- /* Copyright(c) 2011 Nuvoton Technology Corp. All rights reserved. */
- #include "includes.h" //包含所需的头文件
- ** Function name: main
- ** Descriptions: Key1键按下LED1点亮,Key1键长按 LED2点亮 ,Key1键释放 LED1熄灭
- Key2键按下LED3点亮,Key2键长按 LED4点亮 ,Key2键释放 LED3熄灭
- ** input parameters: 无
- ** output parameters: 无
- ** Returned value: 无
- int main (void)
- Set_System(); //封装一些初始化模块
- while(1)
- KeyCode = GetKey();
- switch(KeyCode)
- case KEY1_DOWN_USER:
- DrvGPIO_ClrBit(E_GPA,2); //LED1 点亮
- break;
- case KEY1_UP_USER:
- DrvGPIO_SetBit(E_GPA,2); //LED2 熄灭
- break;
- case KEY1_HOLD_USER:
- DrvGPIO_ClrBit(E_GPA,3); //LED2 点亮
- break;
- case KEY2_DOWN_USER:
- DrvGPIO_ClrBit(E_GPA,4); //LED3 点亮
- break;
- case KEY2_UP_USER:
- DrvGPIO_SetBit(E_GPA,4); //LED3 熄灭
- break;
- case KEY2_HOLD_USER:
- DrvGPIO_ClrBit(E_GPA,5); //LED4 点亮
- break;
- default:break;
hw_config函数- #include "includes.h" //包含所需的头文件
- ** Function name: Set_System
- ** Descriptions: 封装一些初始化模块
- ** input parameters: count
- void Set_System(void)
- InitButtonVar(); //按键初始化
- RCC_Configuration(); //配置系统时钟
- GPIO_Configuration(); //配置GPIO
- TIMER_Configuration(); //配置TIMER
- ** Function name: RCC_Configuration
- ** Descriptions: 系统时钟源设置
- ** input parameters: none
- ** output parameters: none
- ** Returned value: none
- void RCC_Configuration(void)
- UNLOCKREG(); // 对写保护位操作时 需要一次向0x50000 0100写入 0x59,0x16,0x88,
- DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1);//与其 SYSCLK->PWRCON.XTL12M_EN = 1; 等同
- // PWRCON寄存器(这些寄存器在上电复位到用户解锁定之前是锁定的)除了 BIT[6]位其他位都受写保护
- // 解除这些需要向 0x50000 0100写入 0x59,0x16,0x88,
- // 令PWRCON寄存器的BITP[0]为1(即设定12M外部晶振)
- delay_ms(100); //while (DrvSYS_GetChipClockSourceStatus(E_SYS_XTL12M) != 1);//等待外部12MHZ晶振就绪
- LOCKREG(); // 向“0x5000_0100”写入任何值,就可以重锁保护寄存器
- ** Function name: GPIO_Configuration
- ** Descriptions: GPIO配置
- void GPIO_Configuration()
- DrvGPIO_Open( E_GPA, 2, E_IO_OUTPUT ); //led端口设置为输出
- DrvGPIO_Open( E_GPA, 3, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 4, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPA, 5, E_IO_OUTPUT );
- DrvGPIO_Open( E_GPB, 14, E_IO_INPUT ); //按键端口设置为输入
- DrvGPIO_Open( E_GPB, 15, E_IO_INPUT );
- ** Function name: TIMER_Configuration
- ** Descriptions: TIMER配置
- void TIMER_Configuration()
- DrvTIMER_Init(); //初始化定时器
- DrvSYS_SelectIPClockSource(E_SYS_TMR0_CLKSRC,0); //使用外设时注意必须设置该外设的时钟 设置TMR0的时钟源为外部12MHZ
