|   * [url=home.php?mod=space&uid=247401]@brief[/url] This API configures ADC module to be ready for convert the input from selected channel
  * @param[in] adc Base address of ADC module
  * @param[in] u32InputMode Decides the ADC analog input mode. Valid values are:
  *                          - \ref ADC_ADCR_DIFFEN_SINGLE_END      :Single end input mode
  *                          - \ref ADC_ADCR_DIFFEN_DIFFERENTIAL    :Differential input type
  * @param[in] u32OpMode Decides the ADC operation mode. Valid values are:
  *                       - \ref ADC_ADCR_ADMD_SINGLE               :Single mode.
  *                       - \ref ADC_ADCR_ADMD_BURST                :Burst mode.
  *                       - \ref ADC_ADCR_ADMD_SINGLE_CYCLE         :Single cycle scan mode.
  *                       - \ref ADC_ADCR_ADMD_CONTINUOUS           :Continuous scan mode.
  * @param[in] u32ChMask Channel enable bit. Each bit corresponds to a input channel. Bit 0 is channel 0, bit 1 is channel 1..., bit 7 is channel 7.
  * [url=home.php?mod=space&uid=266161]@return[/url]  None
  * [url=home.php?mod=space&uid=536309]@NOTE[/url] M051 series MCU ADC can only convert 1 channel at a time. If more than 1 channels are enabled, only channel
  *       with smallest number will be convert.
  * @note This API does not turn on ADC power nor does trigger ADC conversion
void ADC_Open(ADC_T *adc,
              uint32_t u32InputMode,
              uint32_t u32OpMode,
              uint32_t u32ChMask)
    ADC->ADCR = (ADC->ADCR & (~(ADC_ADCR_DIFFEN_Msk | ADC_ADCR_ADMD_Msk))) | \
                u32InputMode | \
                u32OpMode;
    ADC->ADCHER = (ADC->ADCHER & ~ADC_ADCHER_CHEN_Msk) | (u32ChMask);
    return;
