMB, 0x4);
        /* Clear Capture Interrupt flag for PWMB channel 2*/
        PWM_ClearCaptureIntFlag(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH);
玛尼玛尼哄|  楼主 | 2018-12-22 13:51 | 只看该作者
定时器捕获
* @file     main.c
* @version  V3.00
* $Revision: 3 $
* $Date: 14/01/28 6:42p $
* @brief    M051 Series Timer Driver Sample Code
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
/* Global Interface Variables Declarations        */
extern int IsDebugFifoEmpty(void);
volatile uint8_t  g_u8IsWDTTimeoutINT = 0;
volatile uint32_t g_au32TMRINTCount[4] = {0};
* @brief       Timer0 IRQ
* @param       None
* @return      None
* @details     The Timer0 default IRQ, declared in startup_M051Series.s.
void TMR0_IRQHandler(void)
    /* Clear Timer0 time-out interrupt flag */
    TIMER_ClearIntFlag(TIMER0);
    g_au32TMRINTCount[0]++;
* @brief       Timer1 IRQ
* @param       None
* @return      None
* @details     The Timer1 default IRQ, declared in startup_M051Series.s.
void TMR1_IRQHandler(void)
    if(TIMER_GetCaptureIntFlag(TIMER1) == 1)
        /* Clear Timer1 capture interrupt flag */
        TIMER_ClearCaptureIntFlag(TIMER1);
        g_au32TMRINTCount[1]++;
* @brief       Timer2 IRQ
* @param       None
* @return      None
* @details     The Timer2 default IRQ, declared in startup_M051Series.s.
void TMR2_IRQHandler(void)
    /* Clear Timer2 time-out interrupt flag */
    TIMER_GetIntFlag(TIMER2);
    g_au32TMRINTCount[2]++;
* @brief       Timer3 IRQ
* @param       None
* @return      None
* @details     The Timer3 default IRQ, declared in startup_M051Series.s.
void TMR3_IRQHandler(void)
    /* Clear Timer3 time-out interrupt flag */
    TIMER_GetIntFlag(TIMER3);
    g_au32TMRINTCount[3]++;
void SYS_Init(void)
    /* Enable IRC22M clock */
    CLK->PWRCON |= CLK_PWRCON_IRC22M_EN_Msk;
    CLK_WaitClockReady(CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_HIRC;
    /* Set PLL to Power-down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
    /* Enable external 12 MHz XTAL, IRC10K */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk;
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_IRC10K_STB_Msk);
    /* Enable peripheral clock */
                  CLK_APBCLK_TMR0_EN_Msk | CLK_APBCLK_TMR1_EN_Msk | CLK_APBCLK_TMR2_EN_Msk | CLK_APBCLK_TMR3_EN_Msk;
    /* Peripheral clock source */
    CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL |
                   CLK_CLKSEL1_TMR0_S_HXT | CLK_CLKSEL1_TMR1_S_HCLK | CLK_CLKSEL1_TMR1_S_HIRC | CLK_CLKSEL1_TMR3_S_HXT;
    /* Set P3 multi-function pins for UART0 RXD, TXD, T0, T1 and T1EX */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0 | SYS_MFP_P34_T0 | SYS_MFP_P35_T1 | SYS_MFP_P33_T1EX;
    /* Set P1 multi-function pins for T3 */
    SYS->P1_MFP = SYS_MFP_P11_T3;
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    volatile uint32_t u32InitCount;
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    SYS_LockReg();
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+---------------------------------------------------+\n");
    printf("|    Timer External Capture Function Sample Code    |\n");
    printf("+---------------------------------------------------+\n\n");
    printf("# Timer Settings:\n");
    printf("  Timer0: Clock source is 12 MHz; Toggle-output mode and frequency is 500 Hz.\n");
    printf("  Timer3: Clock source is 12 MHz; Toggle-output mode and frequency is 1 Hz.\n");
