[资料分享]
mmWave studio
1248|2
dirtwillfly|  楼主 | 2019-3-31 21:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
mmWave Studio is designed to characterize and evaluate TI mmWave sensors. mmWave sensors are configured and controlled from mmWave Studio by sending commands to the devices over SPI. Analog-to-digital converter (ADC) data is captured using the TSW1400EVM board, processed in MATLAB®, and results are displayed in the GUI.
mmWave Demo Visualizer and Sensing Estimator are web-based tools that enhance the evaluation of TI mmWave sensors. These easy-to-use tools provide capability to evaluate and prototype chirp designs and experiment with the the out-of-the-box demo. The tools are hosted directly on TI.com and enable interaction with the mmWave sensor evaluation modules. The tools can also be saved for offline use.
特性
  • mmWave Studio
    • Post-processing of ADC data and visualization of processed data
    • Board control (SOP change, reset control)
    • RS-232 connection and firmware download
    • Configures mmWave sensors using radar API commands
    • Interface to TSW1400EVM for raw ADC data capture
  • mmWave Sensing Estimator
    • Enables calculation of chirp parameters directly from scene information, such as max range, max velocity, range resolution, and more
    • Provides real-time feedback on out-of-bounds parameters
    • Enables saving and restoring of previously created chirps
  • mmWave Demo Visualizer
    • Enables real-time plotting of point cloud from output of mmWave software development kit (SDK) out-of-the-box demo
    • Fully configurable directly through GUI interface
    • Profiles tuned to common end-user scenarios, such as range, range resolution, velocity, and velocity resolution
mmWave Studio is free and does not require any royalties to TI.
dirtwillfly|  楼主 | 2019-3-31 21:59 | 只看该作者
MMWave Demo Visualizer User's Guide
MMWave Demo Visualizer User's Guide.pdf (640.69 KB)
dirtwillfly|  楼主 | 2019-3-31 22:01 | 只看该作者
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
