[DemoCode下载]
Keil V5.27自带的M051的GPIO例子
1157|8
598330983|  楼主 | 2019-1-12 22:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 15/05/22 2:51p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show the usage of GPIO interrupt function.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK           50000000
* @brief       Port0/Port1 IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The Port0/Port1 default IRQ, declared in startup_M051Series.s.
void GPIOP0P1_IRQHandler(void)
    /* To check if P1.3 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P1, BIT3))
        GPIO_CLR_INT_FLAG(P1, BIT3);
        printf("P1.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
        P0->ISRC = P0->ISRC;
        P1->ISRC = P1->ISRC;
        printf("Un-expected interrupts.\n");
* @brief       Port2/Port3/Port4 IRQ
* @param       None
* @return      None
* @details     The Port2/Port3/Port4 default IRQ, declared in startup_M051Series.s.
void GPIOP2P3P4_IRQHandler(void)
    /* To check if P4.5 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P4, BIT5))
        GPIO_CLR_INT_FLAG(P4, BIT5);
        printf("P4.5 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT2, PORT3 and PORT4 interrupts */
        P2->ISRC = P2->ISRC;
        P3->ISRC = P3->ISRC;
        P4->ISRC = P4->ISRC;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+------------------------------------------------+\n");
    printf("|    GPIO P1.3 and P4.5 Interrupt Sample Code    |\n");
    printf("+------------------------------------------------+\n\n");
    /* GPIO Interrupt Function Test        */
    printf("P1.3 and P4.5 are used to test interrupt ......\n");
    /* Configure P1.3 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(P1, BIT3, GPIO_PMD_INPUT);
    GPIO_EnableInt(P1, 3, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPIO_P0P1_IRQn);
    /*  Configure P4.5 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
    GPIO_SetMode(P4, BIT5, GPIO_PMD_QUASI);
    GPIO_EnableInt(P4, 5, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPIO_P2P3P4_IRQn);
    /* Waiting for interrupts */
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
598330983|  楼主 | 2019-1-12 22:43 | 只看该作者
貌似跟BSP里的例子一样,是不是
xuanhuanzi| | 2019-1-12 23:32 | 只看该作者
好像必须先在Keil的PACK安装支持包后,才可以用BSP吧
xuanhuanzi| | 2019-1-13 09:38 | 只看该作者
IO中断的操作。
xinxianshi| | 2019-1-13 11:47 | 只看该作者
Keil的PACK带了不少例子。
antusheng| | 2019-1-14 18:04 | 只看该作者
例子还是从前的例子。
所以Keil这个东西,一般不升级也行。
zhuotuzi| | 2019-1-16 23:54 | 只看该作者
有啥更新吗
yiyigirl2014| | 2019-1-18 23:39 | 只看该作者
主要是安装了这个才支持。
幸福小强| | 2019-1-18 23:40 | 只看该作者
我也刚更新,没发现什么不同。
