[STM32F0] 关于STM32F072产生不了PWM
1169|8
 楼主| aa911 发表于 2019-6-24 20:43 | 显示全部楼层 |阅读模式
  1. int main(void)
  3.         RCC_ClocksTypeDef  RCC_Clocks;
  4.         uint32_t sys;
  5.         RCC_HSI_Configuration();
  6.         UART1_Configuration();//波特率9600
  7.         LED_Init();
  8.         TIM1_PWM_Init(23,1);
  9.
  10.         while (1)
  11.         {
  12.                 Clr_LED_1;
  13.                 Clr_LED_2;
  14.                 //TIM1_Set_PWM();
  15.                 //Clr_LED_4;
  16.         }
  17. }
  18. void TIM1_PWM_Init(uint16_t arr,uint16_t psc) //产生pwm
  19. {
  20.         GPIO_InitTypeDef GPIO_InitStructure;
  21.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  22.         TIM_OCInitTypeDef TIM_OCInitStructure;
  23.
  24.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  25.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOF, ENABLE);//使能GPIO外设和AFIO复用功能模块时钟使能
  26.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  27.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  28.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  29.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  30.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  31.         GPIO_Init(GPIOF, &GPIO_InitStructure);
  32.         GPIO_PinAFConfig(GPIOF, GPIO_PinSource0, GPIO_AF_1);
  33.
  34.         TIM_TimeBaseStructure.TIM_Period = arr;//设置在下一个更新事件装入活动的自动重装载寄存器周期的值
  35.         TIM_TimeBaseStructure.TIM_Prescaler =0;//设置用来作为TIMx时钟频率除数的预分频值
  36.         TIM_TimeBaseStructure.TIM_ClockDivision = 0;//设置时钟分割:TDTS = Tck_tim
  37.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//TIM向上计数模式
  38.         TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  39.         TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);//根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
  40.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//PWM模式1
  41.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//正向通道有效
  42.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;//反向通道无效
  43.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  44.     TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCPolarity_Low;
  45.     TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  46.     TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  47.         TIM_OCInitStructure.TIM_Pulse = 100;
  48.         TIM_OC1Init(TIM1,&TIM_OCInitStructure); //通道1
  49.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  50.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  51.         TIM_ARRPreloadConfig(TIM1, ENABLE);//使能TIMx在ARR上的预装载寄存器
  52.         TIM_Cmd(TIM1, ENABLE);//使能TIMx外设
  53. }
如题,为什么没有产生pwm.
香水城 发表于 2019-6-24 22:31 | 显示全部楼层
如果其它配置【时钟、GPIO、TIM外设时钟]都配好了,你现在ARR=23,而CCR又等于100,此时输出的是固定的低电平。【结合你当前极性选择】
你把ARR调整大点,或者把CCR调得比Arr小,你看看还有无波形输出?
 楼主| aa911 发表于 2019-6-26 18:51 | 显示全部楼层
如果其它配置【时钟、GPIO、TIM外设时钟]都配好了,你现在ARR=23,而CCR又等于100,此时输出的是固定的低电 ...
应该是我用的IO口不对,定时器1复用不在PF0上
 楼主| aa911 发表于 2019-6-26 18:52 | 显示全部楼层
香水城 发表于 2019-6-26 22:04 | 显示全部楼层
强烈建议使用STM32CUBEMX进行配置,就可以绕开基本的GPIO/时钟这些配置错误。
 楼主| aa911 发表于 2019-6-27 18:47 | 显示全部楼层
  1. void TIM2_PWM_Init() //产生pwm
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  5.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  6.         float TimerPeriod = 0;
  7.         uint16_t Channel1Pulse = 0, Channel2Pulse = 0, Channel3Pulse = 0, Channel4Pulse = 0;
  8.
  9.         /* GPIOA Clocks enable */
  10.         RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
  11.
  12.         /* GPIOA Configuration: Channel 1, 2, 3 and 4 as alternate function push-pull */
  13.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  14.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  15.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  16.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  17.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  18.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  19.
  20.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_2);
  21.
  22.         /* TIM1 clock enable */
  23.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE);
  24.
  25.         /* Time Base configuration */
  26.         TIM_TimeBaseStructure.TIM_Prescaler = 48-1;//预分频值
  27.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  28.         TIM_TimeBaseStructure.TIM_Period = 500000;  //自动重装载值
  29.         TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  30.         TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  31.
  32.         TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  33.
  34.         /* Channel 1, 2, 3 and 4 Configuration in PWM mode */
  35.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  36.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  37.         TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  38.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//设置输出极性
  39.         TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  40.         TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  41.         TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  42.
  43.         TIM_OCInitStructure.TIM_Pulse = 100000;  //占空比时间
  44.         TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  45.
  46.         /* TIM1 counter enable */
  47.         TIM_Cmd(TIM2, ENABLE);
  48.
  49.         /* TIM1 Main Output Enable */
  50.         TIM_CtrlPWMOutputs(TIM2, ENABLE);
  51. }
我改用PA2,定时器TIM2,通道TIM2_CH3,可是也是产生不了pwm.是在是不知道哪出问题。
 楼主| aa911 发表于 2019-6-27 18:49 | 显示全部楼层
自己顶顶
 楼主| aa911 发表于 2019-7-1 18:53 | 显示全部楼层
在给自己顶
 楼主| aa911 发表于 2019-7-1 19:53 | 显示全部楼层
问题解决了,预分频系数和占空比的时间设置不正确,给的数值均超出了uint32_t的最大值。