- DrvTIMER_Open(E_TMR0,1000,E_PERIODIC_MODE); //设定定时器timer0的tick周期,并且启动定时器:定时器通道 TMR0 每秒1000次 周期模式
- DrvTIMER_SetTimerEvent(E_TMR0,10,(TIMER_CALLBACK) Timer0_Callback,0); //安装一个10ms定时处理事件到 timer0通道
- DrvTIMER_EnableInt(E_TMR0); //使能定时器中断 //TIMER0->TCSR.IE = 1
- DrvTIMER_Start(E_TMR0); //定时器timer0开始计数 //TIMER0->TCSR.CEN = 1;
- ** Function name: Timer0_Callback
- ** Descriptions: 定时处理事件 用来做按键扫描
- void Timer0_Callback (void)
- KeyPro(); //按键扫描 该函数在 button.c 中实现
- ** Function name: delay_ms
- ** Descriptions: 1ms(晶振为12MHZ)延时子程序
- void delay_ms(uint32_t count)
- uint32_t i,j;
- for(i=count;i>0;i--)
- for(j=2395;j>0;j--);
hw_config头文件- #ifndef __HW_CONFIG_H__
- #define __HW_CONFIG_H__
- void Set_System(void);
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void TIMER_Configuration(void);
- void Timer0_Callback (void);
- void delay_ms(uint32_t count);
- #endif
button函数
button头文件- /* Define to prevent recursive inclusion -------------------------------------*/
- #ifndef __BUTTON_H
- #define __BUTTON_H
- #define u8 unsigned char
- #define u16 unsigned int
- /* Bit_SET and Bit_RESET enumeration -----------------------------------------*/
- typedef enum
- { Bit_RESET = 0,
- Bit_SET
- }BitAction;
- /* 按键滤波时间50ms, 单位10ms
- 只有连续检测到50ms状态不变才认为有效,包括弹起和按下两种事件
- #define BUTTON_FILTER_TIME 5
- #define BUTTON_LONG_TIME 100 /* 持续1秒,认为长按事件 */
- 每个按键对应1个全局的结构体变量。
- 其成员变量是实现滤波和多种按键状态所必须的
- typedef struct
- /* 下面是一个函数指针,指向判断按键手否按下的函数 */
- u8 (*IsKeyDownFunc)(void); /* 按键按下的判断函数,1表示按下 */
- u8 Count; /* 滤波器计数器 */
- u8 FilterTime; /* 滤波时间(最大255,表示2550ms) */
- u16 LongCount; /* 长按计数器 */
- u16 LongTime; /* 按键按下持续时间, 0表示不检测长按 */
- u8 State; /* 按键当前状态(按下还是弹起) */
- u8 KeyCodeUp; /* 按键弹起的键值代码, 0表示不检测按键弹起 */
- u8 KeyCodeDown; /* 按键按下的键值代码, 0表示不检测按键按下 */
- u8 KeyCodeLong; /* 按键长按的键值代码, 0表示不检测长按 */
- }BUTTON_T;
- /* 定义键值代码 */
- typedef enum
- KEY_NONE = 0, /* 0 表示按键事件 */
- KEY1_DOWN_USER, /* KEY_User1键按下 */
- KEY1_UP_USER, /* KEY_User1键弹起 */
- KEY1_HOLD_USER, /* KEY_User1键长按 */
- KEY2_DOWN_USER, /* KEY_User2键按下 */
- KEY2_UP_USER, /* KEY_User2键弹起 */
- KEY2_HOLD_USER, /* KEY_User2键长按 */
- }KEY_ENUM;
- /*按键FIFO用到变量 */
- #define KEY_FIFO_SIZE 20
- typedef struct
- u8 Buf[KEY_FIFO_SIZE]; /* 键值缓冲区 */
- u8 Read; /* 缓冲区读指针 */
- u8 Write; /* 缓冲区写指针 */
- }KEY_FIFO_T;
- void InitButtonVar(void);
- void PutKey(u8 _KeyCode);
- u8 GetKey(void);
- void KeyPro(void);
- #endif
已经过测试 OK
工程
