[STM32L1]
STM32L151C8T6的串口配置
783|7
renzheshengui|  楼主 | 2019-6-12 15:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原文:https://blog.csdn.net/jun2036/article/details/82877844
**STM32L151C8T6的串口配置
    //加入以下代码,支持printf函数,而不需要选择use MicroLIB
    #if 1
    #pragma import(__use_no_semihosting)
    //标准库需要的支持函数
    struct __FILE
            int handle;
    FILE __stdout;
    //定义_sys_exit()以避免使用半主机模式
    _sys_exit(int x)
            x = x;
renzheshengui|  楼主 | 2019-6-12 15:55 | 只看该作者
//重定义fputc函数
    int fputc(int ch, FILE *f)
        uint16_t CNT=0;
            while((USART1->SR&0X40)==0)//循环发送,直到发送完毕
            if((CNT++)>60000)//防止异常超时退出
                break;
        USART1->DR = (u8) ch;
            return ch;
    #endif
    * @brief   Uart Init program
    * @param1  USARTx:USART1 USARTUSART2 USART3
    * @param2  bound: USARTx Baud Rate
    * @retval None
    void My_USARTx_Config(USART_TypeDef* USARTx,uint32_t bound)
        //GPIO端口设置
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        My_Struct_Clear(USART_InitStructure);
        My_Struct_Clear(NVIC_InitStructure);
            /* Enable the USARTx Pins Software Remapping */
        if(USARTx == USART1)
            My_Struct_Clear(UART1_Parameter);
            RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
            RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
        else if(USARTx == USART2)
            My_Struct_Clear(UART2_Parameter);
            RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        else if(USARTx == USART3)
            My_Struct_Clear(UART3_Parameter);
            RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
            RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
            /* Configure USART1 Rx (PA.10) as input floating */
            My_Struct_Clear(GPIO_InitStructure);
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
            GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
            GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
            GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
            GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
            GPIO_Init(GPIOA, &GPIO_InitStructure);
            /* Configure USART1 Tx (PA.09) as alternate function push-pull */
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
            GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
            GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
            /* Configure USART2 Rx (PA.03) as input floating */
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
            /* Configure USART2 Tx (PA.02) as alternate function push-pull */
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
            /* Configure USART3 Rx (PB.11) as input floating */
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
            GPIO_Init(GPIOB, &GPIO_InitStructure);
            /* Configure USART3 Tx (PB.10) as alternate function push-pull */
        /* Enable the USARTx Interrupt */
            NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
            NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
            NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        USART_InitStructure.USART_BaudRate = bound;
            USART_InitStructure.USART_WordLength = USART_WordLength_8b;
            USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
            USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
            USART_Init(USARTx, &USART_InitStructure);
        /* Enable USARTx */
        USART_Cmd(USARTx, ENABLE);
        USART_ITConfig(USARTx, USART_IT_RXNE,DISABLE);
        USART_ITConfig(USARTx, USART_IT_TXE,DISABLE);
            GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_USART1);
            GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1);
            GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_USART2);
            GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_USART2);
            GPIO_PinAFConfig(GPIOB,GPIO_PinSource10,GPIO_AF_USART3);
            GPIO_PinAFConfig(GPIOB,GPIO_PinSource11,GPIO_AF_USART3);
renzheshengui|  楼主 | 2019-6-12 15:56 | 只看该作者
    * @brief   USRATx transmit transmit datas or string
    * @param2  Str: Data Addr
    * @retval None
    void USARTx_SendString(USART_TypeDef* USARTx,char * str)
        uint16_t CNT=0;
        while(*str != '\0')// && *str != '\n'
            USARTx->DR = (u8) *str++;
            while((USARTx->SR&0X40)==0)//循环发送,直到发送完毕
                if((CNT++)>60000)
                    break;
    * @param3  StrLength: Data Length
    * @retval None
    void USARTx_printf(USART_TypeDef* USARTx,const char *fmt,...)
        va_list ap;
        char  string[256];
        My_Struct_Clear(string);
        va_start(ap,fmt);
        vsprintf(string,fmt,ap);//此处也可以使用sprintf函数,用法差不多,稍加修改即可,此处略去
        USARTx_SendString(USARTx,string);
        va_end(ap);
木木guainv| | 2019-7-4 16:54 | 只看该作者
感谢楼主分享
renzheshengui|  楼主 | 2019-7-5 11:10 | 只看该作者
非常感谢支持
just_2010| | 2020-8-24 15:40 | 只看该作者
学习一下,最近用到
