明远智睿MY-IMX6-EK200 Linux-4.1.15测试手册v2.0(2)
1038|4
 楼主| Anxyuuu 发表于 2019-3-14 15:40 | 显示全部楼层 |阅读模式
【接上一章节明远智睿MY-IMX6-EK200 Linux-4.1.15测试手册v2.01)】
2.10  GPIO-KEY测试
  【测试说明】:使用 evtest 进行测试
  【接口标识】:KEY3, KEY2, KEY1
  【系统接口】:/dev/input/eventX
测试操作
  运行 evtest 准备测试
=====> 输入指令:
evtest
=====> 输出信息:
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:  WM8962 Beep Generator
/dev/input/event1:  gpio-keys
Select the device event number [0-1]:
  选择 gpio-keys 所对应的序号
=====> 输入指令:
=====> 输出信息:
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "gpio-keys"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 114 (KEY_VOLUMEDOWN)
    Event code 115 (KEY_VOLUMEUP)
    Event code 116 (KEY_POWER)
Properties:
Testing ... (interrupt to exit)
  按动开发板上的按键
Event: time 1537921332.815219, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
Event: time 1537921332.815219, -------------- SYN_REPORT ------------
Event: time 1537921332.985211, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
Event: time 1537921332.985211, -------------- SYN_REPORT ------------
Event: time 1537921335.355204, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
Event: time 1537921335.355204, -------------- SYN_REPORT ------------
Event: time 1537921335.535203, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
Event: time 1537921335.535203, -------------- SYN_REPORT ------------
Event: time 1537921337.375207, type 1 (EV_KEY), code 116 (KEY_POWER), value 1
Event: time 1537921337.375207, -------------- SYN_REPORT ------------
Event: time 1537921337.535204, type 1 (EV_KEY), code 116 (KEY_POWER), value 0
Event: time 1537921337.535204, -------------- SYN_REPORT ------------
测试结果
  当发生按键时,evtest 会输出相应的信息。
2.11  串口测试(UART2)
  【测试说明】:采用串口自发自收的方式进行测试
  【接口标识】:UART2/3/4/5_TTL
  【系统设备】:/dev/ttymxc1
测试操作
  短接串口2的发送发接收管脚(J1的7和9号管脚)
  执行测试指令:
=====> 输入指令:
/my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc1 "www.myzr.com.cn"
=====> 输出信息:
Starting send data...finish
Starting receive data:
ASCII: 0x77      Character: w
ASCII: 0x2e      Character: .
ASCII: 0x6d      Character: m
ASCII: 0x79      Character: y
ASCII: 0x7a      Character: z
ASCII: 0x72      Character: r
ASCII: 0x63      Character: c
ASCII: 0x6f      Character: o
ASCII: 0x6e      Character: n
ASCII: 0x0       Character:
测试结果
  执行测试指令后,应用输出如上类似信息即正常。
2.12  串口测试(UART3)
  【系统设备】:/dev/ttymxc2
测试操作
  短接串口3的发送发接收管脚(J1的11和13号管脚)
  执行测试指令:
=====> 输入指令:
/my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc2 "www.myzr.com.cn"
=====> 输出信息:
测试结果
2.13  串口测试(UART4)
  【系统设备】:/dev/ttymxc3
测试操作
  短接串口4的发送发接收管脚(J1的15和17号管脚)
  执行测试指令:
=====> 输入指令:
/my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc3 "www.myzr.com.cn"
=====> 输出信息:
测试结果
2.14  串口测试(UART5)
  【系统设备】:/dev/ttymxc4
测试操作
  短接串口5的发送发接收管脚(J1的16和18号管脚)
  执行测试指令:
=====> 输入指令:
/my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc4 "www.myzr.com.cn"
=====> 输出信息:
测试结果
2.15  CAN 测试
  【测试说明】:采用CAN1发送,CAN0接收的方式。
  【接口标识】:CAN1,CAN2
  【系统接口】:can0,can1
测试准备
  将CAN1的CAN_L与CAN2的CAN_L连接。
  将CAN1的CAN_H与CAN2的CAN_H连接。
测试命令
  配置 CAN1(can0):
=====> 输入指令:
ip link set can0 up type can bitrate 125000
  配置 CAN2(can1):
=====> 输入指令:
ip link set can1 up type can bitrate 125000
  CAN1 (can0) 后台接收:
=====> 输入指令:
candump can0 &
  CAN2(can1)发送数据:
=====> 输入指令:
cansend can1 1F334455#1122334455667788
=====> 输出信息:
can0  1F334455   [8]  11 22 33 44 55 66 77 88
测试结果
  CAN2(can1)发送数据后,CAN1(can0)会把接收到的数据输出,如:11 22 33 44 55 66 77 88
【下章节为明远智睿MY-IMX6-EK200 Linux-4.1.15测试手册v2.03)】
零三翟邢止胃 发表于 2019-3-15 09:01 | 显示全部楼层
多谢分享啊!!!!
 楼主| Anxyuuu 发表于 2019-3-15 10:47 | 显示全部楼层
不用谢
mcufz 发表于 2019-3-15 18:05 | 显示全部楼层
多谢分享啊! 感谢啊!
 楼主| Anxyuuu 发表于 2019-3-18 08:50 | 显示全部楼层
多谢分享啊! 感谢啊!
不用谢
