[其他产品]
PIC16F877A的50HZ正弦波
503|2
waveforms|  楼主 | 2019-4-24 14:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原帖链接:https://www.cnblogs.com/wangh0802PositiveANDupward/archive/2012/08/11/2633416.html
#include <pic.h>//包含单片机内部资源预定义
#include <math.h>
unsigned char const sin_32[]={104,109,114,119,124,128,133,137,142,146,150,154,157,161,164,//15
167,169,172,174,176,177,178,179,180,180,180,180,179,178,176,175,173,171,168,165,//20
162,159,156,152,148,144,140,135,131,126,121,116,111,106,101,96,91,86,81,76,72,67,63,//23
58,54,50,46,43,39,36,33,31,28,26,24,23,22,21,20,20,20,20,21,22,24,25,27,29,32,35,38,//42
41,44,48,52,56,60,65,69,74,79,84,89,94,99
};//浮点型精度高,换其他会出现尖角
void work0();
unsigned char set_pwm;
void main(void)
    work0();
    while(1)
void work0()//m=0.8;T=(PR2+1)*4*f*TIMR2分频
    //CCPR1L=0X00;//设置CCP1,0%的脉宽输出
    TRISC=0X00;//PORTC are outputs
    CCP1CON=0x0C;//0000 1100,设置CCP1为PWM工作方式,且工作循环位的低两位为00
    PR2=199;//设置PWM周期:(PR2+1)*4*Tosc*(TMR2预分频数1)=200u(5k)
    T2CON=0x04;//Tc赋值=T*D=(PR2+1)*D=200*D
    CCP1IE=1;
    INTCON=0xC0;//GIE=1,开总中断,开启第一外设中断外围功能模块中断
    TMR2IE=1;TMR2IF=0;
//interrupt//
void interrupt pic(void)
    if(TMR2IF&TMR2IE)
        set_pwm++;
        TMR2IF=0;CCP1IF=0;
        CCPR1L=sin_32[set_pwm];
        if(set_pwm==99) set_pwm=0;
幸福小强| | 2019-4-24 22:37 | 只看该作者
波形发生?
这个频率不过,可以很容易实现。
