[DemoCode下载]
ISD9100的GPIO基本操作方法
805|3
小灵通2018|  楼主 | 2019-1-7 22:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GPIO, sd, TE, ck, se
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 1 $
* $Date: 14/07/15 2:52p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    ISD9100 General Purpose I/O Driver Sample Code
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "isd9100.h"
#include "gpio.h"
void GPAB_IRQHandler(void)
                static uint32_t Count=0;
    /* To check if PB2 interrupt occurred */
    if (PA->INTSRC & BIT15)
        PA->INTSRC = BIT15;
        printf("PA15 INT occurred. %d\n",Count);
                if (PB->INTSRC & BIT7)
                                PB->INTSRC = BIT7;
                                printf("PB7 INT occurred. %d\n",Count);
                Count++;
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable External XTL32K */
    CLK_EnableXtalRC(CLK_PWRCTL_LXTEN_Msk);
    /* Enable External OSC49M */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Enable External OSC10K */
    CLK_EnableXtalRC(CLK_PWRCTL_LIRCEN_Msk);
    /* Switch HCLK clock source to HXT */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKSEL0_HIRCFSEL_48M, CLK_CLKDIV0_HCLK(1));
    /* Enable IP clock */
    CLK_EnableModuleClock(UART_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set GPA multi-function pins for UART0 RXD and TXD */
                SYS->GPA_MFP  = (SYS->GPA_MFP & (~SYS_GPA_MFP_PA8MFP_Msk) ) | SYS_GPA_MFP_PA8MFP_UART_TX;
                SYS->GPA_MFP  = (SYS->GPA_MFP & (~SYS_GPA_MFP_PA9MFP_Msk) ) | SYS_GPA_MFP_PA9MFP_UART_RX;
    /* Lock protected registers */
    SYS_LockReg();
void UART_Init(void)
    /* Init UR        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate(115200) */
    UART_Open( UART0,115200 );
/* MAIN function        */
int main (void)
    int32_t i32Err;
                uint16_t PB7;
                uint32_t count=0;
    if(SYS->REGLCTL == 1) // In end of main function, program issued CPU reset and write-protection will be disabled.
        SYS_LockReg();
                /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART0 for printf */
    UART_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+-------------------------------------+ \n");
    printf("|           GPIO Driver Sample Code   | \n");
    /* GPIO Basic Mode Test --- Use Pin Data Input/Output to control GPIO pin                              */
    printf("  >> Please connect PA.15 and PB.7 first << \n");
    printf("     Press any key to start test by using [Pin Data Input/Output Control] \n\n");
    //getchar();
    /* Configure PA.15 as Output mode and PB.7 as Input mode then close it */
    GPIO_SetMode(PA, BIT15, GPIO_MODE_OUTPUT);
    GPIO_SetMode(PB, BIT7, GPIO_MODE_INPUT);
    i32Err = 0;
    printf("  GPIO Output/Input test ...... \n");
    /* Use Pin Data Input/Output Control to pull specified I/O or get I/O pin status */
    GPIO_SET_OUT_DATA(PA, 0x00); // PA15=0
                PB7 = GPIO_GET_IN_DATA(PB) & 0x80;
    if (PB7 != 0) {
        i32Err = 1;
    GPIO_SET_OUT_DATA(PA, 0x8000); // PA15=1
    if (PB7 != 0x80) {
        i32Err = 1;
    if ( i32Err ) {
        printf("  [FAIL] --- Please make sure PA.15 and PB.7 are connected. \n");
    } else {
        printf("  [OK] \n");
    /* Configure PA.15 and PB.7 to default Quasi-bidirectional mode */
    GPIO_SetMode(PA, BIT15, GPIO_MODE_QUASI);
    GPIO_SetMode(PB, BIT7, GPIO_MODE_QUASI);
    /* GPIO Interrupt Function Test        */
    printf("\n  PA15, PB7 are used to test interrupt\n  and control LEDs(PA12,PA13,PB14)\n");
    /*Configure PA, PB for LED control */
    GPIO_SetMode(PA, BIT12, GPIO_MODE_OUTPUT);
                GPIO_SetMode(PA, BIT13, GPIO_MODE_OUTPUT);
                GPIO_SetMode(PB, BIT14, GPIO_MODE_OUTPUT);
                GPIO_SET_OUT_DATA(PA, ~0x1000);
                GPIO_SET_OUT_DATA(PB, ~0x0000);
    /* Configure PA15 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(PA, BIT15, GPIO_MODE_INPUT);
    GPIO_EnableInt(PA, 15, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPAB_IRQn);
    /*  Configure PB7 as Quasi-bi-direction mode and enable interrupt by both rising and falling edge trigger */
                GPIO_EnableInt(PB, 7, GPIO_INT_BOTH_EDGE);
    /* Enable interrupt de-bounce function and select de-bounce sampling cycle time */
    GPIO_SET_DEBOUNCE_TIME(GPIO_DBCTL_DBCLKSRC_HCLK, GPIO_DBCTL_DBCLKSEL_1);
    GPIO_ENABLE_DEBOUNCE(PA, BIT15);
    GPIO_ENABLE_DEBOUNCE(PB, BIT7);
    /* Waiting for interrupts */
    while (1)
                        GPIO_SET_OUT_DATA(PA, ~((count>>14)&0xf000));
                        GPIO_SET_OUT_DATA(PB, ~((count>>14)&0x80));
                        count++;
有多少人用过这个系列?
例子中的一些用法值得学习。
zhuotuzi| | 2019-1-7 23:00 | 只看该作者
也是ARM内核的吧
