[DemoCode下载]
NUC230的ADC模块
608|13
zhuotuzi|  楼主 | 2019-4-12 22:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.0
* $Revision: 2 $
* $Date: 15/04/10 4:41p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    NUC230_240 Series ADC Interface Controller Driver Sample Code
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC230_240.h"
#define PLL_CLOCK       72000000
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcSingleModeTest(void);
/* Define global variables and constants        */
volatile uint32_t g_u32AdcIntFlag;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
    /* Disable the GPA0 - GPA3 digital input path to avoid the leakage current. */
    GPIO_DISABLE_DIGITAL_PATH(PA, 0xF);
    /* Configure the GPA0 - GPA3 ADC analog input pins */
    SYS->GPA_MFP &= ~(SYS_GPA_MFP_PA0_Msk | SYS_GPA_MFP_PA1_Msk | SYS_GPA_MFP_PA2_Msk | SYS_GPA_MFP_PA3_Msk) ;
    SYS->GPA_MFP |= SYS_GPA_MFP_PA0_ADC0 | SYS_GPA_MFP_PA1_ADC1 | SYS_GPA_MFP_PA2_ADC2 | SYS_GPA_MFP_PA3_ADC3 ;
    SYS->ALT_MFP1 = 0;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: AdcSingleModeTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC single mode test.        */
void AdcSingleModeTest()
    uint8_t  u8Option;
    int32_t  i32ConversionData;
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                      ADC single mode sample code                     |\n");
    while(1) {
        printf("Select input mode:\n");
        printf("  [1] Single end input (channel 2 only)\n");
        printf("  [2] Differential input (channel pair 1 only)\n");
        printf("  Other keys: exit single mode test\n");
        u8Option = getchar();
        if(u8Option == '1') {
            /* Set the ADC operation mode as single, input mode as single-end and enable the analog input channel 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
            /* Power on ADC module */
            ADC_POWER_ON(ADC);
            /* Clear the A/D interrupt flag for safe */
            ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
            /* Enable the ADC interrupt */
            ADC_EnableInt(ADC, ADC_ADF_INT);
            NVIC_EnableIRQ(ADC_IRQn);
            /* Reset the ADC interrupt indicator and Start A/D conversion */
            g_u32AdcIntFlag = 0;
            ADC_START_CONV(ADC);
            /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function)*/
            while(g_u32AdcIntFlag == 0);
            /* Disable the ADC interrupt */
            ADC_DisableInt(ADC, ADC_ADF_INT);
            /* Get the conversion result of the ADC channel 2 */
            i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 2);
            printf("Conversion result of channel 2: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
        } else if(u8Option == '2') {
            /* Set the ADC operation mode as single, input mode as differential and
               enable analog input channel 2 for differential input channel pair 1 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
            ADC_POWER_ON(ADC);
            /* Get the conversion result of the specified ADC channel */
            printf("Conversion result of channel pair 1: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
        } else
            return ;
/* ADC interrupt handler        */
void ADC_IRQHandler(void)
    g_u32AdcIntFlag = 1;
    ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT); /* clear the A/D conversion flag */
/* MAIN function        */
main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* Single Mode test */
    AdcSingleModeTest();
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
zhuotuzi|  楼主 | 2019-4-12 22:23 | 只看该作者
我们看到这个配置跟其他系列是一样的,而且ADC模块是有自己的电源开关,可以不用的时候关闭实现低功耗。
zhuotuzi|  楼主 | 2019-4-12 22:24 | 只看该作者
如果不用ADC直接
ADC_POWER_DOWN(adc)
zhuotuzi|  楼主 | 2019-4-12 22:57 | 只看该作者
好多设置其实都是一样 ,比如这个例子中的两个情况。
zhuomuniao110| | 2019-4-13 16:47 | 只看该作者
新唐的ADC设计非常合理
heisexingqisi| | 2019-4-14 21:07 | 只看该作者
230支持LCDMA
734774645| | 2019-4-15 11:27 | 只看该作者
NUC系列的非常好用
huangcunxiake| | 2019-4-15 19:01 | 只看该作者
新唐系列 单片机大部分库函数都是一致的。
幸福小强| | 2019-4-15 23:13 | 只看该作者
有了这个可以省好几块钱的ADC了
玛尼玛尼哄| | 2019-4-16 00:31 | 只看该作者
新唐的性价比很不错。130的支持LCD。
mintspring| | 2019-4-16 00:41 | 只看该作者
库函数做的好,可以方便移植到其他系列。
operating| | 2019-4-16 16:09 | 只看该作者
感谢分享!学习一下。
稳稳の幸福| | 2019-4-16 23:32 | 只看该作者
PLL用的是外部时钟?
xinxianshi| | 2019-4-17 13:26 | 只看该作者
ADC的常用的。