    printf("  Timer1: Clock source is HCLK(50 MHz); Continuous counting mode; TCMP is 0xFFFFFF;\n");
    printf("          Counter pin enable; Capture pin and capture interrupt enable;\n");
    printf("# Generate 500 Hz frequency from T0 and connect T0 pin to Timer1 counter pin.\n");
    printf("# Generate 1 Hz frequency from T3 and connect T3 pin to T1EX capture pin.\n");
    printf("# Get 500 event counts from Timer1 counter pin when each T1EX pin interrupt occurred.\n\n");
    /* Initial Timer0 and Timer3 default setting */
    TIMER_Open(TIMER0, TIMER_TOGGLE_MODE, 1000);
    TIMER_Open(TIMER3, TIMER_TOGGLE_MODE, 2);
    /* Initial Timer1 default setting */
    TIMER_Open(TIMER1, TIMER_CONTINUOUS_MODE, 1);
    /* Configure Timer1 setting for external counter input and capture function */
    TIMER_SET_PRESCALE_VALUE(TIMER1, 0);
    TIMER_SET_CMP_VALUE(TIMER1, 0xFFFFFF);
    TIMER_EnableEventCounter(TIMER1, TIMER_COUNTER_FALLING_EDGE);
    TIMER_EnableCapture(TIMER1, TIMER_CAPTURE_FREE_COUNTING_MODE, TIMER_CAPTURE_FALLING_EDGE);
    TIMER_EnableCaptureInt(TIMER1);
    /* Enable Timer1 NVIC */
    NVIC_EnableIRQ(TMR1_IRQn);
    /* Clear Timer1 interrupt counts to 0 */
    u32InitCount = g_au32TMRINTCount[1] = 0;
    /* Start Timer0, Timer1 and Timer3 counting */
    TIMER_Start(TIMER0);
    TIMER_Start(TIMER1);
    TIMER_Start(TIMER3);
    /* Check T1EX interrupt counts */
    while(g_au32TMRINTCount[1] <= 10)
        if(g_au32TMRINTCount[1] != u32InitCount)
            printf("[%2d] - %4d\n", g_au32TMRINTCount[1], TIMER_GetCaptureData(TIMER1));
            u32InitCount = g_au32TMRINTCount[1];
    /* Stop Timer0, Timer1 and Timer3 counting */
    TIMER_Close(TIMER0);
    TIMER_Close(TIMER1);
    TIMER_Close(TIMER3);
    printf("*** PASS ***\n");
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
598330983| | 2018-12-22 15:43 | 只看该作者
手册有介绍区别的
玛尼玛尼哄|  楼主 | 2018-12-22 23:24 | 只看该作者
今晚学习,发现这个连续计数模式跟PWM捕获有异曲同工之妙。
玛尼玛尼哄|  楼主 | 2018-12-22 23:25 | 只看该作者
一个是检测脉宽,一个可以创造脉宽。
玛尼玛尼哄|  楼主 | 2018-12-23 00:01 | 只看该作者
事件计数功能
定时器提供一个功能可以用来数外部T0~T3引脚的事件个数,被称为事件计数功能。事件的个数反 映在TDR寄存器中。该功能中,CTB(TCSR[24])位应该被设为1,外设时钟源应该选HCLK。 软件可以通过TCDB(TEXCON[7])位使能/关闭Tx引脚的防弹跳功能。如果禁止防弹跳功能,输入事 件的频率应该小于HCLK 频率的1/3;如果使能防弹跳功能,输入事件的频率应该小于HCLK 频率的 1/8 。否则,返回的TDR的值将不正确。软件通过TX_PHASE (TEXCON[0])位可以选择检测的Tx引 脚的边沿相位。 事件计数模式下,定时器计数模式可以选择单脉冲模式、周期模式和连续计数模式。
这个也比较有意思,需要配置IO的多功能选择。就可以使用了。
玛尼玛尼哄|  楼主 | 2018-12-23 00:02 | 只看该作者
事件捕获功能
计数器提供输入捕获功能,当TxEx引脚(x= 0~3)上的信号发生改变时,可以捕获TDR的值存到 TCAP寄存器中。为了将TxEX引脚用作事件捕获,RSTCAPSEL (TEXCON[4])应该设为0并且定时 器时钟源应该选择HCLK。 软件可以通过TEXDB(TEXCON[6])位使能/关闭TxEx引脚的防弹跳功能。如果禁止防弹跳功能,输 入事件的频率应该小于HCLK 频率的1/3;如果使能防弹跳功能,输入事件的频率应该小于HCLK 频 率的1/8 。否则,捕获功能可能工作的不正常。软件通过TEX_EDGE (TEXCON[2:1])位可以选择检 测的TxEX引脚的边沿相位。 事件计数模式下,软件不必考虑计数器工作在哪种模式下,只要TxEX引脚上的信号发生变化(符合 用户设定),捕获事件就会发生。
事件复位计数器功能
定时器提供复位计数器功能,当TxEX引脚(x= 0~3)的信号发生边沿转变,可以复位TDR的值。该模
式下大多设定和事件捕获功能一样,除了RSTCAPSEL (TEXCON[4]) 应该设为1。
玛尼玛尼哄|  楼主 | 2018-12-23 00:09 | 只看该作者
捕获器0和PWM0共用同一个定时器,捕获器1和PWM1共用另一个定时器,以此类推。在输入通道有上 升沿跳变时捕获器将PWM计数器的值锁存至CRLRx寄存器,在输入通道有下降沿跳变时将PWM计数器 的值锁存至CFLRx寄存器。 捕获通道0的中断是可编程的,通过设定CCR0.CRL_IE0[1] (上升沿锁存中 断 使能) 和CCR0.CFL_IE0[2]] ( 下降沿锁存中断使能) 来决定中断发生的条件。 通过设置 CCR0.CRL_IE1[17]和CCR0.CRL_IE1[18],捕获通道1有同样的特性。无论捕获模块何时触发一个捕获 中断,相应的PWM计数器都将在此刻重载CNRx的值。注:相应的GPIO管脚必须配置成捕获功能(禁用 POE和使能CAPENR).
wahahaheihei| | 2018-12-23 11:27 | 只看该作者
这两种分什么情况使用呢、
有什么不同?
xiaoqizi| | 2019-1-7 13:23 | 只看该作者
代码很详细
