[PIC®/AVR®/dsPIC®产品] PIC18F67K22时钟配置
1559|21
 楼主| WUQIMENG 发表于 2019-9-10 14:18 | 显示全部楼层 |阅读模式
主要问题:想使用定时器0中断,并且配置LED2一秒钟变化一次,时钟想配置内部16M,现在的问题是LED2用示波器观测时1.12秒变化一次,目前还没找到问题,求助各位,已经三天了!
/********************部分配置字
#pragma config RETEN = ON
#pragma config INTOSCSEL = HIGH
#pragma config SOSCSEL = DIG
#pragma config XINST = OFF
// CONFIG1H
#pragma config FOSC = INTIO2
#pragma config PLLCFG = OFF
#pragma config FCMEN = OFF
#pragma config IESO = OFF
// CONFIG2L
#pragma config PWRTEN = OFF
#pragma config BOREN = SBORDIS
#pragma config BORV = 3         // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 16  // Watchdog Postscaler (1:1048576)
// CONFIG3L
#pragma config RTCOSC = INTOSCREF // RTCC Clock Select (RTCC uses INTOSCREF)
// CONFIG3H
#pragma config CCP2MX = PORTC   // CCP2 Mux (RC1)
#pragma config MSSPMSK = MSK7   // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON       // Master Clear Enable (MCLR Enabled, RG5 Disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K     // Boot Block Size (2K word Boot Block size)
/************************时钟配置部分
IRCF2 = 1;
    IRCF1 = 1;
    IRCF0 = 1;        //内部16M时钟
    SCS1 = 1;
    PLLEN = 0;        //不4倍频
    SOSCRUN = 0;
    MFIOSEL = 0;
    //OSCTUNE = 0X80;
    while(!HFIOFS);
/***********************定时器配置部分
void Time0InitConfig()
    T08BIT = 0;        //16位定时器
    T0CS = 0;        //内部1/4FOSC时钟
    T0PS2 = 0;
    T0PS1 = 0;
    T0PS0 = 1;        //预分频器1/4分频
    PSA = 0;        //设置使用预分频器的频率
    TMR0L = 0x9c;
    TMR0H = 0xff;
    //TMR0 = 156;        //定时100us
    TMR0IE = 1;        //启动中断
    TMR0ON = 1;        //开启定时器中断
    TMR0IF = 0;
/************定时器中断
void Tmr0Interrupt_ISR()
    static uint x;
    if(TMR0IF == 1)
        TMR0IF = 0;
        TMR0L = 0x9c;
        TMR0H = 0xff;
        BeepWork();
        x++;
        if(x <= 10000)
            LED2 = 0;
        else if(x <= 20000)
            LED2 = 1;
        else
            x = 0;
能帮我看看的朋友能加个好友嘛,好交流一点,着实弄了很久了,现在还是没找到问题QQ:528014617  发表于 2019-9-10 17:40
奔波儿熊 发表于 2019-9-10 14:23 | 显示全部楼层
先别累加, 看看一次中断的测量值和理论值各是多少?
理论值是100us进去一次,实际值是112us进去一次  发表于 2019-9-10 14:31
好的,我试试  发表于 2019-9-10 14:25
北极风 发表于 2019-9-10 14:27 | 显示全部楼层
定时器可以0.5s中断一次呀。
建议用MCC配置和生成基本的程序,自己再修改。
用MCC配置的代码也是这样子  发表于 2019-9-10 16:54
我看看,还没有用过MCC这个东西  发表于 2019-9-10 14:32
奔波儿熊 发表于 2019-9-10 16:58 | 显示全部楼层
可能是时钟误差
误差有点大吧~!!!而且我有接外部4M晶振啊,都一样  发表于 2019-9-10 17:07
lcczg 发表于 2019-9-10 17:09 | 显示全部楼层
这个原因应该是从中断触发到在中断里面重新赋值TMR0L = 0x9c; TMR0H = 0xff的延迟引起; 这是因为进入中断以及中断中执行到TMR0赋值指令都是需要时间的。这个延迟时间应该就是112-100=12uS. 你可以将Timer的时基变大,例如256分频。另外尽量将中断周期加长,使TMR0的值尽可能小,这样周期就得到加长,最好是直接1秒中断一次。在256分频时,取TMR0=0xC2F7应该可以了。
赋值指令也不用这么久的时间吧!PIC16都不会出这个问题。12us太长了,而且我是用来做项目~一秒不现实啊  发表于 2019-9-10 17:23
奔波儿熊 发表于 2019-9-10 17:35 | 显示全部楼层
我看你用的内部16M啊,外部的4M用了吗? 如果是内部的 时钟误差 + 中断延迟 + 指令执行时间 差不多吧
@WUQIMENG :公司不方便啊,电脑没装qq  发表于 2019-9-11 10:36
能加个好友吗~有些地方我这里不太方便发,都用过,外部我配置字是用的HS1然后开PLL倍频,528014617我的QQ  发表于 2019-9-10 17:37
CoolSilicon 发表于 2019-9-11 09:12 | 显示全部楼层
为啥不尝试MCC生产代码??
简单又实用~~~还不用你这样来回折腾.....
CoolSilicon 发表于 2019-9-11 09:14 | 显示全部楼层
方便又实用..
@WUQIMENG :你需求的是1s或者2s的中断, 1. 要么直接设置一个1s或者2s的中断, 那么进中断的时候几个指令周期的误差, 相对于s单位来说, 可以忽略不计了. 2. 你非要用100us这样的小单位的计数累加, 来实现1s或2s的中断, 那么, MCU会中断的非常频繁, 并且对delay要求非常严格, 你要手动补偿, 补偿不准的话, 误差还会累积. 如果非要用这种方法做, 时间累计单位用100ms或2  发表于 2019-9-11 13:59
用过了,一样这个效果,然后经过多次测试~确实是又14个时钟周期的误差,不管我延时多久,总是有14个时钟误差在里面  发表于 2019-9-11 09:52
奔波儿熊 发表于 2019-9-11 10:35 | 显示全部楼层
楼主你看看这个帖子就明白了 , 这个帖子里是9us https://bbs.21ic.com/icview-2854688-1-1.html
 楼主| WUQIMENG 发表于 2019-9-11 14:19 | 显示全部楼层
这个~没说是要1S延时,要100us,1s我是用来测试的
奔波儿熊 发表于 2019-9-11 14:57 | 显示全部楼层
楼主还可以提高主频试试,还可以调整编译器的优化等级看看,  没其他太好的办法
