编译时出现如下错误
303|6
xxrs|  楼主 | 2019-3-15 18:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ADD: sdb.M0059: error: Error in component: cy_boot. The cy_boot_v1_10 component (cy_boot) is an Obsolete component. It is no longer recommended for use and should be replaced with a production version of the component (or an alternative implementation).
Error: cdf.M0005: CyDsFit aborted due to errors, please address all errors and rerun CyDsFit. (App=cydsfit)
houcs| | 2019-3-15 18:47 | 只看该作者
芯片选择对了么
liuzaiy| | 2019-3-15 18:50 | 只看该作者
是否用高版本去编译低版本的例程
yinxiangh| | 2019-3-15 18:54 | 只看该作者
程序升级是否完整,我有过升级一半我嫌慢就取消掉了,后来就再也不能用只能重新装一遍的情况了
pangb| | 2019-3-15 18:57 | 只看该作者
你的文件是在“我的文档下面吗”,
chenjunt| | 2019-3-15 19:00 | 只看该作者
Currently, PSoC Creator does not support building a project from a network share drive. Typically, “My Documents” or equivalent folder is seen as a shared network folder by Windows running on Parallels Desktop. Please save the project in a local folder (say C:\Documents and Settings\User\...) and rebuild the example project.
xxrs|  楼主 | 2019-3-15 19:06 | 只看该作者
哦,我看看
