基于gd32f103vk移植RTTHREAD 3.1.2系统
696|0
一、下载RTT 安装包 下载地址:http://www.keil.com/dd2/pack/
二、解压安装到MDK目录下
三、复制RTT到工程里
四、修改board.c
(1)、使用固件库的systick寄存器,,屏蔽rtt的定义
#if 0
#define _SCB_BASE       (0xE000E010UL)
#define _SYSTICK_CTRL   (*(rt_uint32_t *)(_SCB_BASE + 0x0))
#define _SYSTICK_LOAD   (*(rt_uint32_t *)(_SCB_BASE + 0x4))
#define _SYSTICK_VAL    (*(rt_uint32_t *)(_SCB_BASE + 0x8))
#define _SYSTICK_CALIB  (*(rt_uint32_t *)(_SCB_BASE + 0xC))
#define _SYSTICK_PRI    (*(rt_uint8_t  *)(0xE000ED23UL))
// Updates the variable SystemCoreClock and must be called
// whenever the core clock is changed during program execution.
extern void SystemCoreClockUpdate(void);
// Holds the system core clock, which is the system clock
// frequency supplied to the SysTick timer and the processor
// core clock.
extern uint32_t SystemCoreClock;
static uint32_t _SysTick_Config(rt_uint32_t ticks)
    if ((ticks - 1) > 0xFFFFFF)
        return 1;
    _SYSTICK_LOAD = ticks - 1;
    _SYSTICK_PRI = 0xFF;
    _SYSTICK_VAL  = 0;
    _SYSTICK_CTRL = 0x07;
    return 0;
#endif
(2)、修改函数“void rt_hw_board_init()”,
#if 0
        /* System Clock Update */
        SystemCoreClockUpdate();
        /* System Tick Configuration */
        _SysTick_Config(SystemCoreClock / RT_TICK_PER_SECOND);
        #endif
(3)、新建“board.h”头文件
#ifndef _board_H
#define _board_H
#include "bitband.h"
void rt_hw_board_init(void);
void SysTick_Handler(void);
#endif
五、修改“rtconfig.h”头文件
//#include "RTE_Components.h"
// <<< Use Configuration Wizard in Context Menu >>>
// <h>Basic Configuration
// <o>Maximal level of thread priority <8-256>
//        <i>Default: 32
#define RT_THREAD_PRIORITY_MAX 32
// <o>OS tick per second
//  <i>Default: 1000   (1ms)
#define RT_TICK_PER_SECOND 1000
// <o>Alignment size for CPU architecture data access
//        <i>Default: 4
#define RT_ALIGN_SIZE 4
// <o>the max length of object name<2-16>
//        <i>Default: 8
#define RT_NAME_MAX 8
// <c1>Using RT-Thread components initialization
//  <i>Using RT-Thread components initialization
#define RT_USING_COMPONENTS_INIT
// </c>
// <c1>Using user main
//  <i>Using user main
#define RT_USING_USER_MAIN
// </c>
// <o>the size of main thread<1-4086>
//        <i>Default: 512
#define RT_MAIN_THREAD_STACK_SIZE 512
六、编译通过
