[技术问答]
关于N76E003串口多机通讯的问题
607|13
yunxiang521|  楼主 | 2019-8-7 16:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有没有相关的实例,按官方的PDF里的方法,设置了SM2=1,
P12_PushPull_Mode;
                P06_Quasi_Mode;
                P07_Quasi_Mode;
                SADDR=0x01;
                set_SM2;
                SCON = 0xD0;                        // Special setting the mode 3 and
                TMOD |= 0x20;            //Timer1 Mode1
    set_SMOD;                //UART0 Double Rate Enable
    set_T1M;
    clr_BRCK;                //Serial port 0 baud rate clock source = Timer1
                TH1 = 256 - (1000000/115200+1);               /*16 MHz */
                set_TR1;
                set_RB8;                                        //This bit is for setting the stop bit 2 high/low status,
                clr_TI;
    set_ES;           //enable UART interrupt
    set_EA;           //enable global interrupt
接收中断里要不要设置。
相关的资料很少,不知有那位大牛可以给详细说说。
21mengnan| | 2019-8-7 23:44 | 只看该作者
参考BSP的那些例子的配置方式。
dongnanxibei| | 2019-8-7 23:56 | 只看该作者
看你是中断接收还是查询接收
建议中断接收。
dongnanxibei| | 2019-8-7 23:59 | 只看该作者
一个发送一个接收吗
BSP里有发送和接收的参考。
dongnanxibei| | 2019-8-8 00:00 | 只看该作者
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 UART-1 Mode1 demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#define BUFFER_SIZE                16
UINT8  UART_BUFFER[BUFFER_SIZE],temp;
UINT16 u16CNT=0,u16CNT1=0;
bit riflag;
* FUNCTION_PURPOSE: Serial port 1 interrupt, echo received data.
* FUNCTION_INPUTS : P0.2(RXD) serial input
* FUNCTION_OUTPUTS: P1.6(TXD) serial output
* Following setting in Common.c
#if 0
//void InitialUART1_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
//                P02_Quasi_Mode;                //Setting UART pin as Quasi mode for transmit
//                P16_Quasi_Mode;                //Setting UART pin as Quasi mode for transmit
//          SCON_1 = 0x50;           //UART1 Mode1,REN_1=1,TI_1=1
//    T3CON = 0x08;           //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1), UART1 in MODE 1
//                clr_BRCK;
//#ifdef FOSC_160000
//                RH3    = HIBYTE(65536 - (1000000/u32Baudrate)-1);                  /*16 MHz */
//                RL3    = LOBYTE(65536 - (1000000/u32Baudrate)-1);                        /*16 MHz */
//#endif
//#ifdef FOSC_166000
//                RH3    = HIBYTE(65536 - (1037500/u32Baudrate));                          /*16.6 MHz */
//                RL3    = LOBYTE(65536 - (1037500/u32Baudrate));                                /*16.6 MHz */
//#endif
//    set_TR3;         //Trigger Timer3
#endif
void SerialPort1_ISR(void) interrupt 15
    if (RI_1==1)
    {                                       /* if reception occur */
        clr_RI_1;                             /* clear reception flag for next reception */
        UART_BUFFER[u16CNT] = SBUF_1;
        u16CNT ++;
                                riflag =1;
    if(TI_1==1)
        clr_TI_1;                             /* if emission occur */
* FUNCTION_PURPOSE: Main function
!!! N76E003 UART1 pin also occupied by debug pin,
please remove Nu-link or not in debug mode to test UART1 function.
External UART1 connect also disturb debug download
void main (void)
        P12_PushPull_Mode;                // For I/O toggle display
#if 0
//for Simple use UART1 transmit out
                InitialUART1_Timer3(115200);
    while(1)
    Send_Data_To_UART1(0x55);
#else
// For interrupt setting check receive
                set_ES_1;                                        //For interrupt enable
                set_EA;
                while(1)
                        if (riflag)
                                        P12 = ~ P12;                        //Receive each byte P12 toggle, never work under debug mode
                                        riflag = 0;
#endif
yunxiang521|  楼主 | 2019-8-11 16:26 | 只看该作者
楼上的代码只是接收和发送,我想做成一条线上,接收多个串口从机。里面有个地址位。是使用的中断接收。发送。接PDF里开启了set_SM2,可是没效果。接收的还是所有数据,不是先接收地址位,再接收数据。
dongnanxibei| | 2019-8-12 20:19 | 只看该作者
自己模拟,自己定义好那个协议。
天灵灵地灵灵| | 2019-8-12 20:48 | 只看该作者
多机通信?一个主机对多个丛集吗
yunxiang521|  楼主 | 2019-8-14 13:50 | 只看该作者
是的
玛尼玛尼哄| | 2019-8-14 20:40 | 只看该作者
多机串口是什么概念。
