[菜农助学交流] 菜鸟学习第五帖:按键和pwm结合控制舵机
 楼主| gaochy1126 发表于 2011-9-13 12:23 | 显示全部楼层 |阅读模式
#include <stdio.h>
#include "NUC1xx.h"
#include "Driver\DrvGPIO.h"
#include "Driver\DrvSYS.h"
#include "Driver\DrvUART.h"
#include "Driver\DrvTIMER.h"
#include "Driver\DrvPWM.h"
volatile  uint8_t PWM0_Duty_Cycle = 3;  //PWM占空比
void UART_INT_HANDLE(uint32_t u32IntStatus);
void Init_System(void)
    UNLOCKREG(x);
DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1);
DrvSYS_Delay(5000);
LOCKREG(x);
void Init_PWM0(void)
S_DRVPWM_TIME_DATA_T sPt;
/* PWM Timer property */
sPt.u8Mode = DRVPWM_AUTO_RELOAD_MODE;  /*自动重载模式    DRVPWM_ONE_SHOT_MODE为单触发模式*/
sPt.u32Frequency = 50;      /*PWM 频率 为400HZ即2500us为一周期*/
sPt.u8HighPulseRatio = PWM0_Duty_Cycle;     /* 高脉冲宽度 : 总脉冲宽度 = 1 : 100 */
sPt.i32Inverter = 0;      /*反向关闭*/
/* Enable PWM clock */
    DrvPWM_Open();
/* Select PWM engine clock */
DrvPWM_SelectClockSource(DRVPWM_TIMER0, DRVPWM_EXT_12M);
/* Set PWM Timer0 Configuration */
DrvPWM_SetTimerClk(DRVPWM_TIMER0, &sPt);
/* Enable Output for PWM Timer0 */
DrvPWM_SetTimerIO(DRVPWM_TIMER0, 1);
/* Set PWM pins */
DrvGPIO_InitFunction(E_FUNC_PWM01);
/* Enable the PWM Timer 0 */
DrvPWM_Enable(DRVPWM_TIMER0, 1);
int main (void)
uint8_t PWM0_Duty_Cycle_tmp = 3;
uint16_t PWM_CNR0_tmp = 0;
uint16_t tmp;
Init_System();
Init_PWM0();
    while(1)
  if (0==DrvGPIO_GetBit(E_GPB,15)) //利用助学板上的key1和key2来调节舵机的运动角度
      DrvSYS_Delay(5000);
   if(PWM0_Duty_Cycle < 4 ) PWM0_Duty_Cycle=3;
   else PWM0_Duty_Cycle--;
  if (0==DrvGPIO_GetBit(E_GPB,14))
      DrvSYS_Delay(5000);
   if(PWM0_Duty_Cycle >11 ) PWM0_Duty_Cycle=12;
   else PWM0_Duty_Cycle++;
     if (PWM0_Duty_Cycle_tmp!=PWM0_Duty_Cycle)
      PWM0_Duty_Cycle_tmp = PWM0_Duty_Cycle;
      if (0==PWM0_Duty_Cycle)
    PWMA->CMR0 = 0;
   else
    tmp = (PWM_CNR0_tmp+1)*PWM0_Duty_Cycle/100-1;
    PWMA->CMR0 = tmp;
hotpower 发表于 2011-9-13 15:05 | 显示全部楼层
很好!
yulri 发表于 2012-2-9 17:59 | 显示全部楼层
记下了,谢谢!
plc_avr 发表于 2012-2-10 08:12 | 显示全部楼层
不错,最好上个图,呵呵。什么型号的舵机?
