[DemoCode下载]
看门狗定时器做中断定时器使用
515|2
huangcunxiake|  楼主 | 2019-6-30 22:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 Watch Dog as pure timer with interrupt demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
*    WDT interrupt sub-routine
void WDT_ISR (void)   interrupt 10
                                        //---------toggle GPIO1---------
                                                clr_GPIO1;
                                                Timer2_Delay500us(5);
                                                set_GPIO1;
                                                clr_GPIO1;
                                                set_GPIO1;
                                        //---------end toggle GPIO2--------
                clr_WDTF;
                set_WDCLR;
*    Main function
void main (void)
/* Note
  WDT timer base is LIRC 10Khz
  Set_All_GPIO_Quasi_Mode;
                                                clr_GPIO1;
                                                Timer0_Delay1ms(500);
                                                set_GPIO1;
                                                clr_GPIO1;
                                                set_GPIO1;
//WDT init
//Warning:
//Pleaes always check CONFIG WDT disable first
//only when WDT reset disable, WDT use as pure timer
          TA=0xAA;TA=0x55;WDCON=0x07;                  //Setting WDT prescale
                set_WDTR;                       //WDT run
                set_WDCLR;        //Clear WDT timer
                set_EWDT;
                EA =1;
#if 0
    while(1);
#else
                set_WIDPD;        //WDT run in POWER DOWM mode setting if needed
                while (1)
                        set_PD;
                                                clr_P04;
                                                Timer1_Delay10ms(5);
                                                set_P04;
                                                clr_P04;
                                                set_P04;
                                        //---------end toggle GPIO1---------
#endif
huangcunxiake|  楼主 | 2019-6-30 22:48 | 只看该作者
没想到吧,看门狗定时器其实还可以作为一个普通的中断定时器使用,因为看门狗定时器非常特别,所以可以有其他定时器做不到的效果。
那就是使用低频时钟作为时钟源。
