[DemoCode下载]
N76E003多通道ADC操作
531|1
zhuotuzi|  楼主 | 2019-5-26 10:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Jan/21/2017
//  File Function: N76E003  ADC mutli channel demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
                unsigned char ADCdataH[4], ADCdataL[4];
The main C function.  Program execution starts
here after stack initialization.
void main (void)
                unsigned char i;
        while(1)
                CKDIV = 0x02;        // IMPORTANT!! Modify system clock to 4MHz ,then add the ADC sampling clock base to add the sampling timing.
                i = 0;
                        Enable_ADC_AIN0;
                        clr_ADCF;
                        set_ADCS;
      while(ADCF == 0);
                        ADCdataH[i] = ADCRH;
                        ADCdataL[i] = ADCRL;
                        Disable_ADC;
                i++;
                        Enable_ADC_BandGap;
                        clr_ADCF;
                        set_ADCS;
      while(ADCF == 0);
                        Disable_ADC;
                i++;
                        Enable_ADC_AIN3;
                        clr_ADCF;
                        set_ADCS;
      while(ADCF == 0);
                        Disable_ADC;
                CKDIV = 0x00;
zhuotuzi|  楼主 | 2019-5-26 10:59 | 只看该作者
这个例子有意思,本来可以用一个for循环实现的。
