哪位高手编过段式LCD驱动芯片BU9792AFUV?
6304|7
 楼主| hopewise 发表于 2011-11-12 08:38 | 显示全部楼层 |阅读模式
之前编过HT1621,TM1721等芯片,但它们都是功耗高.
因时间紧,想参考一下网友的程序,但百度之类网站很少.
ups888 发表于 2011-11-14 00:23 | 显示全部楼层
#define   LcdDrv_SlvAddr                0x7c
void I2C_CycleErrChk(void)
        uchar i,j;
        Set_InPut_P_EeprSda;
        Set_OutPut_P_EeprScl;
        P_EeprScl_High;
        if(P_EeprSda==0)
                //there is and error on I2C bus
                for(i=0;i<10;i++)
                        P_EeprScl_Low;
                        Null01();Null01();
                        P_EeprScl_High;
                        if(P_EeprSda==1)break;
void Lcd_Start(void)
        Set_OutPut_P_LcdScl;Set_OutPut_P_LcdSda;
        Null01();
        P_LcdSda_High;
        us_delay(2);
        P_LcdScl_High;
        Null01();
        P_LcdSda_Low;
        Null01();nop();nop();nop();
        P_LcdScl_Low;
      nop();nop();nop();
void Lcd_Stop(void)
        nop();nop();nop();
        //P_LcdSda_High;
        nop();nop();nop();
        P_LcdScl_Low;
       nop();nop();nop();
        P_LcdSda_Low;
        nop();nop();nop();nop();nop();
        P_LcdScl_High;
        P_LcdSda_High;
void Lcd_AckWr(void)
        uchar i;
        Set_InPut_P_LcdSda;
        P_LcdScl_High;
        GB_LcdAck标志寄存器=0;
        for(i=0;i<10;i++)
                if(!P_LcdSda){break;}
        us_delay(1);
        P_LcdScl_Low;
        if(i>=10){GB_LcdAck标志寄存器=1;}
        nop();nop();
void Lcd_AckRd(void)
        nop();nop();nop();
        P_LcdSda_Low;
        nop();nop();nop();
        P_LcdScl_High;
        us_delay(1);
        P_LcdScl_Low;
        nop();nop();nop();
        Set_InPut_P_LcdSda;
        nop();nop();
void Lcd_NoAck(void)
        nop();nop();nop();
        P_LcdSda_High;
        nop();nop();nop();
        P_LcdScl_High;
        us_delay(1);
        P_LcdScl_Low;
        nop();nop();nop();
uchar Lcd_Rd1Byte(void)
        union UN_DEF LUB_data;
        uchar i;
        Set_InPut_P_LcdSda;
        LUB_data.BYTE=0;Null01();nop();
        for(i=0;i!=8;i++)
                P_LcdScl_High;
                Null01();
                LUB_data.BIT.b0=P_LcdSda;
                P_LcdScl_Low;
                if(i==7)
                        P_LcdSda_Low;
                        //Lcd_AckRd();
                        return LUB_data.BYTE;
                        break;
                LUB_data.BYTE<<=1;
                nop();nop();nop();
                //Null01();
void Lcd_Wr1Byte(uchar PB_data)
        uchar i;
        LUB_data.BYTE=PB_data;Null01();nop();
        for(i=0;i!=8;i++)
                P_LcdSda=LUB_data.BIT.b7;
                //Null01();
                P_LcdScl_High;
                LUB_data.BYTE<<=1;
                P_LcdScl_Low;
        P_LcdSda_Low;
        Lcd_AckWr();
void Dis_Trans(uchar PuB_Frq)
        uchar i;
        //asm("FCLR I"); /* Interrupt disable */
        //I2C_CycleErrChk();
        Lcd_Start();
        Lcd_Wr1Byte(LcdDrv_SlvAddr);        /*send device address*/
        if(GB_LcdAck标志寄存器)
                P_LcdScl_Low;P_LcdSda_Low;
                LCD_PowerOff;sub_delay(90);LCD_PowerOn;
                sub_delay(10);
                Soft_ResetLcd();
                Lcd_Start();
        Lcd_Wr1Byte(0xc8);        /*Modeset */
        Lcd_Wr1Byte(PuB_Frq); /*DISCTL*/
        Lcd_Wr1Byte(0xe8);        /*ICSET */
        Lcd_Wr1Byte(0xf0);        /*BLKCTL*/
        Lcd_Wr1Byte(0xfc);       /*APKCTL*/
//        Lcd_Wr1Byte(0);
        Lcd_Wr1Byte(2);
        for(i=0;i<Gcst_LCDBufSize;i++)
                Lcd_Wr1Byte(GAub_LCD_Buf[i]);
        Lcd_Stop();
        //asm("FSET I"); /* Interrupt enable */
调用的时候低功耗Dis_Trans(0x0a2);高功耗选Dis_Trans(0x0bc);
 楼主| hopewise 发表于 2011-11-14 08:01 | 显示全部楼层
非常感谢ups888无私的发表,格式非常整洁,易懂,这样的好贴不多了.因为我搞软件时间不到2年,基本上用汇编写程序,用C写的只能是简单的产品.下面还是有些不明白:
1.Set_InPut_P_EeprSda与P_EeprSda是啥关系?
  Set_InPut_P_EeprSda是宏指令么?
2. Null01()是啥内容?
3.us_delay(1)是延时1us么?要是的话,怎么不用1个nop?
看来有空的话我要快恶补一下C语言了.
yewuyi 发表于 2011-11-14 10:22 | 显示全部楼层
这个应该是ROHM的一个LCD驱动芯片,可以联系上海格洲,他们是ROHM的代理,应该有做好的C函数或者汇编函数给你参考。
stupidboy456 发表于 2013-7-18 13:40 | 显示全部楼层
学习了,,谢谢大家
szbanqiu1688 发表于 2018-7-30 11:22 | 显示全部楼层
推荐可以试试 VKL144A  超低功耗
jcdzxh 发表于 2018-8-2 11:35 来自手机 | 显示全部楼层
写过,电表屏
