- #include "includes.h" //包含所需的头文件
- ** Function name: Set_System
- ** Descriptions: 封装一些初始化模块
- ** input parameters: count
- ** output parameters: 无
- ** Returned value: 无
- void Set_System(void)
- RCC_Configuration(); //配置系统时钟
- GPIO_Configuration(); //配置GPIO
- TIMER_Configuration(); //配置TIMER
- ADC_Configuration(); //配置ADC
- ** Function name: RCC_Configuration
- ** Descriptions: 系统时钟源设置
- ** input parameters: none
- ** output parameters: none
- ** Returned value: none
- void RCC_Configuration(void)
- UNLOCKREG(); // 对写保护位操作时 需要一次向0x50000 0100写入 0x59,0x16,0x88,
- DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1);//与其 SYSCLK->PWRCON.XTL12M_EN = 1; 等同
- // PWRCON寄存器(这些寄存器在上电复位到用户解锁定之前是锁定的)除了 BIT[6]位其他位都受写保护
- // 解除这些需要向 0x50000 0100写入 0x59,0x16,0x88,
- // 令PWRCON寄存器的BITP[0]为1(即设定12M外部晶振)
- delay_ms(100); //while (DrvSYS_GetChipClockSourceStatus(E_SYS_XTL12M) != 1);//等待外部12MHZ晶振就绪
- LOCKREG(); // 向“0x5000_0100”写入任何值,就可以重锁保护寄存器
- ** Function name: GPIO_Configuration
- ** Descriptions: GPIO配置
- void GPIO_Configuration()
- DrvGPIO_Open( E_GPA, 2, E_IO_OUTPUT );//数码管段选
- DrvGPIO_Open( E_GPA, 3, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 4, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 5, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 6, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 7, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 8, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 9, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPC, 14, E_IO_OUTPUT );//数码管位选
- DrvGPIO_Open( E_GPC, 15, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPC, 6, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPC, 7, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 1, E_IO_INPUT ); //AD1
- ** Function name: TIMER_Configuration
- ** Descriptions: TIMER配置
- void TIMER_Configuration()
- DrvTIMER_Init(); //初始化定时器
- DrvSYS_SelectIPClockSource(E_SYS_TMR0_CLKSRC,0); //设定TIMER0的时钟源为外部12MHZ
- DrvTIMER_Open(E_TMR0,1000,E_PERIODIC_MODE); //设定定时器timer0的tick周期,并且启动定时器:定时器通道 TMR0 每秒1000次 周期模式
- DrvTIMER_SetTimerEvent(E_TMR0,5,(TIMER_CALLBACK) Timer0_Callback,0); //安装一个定时处理事件到 timer0通道
- DrvTIMER_EnableInt(E_TMR0); //使能定时器中断 //TIMER0->TCSR.IE = 1
- DrvTIMER_Start(E_TMR0); //定时器timer0开始计数 //TIMER0->TCSR.CEN = 1;
- ** Function name: ADC_Configuration
- ** Descriptions: 配置ADC
- void ADC_Configuration()
- DrvADC_Open(ADC_SINGLE_END, ADC_SINGLE_OP, 0, EXTERNAL_12MHZ, 3); // ADC_SINGLE_END AD为单端输入模式
- // ADC_SINGLE_OP 单一转换
- // 1 GA0作为输入 模式输入通道使能
- // EXTERNAL_12MHZ ADC时钟为 外部12MHZ
- // 3 AD时钟频率 = ADC时钟/(3+1) = 3MHZ
- DrvADC_SetADCChannel(0x02,ADC_SINGLE_END); // 2 GA1作为输入 模式输入通道使能
- // ADC_SINGLE_END AD为单端输入模式
- ADC->ADCR.DMOF = 0; //转化结果无符号
- ** Function name: Timer0_Callback
- ** Descriptions: 定时处理事件,LED动态扫描
- void Timer0_Callback (void)
- static uint8_t count= 0;
- static uint8_t i,xx[4];
- uint32_t data;
- uint16_t ValueBuff ;
- ValueBuff = value;
- count++;
- if(count >= 5)
- count = 1;
- for(i=0;i<4;i++)
- xx[i] = ValueBuff%10;
- ValueBuff = ValueBuff/10;
- switch(count)
- case 1:
- DrvGPIO_SetBit(E_GPC,14);
- DrvGPIO_ClrBit(E_GPC,15);
- DrvGPIO_ClrBit(E_GPC,6);
- DrvGPIO_ClrBit(E_GPC,7);
- data = Table[xx[0]]<<2;
- GPIOA->DOUT = data;
- break;
- case 2:
- DrvGPIO_SetBit(E_GPC,15);
- DrvGPIO_ClrBit(E_GPC,14);
- data = Table[xx[1]]<<2;
- break;
- case 3:
- DrvGPIO_SetBit(E_GPC,7);
- data = Table[xx[2]]<<2;
- break;
- case 4:
- DrvGPIO_SetBit(E_GPC,6);
- data = Table[xx[3]]<<2;
- DrvGPIO_ClrBit(E_GPA,9); //显示小数点
- break;
- default:break;
- ** Function name: delay_ms
- ** Descriptions: 1ms(晶振为12MHZ)延时子程序
- void delay_ms(uint32_t count)
- uint32_t i,j;
- for(i=count;i>0;i--)
- for(j=2395;j>0;j--);
hw_config.h头文件- #ifndef __HW_CONFIG_H__
- #define __HW_CONFIG_H__
- void Set_System(void);
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void TIMER_Configuration(void);
- void ADC_Configuration(void);
- void Timer0_Callback (void);
- void delay_ms(uint32_t count);
- #endif
其他的不贴了,都在工程里
截图
工程
